На сайте: гостей - 75,
участников - 3 [ r75, RA6FOO, augrabies]
 Форум —› Главный раздел —› VBW - определение
Alan 48 Excel
Alinco DR-135CBA New
MegaJet MJ-3031M Turbo
President Harry III ASC
Yosan Stealth 5
G305e
с июл 2007
Оттуда
Дата: 10 Дек 2007 17:43:24 #
чет не нашел в поиске. Кто бы дал определение что такое видео полоса пропускания.
Спасибо!
БЕГЕМОТ
Offline7.8
с авг 2004
из ниоткуда в никуда
Дата: 10 Дек 2007 19:10:27 #
G305e
Это должно помочь http://ece-classweb.ucsd.edu:16080/winter07/ece157a/labs/lab1.pdf
1 Spectrum Analyzers
As discussed in the Prelab reading, a spectrum analyzer measures the total power (dBm) in a
frequency band specified by the resolution bandwidth (RBW) of the spectrum analyzer (SA).
1Power referenced to 1 mW. 0 dBm = 1 mW, -30 dBm = 1 W.
Setting the RBW for the Advantest R3261A is under the COUPLE menu on the front panel.
Also under this menu is video bandwidth VBW which controls the bandwidth of the display. Most
modern spectrum analyzers have replaced the video bandwidth function with signal processing
(averaging and/or filtering), but it term is still used. We will always let the SA determine the
VBW based on the RBW.
The range of frequencies (x-axis) to be analyzed is set using either START and STOP or
CENTER FREQ and FREQ SPAN both on the front panel. The minimum time to sweep the
range of frequencies is determined by the frequency span and the resolution bandwidth. For this
class, we will set RBW and let the SA automatically change the sweep time.
The y-axis settings for the amplitude are controlled under the REF LEVEL menu on the front
panel. The reference level sets the “top” of the trace, while dB/DIV sets the scale per division in
dB. All SAs (hard and soft) share these common features.
по руссски не знаю где искать.
NDR
Offline4.7
с янв 2004
Дата: 10 Дек 2007 20:11:12 #
G305e
Сие есмь полоса пропускания последетекторного фильтра - и ничего более:) Этот фильтр - ФНЧ первого порядка. Служит для сглаживания отображаемого отклика на экране. Это нужно для удобства наблюдения исследуемого процесса. А его полоса - 1/Тс. Т.е. чем больше полоса видеофильтра, тем сильнее сигнал "телепается" на экране. Сужение полосы VBW эквивалентно усреднению сигнала по тем большему количеству реализаций, чем уже полоса пропускания.
Ну и нагородил я под конец рабочего дня:)
G305e
с июл 2007
Оттуда
Дата: 10 Дек 2007 20:14:08 #
NDR
во, спасибо, то что надо :)
