На сайте: гостей - 61,
участников - 3 [ CDMA, TevatroN, Voevoda]
 Форум —› Главный раздел —› Владельцам Maycom AR-108
БЕГЕМОТ
Offline7.8
с авг 2004
из ниоткуда в никуда
Дата: 04 Фев 2007 00:29:19 #
Нашел такую вот инфу:
Functions not mentioned in the
Maycom AR-108 Manual
How to delete a memory channel:
Push MR and use the UP/DN buttons to select desired memory channel.
Enter the Memeory Set mode FUNC + MR.
Push and hold FUNC + MON down for more than 1 second.
Now are the desired memory channel deleted.
Display test:
Push and hold AI and turn the scanner on.
Now you will se all the segments of the AR-108 display.
How to reset the Maycom AR-108 to the factory settings:
Push and hold AI + FUNC and turn the scanner on.
The message INITIAL are shown in the display..
Now is the Maycom AR-108 reset to the factory settings,
with 124 MHz stored i memory channel 1 in the Air band,
and with 156 MHz stored i memory channel 1 in the "VHF band".
How to change the Maycom AR-108 from an American version (with WX-channels) to an European version (with full VHF coverage from 136 MHz to 180 MHz):
Open the receiver an solder the solder path's marked OP 4.
PS: возможно владельцам это не ново, у меня этой игрушки никогда не было.
Время загрузки страницы (сек.): 0.038; miniBB ®
