На сайте: гостей - 49,
 Форум —› Радиостанции —› Помогите найти инфу по раскрытию FT-987
Беркут Hunter
Егерь 3
President Randy II P
Турист 3
Штурман 80
Дата: 07 Янв 2005 16:22:00 #
Уважаемые, гопоспода-товарищи!
Прошу Вас поделиться бесценным опытом по "раскрытию" FT-897.
Заранее благодарен.
Гонец
с июл 2004
Дата: 07 Янв 2005 17:03:58 #
http://www.mods.dk/view.php?ArticleId=2590
Remove the 8 screws affixing the top panel of the transceiver and gently lift it off.
Carefully remove the small 2-pin speaker plug from the left rear corner of the transceiver interior, then remove the heavier 6-pin plug from the connector inside the right side of the transceiver. This can be removed by pushing on the tab to release the connector.
Locate the nine jumpers. These are located about 2" from the front edge of the main unit and about 3/4" from the left edge. You now have a choice of 2 different mods:
For 144/430MHZ TX expansion only, remove the jumper at JP1002, leaving the other jumpers alone. For the complete expansion per the above listing, place jumpers at JP1007/1008/1009, and remove the jumpers at JP1001/1002/1003/1004/1005(leave the jumper at JP1006 in place). Note the unusual sequence for the numbering. With the front of the rig facing forward, from the front of the rig to the back, the numbers of the jumpers are as follows: 1003,1002,1001,1006,1005,1004,1009,1008, 1007.
Result of radio should look like below after FULL mod was done:
----BACK OF RADIO------
1007 - Jumper
1008 - Jumper
1009 - Jumper
1004 - Blank
1005 - Blank
1006 - Jumper
1001 - Blank
1002 - Blank
1003 - Blank
----FRONT OF RADIO-----
Replace the top panel
With the transceiver off, press and hold the [F] and [V/M] keys; while holding them in, turn the radio on. Modification is now complete.
The radio is now complely reset to all the original factory settings except that it now is able to transmit 1.8-56 MHz, 137-164 MHz, and 420-470 MHz. You will need to reprogram all the menu operations and memory channels.
Желательно иметь хороший тоненький паяльник с заземлённым жалом и хорошую лупу!
Дата: 07 Янв 2005 17:11:47 #
Огромное спасибо за быстрый ответ.
Гонец
с июл 2004
Дата: 07 Янв 2005 17:22:24 #
Не за что!
Гонец
с июл 2004
Дата: 13 Янв 2005 21:51:57 #
Сегодня проделал это на практике. Работает. Надеюсь будет доступ к цифровику-сделаю подробное описание на русском языке с пошаговым руководством.
toshik
Offline2.7
с мар 2004
Дата: 13 Янв 2005 22:12:42 #
А зачем париться? Все уже есть на http://www.mods.dk/view.php?ModelId=69
По фоткам и так все понятно.
Гонец
с июл 2004
Дата: 13 Янв 2005 22:37:22 · Поправил: Гонец #
Не увидел фотографий......Само-собой понятно. НО если Вы против, то могу конечно и не делать.
Гонец
с июл 2004
Дата: 13 Янв 2005 22:37:57 #
toshik
Offline2.7
с мар 2004
Дата: 13 Янв 2005 23:44:42 #
Вот линк http://www.mods.dk/view.php?ArticleId=3112
И на нем полные инструкции в PDF http://www.mods.dk/mod/yaesu/DG2IAQ_Modification_Sheet_YAESU_FT-897.pdf
А там хоть велосипед изобретайте.
Гонец
с июл 2004
Дата: 14 Янв 2005 12:23:30 #
Сорри! Не читал сразу этот линк.
Romario
Offline6.1
с ноя 2003
Дата: 21 Янв 2005 00:55:56 · Поправил: Romario #
Планирую приобрести FT-897D Нашел за 999$ в ICS, но у них только Штатовские версии остались.
1.Знаю, что легко раскрывается, но на душе не спокойно... Нет ли там аппаратных ограничений по сравнению с другими версиями?
2.Нормальная это цена?
haba
Offline5.2
с авг 2003
Дата: 21 Янв 2005 13:43:46 #
ограничений нет. раскрывается нормально.
цена незнаю. в штатах он по моему 899 стоит. за 100 долларов его оттуда НИКТО не привезет. так что наверное цена нормальная. учитывая наличие российской гарантии.
