Дата: 06 Июл 2007 00:07:17
цветной дисплей и полифония :) с мп3плеером : .... и флеш картой ::)))
Дата: 19 Июл 2007 13:43:19
На мясницкой трёшка уже появилась :) Цена пока не известна, сказали определяться в течении недели.
А так по внешнему виду понравилась, крепче чем двойка. Валкодер не такой уж и страшный как казалось, правда выпирает сильно. Среди аксессуаров есть кейс под пальчиковые батарейки который будет совместим с VX-2.
Вообщем, как говорят, must buy.
Дата: 20 Июл 2007 20:52:57
Видел в продаже по 200$
Дата: 20 Июл 2007 20:58:26
mz3du Где? Как это она может стоить дешевле двойки?
Дата: 20 Июл 2007 21:05:09
Многим очень нравится.
Вот, что пишет народ-
From my experience, the 3R has better RX than my 2R and 6R. I bought a second battery (Ultralast UL-NP60 1200 mAH). The Sub-RX feature works real well, not like Dual Scan which periodically switches Freqs to scan the primary station. Also, you can monitor all bands through the stereo audio jack. There is an interesting Text Message feature that I won't be able to test until I find someone with another 3R or the new FT-10R. The only downside is that the battery cover is not a tight fit (top end shifts side to side).
My first tests were on the local 2m machine that serves my county (146.88 in Somerset, KY), it brought up the machine from 18.5 miles away with only 1.5 watts, but I was not able to steadily hold it or get a clear transmission. Regardless, that is pretty good considering the distance and semi mountainous terrain of this part of KY.
Once I got home, I tried the 440 machine located at the same location as the 2m and was able to get into it full quieting from 12.8 miles away, on only 1 watt. Haven't tried the 2m side from this location.
Most of my out of ham-band listening has been on UHF Police/Fire/EMS frequencies locally and reception has been excellent, even with the stubby SMA-501 antenna in my basement, which is almost fully underground.
Overall, the design is excellent and feels much more sturdy than the old VX-1 I had. The locking knob is a nice feature, the buttons have good tactile feedback.
The only thing that I really noticed, which isn't really a negative, is that when talking, the raised pattern on the PTT button imprints itself on your PTT finger. A slightly larger smooth PTT with a non-raised pattern would have been nice.
Pros:
- Small Size
- Sturdy feel
- Charging Status
- Regular sized stereo headphone jack
- Same if not more features than larger HTs
- Decent Price (for a new release)
- Dualband with Wideband receive
Cons:
- No beltclip of any kind
Дата: 22 Июл 2007 20:38:47
а где Вы её видели уже по 200 ? Если она на Юниверсал сейчас по 220 ...
Дата: 22 Июл 2007 21:12:04
Дата: 22 Июл 2007 22:03:35
Правильно, а 2R помечена как снятая с производства.
Дата: 25 Июл 2007 20:38:45
Интересно, сколько будет она стоить в россии. И сколько теперь будет стоить 2ка.. 2ку бы я хотел прикупить себе в дополнение к 60ке =)
Дата: 25 Июл 2007 20:50:25
jd01
Вот! Если....... Даваите спустимся с небес и будем обсуждать то что существует в продаже на сегодняшний день. А то что было бы Если Айком, или Кенвуд эти свои аппараты засунут в железо, да ещё и плавать научат то не ведомо никому!
Да без всяких если УЖЕ аналоги vx-7r от айкома и кенвуда стоят дороже.
Дата: 26 Июл 2007 01:45:37 · Поправил: Dimitriy (26 Июл 2007 01:56:08)
В Yaesu на Мясницкой 3-ки в свободной продаже, розница 250 у.е.
стоит на витрине, можно пощупать, у.е. у них 26. с чем не помню.
На 2-ки цена не упала, как были 210, так и остались.
Про снятие 2-ки с производства японцы им ничего не объявляли,
поставки не отменяются.
Трешку держал в руках, механизм блокировки валкодера
забавный- вытащил вверх= крутишь, опустил вниз - фиксируется.
Усилие при этом некоторое есть.
Во внутреннем кармане крутить и фиксировать несколько неудобно по-моему будет.
Индикация сделана более наглядной, + стерею ФМ при одновременном мониторинге
другой частоты. Батарейный отсек как опция.
В целом производит впечатление той же двойки, но в другом корпусе и с другим дисплеем.
Про преймущества ферритовой антенны продавцы умалчивают, сами еще
отзывов не накопили.
Дата: 26 Июл 2007 02:02:09
rocker
Если можно, по подробнее про аналоги.
Дата: 01 Авг 2007 01:29:37
Я последние несколько дней изучаю имеющиеся на рынке модели и, насколько я могу судить, аналогами Yaesu VX-7R являются KENWOOD TH-F7E и ICOM IC-E91. Полагаю, rocker имел в виду именно эти модели.
Немного оффтопичный вопрос ко всем. Читая отзывы на eham.net о Yaesu VX-7R, на самой первой странице увидел упоминание того, что эту радиостанцию в скором времени могут снять с производства, если я правильно перевёл для себя следующий текст: "...because I’ve been told they are on the last runs of the VX7 and I wanted another before they are gone. I don’t know for sure if the production will end soon but I like them that much so I got one now just in case!"
Кто-нибудь что-нибудь слышал на эту тему? Я планировал купить себе VX-7 несколько позднее, где-то в марте, подкопить пока денег. Если они действительно могут кончиться, то, похоже, надо бежать занимать :-)
Т80Участник
  с фев 2005 Столица России одна - Город-Герой Москва Сообщений: 1058
Дата: 01 Авг 2007 01:44:01
zpt
чел пишет, что-де "он неуверен".
Но рано или поздно конечно же модель будет снята с производства.. Как и любая модель любого производителя любой продукции, что сейчас есть в продаже. А что тут удивительного?
И еще - что такого волшебного в vx7, что надо её обязательно купить, но не сделали этого ранее?
Дата: 01 Авг 2007 02:00:28 · Поправил: zpt (01 Авг 2007 02:05:21)
Я лишь в воскресенье осознал, что рация мне вообще нужна. После чего я дня два изучал этот сайт и другие ресурсы и на данный момент пришёл к выводу, что мне нужна именно эта рация.
Я бы с радостью обошёлся чем-то вроде мидланда, но, боюсь, в скором времени я захочу его сменить и всё равно придётся покупать дорогую рацию. Купить я её хочу в целом для игры в страйкбол, но планирую использовать и на охоте, например. В семёрке мне нравится универсальность диапазонов приёма и передачи; наличие двух приёмников, что позволит, например, слышать переговоры противника; а также механическая прочность и водостойкость, которые у упомянутых моделей кенвуда и айкома всё же поменьше. Нравится и большАя мощность передатчика.
Если Вы подскажете менее дорогостоящую рацию, которая подойдёт под мои задачи, буду рад.
Т80Участник
Дата: 01 Авг 2007 02:16:01 · Поправил: Т80 (01 Авг 2007 02:31:27)
zpt
Может быть не брать новую vx7, с большой вероятностью убить её, недешёвую, в хлам в первые же дни, а поискать для начала что-то на вторичном рынке из других моделей, да подешевле? Тем более что Я лишь в воскресенье осознал, что рация мне вообще нужна.
Не, если двух дней изучения хватило - вперед, на баррикады.
Что касаемо влагозащиты и прочая - на эти особо у любительских станций полагаться не надо.
ИМХО.
Полистайте раздел "рейтинг", может еще что приглянется:
http://www.radioscanner.ru/rating/category/transceivers_portable/ |
Дата: 01 Авг 2007 02:54:46
1) б/у брать не очень хочется.
2) На eham.net пишут, что она весьма прочная и надёжная. Разные люди её неоднократно роняли, в том числе и с 40 футов, и она выживала.
Я проглядел весь раздел "рейтинг" и весь "главный раздел" форума. Ещё изучу раздел "радиостанции" в ближайшие пару дней, и, если ничего нового не узнаю, видимо, буду брать именно её. |
Дата: 01 Авг 2007 11:04:26
я бы все же рекомендовал для начала приобрести FT-60R. потом купите ради интереса 7ку - разочаруетесь в ней и продадите.
любопытный факт - обявлений о продаже 6ок и 7ок бэу народом - довольно много. а обьявлений о продаже бэу фт60 - раз два и обчелся. а покупают их намного больше.
Дата: 01 Авг 2007 14:23:49
60-ка и 7-ка всё таки различны, и в основном, в сервисе. В 7-ке его больше.
Дата: 01 Авг 2007 14:29:19
вот и я про то же. подавляющему большинству юзеров достаточно сервисов 60ки. да и работает она качественнее ВНЕ диапазонов, да впрочем написано про 60ку немало, что повторяться.
плюсов - море. начиная от широкораспространенного аккумулятора и батарейного отсека позволяющего работать с полной мощностью заканчивая лучшими (чем у 5 - 6 - 7ок) приемными хар-ками.
Дата: 01 Авг 2007 15:42:31 · Поправил: Karabas (01 Авг 2007 20:42:36)
60-ка по чутью и селективности, избирательности одна из самых удачных у YAESU, но почему-то многие ведутся на "попсовость" 7-ки и... в результате разочарование, и как следствие, продажа.
VX-3R На Мясницкой:
 Увеличить |
Дата: 01 Авг 2007 20:41:38
а я брал чисто из энергоэргономических соображений
когда взял в руку - Шестерка как влитая туда легла, не хотела отлиплятся, 60-ая чуть тяжеле и некозистее показалась! так и выбрал! :))
а 2 или 3 все равно возьму - это чистой воды удовлетворение гаджетомании))) - что-то незаметное - и эфир всегда с тобой ! !
Дата: 02 Авг 2007 09:58:13 · Поправил: 158 (02 Авг 2007 12:59:58)
как можно сравнивать велосипед и джип???
у меня была 60-ка
сейчас 2-ка и 7-ка....это разные аппарады ДЛЯ РАЗЛИЧНЫХ ЦЕЛЕЙ И ЗАДАЧ
....ведь "каждый выбирает для себя.женщину.религию дорогу ... и рстанцию"
60-ка чисто радиолюбительский аппарат с охренительным с-метром
лучше пока не видел,минусов нет(если не считать веса аккамулятора-но это компромис за
мощность и долгую работу,мне хватало на 2-3 дня) .......хорошо слушать спутники......
7-ка....это аппарат для экстрималов,есле вы вываливались с лодки и жалели что ваша
станция не работает-купите 7-ку (желательно бу)
аппарат для работы за городом.........
из минусов-очень быстро разряжается,при активном пользовании может и на пол дня не хватить
подзаряжать приходится каждый вечер-причём время зарядки
более 6-8 часов!!!!
2-ка-этот аппарат я бы назвал "для повседневной носки"
маленький ,лёкгий,время зарядки 2-3 часа (купил машинный адаптер за 160 руб.-
хотя и так на 2-3 дня хватает) Минусов-НЕТ
Дата: 02 Авг 2007 12:40:49
Сколько стоит VX-3R На Мясницкой или с ценой еще не определились.
Дата: 02 Авг 2007 12:54:10
zpt
да, спасибо, именно эти модели я и имел ввиду. Да и не так много такого уровня станций, что нельзя угадать с 1 раза =)
Дата: 03 Авг 2007 20:00:46
Кто нибудь взял себе VX-3, как впечатления?
Дата: 03 Авг 2007 20:40:11
vertex
почитайте на eham.net/reviews/
Т80Участник
Дата: 11 Авг 2007 01:43:15
vertex
Ресурс известный конечно же, но более интересно мнение местных форумчан. Но пока отзывов не слышно- не видно.. Кто первый? ;)
Дата: 11 Авг 2007 09:14:47 · Поправил: geka (11 Авг 2007 11:06:57)
Спрашивайте... =)
Чё в рейтинге нет, добавлю.
Дата: 11 Авг 2007 11:19:52
geka
Ну там и понаписали... :)))
Как начали с минусов, так и расхотелось даже вживую посмотреть на это "чудо"!
