Дата: 06 Дек 2009 15:25:07 · Поправил: Zesty67 (06 Дек 2009 15:32:43)
Частота 8977
[HFNPDU PERFORMANCE]
09:39:42 UTC Flight ID = SU0121 LAT 52 31 10 N LON 21 0 45 E
10:06:42 UTC Flight ID = AT0271 LAT 34 30 23 N LON 2 57 8 W
10:07:02 UTC Flight ID = CO0059 LAT 54 10 28 N LON 2 51 10 E
10:26:56 UTC Flight ID = AY1541 LAT 33 59 29 N LON 4 57 17 W
10:27:56 UTC Flight ID = CPA019 LAT 49 18 47 N LON 16 52 30 E
10:41:52 UTC Flight ID = AY1609 LAT 37 32 52 N LON 3 25 42 W
10:42:54 UTC Flight ID = AWE796 LAT 42 46 17 N LON 8 47 41 E
[HFNPDU FREQUENCY DATA]
10:44:36 UTC Flight ID = CM0284 LAT 7 47 15 S LON 69 46 43 W
10:45:30 UTC Flight ID = SU0279 LAT 53 32 22 N LON 26 24 36 E
[HFNPDU ACARS FM AIR LP2706 TO GND]
<SOH>2.CC-CWH<NAK>801<STX>M39ALP2706/MADOWLA MADOWLA.3B01 OTHER 2706/06 SPIM/LEMD .CC-CWH
BS DIAS ETA 1222 COND 1
RQST GATE/CONEX/<ETX>#o<NUL>
10:49:42 UTC Flight ID = SU0845 LAT 56 23 44 N LON 35 45 41 E
10:59:08 UTC Flight ID = RJA107 LAT 40 21 54 N LON 9 30 23 E
11:31:48 UTC Flight ID = SU0241 LAT 52 56 9 N LON 6 3 18 E
11:34:36 UTC Flight ID = LA0530 LAT 37 31 38 N LON 75 39 49 W
11:35:36 UTC Flight ID = CPA019 LAT 52 18 10 N LON 5 14 17 E
11:50:30 UTC Flight ID = SU0129 LAT 53 8 17 N LON 13 44 29 E
[LPDU UNNUMBERED DATA FM GND TO AIR A9]
HACARS mode: 2 Aircraft reg: .VP-BWL Aeroflot
12:06:00 UTC Flight ID = CPA019 LAT 53 26 16 N LON 0 39 12 W
[HFNPDU ACARS FM AIR MXA158 TO GND]
<SOH>2.XA-MXQ<NAK>Q01<STX>S75AMX1586<ETX>:%<NUL
[LPDU UNNUMBERED ACKED DATA FM AIR MXA158 TO GND]
HACARS mode: 2 Aircraft reg: .XA-MXQ
Message label: Q0 Block id: 1 Msg. no: S75A Flight id: MX1586
Дата: 11 Дек 2009 18:29:34
Частота 8977
[HFNPDU ACARS FM AIR 4Y4042 TO GND]
<SOH>2.D-AIDR<NAK>Q00<STX>S08A4Y4042<ETX><SI><NUL><NUL>
HACARS mode: 2 Aircraft reg: .D-AIDR
Message label: Q0 Block id: 0 Msg. no: S08A Flight id: 4Y4042 (VIP reportedly for Prime Minister Abdulla Ahmad Badawi)
ICAO 498422 /Czech Government, 'OK-AAB' on HFDL/Czech Air Force
13:59:02 UTC Flight ID = C20002 LAT 50 8 7 N LON 8 13 17 E
ICAO 498422/Czech Government, 'OK-AAB'/2801/
13:35:02 UTC Flight ID = C20008 LAT 50 53 45 N LON 4 30 17 E
[LPDU UNNUMBERED DATA FM GND TO AIR 40]
HACARS mode: 2 Aircraft reg: .N13110
Message label: C1 Block id: X [Uplink]
Message content:-
POS EMP NAME EMP NO TO FLT STA GATE ETD TURN
CA RYAN WILLIAM 011860 TERM
FO JOHNSON BRENTON G09176 TERM
FO TH
----------------------------------------------------------[11/12/2009 16:30]
[HFNPDU ACARS FM GND TO AIR 40]
<SOH>2.N13110<NAK>C1X<STX>POS EMP NAME EMP NO TO FLT STA GATE ETD TURN
FO TH<ETB>#a<NUL>
HACARS mode: 2 Aircraft reg: .N13110 / N13110 recently seen 2009-12-11 as flight CO0123 (COA123)
from CPH/EKCH (Copenhagen) to EWR/KEWR (Newark)./
Message content:-
FO TH
FO TH<ETB>#a<NUL>
Дата: 11 Дек 2009 18:46:37
Может все таки треки и координаты бортов в графическом виде? Эдак скоро в этой ветке читать и смотреть будет нечего.
Дата: 13 Янв 2010 09:25:23 · Поправил: SPEAKER (13 Янв 2010 09:30:38)
Заинтересовало меня декодирование HFDL на КВ. Помогите с ключиками на программы версий PC-HFDL 2.01 и 2.031. Есть ли другие программы декодеры HFDL без ключей, которые могут работать в связке с программой Airnav Suite 4
Дата: 13 Янв 2010 11:21:40
SPEAKER
в личку скинул.
Дата: 13 Янв 2010 19:44:13
Фанат что-не запускается. Высвечивается дисплей программы с бегущими квадратиками и зёлённым перекрестием из 4 палочек, а рыжего спектра сигнала от приёмника на дисплее и вверху справа нету. Сутки бьюсь и ничего не выходит. Программу с кряком скачал а его надо вставлять или уже всё настроенно ?
Участники что может быть такое. Объясните мне чайнику.
Скиньте пожалуйста рабочую программку здесь или в личку.
Дата: 15 Янв 2010 22:19:07
Наткнулся на такое CPDLC сообщение:
QU EDWA1MC
.DDLXCXA 051555
FML
FI MC2/AN 80002S
DT DDL XXD 051555 F16A
AT1.80002SA0BF678A33B970A7D3
973E94421364CCA6C1CD20E84D9A
D020A853E9D51ACA34A58A5316C0
ACD8AB1CA6AD1B828D3AA0424485
5694B8A415E62448B067410A0037
51295760E6900092218EC29F4D04
A62D9059B15504A6AD1BA08D3AA2
0A1366B4412E7D2880DF63
В какой программе его можно декодировать?
Дата: 15 Янв 2010 22:35:01 · Поправил: cemichael (15 Янв 2010 22:36:37)
SPEAKER
В окошке спектрум, должен быть серый шум, а при появлении сквиттера более плотный шум размером с квадратик. А если все галочки включить, в окне никаких мессаджей нет?
У меня только 2.01 (635-3) хорошо работает, остальные завести не удалось.
Дата: 16 Янв 2010 01:47:01
cemichael
Серая узкая полоса есть, а вот спектра сигнала нет. Звуковуха на компе рабочая. В настольных динамиках компа сигнал гремит. В инете нашёл старенькую программку PC-HFDL 1.0 тоже не запускается.
Дата: 17 Янв 2010 00:10:48
Запустил я всё-таки HFDL в паре с AirNav Suite!!!
Спасибо большое участнику сайта, в оказании мне помощи в запуске!
На частоте Бахрейна - 5544 кГц сейчас принимаю и наблюдаю борта на мониторе.
Отличная вещь на КВ однако!
Дата: 17 Янв 2010 00:42:56 · Поправил: SPEAKER (17 Янв 2010 00:51:32)
Мой первый мониторинг HFDL на частоте 5544 кГц:
На карте видны два борта "Аэрофлотовских" рейсов :
AFL-761 Москва (Шереметьево) - Кемерово,
AFL-773 Москва (Шереметьево) - Краснодар (Пашковский)
![](http://www.radioscanner.ru/uploader/2010/ollo.jpg) |
Дата: 17 Янв 2010 04:29:50 · Поправил: SPEAKER (17 Янв 2010 04:56:49)
Подскажите зависимость рабочей частоты HFDL от нахождения борта.
Вот к примеру : борт А/К FINAIR рейсом FIN-1947 над Москвой появился на частоте 5544 ( MUHARRAQ-BAHRAIN) и пропал. Перестроился я Дегеном ч/з пол-часа на частоту 6532 кГц (SHANNON) - появился этот же Финский борт на 6532 кГц над Волгоградом.
По идее к Шаннону ближе ему над Москвой и вещать на 6532 чем на Бахрейновской 5544, а над Волгоградом лучше на Бахрейновской 5544, чем он вещал на Шаннонской частоте.Почему так? Какая закономерность перехода борта в полёте на частоты круговых базовых станций на земле. Кроме мёртвых зон по прохождению радиоволн конечно.
Кстати, данный Финский борт FIN-1947 около Волгограда услыхал на УКВ 134.6 МГц! Двойное подтверждение так сказать:) Всё совпадает по HFDL, считай он-лайн идёт на КВ!
Хорошее прохождение сейчас на второй частоте MUHARRAQ-BAHRAIN - 8885 кГц. Борта с Центральной Африки идут и со Средней Азии.
Дата: 17 Янв 2010 11:47:39 · Поправил: SPEAKER (17 Янв 2010 11:49:24)
Рейс AFL-192 (SU 192) Ереван - Москва (Шереметьево) летит через воздушное пространсво Турции в обход грузии.
Армянские же борта сейчас на Москву летают ч/з грузинское воздушное пространство и далее ч/з Ставрополье.
![](http://www.radioscanner.ru/uploader/2010/v_obhod_gruzii.jpg) Увеличить |
Дата: 17 Янв 2010 12:34:30
SPEAKER
Поздравляю! Всегда приятно взять борт в нескольких системах связи, тем более если одна из них является цифровой.
Дата: 17 Янв 2010 12:50:07
РУБИН спасибо!
На КВ (голосом) и переход ч-з несколько минут в УКВ (голосом) одни и теже борта приходилось принимать несколько раз.
Дата: 17 Янв 2010 15:01:46
SPEAKER
поздравляю! А вот у меня не декодирует из за плохого сигнала, помехи мешают.
Дата: 17 Янв 2010 15:06:54
Фанат
Спектр от приёмника есть на мониторчике программы HFDL?
Дата: 17 Янв 2010 15:29:37
SPEAKER
да, всё есть! Сигнал в перемешку с помехами идёт, из за этого не декодирует! Вот за городом на диктофон сигнал писал, потом к микрофону поднёс, чистый сигнал декодирует! Как ты включил картинку? У меня такая не появляется.
Дата: 17 Янв 2010 15:55:48 · Поправил: SPEAKER (17 Янв 2010 15:56:50)
Фанат
От компа у меня помехи тоже идут, но средние по уровню сигналы декодирует.
Ещё надо второй гетеродин приёмника точно настраивать, чтоб декодироались сигналы хфдл. В окошке программки хфдл указывается расстройка в Гц. Настраиваю приёмник на заведомо знакомые частоты, потом в тон по голосу подстраиваю второй гетеродин. Далее настраиваюсь на частоты хфдл.
+- 100Гц сигнал ещё декодируется
Картинка взята из второй программы AirNav Suite 4, которую запускаю только после запущенной PC-HFDL.
Дата: 17 Янв 2010 16:12:27
Наблюдал сегодня за рейсом 9W230 (Дели-Торонто). В районе Каспия он передавал свои координаты в таком виде:
LPDU UNNUMBERED ACKED DATA FM AIR JAI230 TO GND]
HACARS mode: 2 Aircraft reg: .VT-JWE
Message label: H1 Block id: 7 Msg. no: F07A Flight id: 9W0230
Message content:-
#M1BPOSN41352E054079,BEGLI,100313,352,TIROM,101144,INRED,M60,28498,821/GA/TS100313,1701106A6E
----------------------------------------------------------[17/01/2010 13:09]
кстати сказать , в таком же виде координаты встречаются и на УКВ. При этом позывной 9W0230 в соответствии с IATA. Спустя некоторое время координаты стали передаваться в типичном для hfdl виде:
[LPDU UNNUMBERED DATA FM AIR JAI230 TO GND]
10:24:54 UTC Flight ID = JAI230 LAT 43 11 16 N LON 51 56 20 E
Performance version 1
Flight Leg 146
GS KRASNOYARSK - RUSSIA
SYNCHED TO UTC
Frequency 10087.0(KHz)
Previous Leg lost count 0
Current Leg lost count 0
Previous Leg Number of sec disabled 5332
Current Leg Number of sec disabled 0
Number of MPDUS received O.K
и здесь позывной уже ICAO - JAI230. В результате трек в AirNav получился "составной"
![](http://www.radioscanner.ru/uploader/2010/airnav_karte.jpg) Увеличить |
Дата: 17 Янв 2010 16:45:16 · Поправил: SPEAKER (17 Янв 2010 16:49:19)
Klugman
Этот борт JA1230 тоже намониторил на 10087 кГц. Проходил в районе г. Константиновска :
![](http://www.radioscanner.ru/uploader/2010/ja1230.jpg) Увеличить
Одинаковую координату борта приняли:) |
Дата: 22 Янв 2010 13:47:13
BrOoM
Подскажите пожалуйста как декодировать ADSку в PlanePlotter'е и какая версия программы у вас?
Дата: 22 Янв 2010 13:48:23 · Поправил: LikBez (22 Янв 2010 13:54:58)
пытаюсь декодировать ads и cpdlc сообщения в оффлайне в версии 5.4.4.2 ничего не получается, что-то делаю не так или чего-то не доделываю а что не пойму
Дата: 03 Фев 2010 01:42:21
Коллеги, подскажите в какой модуляции принимать HFDL? Просто АМ, или USB?
Дата: 03 Фев 2010 06:05:11
whyayeman, принимать хфдл надо в USB.
Дата: 03 Фев 2010 12:13:21
Дата: 05 Фев 2010 22:54:45 · Поправил: cemichael (05 Фев 2010 23:01:53)
Ни у кого свеженького pchfdl.dat/systable.txt нету еще? На днях обновилась system table, теперь DB = 35
Дата: 14 Фев 2010 08:42:41
Ну все, началась Олимпиада...
[HFNPDU ACARS FM GND TO AIR F7]
<SOH>2.C-FIVS<NAK>4PT<STX>-// PNT PA01 Q1A0582 14FEB/0532 C-FIVS/742/AC0007
1 SILVER MEDAL..FREESTYLE MOGULS (канадка второе место во фристайле, и первая медаль в копилке)
KEN/AC FLT DX
END
<ETX>O<FS><NUL>
Дата: 08 Мар 2010 02:37:39 · Поправил: rusmax (08 Мар 2010 06:19:55)
Доброго всем.
Здесь выложил что наудил за утро. Может кому интересно. Я пока не особо понял ценность (?) для меня этой информации.
К стати есть ли у кого просто полный список частот для этой моды? Чтобы записать в каналы, на всякий случай. Часто бываю в лесах и интересно полушать работу различных станций. И еще вопрос, на УКВ (ну в диапазоне 118-136) есть такое?
да-а-а-а... решил оставить включенным еще на пол дня. Пока "то, да се".. смотрю на экран а там список не помещается :-) Поставил в догонку (вчера) програмулю AirNav Suite4. Сломать не получилось, чего-то видимо упустил. Но рисует красиво! Порхностно разобрался с программой, с PC-HFDL сочленил. Мдя... Чего только сейчас нет в мире.
Но прошу прощения, что задам такой вопрос с строю увлеченных, но толк в этом есть? Помимо сидеть и смотреть кто и куда летит? Или это лишь часть глобальных комплексных мероприятий по ... ? Я по карте посмотрел, над моей головой трассы проходят. Но даже если оновиться через Инет и видеть в "окне" хвост от борта, в программе ничего нет. Ясно, что наши не оборудованы (видимо) таким, хотя иногда смотря в бинокль вижу там "не нашего завода" борты.
Сюда положил еще кусок файла лога.
В файле справки по PC-HFDL нашел список частот. Видимо он "совсем" старый. Половину я должен слышать (по частоте, расстоянию и времени суток) но там тишина. Из всего перепробованного лишь Гаваи, Красноярск и Гуам. Все... ничего более не слышу. Может кто ткнет в более свежий-полный список частот? Я понимаю, что через пару дней интерес угаснет, но пока он разгорается - хочется! :-)
MOLOKAI - HAWAII UTC LOCKED Active freqs (Hz) 1 5 11 - это строка (как я понял) с № частот той или иной станции, а номиналы (в кГц или МГц) где есть? |
Дата: 08 Мар 2010 12:11:16 · Поправил: skychaser (08 Мар 2010 12:51:41)
rusmax
HFDL - Страница 2
SAN FRANCISCO - CALIFORNIA UTC 7,8
MOLOKAI - HAWAII UTC 10,11,15
REYKJAVICK - ICELAND UTC 4,5,6
RIVERHEAD - NEW YORK UTC 14,17
AUCKLAND - NEW ZEALAND UTC 3,5
HAT YAI - THAILAND UTC 1,2
SHANNON - IRELAND UTC 3,8
JOHANNESBURG - SOUTH AFRICA UTC 2,3
BARROW - ALASKA UTC 5,13
ANNAPOLIS - MARYLAND UTC 7
SANTA CRUZ - BOLIVIA UTC 6,8
KRASNOYARSK - RUSSIA UTC 2,5
AL MUHARRAQ - BAHRAIN UTC 1,2
AGANA - GUAM UTC 1,2
CANARIAS - SPAIN UTC 1,4 |
