На сайте: гостей - 74,
участников - 4 [ Sergey4565, muha131, Geksogen, Владимир.1]
 Форум —› Частоты Москвы, России и мира —› Частоты метеоспутников
Беркут Hunter
Егерь 3
President Randy II P
Турист 3
Штурман 80
vovan58
с июл 2004
СССР
Дата: 19 Дек 2004 01:47:05 · Поправил: Администратор #
подскажите пожалуйста частоту метео спутников
спасибо !!!
Mexico
Offline7.0
с янв 2004
Дата: 19 Дек 2004 02:15:19 · Поправил: Mexico #
LAUNCHED: 1991/05/14
SITE: Vandenburg AFB, CA, USA via Atlas-E.
STATUS: Operational, secondary to NOAA-15.
BEACON: 136.770
DNLINK: 137.500* (APT)
DNLINK: 1698.00 (HRPT)
LAUNCHED: 1994/12/30@10:02 by an Atlas-E rocket
STATUS: Operational only HRPT, APT turned off
BEACON: 137.770*
DNLINK: 137.620 APT (OFF)
DNLINK: 1707.000 HRPT
NOTE: Weather spacecraft. It will replace NOAA 11 whose cloud cover imaging instrument had failed. Besides an imaging radiometer, it carries optical sounders to monitor temp.
LAUNCHED: 1998/05/31@15:52:04 via Titan 2 rocket
STATUS: Operational
BEACON: 137.350*
DNLINK: 137.500* APT
DNLINK: 1702.500 HRPT
NOTE: Is an American weather satellite. It carries imaging and sounding instruments to obtain data on cloud coverage, atmospheric temperature, humidity
LAUNCHED: 2000/09/21 UTC
SITE: Vandenberg AFB, CA, USA via Titan 2.
STATUS: Semi-operational, APT not active
DNLINK: 137.620 NFM (APT-OFF)
DNLINK: 1698.000 (HRPT)
NOTE: NOAA 16's APT transmission system failed a few months after launch.
NAME: NOAA 17 -Пашет точно. Проверял.
LAUNCHED: 2002/06/24@18:23:04 UTC
STATUS: Operational
BEACON: 137.770*
DNLINK: 137.620* (APT)
DNLINK: 1707.000 (HRPT)
NOTES: This is the NOAA M satellite. It has eight instruments to serve the science community. It also has two instruments that act as SARSAT radio relays.
SICH-1 (хохлацкий спутник,но пашет ли он сейчас,не знаю)
DNLINK: 137.400 NFM (APT)
Data for SICH-1
Downlink: 137.400 and 465.000 (APT-like)
Notes: Launched 31 Aug 1995 by National space agency of Ukraine - First Ukrainian satellite (although numerous Ukrainian-made satellite were launched before under the CIS flag)
OKEAN 1-7(наш спутник)
Notes: Weather satellite - (infrequent transmissions, but includes RADAR - well worth keeping a look out for)
OKEAN-O (наш спутник)
DNLINK: 137.400 NFM
Notes: weather satellite - heard infrequently at very low elevation passes - below 10° - in mornings
Для справки:
APT-это "формат" передачи картинки и телеметрии на землю. Можно принимать подключив приемник к компьютеру при помощи программы в домашних условиях.
BEACON-это не хавчик =),а "маячок",передающий постоянно или периодический сигнал. Типа как огоньки у бакена.
Mexico
Offline7.0
с янв 2004
Дата: 19 Дек 2004 02:52:00 · Поправил: Mexico #
Спутников больше,но я тебе дал лишь те которые можно принять на "двойке",на простую,даже одноэлементную антенну,т.к они низкоорбитальные, высота 600-1000 с гиком км. Высокоорбитальные ты скорее всего не примешь из-за небольшой мощности передатчика спутника и неэффективности своей антенны (понадобиться очень качественная,хорошо настроенная и изготовленная,направленная антенна,с усилением 10(минимум)-30Дб. Причем 10-30 Дб не в сравнении с фалоимитатором(изотропным излучателем/гвоздем/пальцем/хрен знает чем)которое часто указывают производители импортных антенн.
Вот тебе дружище еще немного:
Data for RESURS O1-N4
DNLINK: 137.850 NFM (APT)
Notes: Russian natural resources sensing satellite that was launched by a Zenit 2 rocket from Baikonur at 05:45 UT. It will also do ecological and meteorological monitoring
Data for UOSAT-12
(UO-36)
Uplink: 145.960 (9600 FSK)
Downlink: 437.025
Downlink: 437.400
Notes: a British minisatellite that was launched by a converted SS-18 (renamed Dnepr 1) ICBM from a silo in Baikonur at 05:00 UT on 1999 April 21. It carries multispectral remote sensing cameras
Вот тебе два военных для экспериментов:
MTI (MultiSpectral Thermal Imager)
DNLINK: 401.565 CW
Notes: space-based research and development project sponsored by the U.S. Department of Energy (DOE), Office of Nonproliferation and National Security. MTI's primary objective is to demonstrate advanced multispectral and thermal imaging, image processing, and associated technologies that could be used in future systems for detecting and characterizing facilities producing weapons of mass destruction.
RADCAL (Radar Calibration Satellite)
STATUS: Unknown
DNLINK: 150.015 CW
Downlink: 306.775 Mhz
Notes: Launched 25 June 1993 - Provide a Space-Based C-Band RADAR Calibration Target, Store-and-Forward and Bentpipe, can Determine Satellite Position within 5 Meters
Просьба к тебе и другим,кто будет пробовать принимать.ДЕЛИТЕСЬ пожалуйста со мной и другими результатами. Ведь вся прелесть любого "коммьюнити",тем паче нашего и состоит в обмене интересующеЙ,актуальной,ПРАВДИВОЙ,информацией. Это экономит время на поиск и проверку ее.Дает дополнительную информацию. Ведь вместо того чтобы "изобретать велосипед",искать,проверять и делать то что кому-то уже в деталях известно можно потратить это время на что-то более новое или интересное и поделиться с другими. По такому принципу работают сети распределенных вычислений.Например проект поиска внеземных цивилизаций Seti,проект поиска лекарства от рака и много много других. Только здесь не компьютеры выполняющие часть работы,а более ценный,важный и капризный ресурс-люди=).
Спасибо за понимание.
Salesperson
Дата: 19 Дек 2004 11:56:58 #
Mexico
Просвятите общественность, что есть HRPT?
Есть ли у Вас опыт приема и декодирования этого сигнала?
Mexico
Offline7.0
с янв 2004
Дата: 19 Дек 2004 13:48:21 #
Помимо стандарта WXFAX, низкоорбитальные спутники передают свои данные в цифровом формате HRPT. Для приема в этом стандарте насколько мне известно необходима специальная аппаратура.
Опыта приема HRPT нет.
vovan58
с июл 2004
СССР
Дата: 19 Дек 2004 14:01:31 #
Mexiko
Спасибо за информацию !!!
Mexico
Offline7.0
с янв 2004
Дата: 19 Дек 2004 14:21:20 · Поправил: Mexico #
Да и еще.
Есть только одно исключение: спутники Океан и Сич вещают только в момент видимости земных станций на территории России. Это означает, что получить их информацию можно только в Европе, Cеверной Африке и Евразии, но не на Дальнем Востоке и в США.
Еще спутники.
Метеор 2-21 - 137,400 МГц
Метеор 3-5 - 137,300 МГц
WEFAX (Weather Facsimile) представляет собой разновидность факса, ориентированную на передачу погодных карт. Три спутниковые системы осуществляют передачу в этом стандарте: GOES (США), Meteosat (Европейское Сообщество), а также GMS (япония). WEFAX дает возможность принимать монохромное изображение аналоговым способом в звуковом канале приемника. В зависимости от конкретного стандарта изображение передается со скоростью от нескольких сотен до нескольких тысяч точек в секунду. Изменение уровня яркости передается изменением значения поднесущей частоты передатчика.
Земля сканируется каждые полчаса, и необработанные данные поступают на наземную станцию, оборудованную полутораметровой "тарелкой" и другими сложными устройствами. Получаемые данные обрабатываются в реальном времени. При этом на них накладывается изображение политических границ государств. Затем данные передаются обратно на спутник, который ретранслирует их на землю на частоте 1691 МГц. Таким образом, для приема сигналов в стандарте WEFAX необходимы приемник (конвертер) на частоту 1691 МГц и небольших размеров "тарелка".
"Картинка", передаваемая в стандарте WEFAX представляет собой аннотированное изображение с разрешением 800 на 800 точек. На передачу каждойстроки затрачивается 250 мс, таким образом, полное изображение передается три с половиной минуты. Существует точное расписание, по которому можно определить, когда какое изображение и по какому каналу передается со спутника.
Интерпретация изображений:
Радиометры, устанавливаемые на метеорологических спутниках, измеряют излучение Земли в различных участках частотного спектра, называемых "атмосферными окнами". Излучение в таких "окнах" не подвергается сильному ослаблению со стороны атмосферы. На погодных спутниках не устанавливают датчиков, позволяющих передавать изображение земной поверхности во всех цветах видимого участка спектра. Датчики таких спутников перекрывают часть спектра от красного в видимом свете до инфракрасного. Сделано это потому, что видимое изображение формируется отражением от земной поверхности солнечного света и наблюдается лишь в освещенной части земной поверхности.
В видимом спектре можно наблюдать облачность. При этом участки белого цвета на полученных изображениях соответствуют облачности, в то время как темные - чистому небу. Так происходит оттого, что чем толще слой облаков, тем выше его отражающая способность и тем белее он будет выглядеть.
Наиболее важным для изучения погоды диапазоном как дневное, так и в ночное время является инфракрасный диапазон. Инфракрасные изображения, передающиеся со спутников в псевдоцветах, показывают распределение температуры по поверхности Земли. Как правило, чем темнее участок земной поверхности, тем он теплее и наоборот. Низкая облачность очень часто способствует повышению температуры.
Как правило, спутниковые снимки погоды, которые Вы видите в телепередачах, сделаны в инфракрасном диапазоне.
По изображениям, получаемым в спектре поглощения водяных паров, определяют уровень влажности в том или ином месте. Такие изображения содержат информацию о раскручивающихся тропосферных вихрях и тропосферных потоках. При этом более темные участки изображения соответствуют более сухим участкам на земной поверхности и наоборот.
Геостационары:
B соответствии с программой Европейских Геостационарных спутников работает Метеосат 7. Высота его орбиты составляет 36000 км, и он как бы «висит» над одной и той же точкой на поверхности Земли, находящейся на экваторе.
Главной особенностю данных, получаемых с геостационарных спутников, является оперативность, поскольку каждые 4 минуты передается новый блок данных.
Каждые полчаса производится сканирование поверхности Земли. Затем данные группируются поблочно и передаются на Землю по особому расписанию.
Изображения европейского сегмента передаются каждые полчаса. Поскольку спутник находится на геостационарной орбите, становится возможным создание анимации погодных карт, с помощью которой становится наглядным движение изображенных на них погодных объектов. Изображения всей поверхности Земли, видимой со спутника, передаются по каналу N2 спутника. Эти изображения называются Всемирными и идентифицируются как CT0T, DT0T или ET0T. При этом первыя буквы идентификаторов C,D и E обозначают изображения в видимом, инфракрасном спектре и спектре поглощения водяных паров соответственно. Всемирные изображения делятся на 9 сегментов, передающихся с более высоким разрешением. Сегменты передаются по каналу N1 каждые четыре минуты и идентифицируются как C1; C2 ...; D1; D2 ...; E1; E2 .… При этом назначение буквы такое же, как и в предыдущем случае, а цифра – это номер сегмента.
Для того чтобы принимать информацию с Метеосата у Вас должна быть «тарелка», направленная на юг и приемник, подключенный к компьютеру, с установленным на нем специальным программным обеспечением.
Геостационарные спутники «видят» друг друга и могут обмениваться данными. Поэтому с Метеосата можно получить информацию, полученную с российского спутника GOMS, японского GMS, а также американского GOES East, что дает нам практически полное покрытие поверхности Земли.
Геостационарные спутники обеспечивают непрерывное наблюдение за земной поверхностью, необходимое для экстенсивного анализа данных. Полученные изображения обрабатываются в реальном времени, оцифровываются и направляются в центры предсказания погоды.
Главной задачей большинства геостационарных спутников является формирование изображений видимой земной поверхности. При этом сканирование в горизонтальной плоскости обеспечивается за счет вращения спутника вокруг своей оси со скоростью 100 оборотов в минуту. Сканирование в вертикальной плоскости с периодом, составляющим 20 минут, производится при помощи подвижного зеркала.
Первичные данные передаются на землю с большим разрешением в цифровом виде, что требует специального оборудования для их приема и отображения. Наземные высокоскоростные компьютеры обрабатывают эти данные, решая две задачи. Во-первых, исходные данные ретранслируются в другом цифровом формате, обладающем меньшим разрешением. Во-вторых, сформированные на спутнике изображения делятся на отдельные квадранты и ретранслируются в аналоговом виде в стандарте WEFAX.
Основными инструментами на борту погодного спутника являются фотодатчик и ИК-датчик. Первый реагирует на излучаемую энергию и энергию, отраженную от земной поверхности и атмосферы. Второй формирует данные о вертикальной температуре атмосферы и профилях влажности, температуре земной поверхности и распределении озона.
Изображения, полученные с геостационарных спутников, используются для отслеживания движения холодных фронтов и штормов, вулканических облаков. Характеристики ветров, определяются по движению облачности. Дожди оцениваются по наблюдаемым грозам и ураганам. По этим же признакам выдаются штормовые предупреждения. Изображения дают возможность оценить запасы снега в конкретном районе и общую площадь снежного покрова.
Страны, обладающие большой территорией и не имеющие возможности запустить собственный спутник, могут пользоваться первичной информацией со спутников других стран. Так Австралия по двухстороннему соглашению с японией имеет полный доступ в реальном времени ко всем даным японских геостационарных метеорологических спутников (GMS). Сейчас из этой серии работает GMS-5, занимающий позицию 140 градусов восточной долготы и покрывающий Восточную Азию, западную часть Тихого океана и Австралию.
Также как и на КВ, для автоматического приема сигналов со спутников, используется стандарт APT (Automatic Picture Transmission).
Низкоорбитальные спутники:
Карты погоды можно принимать и с низкоорбитальных спутников, движущихся по полярным орбитам. Этот вариант может оказаться самым удобным и дешевым, хотя заведомо имеет некоторые ограничения. Весь комплект аппаратуры в этом случае может состоять из УКВ-антенны (подходит проволочный диполь), ЧМ приемника с диапазоном 137МГЦ (подходит любая портативная радиостанция этого диапазона), компьютер со звуковой картой и соответствующее программное обеспечение.
Полярными орбиты спутников, о которых идет речь, называются потому, что проходят вблизи от обоих полюсов. Находясь на полярной орбите, спутник движется почти на постоянной высоте, причем довольно низко над Землей (800-1000км), что обеспечивает получение изображений с высоким разрешением. Спутник при этом передает на Землю то, что он в данный момент видит под собой. При этом сканирование производится лишь в плоскости поперек направления движения спутника. Развертка в продольном направлении производится за счет быстрого движения самого спутника по орбите. Таким образом, снимается проблема наблюдения высокоширотных районов, возникающая из-за «кривизны» Земли, присущая геостационарным спутникам.
Низкоорбитальные спутники серии NOAA находятся на гелиосинхронных орбитах. Это означает, что из одной и той же точки их видно каждый день в одно и то же время. В отличие от изображений, полученных с геостационарных спутников, изображения с низкоорбитальных спутников труднее анимировать. Спутник, движущийся по орбите, проходящей у тебя над головой, будет виден чуть более 12 минут. Но если орбита проходит сбоку, то время сократится. При этом зоны покрытия земной поверхности, изображения которых передаются спутником, будут совпадать не полностью.
Чтобы получать сигнал со спутника, твоя станция должна находиться в зоне его радиовидимости. При этом если Вы хотите получать данные о погоде в других частях света, Вам придется пользоваться другими источниками.
Помимо стандарта WXFAX, низкоорбитальные спутники передают свои данные в цифровом формате HRPT. Для приема информации в этом стандарте нужна специальная аппаратура!
Mexico
Offline7.0
с янв 2004
Дата: 19 Дек 2004 14:48:02 #
Вот спутник NOA:
Орбиты:
vovan58
с июл 2004
СССР
Дата: 22 Дек 2004 02:01:21 #
Спасибо Mexico
Понял как и что примерно работает.
Уже ловлю три дня спутники на частоте 137.225 и 137.250 даже на резину на
р-10 ,но сигнал то есть то нет максимальный был на 6 баллов.
теперь думаю как это всё посмотреть.
Дата: 22 Дек 2004 05:24:14 #
vovan58
"Уже ловлю три дня спутники на частоте 137.225 и 137.250"
Эти спутники Вы не посмотрите.Это спутники связи Orbcomm.
Метео ловите тоько на 137.500 и на 137.620.( +/- 5 килогерц
максимум.)
PenTod
Offline5.3
г. Королёв
Дата: 22 Дек 2004 10:46:49 #
Реально, из низкоорбитальных, работают сейчас только NOAA12,15 (137.5Мгц)и 17(137.62Мгц). Все остальное умерло, наши в том числе.
Дата: 22 Дек 2004 14:14:56 #
Yes yes
Mexico
Offline7.0
с янв 2004
Дата: 22 Дек 2004 17:55:31 #
Сич тоже умер? Из хэмовских низкоорбитальных или хэмовских которые можно принять "начинающему" что сейчас можно услышать?
PenTod
Offline5.3
г. Королёв
Дата: 22 Дек 2004 18:05:32 · Поправил: PenTod #
Mexico
На cqham.ru пишут, что работает SO-41 слушать на-436.775Мгц, передавать на-145.850Мгц. модуляция-чм. инфо по хэмовским спутникам можно найти на www.amsat.org
Mexico
Offline7.0
с янв 2004
Дата: 22 Дек 2004 18:11:51 #
Пардон,сформулирую вопрос по иному.
Лично,САМ,на СВОЮ аппаратуру кто-нибудь недавно СИЧ или хэмовские спутники слышал? Если да,то какие,как и на что.
Дата: 22 Дек 2004 20:12:52 #
Mexico
Ща послушаем.
Дата: 22 Дек 2004 20:23:36 #
LO-19 частота 437.125 Телеграф.Маяк.Слышно на 3 балла.Уже уходит из зоны
радиовидимости.
Дата: 22 Дек 2004 20:29:18 #
http://homepage.ntlworld.com/phqfh1/status.htm
Здесь всегда свежая информация по погодным спутникам.
Дата: 22 Дек 2004 21:19:50 #
TO-31,SO-50 не слышал.На подходе AO-51 и NO-45.Ждем-с.
Дата: 22 Дек 2004 21:24:24 #
435.848 SSB FO-29 2-3 балла.
Дата: 22 Дек 2004 21:46:39 #
AO-51 - не слышал.
NO-45 - тоже тишина.
"Неохваченные" спутники будут над Москвой поздно
ночью.Так что пока все.
Mexico
Offline7.0
с янв 2004
Дата: 22 Дек 2004 23:34:38 #
Вот это дело.Спасибо. На какую антенну принимаете?
Дата: 23 Дек 2004 00:23:22 #
Антенна Diamond X-510H Вертикальная коллинеарная двухдиапазонная
144/430 (3 x5/8L на 144;8 x5/8L на 430).
С направленными антеннами слышимость была бы намного лучше.
Дата: 23 Дек 2004 00:38:40 #
SO-50 436.800 +- 10 килогерц FM. Сигнал 2-3 балла.
PenTod
Offline5.3
г. Королёв
Дата: 23 Дек 2004 10:13:50 #
RW3DJO
Это был маяк, или кто-нибудь работал?
PenTod
Offline5.3
г. Королёв
Дата: 23 Дек 2004 10:17:01 #
Mexico
СИЧ сдох давно.
Дата: 23 Дек 2004 11:22:29 #
Здесь есть кое-что интересного по теме:
http://www.scanex.ru/rus/default.htm
Дата: 23 Дек 2004 16:14:20 #
PenTod
Гутарили буржуйские радиолюбители.
Будет сигнал помощнее - запишу при случае.
Дата: 23 Дек 2004 17:21:43 #
Mexico
СИЧ сдох давно.
Он исправненько работает.Только не для всех.Сечас на заводе уже новый приготовили-"Sich-1M".
PenTod
Offline5.3
г. Королёв
Дата: 23 Дек 2004 17:34:04 #
Только не для всех
Интересно)), а для кого он работает, если не секрет?
 Страница:  1  2  3  »»
