На сайте: гостей - 62,
участников - 6 [ BoostPRO, 13466, John79, Greenland, БрандмайорЪ, ut0va]
 Форум —› Главный раздел —› Активная антенна от Дегена
Hytera TC-320
Hytera TC-508
Hytera TC-580
Hytera PD-355
Hytera X1E
klaustro
с апр 2005
Дата: 14 Июн 2005 03:28:26 #
Недавно mapper рассказал мне, что Деген начинает выпуск активной антенны для мыльниц. Если кто не в курсе, вот ссылка.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=15051&item=5779176960
Информации об изделии мало. Главное, непонятно, будет ли оно продаваться у нас. У кого есть сведения, поделитесь, пожалуйста.
oitss
с фев 2004
Дата: 14 Июн 2005 09:44:16 #
я уже давал эту ссылку
http://degen.com.cn/UploadFile/2005-4/2005429101254484.jpg
на yahoo был ее обзор , но какой то невнятный
klaustro
с апр 2005
Дата: 15 Июн 2005 06:01:43 #
Спасибо. Вещь, конечно, полезная. Но все равно, непонятно, как будет с поставками в Россию.
oitss
с фев 2004
Дата: 16 Июн 2005 15:46:12 #
c kaito-de1103@yahoogroups.com
About the DE31 antenna, I'm globally *very* satisfied
by it.
I used it with a Sony 7600GR and an ATS-909
I tried to compare it to a classic inactive wire
antenna, and the DE31 almost always performed better.
I was surprised when I opened the package. The wire
upon which the rod antenna looks and feels like normal
rope. However, when you plug in the antenna, and tune
in to a radio station, and change the "shape" of the
antenna from a diamond shape to a triangle shape by
lowering the upper part of the rope so it touches the
lower part of the rope for example.... well you don't
receive anything anymore! So it seems that the "rope"
really has some electromagnetic properties.
I also noticed that the antenna doesn't really work at
3900 kHz (as it claims it does) but really starts to
work well at 4300 kHz (according to the very short
tests I did). I did not try to see how far up it would
go.
Another surprising thing is that it performs very
inconsistently. On some stations plugging it in will
considerably increase the SNR compared to reception
from the whip. On others it will amplify the noise and
not the signal ( ! ). However when this happens, it
can be a good idea to turn the antenna off. It then
most of the time still receives better than from the
whip (even on the 7600).
And contrary to another thing I read, the tuning knob
on the antenna is very sensitive. Tuning it as Liypn
explains in the short user guide he sends to buyers
via e-mail suffices.
Also when turned off the antenna will receive better
than from the whip on some stations and worse on
others... It's really strange.
Дата: 16 Июн 2005 15:58:49 #
...it can be a good idea to turn the antenna off
klaustro
с апр 2005
Дата: 17 Июн 2005 00:37:47 #
Да, не очень обнадеживающая информация. Может, и нет смысла сильно интересоваться ее поставками в Россию.
Гонец
с июл 2004
Дата: 30 Дек 2005 12:03:44 #
Таки есть в продаже в СНГ или нет ещё?
АВД
с дек 2004
Дата: 30 Дек 2005 13:24:23 #
Гонец, зачем Вам в СНГ? Дешевле, чем у liypn-а не будет:
"...$24.80 за активную антенну
http://cgi.ebay.com/NEW-INDOOR-ACTIVE-LOOP-ANTENNA-FOR-SHORT-WAVE_W0QQitemZ5798621146QQcategoryZ15051QQcmdZViewItem ).
Здесь её сравнение - Degen DE31 vs. Sony ANLP-1:
http://www.radiointel.com/review-degende31.htm
АВД
Гонец
с июл 2004
Дата: 30 Дек 2005 13:26:49 #
АВД спасибо, читал. Может есть у кого рядом?
Дата: 30 Дек 2005 14:16:10 #
А не подскажете, вообще в РФ какие-нибудь магнитные (loop) антенны продаются? Хоть на КВ, хоть на СВ/ДВ.
В своё время на Митинском рынке я их не обнаружил. Или "места надо знать" ?
Бывалый
4Z5NU
Дата: 30 Дек 2005 16:07:23 · Поправил: Бывалый #
Сохранились фотки по теме, а откуда- не помню:
mike2140
с авг 2004
Дата: 30 Дек 2005 19:38:33 #
Интересно, петля связи, приклееная к пластиковой подставке - это чтобы можно было показать работу с любыми приемниками, даже без разъема для внешней антенны??
Гонец
с июл 2004
Дата: 30 Дек 2005 19:57:23 #
Нет, магнитная антенна только на СВ и ДВ используется. Непонятно совсем, для чего катушка сделана. Разве конвертер какой-то.
Hoary
США
Дата: 30 Дек 2005 21:09:26 · Поправил: Hoary #
http://www.radioscanner.ru/uploader/2005/de31plus01.jpg
http://www.radioscanner.ru/uploader/2005/de31plus.jpg
Отсюда:
http://groups.yahoo.com/group/kaito-de1103/message/2252
Tao Qu & сотоварищи ваяют новую MW антенну TG33.
Здесь http://groups.yahoo.com/group/kaito-de1103/message/2363 он написал:
"Now we put the all resource for the TG33 indoor active loop antenna, and upcoming TG32 shortwave receiver antenna tuner, and TG35 MW indoor loop antenna, the TG33 is on the manufacture line now, and we finished the TG32 and TG35 engineering sample test already."
Для тех, кто не знает, Tao Qu - продавец на ebay:
http://stores.ebay.com/RADIO-AND-COMPONENT
