На сайте: гостей - 70,
участников - 3 [ ГУ50, Men, seregamaxonin]
 Форум —› Программное обеспечение —› Есть ли программа для декодирования FAX (NMT-450)?
Yaesu FT-60R
Yaesu VX-3R
Yaesu VX-6R
Yaesu VX-8DR
Yaesu FT-1D
Дата: 07 Ноя 2007 23:21:10 #
Privet,
Est li programa dlia dekodiruvanie FAX, kotori idion cherez NMT-450.? (wav to image)
Skif585
Offline5.9
Дата: 08 Ноя 2007 00:01:53 #
Стандарт NMT-450 декодируется прогой «wavecom w61pс», URL http://www.wavecom.ch/
Info с их сайта:
NMT-450 is an analogue mobile telephone system, developed by the Telecommunication Administrations of Denmark, Finland, Norway and Sweden. The idea was to establish a compatible, automatic, public mobile telephone system in the Nordic countries. NMT-450 mobile station signals can be found from 453 MHz to 457,5 MHz, base station signals from 463 MHz to 467,5 MHz. The frequency range is divided into 180 channels of 25 kHz each (channel 1 -180).
In areas with a lot of mobile subscribers, an extended band from 452.5 MHz - 452.975 MHz (mobile) and 462.5 MHz - 462.975 MHz (base) may be used as an option. The offset between mobile and base frequency is always 10 MHz.
Control messages (signals) containing system wide information, assignment, status and dialed number are exchanged between the mobile station and the base station.
All signals are transmitted at 1200 baud FFSK with a center frequency of 1.5 kHz and a shift of 600 Hz.
An encoded NMT-450 frame has a length of 166 bits. Every frame contains 15 bits bit sync sequence followed by an 11 bits frame sync sequence. The last 140 bits contains the encoded message. In order to combat errors on the radio path, due fading and interference, an error-correcting code is used.
Today , NMT-450 is used in Sweden and a modified NMT-450 in Poland and Eastern Europe. More information can be found in the NMT DOC 450-1 / 450-3 specifications.
Дата: 08 Ноя 2007 00:13:56 #
Spasibo!, shliu. U menia pochemuto NMT lovit 441-445MHz (TV-tuner)
Дата: 08 Ноя 2007 00:31:57 #
kak ya ponel, dlya etoj programi nuzno specialnoe oboroduvanie.Ili vozmozhno, s zapysenych wav failov poluchit kokuyu to info pro NMT?
Skif585
Offline5.9
Дата: 08 Ноя 2007 00:47:25 #
Для w61pс, нужна специальная карта, и стоит она нереальных денег. Если найду по этой теме еще что-то, выложу. А вообще NMT-450 это умирающий аналоговый стандарт, сейчас переходят в цифру, в основном TETRA.
P.S. пишите, пожалуйста, на русском или на английском, а то я в криптографии почти не чего не понимаю :)
mandgusta
с окт 2007
uae
Дата: 08 Ноя 2007 01:21:17 #
Служебную информацию NMT-450 можно декодировать с помощю CODE300-32
см. Mode->VHF/UHF->MPT1327.
Эти пртоколы совместимы...
Вот что получилось у меня:
synt
GTC PREFIX 35 CALLEDP 522 SPEECH CHAN# 218 CALLINGP 5600 ALOHA# 2
sync
synt
GTT/DRUGI
sync
sync
sync
sync
synt
synt
GTC PREFIX 117 CALLEDP 6930 DATA CHAN# 883 CALLINGP 7170 ALOHA# 2
Правда это было где-то года полтора назад. Сейчас в нашем регионе NMT не слышно, возможно действительно перейшли на TETRA. :((
sibist1
Рига
Дата: 08 Ноя 2007 03:38:33 #
У нас давно уже перешли на CDMA на 450Мгц,NMT уже умер.Теперь уже непослушаеш телефоны как раньше , да и рации многие уже перешли в тетру на 380мгц
alpo
Пермь
Дата: 08 Ноя 2007 08:01:56 #
Venta Fax.
Дата: 08 Ноя 2007 10:58:21 #
synt
sync
synt
GTT/DRUGI
sync
sync
sync
sync
synt
synt
Вот такое-же декодировал с 86.45Мгц с Дегена. Что это было (гармоника, интермодуляция?) незнаю, на юге Москвы шипит и жужжит постоянно.
Skif585
Offline5.9
Дата: 08 Ноя 2007 20:20:34 #
Цитата из http://signals.radioscanner.ru/signal26/
Управляющий канал MPT-1327 подобных систем, их несколько использующих примерно одинаковый протокол, с мелкими различиями, которые ставят в тупик декодеры, заточенные именно под MPT-1327, но которые не могут настолько изменить сигнал, что бы нельзя было его опознать, принадлежность к семейству MPT-1327 очень легко обнаруживается при внимательном изучении. Почему то путают MPT-1327 и NMT-450, на самом деле их спутать можно, только после "большого бодуна", или при полном нежелании напрячься, это очень очень разные сигналы.
Это действительно очень разные сигналы, mandgusta и Sergey4565 что Вы принимали???
Пример декодированного MPT-1327 с http://signals.radioscanner.ru/signal26/ программой CODE300-32:
CCSC SYS identity 18562
ALH INV-TX 699135 ALH CHAN4# 5 DELAY 1 RSVD 0 ADDR-QUAL# 0 ALOHA# 0
ALH INV-TX 699135 ALH CHAN4# 5 DELAY 1 RSVD 0 ADDR-QUAL# 0 ALOHA# 2
Saved decoder text at: 20:02:59 08.11.2007
P.S. Если возможно выложите эти записи на форум…
Дата: 08 Ноя 2007 21:33:39 #
http://www.radioscanner.ru/uploader/2007/86.45.zip
http://www.radioscanner.ru/uploader/2007/86.45mhz_fm_25_07_20.zip
Первый сигнал похож на маркер канала (занятие частоты, слышал такое какраз на телефоне NMT450)
второй - собственно передача данных, иногда на частоте только несущая.
P.S. по привычке в рар загнал, нужно сменить расширение если так не поймёт.
Skif585
Offline5.9
Дата: 08 Ноя 2007 21:48:48 #
Спасибо за сигналы, поюзаю! У Вас он декодируется? Если что-то получиться целесообразно эту тему перенести в радиосигналы! Еще просьба будут подобные сигналы - выкладывайте побольше и таблетку от жадности.
Дата: 08 Ноя 2007 21:54:40 #
Есть вариант шумелки длит. 1800сек. если интересно то попробую засунуть на ифолдер.
Декодировать пробовал с эфира, писал в вав 11кгц, объём большой 38.7мб.
Skif585
Offline5.9
Дата: 08 Ноя 2007 23:04:04 · Поправил: Skif585 (08 Ноя 2007 23:05:35) #
Еще раз спасибо за сигнал, это явно не NMT-450, переношу обсуждение данного вопроса в раздел радиосигналы - 86,45 МГц PSK-2 на опознание, присоединяйтесь!!!
P.S. заливать 38.7мб не надо, во первых большой объем, во вторых не понятная шумела. Если будет что-то вроде 86,45 МГц, тогда кидайте.
mandgusta
с окт 2007
uae
Дата: 08 Ноя 2007 23:09:07 #
Сигнал принимал на частоте 462,000 МГц. У нас было на то время четыре канала:
Один сужебный (маркерный) - работал постоянно не выключаясь и три информацыинные.
Разнос между каналами составлял 125 кГц. Из информационых каналов в постоянной работе находился только один, смена информационных каналов осуществлялась после передачи разговора. Больше ни каких особенностей не отмечалось (трафик слабенький был - 1-2 разговора в сутки).
Аналоговой записи (ВАВ-ки) не сохранилось. Могу дать бинарный поток.
Дата: 08 Ноя 2007 23:13:10 #
Большой вариант это тоже что и http://www.radioscanner.ru/uploader/2007/86.45mhz_fm_25_07_20.zip просто в копилке обрезанный 10сек сигнал. Выложу если получится декодировать обрезок.
Skif585
Offline5.9
Дата: 08 Ноя 2007 23:39:54 · Поправил: Skif585 (08 Ноя 2007 23:41:39) #
mandgusta
бинарный поток Это просто здорово, теперь подтянутся мастера ковыряния крипто.
обсуждение данного вопроса в разделе радиосигналы - 86,45 МГц PSK-2 на опознание, присоединяйтесь!!!
mandgusta
с окт 2007
uae
Дата: 08 Ноя 2007 23:41:33 #
Дата: 08 Ноя 2007 23:43:03 #
mandgusta
Ну так вы очевидно принимали MPT-1327, а не NMT, отсюда и удивленный вопрос Skif585...
Skif585
Offline5.9
Дата: 08 Ноя 2007 23:46:17 #
mandgusta
переходите в раздел радиосигналы - 86,45 МГц PSK-2 на опознание, присоединяйтесь!!! Мы нарушаем правило форума - отошли от темы Программное обеспечение:|
mandgusta
с окт 2007
uae
Дата: 08 Ноя 2007 23:56:53 #
Я уже там...
Skif585
Offline5.9
Дата: 14 Ноя 2007 23:58:50 #
win
По Вашему вопросу есть это:
RecSoundPlayer - Программа предназначена для обработки и расшифровки аудиофайлов, записаных в форматах mp3, wav, wav с компандированием по "А закону", и т.д., в том числе:
• Демодулировать и декодировать имеющиеся в аудиозаписи сигнализации следующих средств радиосвязи:
1. сотовой связи стандарта NMT;
2. радиоудлинителей телефонного номера SENAO 868, SENAO-256, HARVEST;
3. системы транкинговой связи SmarTrunc-2;
4. системы радиотелефонной связи Алтай.
5. декодировать сообщения пейджинговой связи стандартов POCSAG и FLEX с автоматической перекодировкой в русский текст.
• Для расшифровки аудиофайлов телефонных разговоров имеются декодеры:
1. АОН
2. DTMF
3. Pulse
4. Декодер факсовых сообщений (реализован не во всех версиях)
На сколько я понял создатели хотят 25$
Вот ссылка http://recsound.org/rsplayer.html + смотрите Форум —› Программное обеспечение —› Декодер Senao
На мой взгляд, дешево и сердито.
Время загрузки страницы (сек.): 0.221; miniBB ®
