HF converter Funcube
Разборка конвертера по параметрам
Schematic expertise gave impression of a circuit constructed with simulated block but never completely
measured, neither totally checked !
- Input filter designed under 50 Ohms not matched to NE602 input (Zin 1500 Ohms).
- Output filter designed under 50 Ohms not matched to NE602 output (Zin 1500 Ohms).
- FM band notch C19 // L11 not efficient ! calculated resonant frequency 100H (low Q ferrite inductor) with
25 pF is about 3.2 MHz ! May be a calculation mistake, inductor should be 100 nH !
- Local oscillator (HCMOS) and NE602 LO input are not 50 Ohms !
- Poor supply decoupling from USB !
- L10 at 1 mH is more capacitive than inductive from 106 to 136 MHz ! It should be 1 H !
- C1 and C12 are too low value and limits frequencies under 20 MHz as high pass filter ! better with 1 nF.
Комментарии могут добавлять зарегистрированные участники с активированной учётной записью и правом публикации.
