На сайте: гостей - 70,
участников - 4 [ aspi, Silent, XOR, spbtvmaster]
 Форум —› Антенны и фидеры —› Автоантенна (легкая загадка)
Зарядные устройства
Гарнитуры и тангенты
Аккумуляторы
Динамики
Переходники
Ware
Offline6.5
с июн 2003
Дата: 10 Мар 2006 19:24:08 #
Для чего?:)
AntonSor
Видное, Московская область
Дата: 10 Мар 2006 20:12:59 #
На сайте www.sensis.com про эту систему написано. Называется Sensis VeeLo. Цитирую:
The Sensis VeeLo is an airport vehicle location unit designed to operate in conjunction with the widely used Sensis Multistatic Dependent Surveillance (MDS) system as well as standard Advanced - Surface Movement Guidance and Control Systems (A-SMGCS). The unit installs on the external surface of vehicles operating in the airport movement and apron areas. In addition to the safety benefit of providing air traffic controllers with vehicle position and identity, VeeLo can contribute to airport efficiency through asset tracking and dispatch management.
VeeLo is designed to operate in the licensed 1090 Mhz aviation band and emits the same type of signals as an aircraft transponder. Additionally, VeeLo is architected for compatibility with future technologies such as Automatic Dependent Surveillance - Broadcast (ADS-B).
VeeLo has undergone strenuous testing and is fully compliant with safety, environmental and aviation standards such as the Radio Technical Commission for Aeronautics (RTCA) DO-260A and ADS-B Minimum Operational Performance Standards (MOPS). To accommodate nearly any installation requirement and concept of operation, configuration software, mounting brackets, cable kits and a safety tether are available.
http://www.sensis.com/docs/50/
Ware
Offline6.5
с июн 2003
Дата: 10 Мар 2006 20:19:26 #
Ура, товарищи!
Ware
Offline6.5
с июн 2003
Дата: 10 Мар 2006 20:21:39 #
