На сайте: гостей - 59,
участников - 4 [ admhome, Tillman, UA0OAG, skytruck]
 Форум —› Главный раздел —› Паамааагиите!!! (часть 2)
Hytera TC-320
Hytera TC-508
Hytera TC-580
Hytera PD-355
Hytera X1E
слон
с мар 2004
Рига
Дата: 19 Авг 2004 11:01:59 #
Опять я с глупыми вопросами :o), есть ли у этого чуда техники (Yaesu VR-5000) функция сканирования полосы, если да то как завести начальную и конечную частоты.
Дата: 19 Авг 2004 11:15:05 #
Да, есть такая функция. Называется Programmable (Band Limit) Memory Scan (PMS).
Переводить честно говоря лень, попробуйте засунуть нижеследующий кусок в какой-нибудь он-лайн переводчика типа яндекса.
This feature allows you to sub-band limits scanning.
Programming
1. Press the [F] key momentarily, then press the [PMS(PMS SET)] key to enable the
storing the frequency pair into the PMS memory.
2. Rotate the DIAL knob to select the cursor to the “PMS TAG” menu.
3. Press the [ENT(SET)] key to enable the programming of the name tag to the PMS
memory. To attach an alpha/numeric name to the PMS memory, program the
alpha-numeric “label” using the DIAL knob and keypad, as described previously;
otherwise press the [ENT(SET)] key again.
4. When you have complete the creation of the label, press the [ENT(SET)] key.
5. Rotate the DIAL knob to select the cursor to the “START F” menu, then press the
[ENT(SET)] key.
6. Select the VFO frequency to the Low sub-band limit, then press the [ENT(SET)] key.
7. Confirm that the cursor is on the “END F” menu, press the [ENT] key.
8. Select the VFO frequency to the Upper sub-band limit, then press the [ENT(SET)]
key.
9. Rotate the DIAL knob to select the cursor to the “END” menu, then press the
[ENT(SET)] key.
10. Confirm that the cursor is on the “WRITE” menu, press the [ENT] key.
11. The PMS memory programming is now completely.
Note: 50 PMS memories are available. You therefore can set upper and lower operation
limits on a number of bands, if you like.
Operation
1. Press the [PMS(PMS SET)] key to initiate PMS scanning in an upward direction.
2. If the scanner encounters a signal strong enough to open the squelch, the scanner
will halt and pause on that frequency.
3. To reverse the direction of the scan (i.e. toward a lower frequency, instead of a
higher frequency), turn the DIAL knob one click in the counter-clock direction or
press the [t(q)] key momentarily while the VR-5000 is scanning. To revert to
scanning toward a higher frequency once more, rotate the DIAL knob one click
clockwise or press the [u(p)] key momentarily.
4. Press the [V/M(MW)] key to disable the PMS scanner, and return to VFO mode.
Adjusting the PMS scanner
1. Press the [F] key momentarily, then press the [PMS(PMS SET)] key.
2. Rotate the DIAL knob to select the cursor to the “MISC” menu, then press the
[ENT(SET)] key.
3. Rotate the DIAL knob to select the cursor to the desired menu from the following
list to be you wish adjusting.
ScanStop: Select the Scan Resume mode among “HOLD,” “DELAY,” and “PAUSE”
via pressing the [•(BEEP)] key.
(1) In the “HOLD” mode, when a signal is received the scanner will hold for 2
second, then the scanner will stop.
(2) In the “DELAY” mode, when a signal is received the scanner will hold until the
signal disappears, then the scanner will resume after 2 seconds.
(3) In the “PAUSE” mode, when a signal is received the scanner will hold for 2
second, then scanner will resume after 2 seconds.
S-LvlScan: The scanner will halt and pause on the frequency when the is a signal
strong enough to stops on
VCS: Enable/disable the VCS (Voice Channel Scan) feature via pressing the
[•(BEEP)] key. When enable the VCS feature enabled, the scanner will only halt
and pause on the frequency that is having the voice signal.
ATT: Enable/disable the RF signal Attenuator via pressing the [•(BEEP)] key.
RF-TUNE: Enable/disable the RF-TUNE circuit via pressing the [•(BEEP)] key.
Lorenz
с авг 2003
Дата: 19 Авг 2004 12:12:07 #
Медведев
Слон английский не знает :))
Дата: 19 Авг 2004 15:06:47 #
Lorenz, читай внимательно русскоязычную часть моего сообщения :)
Lorenz
с авг 2003
Дата: 19 Авг 2004 15:34:12 #
А Яндекс не знает технический английский :)))
