На сайте: гостей - 63,
участников - 2 [ AOR, ua3dfa]
 Форум —› Главный раздел —› Degen 1103 - User Manual
Yaesu FT-60R
Yaesu VX-3R
Yaesu VX-6R
Yaesu VX-8DR
Yaesu FT-1D
Дата: 06 Окт 2004 19:26:15 #
конвертер можно собрать :))
Ewgraf
с фев 2004
Саратов
Дата: 06 Окт 2004 21:41:13 #
по поводу зарядки....
на аккумуляторах написано:
стандартный заряд -12-14 ч. Х 120 mA
быстрый заряд-4-5 ч. Х 300 mA.
в инструкции такие сведения: Charging hours = Battery power (mAh)/ 100 mA
по-моему всё понятно.....
Дата: 08 Окт 2004 09:02:19 #
относитльно нашего УКВ Вот что нашел инете может и с 1103 такое можно проделать?
This is translated from Chinese. http://www.whbaihui.com/dgzn9.htm, http://bcl.myetoys.com/article/Article_Show.asp?ArticleID=72 I have done the procedure on my own DE1102, but I don't really find it much use. In my experience, it's no use! Just receiver noise and FM overload. But some people online have reported getting Longwave and Bands 1 and 3 TV sound. However it doesn't seem to affect the regular use of the set. But of course I can't be responsible for any damage it does to anyone else's radio!
With P7 and P9 clear of memories (this is possibly not necessary), save a frequency between 522KHz and 1620 KHz somewhere on memories 1 to 11 on P8. For example, save 1000KHz on P8, M5.
Switch to P7.
Switch off the DE1102.
Press Lock to lock the keyboard, then press it again to unlock.
Turn on the radio, and press Scan so that MEM is shown on the LD display. On any FM frequency, press MEM, so M is empty (there's no preset) and P is 7. Press - (the tune down button), and the screen displays MW 1000KHz, MEM, M1 P7.
Press M and store this setting to any memory 1-19, eg M5. The screen should show MW 1000KHZ, MEM, M5 P7.
Setting the FM range to 00.00 - 327.67MHz.
With MW 1000 KHz, MEM, M5 P7 displayed on the screen, press Enter and input 1620, press Scan, and press FM. FM 16.20MHz, STEP, M [blank] and P7. Press + (tune up button), and tune up to FM18.00, then press M and store it in 1-19, for example M6, and the screen shows SW1.800, Step, M6 P7.
Now you can tune around and see where you can tune. If the mode switches to MW or SW, press FM again. This increases the displayed frequency by 10.
Apparently removing the power for 30 seconds resets all this.
наблюдатель
Дата: 08 Окт 2004 11:21:04 #
Павел
Ваши указанные ссылки открываются на иегорлифаф китайских , что сделать , что бы посмотреть ссылки ??
Maxim
Offline6.0
Дата: 08 Окт 2004 12:39:27 #
Какая-то битая ссылка. Среди иероглифов просматривается HTTP 错误 404
наблюдатель
Дата: 08 Окт 2004 12:43:13 #
Maxim
Согласен. Тоже самое у меня . А вообще затея интересная , судя по статейки , которую выложил Павел.Такую бы статейку про 1103 , да еще и в русском варианте , я бы точно рискнул бы попробовать модифнуть приемник .
Дата: 08 Окт 2004 13:58:21 #
Написано: "This is translated from Chinese."
кто-то иероглифы уже перевел на английский больше ничего добавить не могу.
я все скопировал как есть это находися на форуме: http://www.dxing.info/community/viewtopic.php?t=1367&sid=009d1676e6e975a702bb228959e42333
Дата: 08 Окт 2004 14:06:51 #
Еще было сообщение что у кого-то приемник( именно 1103) ребенок как-то слуйно включил на частоте вне FM диапазона а гдето-рядом. а вот как непонятно. После выключения приемник стал работать как и раньше.
наблюдатель
Дата: 08 Окт 2004 14:53:44 #
Павел
Совершенно верно. Это было написано именно мною. Сын взял послушать приемник ( 10 лет сыну ) , и начал на клавиши ради интереса нажимать , как на пианино. Итог был таков , что в ФМ участке частота на таблоиде улетела высоко вверх за паспортный диапазон . Теперь я понимаю , какую ошибку я совершил , надо было погонять на прием его по частотам , которые можно было попытаться отловить. А я сразу его решил рестартануть , потому как подумал , что сын приемнику просто свернул башку.
Дата: 03 Ноя 2004 14:24:52 · Поправил: Liner #
Вроде как официальное руководство пользователя Degen 1103 на английском (pdf, 6 Mb):
http://www.degen.com.cn/chanpinshuo/e1103.pdf
v255
с окт 2004
Дата: 03 Ноя 2004 14:41:15 #
Имеется описание DE 1103 на русском языке. Если надо, могу отсканировать в pdf и предоставить.
Дата: 03 Ноя 2004 14:53:21 #
Русское руководство уже вроде заливали, только зачем-то закрыли паролем...
http://www.radioscanner.ru/forum/index.php?action=vthread&forum=1&topic=14045
Online5.7
Дата: 03 Ноя 2004 15:52:09 #
v255
А у Вас какой вариант? Это кто-то переводил сам или поставлялось с приемником?
v255
с окт 2004
Дата: 03 Ноя 2004 16:06:34 #
С приемником, ксерокопия с картинками. Есть пара ошибок. Я сравнил - почти копия с ангийского варианта и есть некоторые не принципиальные отличия.
Гонец
с июл 2004
Дата: 03 Ноя 2004 18:06:36 #
Что за отличия, если не секрет?
наблюдатель
Дата: 03 Ноя 2004 18:09:00 #
v255
Ну если нормального качества будет и без паролей , то я бы не отказался от инструкции.
v255
с окт 2004
Дата: 04 Ноя 2004 10:33:28 #
Для Гонца:
Ну как я могу имеено Вам сказать про отличия (Вы ведь свою инструкцию запаролили - фиг прочтешь).
Для всех прочих пожалуйста:
- некорректное описание работы переключателя "DX/LOCAL";
- "Автопоиск из памяти (256 настрек)" - описан порядок, но не функционирует (в английском описании я этой функции не нашел).
- неверно описан алгоритм зарядки аккумуляторов: "Если Вы, все же включили радиоприемник во время процесса зарядки, зарядка автоматически прекратится" На самом деле зарядка продолжается при включении приемника в режиме зарядки аккумуляторов (проверил это измерением токов от аккумулятора во всех режимах) Получилось:
I am >=79 mA
I fm >= 60 mA
I зар = 110 mA
Дата: 05 Ноя 2004 19:08:44 #
ВОЗМОЖНО-ЛИ ПЕРЕДЕЛАТЬ DE1103 ДЛЯ ПРИЕМА РОССИЙСКОГО
УКВ ДИАПАЗОНА
Гонец
с июл 2004
Дата: 05 Ноя 2004 19:37:11 #
v255 она уже открыта для всех.
 Страница:  ««  1  2
