На сайте: гостей - 76,
участников - 7 [ Slavik, Microtech, Nifedow, sibirjac, tradeeee, XOR, ew2abc]
 Форум —› Главный раздел —› Номерные станции
Icom IC-R6
Yaesu VR-120D
Icom IC-R75
Yaesu VR-160
Icom IC-R20
 Страница:  ««  1  2  ...  19  20  21  22  23  ...  60  61  »»Поиск в теме
Ivellios
с фев 2010
Польша
Дата: 14 Фев 2010 18:06:12 #
Hi everybody,
Although I don't speak russian, I can read grazhdanka, but to make my user's life easier I use translators. On your forum I found a lot of interesting informations. Now I would like to post something own :)
I have registered on globaltuners.com, a website which allows people who doesn't have their own shortwave receivers to use receivers located in many regions of the world. During "having fun" with these receivers I have received a few interesting transmissions.
The first two recordings I made on 31th January 2010:
Phonetic alphabet: http://www.youtube.com/watch?v=H88sD99FWps
5783 kHz - "Russian Man", also called E6: http://www.youtube.com/watch?v=_qyJ0YylpkI
Today, at 02:34 local polish time, I have received something quite interesting. It was an extremely rare situation, when one numbers station broadcasted two transmissions on the same frequency and at the same time! I think this organisation should lay-off its radio workers... http://www.youtube.com/watch?v=6GYfslHD_-A
Some time ago I wrote an article about numbers stations - if you are interested in stations broadcasting from Poland, Russia, Ukraine and other countries in our part of the world, you read my article: http://www.paranormalium.pl/stacje-numeryczne-radiowe-audycje-widmo,753,24,artykul.html (you can translate it by Google Translate or Translatica.pl - a very good polish-to-russian translator)
медведь
Offline5.8
с фев 2008
Дата: 14 Фев 2010 19:30:42 · Поправил: медведь (14 Фев 2010 19:40:59) #
медведь
Offline5.8
с фев 2008
Дата: 14 Фев 2010 19:31:47 · Поправил: медведь (14 Фев 2010 19:39:54) #
Таблица частот - вот эту штуку довольно часто поздно по вечерам слышно. В конце передачи всегда "мэсэдж........энд оф мэсэдж, энд оф трансмишн". Само сообщение из тех же слов, что и до сообщения...
http://ru.wikipedia.org/wiki/Моссад
Akonit
с апр 2009
Черноземье
Дата: 15 Фев 2010 12:16:02 #
14.02.10 22-00 6840 кГц EZI сообщение для 57.
в 22-05 врубился бабблер.
медведь
Offline5.8
с фев 2008
Дата: 15 Фев 2010 19:37:59 #
врубился бабблер - а он вообще не часто врубается? Вчера не слушал...
ic746
с авг 2004
Дата: 16 Фев 2010 08:41:30 · Поправил: ic746 (16 Фев 2010 08:42:19) #
Понедельник-излюбленный день S06 YL:
8420khz / 1300z / 15/02/10 / AM S06 YL / MON [сообщение №940 из 5 групп для 831 до 1305z]
Это же сообщение было продублировано на частоте 10635 khz в 1310z
В 1610z на частоте 6668khz было сообщение для 176.
Akonit
с апр 2009
Черноземье
Дата: 16 Фев 2010 10:00:17 #
когда как. иногда сообщения не глушится вообще, иногда глушилка практически сразу врубается.
вообще как-то не вполне понятен смысл работы этих бабблеров. сквозь них речь довольно разборчиво бывает слышно. нечасто приходилось слышать, чтобы наглухо забивалось сообщение.
кто-нибудь пытался проследить тенденцию глушения в зависимости от позывного (EZI, ART и т.д.) ?
ic746
с авг 2004
Дата: 16 Фев 2010 11:23:11 #
Это здесь речь слышно, т.к. вы наблюдаете со стороны. Возможно тот, кому предназначены сообщения их не принимает, поскольку имеет другое местоположение.
Ivellios
с фев 2010
Польша
Дата: 16 Фев 2010 15:20:43 #
Here are recordings of stations that I received on 16th February at night:
http://ivellios1988.wrzuta.pl/audio/1LjyZVa7q0I/stacja_numeryczna_g16_e16_whisky_lima
4724 khz USB at 0006 UTC
http://ivellios1988.wrzuta.pl/audio/aQ5N1punFjm/stacja_numeryczna_mossad_e10
3415 khz, later I found the same transmission on 2743 khz, it's Mossad E10, received at0030 UTC, strong interferences from Volmet broadcasting on 3417 khz
http://ivellios1988.wrzuta.pl/audio/675oDDxaAwI/stacja_numeryczna_squeaky_wheel_s32
3828 khz, station known as squeaky wheel, also called S32, received at 0025 UTC
http://ivellios1988.wrzuta.pl/audio/7lQki9RVW5m/stacja_numeryczna_wtf
4508 khz received on 15th February 2010 at 2354 UTC, later this signal vanished... does anybody have any idea about what could be that?
All the stations presented here I received by the receiver located in Kristianstad in Sweden, receiver shared on globaltuners.com
ic746
с авг 2004
Дата: 17 Фев 2010 14:25:36 #
Ivellios
As far as I know G16 E16 ceased work in 1997. Tell us about the radio station S32. You do not confuse it with the S21, operating at a frequency of 3823 kHz?
ic746
с авг 2004
Дата: 19 Фев 2010 09:19:53 #
Тока что 0600z S06 YL отметилась на 5460 кГц
Akonit
с апр 2009
Черноземье
Дата: 19 Фев 2010 10:03:05 #
18.02.10 22-43 на 6840кГц Е10 забивалась бабблером. в 22-46 - конец сообщения и передачи.
в 22-46 обнаружил на 6987 кГц тот же голос, читающий другое сообщение в ускоренном темпе. в 22-47 появилась сильная помеха и сообщение прервалось.
ic746
с авг 2004
Дата: 19 Фев 2010 12:58:54 · Поправил: ic746 (19 Фев 2010 12:59:21) #
Вновь S06 YL вышла в эфир:
В 9.30z сообщение 20/7 для 516 на частоте 11780 кГц. Это же сообщение повторено в 9.40z на 12570 кГц
Ivellios
с фев 2010
Польша
Дата: 21 Фев 2010 04:35:08 #
ic746, at this moment I'm not quite sure what that could be - I thought that it was G16 E16, but administrator of simonmason.karoo.net suggested, that it could be rather station provided by american army (using similar phonetic alphabet).
With S32, my knowledge about this station is based on internet publications like this: http://hfsurfing.blogspot.com/2008/11/s32-squeaky-wheel-changes-tempo.html and this: http://www.tajemnicesw.cba.pl/tajemnice_sw.htm#_Squeaky_Wheel According to these websites, the station that I received is known as S32 "Squeaky Wheel".
biv_2
Чита
Дата: 21 Фев 2010 05:01:15 #
А есть кто-нибудь в форуме "матерый", кто эти самые станции уже лет 30-40 слушает?
Например, знаю, что давно уже работала станция, которая в качестве вызова передавала песню Эдит Пиаф "Падам", а потом в конце передавалась фраза "count zero zero zero" (видимо если было сообщение что то другое происходило, но ...). Как я понимаю это была предшественница известной в последствии E05. Я коллекционирую вызовы разных станций уже более 15 лет. Готов к обмену. Вот :)
ic746
с авг 2004
Дата: 24 Фев 2010 09:00:55 #
Вчерашний 23/02/10 мониторинг:
В 0740z на 13427khz принята передача XPA.
В 8.00z на частоте 10265khz и в 0810z на 9135khz S06 YL
передала следующее сообщение:
352...352 970 970 6 6
21767 35672 11834
81022 36903 41412
970 970 6 6
0 0 0 0 0
В 0820z на 6767khz и в 0840z на 7367khz радиостанция E07 OM передала сообщения для 873.
Уровень модуляции как всегда очень мал, принимать весьма затруднительно.
Akonit
с апр 2009
Черноземье
Дата: 25 Фев 2010 08:27:34 · Поправил: Akonit (25 Фев 2010 08:28:05) #
24.02.10 в 22-07 на 6738кГц SSB сквозь сильную помеху обнаружился металлический мужской голос, начитывающий цифро-буквенные сообщения.
особенность - "эхо" с задержкой примерно в полсекунды. причем "эхо" было слышно четче чем исходный звук.
в 22-09 передача прекратилась.
Nabludatel
Offline6.4
с мая 2009
Дата: 25 Фев 2010 09:58:18 #
23 февраля, показывали один советский фильм про шпиона который приехал в СССР для сбора инф. Шпион поселился в деревни. Показали один момент когда он долго крутил бытовой КВ приемник и поймал номерную станцию (женский голос, немецкий язык), шпион записал на бумагу принятую инф. и начал расшифровывать используя криптоблокнот. Наверное и сейчас так делают "резиденты" разведок, хотя значительно проще использовать современные системы связи (интернет, сотовая связь, спутниковая связь.) А когда передают инф. да еще и в SSB ?
ic746
с авг 2004
Дата: 25 Фев 2010 11:11:47 #
Да, проще но это оставляет следы. Интернет, сотовая связь-все протоколируется Почитайте про GCHQ. Спутниковая связь- тарелку надо городить, если спутниковый телефон-тоже что и сотовая связь. А тут бытовой приемник. Вычислить невозможно, при соблюдении элементарных правил. Точно также как и одноразовый шифрблокнот.
Интересуюсь
Offline2.8
с окт 2009
бывшая сюзная...
Дата: 25 Фев 2010 13:43:48 #
Про 30-40 лет не скажу, но в конце 80х начале 90х наблюдал в Апхазии моссадовскую даму на СВ ( в районе 540 кгц).
Nabludatel
Offline6.4
с мая 2009
Дата: 25 Фев 2010 22:38:23 #
ic746
Допустим Вас, или меня, если Вам или мне кто-то передаст инф. на электронную почту, или отправят СМС с текстом (Посылка пришла, распокавал) на это не кто не обратит внимания.А под этим текстом зашивровано сообщение. На портативный приемник больше обратят вниминие чем на КПК или сотовый телефон. Вспомните аэропорт когда все возможные радиосканеры и т.д. провозимые пассажирами вызывают очень много вопросов и документов на провоз этих радиоприборов тоже куча нужна. Не дает мне спокойно жить вопрос, почему при развитии современых систем связи все это надо на КВ. Ведь кроме "резидента" , № ст. слышат много народу и такие как мы ломаем голову. Что-то здесь ни так. ???
Tomin
с июл 2006
50/90/150
Дата: 25 Фев 2010 23:45:41 #
Nabludatel
слышат многие, а смысл разумеют единицы.. Да и слушать, внешне обычное радио, тоже не привлекает внимания.
Гонец
с июл 2004
Дата: 25 Фев 2010 23:53:19 #
Nabludatel не городите ерунды, даже европейцы не задают никаких вопросов вытащив на спецконтроле R20 Icom. Правда без антенны. И тут же за ним Sangean ATS 909 из того же отделения рюкзака. Таскаю много и часто с собой подобное железо. Только родная таможня нервничает, видя на ренгене кучу проводов и электроники, начинают канючить что кризис на их зарплату повлиял и им бедным тяжело стало, намекая что с ними надо пытаться договориться. На крайний случай лицензия р/любительская всегда в соседнем кармане.
Piotr
Malbork,Poland/Bedford UK
Дата: 26 Фев 2010 01:14:02 · Поправил: Piotr (26 Фев 2010 02:12:05) #
Теперь "?" на 5135 КГц. Говорить группы номеров.
http://terpio.wrzuta.pl/audio/93fyTDY8TEr/5135k.2215utc.25.02.10e7
Akonit
с апр 2009
Черноземье
Дата: 26 Фев 2010 08:28:57 · Поправил: Akonit (26 Фев 2010 09:40:59) #
25.02.10 в 21-34 на 7848кГц АМ громобойно вещала незнакомая станция.
женский голос в течение минуты по кругу передавал сообщение: 416 22. между группами цифр - слово то ли oblik, то ли obrik.
в 21-35 передача прервалась.
ic746
с авг 2004
Дата: 26 Фев 2010 09:11:32 #
Прочитайте про СОРМ, СОРМ2.
Ведь кроме "резидента" , № ст. слышат много народу и такие как мы ломаем голову. Что-то здесь ни так. ?Ну и толку что все слышат? За все время вычислили сообщение Good Night. Возможно это был прикол. Можно и дезу гонять, вариантов много..
Akonit 26.02.10 в 21-34 Ваше сообщение добавлено в 26 Фев 2010 08:28:57. Не совсем понятно..Время UTC или MSK? Число не перпутали?
Akonit
с апр 2009
Черноземье
Дата: 26 Фев 2010 09:41:23 #
Число не перпутали?
пардон. 25.02.10
Nabludatel
Offline6.4
с мая 2009
Дата: 26 Фев 2010 12:57:42 #
[b]Гонец[Вы и не будете привлекать внимания слушая приемник если вы не шпион, а если шпион то и контрразведка не дремлит. Вспомните сколько резидентов ловят в разных странах, хотя они профи. а причина то есть. Вот и вызовет подазрение обычный приемник у такого дяденьки, а на Ваш R 20 и глазом не взглянут, ведь Вы обычный человек.
ic746
с авг 2004
Дата: 27 Фев 2010 08:32:41 · Поправил: ic746 (27 Фев 2010 08:35:01) #
Вчера 26.02.2010 в 1600z на частоте 8130кГц включилась S06 OM с сообщением 732/41 для 480. При этом на её фоне включалась служебная радиостанция с мощным сигналом на 8131кГц. В 1603z передача S06 прекратилась. Затем передача сообщения возобновилась сначала через 2 минуты и продолжилась до 1617z. Как будто кто то позвонил и попросил продублировать сообщение изза помех ;-)
Akonit
с апр 2009
Черноземье
Дата: 27 Фев 2010 08:54:21 · Поправил: Akonit (27 Фев 2010 08:55:10) #
26.02.10 в 21-47 на 3491кГц SSB обнаружил нашинского "живого" мужика, зачитывающего цифирь.
сообщения были следующего формата:
0219 в 41м 49.
0008 073 95 36 53.
0216я в 076 65 в 64 54.
0084 075 30 в 65м 00 2157.
0216 073 45 в 55м 01.
в общем я так понял, что последние 2(4) цифры - это время - минуты (часы-минуты)
первые 3-4 цифры - обозначения чего-то, остальные цифры - местоположение.
мужик сыпал цифрами довольно быстро, иногда запинался. также было слышно тыцание тангеты.
передача завершилась примерно в 22-26.
шо это такое может быть?
Время загрузки страницы (сек.): 0.090; miniBB ®
