Дата: 02 Май 2012 21:29:27
sibirjac
Восточное побережье США
USS Dwight D. Eisenhower (CVN-69) (IKE) Carrier Strike Group
IW
Сейчас работает на 9.031.
Дата: 04 Май 2012 23:51:23
Радиосеть "Координации ПВО"
частота 9031 кГц, J3E/USB.
Позывные:
IW - КП ПВО
D -
A -
E - иностранец?
H -
K -
L -
O -
S -
23.30
IW - K side 210 escort track 3057
K - IW CAP side 210 on 270 base + 28 from K
00.00
W - IW my 2000z air set sitrep
line 1 - 2000
line 2 - white
line 3 - safe
line 4 - 1 no ready for ..
line 5 - 360
line 6 end 7 - nothing to report
line 8 - station active not set Miami Boston Orlando
line 9a - H
line 9b - E
line 9c - H
line 10 - nothing to report
line 11 - in accordance with airplane alert 30 helo 610
line 12 13 - nothing report
line 14 - Rock
Дата: 05 Май 2012 00:04:08
Радиосеть "Самолетов БПА США в Атлантике"
частота 8971 кГц, J3E/USB, ANDVT.
Позывные:
FIDDLE - TSCC NAS Jacksonville FL
Pelican 71N - P-3C VP-45 - position 2937n 07742w
Fighting Tiger 71Q - P-3C, VP-8
Tiger 71P - P-3C, VP-8
Дата: 06 Май 2012 19:01:56
Позывные:
IW - КП ПВО
IC - ЗКП ПВО
IB - Strike Group Commander
A -
D -
E - иностранец?
H -
K -
L -
O -
P -
S -
U - E-2C Hawkeye
T - E-2C Hawkeye
W - IW with 1300z sitrep
line 2 - white
line 3 - safe
line 4 - 1 no air defence system ...
line 5 - 360
line 6 7 8 - nothing report
line 9a - H
line 9b - A
line 9c - H
line 11 - ...
line 14 - Rock
- IW track 2311 c/s Pelican 71V
22.40
IW - T side 102 110 escort track 02155
22.55
A - IW New York - negative side Boston - side 407 411 Orlando - side 307 310
23.06
IW - T track 2034 splashed side 201
IW - U negative intercept track 2327 recommend D - bird
23.18
W - IW up-date sitrep
line 2 - red
line 3 - safe
line 4 - 1 ... time 1918
23.26
IW - U side 102 recept station Orlando
23.30
U - IW Roger understand side 207 310 102 407 411 station Orlando
23.36
IW - U new watch from SPY actual area 5 6 7 X-ray on all CAP 2400 feet ... area 8 X-ray close all exercise players
23.40
IW - U side 307 311 407 411 201 302 110 by my control
23.45
E - IW you are duty IC standby sitrep
E - IW my 1945 air set sitrep follows
line 2 - red
line 3 - safe
line 4 - 1 no ...
line 5 - 295 - 000
line 6 - 310
line 7 - 05 03 ... 302 ... at U-control
line 8 - side 200 204 ... set for E-control ... 302 ... 0503 ... side 402 for E-control
line 9a - H
line 9b - E
line 9c - H
line 10 - 603
line 11 - in accordance with air plane
line 14 - Rock ....
IW - E my unit is duty IC
W - IC I am duty IC
23.49
IC - H ... establish communication IB - Strike Group Commander on ST812A
00.27
IB - U track 2320 side 200 204 kill track 2320
00.35
IB - U side 200 escort track 2604
Дата: 07 Май 2012 00:52:24
00.37
Air High Command - Air Tactic Command with Target report position report
Air Tactic Command - Air High Command Roger
Air High Command - Air Tactic Command Target № 1 position north 2932 west 07932 =
Target № 2 position north 2941 west 07942 =
Target № 3 position north 3078 west 08098
Air Tactic Command - Air High Command Roger thank you out
00.42
W - IC kick AA406A - перешли на частоту 3152 кГц
частота 3152 кГц
01.20
IC - H intend to set Savannah with side 302 303 Orlando with side 214 407
01.30
W - IW
line 1 - 2129
line 2 - white
line 3 - safe
line 4 - no air ...
line 5 - 295 to 000
line 6 - 310
line 7 nothing report
line 8 side 302 303 set Savannah side 214 407 set Orlando
line 9a - H
line 9b - E
line 9c - H
line 10 - T
line 11 12 13 - nothing report
line 14 Rock ...
01.40
W - IW mini sitrep = Savannah side 102 407 at Strike state Tiger H-control = 200 204 on take .. Orlando = track 2037 from Rock 112 - 79 c/s Bolt 06
01.55
IW - H side 200 204 set Orlando
02.00
W - IW my 2200z air set sitrep
line 2 - white
line 3 - safe
line 4 - 1 ready for ...
line 5 - 295 to 000
line 6 - 310
line 8 side 102 407 heading set Savannah state Tiger H-control = 200 204 set Orlando state Tiger H-control
line 9a - H
line 9b - E
line 9c - H
line 10 11 12 13 - nothing report
line 14 Rock ... execute comms AA406B at time 2210
02.10 перешли на 9031 кГц
Проверка и установление связи
частота 9031 кГц
02.30
T - IC event 5 ...intention set CAP station Oakland with side 107 110 set CAP station Orlando with side 211 212 set CAP station Savannah with side 301 307 all for T-control
02.38
All station - IW 107 110 211 212 not air cotrol 301 307 S-control next event
S - IW ready to control event 5C1
IW - S Roger 301 307 on button 9
W - IW Finex Finex Finex event 06107
Все корабли подтвердили
IW - H side 200 204 102 407 D-control
02.50
A - IW you are duty IC aprox 20m
IW - A Roger
W - A I am Duty IC
Дата: 08 Май 2012 23:07:18
20.04
W - IW track 2065 197 - 18 from Rock c/s Pelican 71Y
W - IW with my 1600z air set sitrep
line 1 - 1604
line 2 - white
line 3 - safe
line 4 - 1 no {.. system the ...}
line 5 - 360
line 6, 7 - nothing report
line 8 - station active not set Oakland Portland New York
line 9a - H
line 9b - A
line 9c - H
line 10 - nothing report
line 11 - ... for air plan
line 12, 13 - nothing report
line 14 - Rock
21.00
W - IW my 1700z air set sitrep
line 2 to line 7 nothing change
line 8 - intention to set station Oakland side 102 104 O-control
line 9 to line 14 nothing change
23.11
IW - L Q is surface track 2030 and track 2110 end report event 08120
23.35
IC - A negative comms c/s D on Red Crown
IC - A request comms ST812A channel for IB ...
00.05
W - IC ...
line 8 .. active 4A1 all force A-control
line 9a - D
line 9b - A
line 9c - D
line 14 - Rock
IC - T Roger out // E-2C Hawkeye//
IC - T no comms side 103
IC - L Proud Warrior 437 3+54 by my control //вертолет SH-60B, HSL-42//
00.48
W - IC track 2677 Rock 07.29 c/s Proud Warrior 433
IC - S thet is negative c/s Proud Warrior 461
00.01
IC - L Proud Warrior 437 off deck ... 2+00
Дата: 10 Май 2012 00:43:00
00.05
W - IW track 2601 and track 2161 bearing 256 - 74 from Denver check mend line 7, 16, 17 c/s Raven flight
00.38
K - IW confirm ready control side 200
IW - K from IZ side 200 is no event ..
00.40
IW - D Proud Warrior 462 D-control 3+15
00.46
IW - K track 2611 CAP position 2 on Denver 311-77
Дата: 10 Май 2012 22:09:45
22.05
W - IW with my 1800z air set sitrep
line 1 - 1805
line 2 to line 9c - no change
line 10 - 603
line 11 - alert 30 Helo 616
line 12 - 13 - nothing report
line 14 - Rock
22.14
IW - T airborne .. 1+30 on station
22.48
IW - T be advise warning area AA BB CC now Hot angel 15
![](http://www.radioscanner.ru/uploader/2012/ganex.jpg) Увеличить
22.25
K - IW possible Tiger 71B on station 1330 local
22.28
W - IW track 7024 bearing 152.19 c/s Tiger 71B
23.35
K, S - IW request call H on AA406A for comms check
23.49
IW - U airborne proceeding station
00.05
line 1 - 2002
line 2 - white
line 3 - safe
line 4 - 1 no ID system the ...
line 5 - 360
line 8 - system active not set Oakland Portland New York
line 9a - H
line 9b - A
line 9c - H
line 10 - 602
line 11 - alert 30 helo 616
line 14 - Rock ...
execute ADEX for event 10121 A H K and S ... exercise guard comms check report next ...
00.19
IW - O track 0500 c/s LW 23
00.33
IW - H standby 5 m exercise guard comms check c/s S
S - IW c/s H request guard comms check
IW - S int line
S - IW line ED655 //предположительно 156.8 мГц - Channel 16//
00.40
S - IW track 2102 c/s Pelican 71A
00.43
s - IW track 0500 c/s LW 23
01.10
K - IW side 304 - Boston side 107 112 - Orlando
01.15
H K A S U - IW event 10121 event is launch
01.28
IW - S Proud Warrior 434 on deck ... seat down
01.31
W - IW side 107 112 H-control side 304 - H-control
01.36
H - IW set 107 112 - Orlando
IW - H Roger out
01.45
IW - H track 3010 escort side 107 112 track 7004 side 304
01.50
W - IW mini sitrep
= track 3010 strength 1 escort side 112
= track 7006 strength 2 escorting side 107 304
= track 2502 standby warning 30 nm from K
02.15
IW - K bird away track 7013
IW - K splahed track 7013
02.19
H - IW CAP Orlando side 107 304
02.29
H - IW what state all side
IW - H side 112 107 304 state Tiger
02.30
A - IW you are duty IC standby sitrep
IW - A standby
A - IW my 2230 air set sitrep
line 2 - white
line 3 - safe
line 4 - ...
line 5 - 270 ... 010 axis 310
line 7 - suspect track 2636 strength 2 escorting by side 107 304 track 3010 escorting by 112 state Tiger
line 8 - nothing report
line 9a - H
line 9b - A
line 9c - H
line 10 - 602 c/s U
line 14 - Rock ...
IW - A Roger out
W - A I am duty IC
03.00
IC - T airborne on station |
Дата: 10 Май 2012 23:30:38
Позывные:
Cardfile 713 - P-3C, VP-5 - off station 2225z
Pelican 71A - P-3C VP-45
Aircraft 927 -
Tiger 71B - P-3C VP-8
Tiger 71C - P-3C VP-8
Pelican 71D - P-3C VP-45 - 01.43 мск - off deck
IX - КП ПЛО (Undersea Warfare Commander)
02.00
FIDDLE - Pelican 71D on station 2150z
Pelican 71D - IX read you loud and clear
IX - Pelican 71D read you same
Дата: 11 Май 2012 21:43:23
21.35
A - IW side 110 111 no VID track 2235 returning H-control
K - IW track 2235 from Denver 237.86
22.03
W - IW my 1800 air set sitrep
line 1 - 1803
line 2 - white
line 3 - safe
line 4 - 1 ...
line 5 - 360
line 6 - nothing report
line 7 - track 2244 lost bearing 250.51 from Denver
line 8 - recommended side 110 111 H-control side 200 305 302 T-control
line 9a - H
line 9b - A
line 9c - H
line 10 - 600
line 14 - Denver
22.40
T - IW Roger side 202 212 ETA S-control set state Tiger
22.57
IW - T by my control side 301 112 106 ...
Дата: 13 Май 2012 08:20:40
06.45
D - IW my 0245z air set sitrep
line 2 - white
line 3 - safe
line4 - 1 no air ... system the ...
line 5 - 360
line 9a - H
line 9b - A
line 9c - H
line 14 Rock = intention air building maintain Recognized Air Picture =
D - IW you are duty IC
IW - D Roger I am duty IC = принял обязанности ЗКП ПВО =
IC - H Roger out
07.45
E - IC you are duty IC
IC - E Roger
W - IC standby for shift of IC to c/s E by 0345z sitrep follows
line 2 - white
line 3 - safe
line 4 - 1 simulated ...
line 5 - 360
line 8 - side 106 set between Oakland and Boston under S-control
line 9a - D
line 9b - A
line 9c - D
line 14 - Rock = intention air building maintain RAP
W - E I am duty IC = принял обязанности ЗКП ПВО =
08.02
W - IC my sitrep 0402z as follows
line 2 - white
line 3 - safe
line 4 - 1 simulated no weapons ??? = не разобрал =
line 5 - 360
line 6, 7 - non
line 8 - 106 under S-control CAP station Boston
line 9a - H
line 9b - E
line 9c - H
line 14 - Rock
intention for IC air to building maintain Recognized Air Picture I report all contact with in battle area been escort and any contact with in CCOI =
http://www.radioscanner.ru/uploader/2012/ice_sitrep.mp3
08.40
IC - L track 1274 strength 1 positive line 3 line 14 15 16 21 track 1274 from Rock 091.62 tracking SE
L - IC track 1274 classification as c/s Proud Warrior 437
17.00
W - IW my 1300z air set sitrep up-date
line 11 - alert 60 set side 112 311 614 = alert 30 set side 210 617 |
Дата: 14 Май 2012 17:49:34
16.50
IW - K side 304 406 Strike control
17.00
IW - K int. Red Crown
K - IW negative comms side 304 406
19.00
IW - H track 0562 my Pony c/s Venom 511 //HSL-48, SH-60B//
19.50
IW - H side 307 406 state Tiger
20.00
W - IW ...
line 11 alert 7 side 107 310 alert 15 side 103
21.00
line 1 -1659z
line 2 - white
line 3 - safe
line 4 - 1 ...
line 5 - 360
line 7 - track 2120 aqua ... escorting side 406 H-control state Tiger
line 8 - side 307 set Tampa H-control state Tiger side 406 escorting track 2120 H-control state Tiger
line 9a - H
line 9b - A
line 9c - H
line 10 - T
line 14 - Denver ...
21.22
W - IW mini strep ....
line 8 event 1d1 side 402 404 H-control ...
21.25
line 2 - Red
line 3 - tight
line 4 - 1 no{ ID system them auto}
remain exercise event {TPY} ...
Дата: 14 Май 2012 20:07:44
Позывные:
Pelican 71K - P-3C VP-45 - off station time 1600 RTB
Дата: 14 Май 2012 20:16:03 · Поправил: Mamadu (14 Май 2012 21:15:44)
sibirjac
??? = не разобрал = - слышу как doctrine Nardo.
with in CCOI - а здесь как СIAA (Collections of Information Antipiracy Act??).
Дата: 15 Май 2012 17:12:04
MAMADU
Спасибо, надо ещё слушать, если будут хорошие записи выложу для разбора.
17.00
W - IW up-date line 11
Alert 7 set side 303 406
Alert 15 set side 210
Alert 30 set side 100
Alert 60 set side 602 611
19.00
W - IW
line 2 - Red
line 3 - tight
line 4 - 1 ...
line 5 - 360
line 9a - H
line 9b - A
line 9c - H
line 10 - side 602 standby launch
line 11 - Alert 7 side 303 406
Alert 15 side 210
Alert 30 side 100
Alert 60 side 611
line 12 13
line 14 Denver ..
Дата: 15 Май 2012 19:23:18
USS Dwight D. Eisenhower (CVN-69) - c/s K
19.06
IW - K correction side 611 airborne shortly = Alert 60 set side 616
K - IW confirm 611 launch first side 602
19.18
IW - T airborne on station 3+00 Hour say warning state status
T - IW warning Red weapons tight ... c/s Bolt 06 from Denver 235.117
19.45
A - IW track 2715 from Denver 235.57 c/c Tiger 71Q = track 2717 c/s Tiger 71P
20.09
W - IW kick AA406A authentication time 1608 JF
Перешли на 3152 кГц, а там все "очень плохо со слышимостью" ...
Дата: 16 Май 2012 05:14:02
частота 3152 кГц, J3E/USB.
05.06
IW - U currently side 304 305 on tanker side 107 111 ...
06.00
W - IW my 0200z sitrep
line 2 - white
line 3 - safe
line 4 - 1 no air set system in ADO (Air Defense Operations)
line 5 - 360
line 9a - H
line 9b - A
line 9c - H in the going to {AD}
line 9d - ... ??? c/s SW unit {said} is E
line 10 - side 600 c/s U
line 11 - nothing report
line 12 - ... ??? acknowledge off station ...
line 13 - nothing report
line 14 - Dеnver
http://www.radioscanner.ru/uploader/2012/3152_0600_sitrep.mp3
12.00
W - IW my 0800z sitrep
line 2 - white
line 3 - safe
line 5 - 360
line 6 7 - nothing report
line 8 - Oakland Mobile {Hamersley} Homestead station set not active
line 9a - H
line 9b - A
line 9c - H
line 10 11 - nothing report
line 12 - nord south point {скэмбин тоун} in them
line 14 - Rock ...
17.45
IW - H Canvas 616 kick K-control
21.35
D - IW side 200 402 set Oakland D-control
D - IW side 111 112 set Mobile maintenance control
22.20
IW - A Sugar A - 4 Sugar J - 59 Sugar S - ...
22.30
IW - Trident ...
Trident - IW c/s D positive comms side 200 402 111 112 on button 2
22.42
W - IW request Sugar report
- A Sugar J base + 53
- D Sugar J base + 51
- L Sugar J base + 26
- K Sugar J 51
SUGAR - Surface to air missile (SAM) state report. |
Дата: 17 Май 2012 19:38:27
В период с 24 апреля по 17 мая отработка задач COMPTUEX - Composite Unit Training Exercise
Dwight D. Eisenhower (IKE) Carrier Strike Group:
USS Hue City (CG 66) -
USS Oscar Austin (DDG 79) -
USS Winston S. Churchill (DDG 81) -
USS Jason Dunham (DDG 109) -
SPS Blas de Lezo (F103) (Spanish Navy) -
USS Laboon (DDG 58)
USS Klakring (FFG 42)
USS Carr (FFG 52)
USS Fort McHenry (LSD 43)
BNS Independencia (F 44) (Brazilian Navy)
Позывные кораблей:
A -
D -
E - SPS Blas de Lezo (F103)
G -
H - USS Hue City (CG 66) ?
J -
K - USS Dwight D. Eisenhower (CVN-69)
L -
O -
P -
S -
Y - ?
Carrier Air Wing 7 = AG:
VFA-143 Pukin Dogs F/A-18E Super Hornet - side 1xx = 100 102 103 104 106 107 110 111 112 - c/s Dog /Taproom
VFA-103 Jolly Rogers F/A-18F Super Hornet - side 2xx = 200 201 202 204 207 210 211 212 214 - c/s Victory
VFA-83 Rampagers F/A-18C Hornet side - 3xx = 300 301 302 303 304 305 307 310 311 - c/s Ram
VFA-131 Wildcats F/A-18C Hornet - side 4xx = 400 402 404 405 406 407 411 - c/s Wildcat / Cat
VAQ-140 Patriots EA-6B Prowler - side 5xx = 500
VAW-121 Bluetails E-2C Hawkeye - side 60x = 600 602 603 - c/s Bluetail
HS-5 Nghtdippers SH-60F Seahawk - side 61x = 610 611 614 616 617 - c/s Canvas
VRC-40 Rawhides C-2A Greyhound - side 51 - c/s Rawhide
Вертолеты:
Proud Warrior 462 - на c/s D ?
Proud Warrior 434 - на c/s S ?
Proud Warrior 437 - на c/s L ?
Proud Warrior 433 -
Proud Warrior 461 -
Venom 511 - на c/s H
CAP stations:
Miami
Boston
Orlando
New York
Savannah
Oakland
Portland
Tampa
Mobile
Homestead
Bullseyes:
Rock
Denver
Дата: 23 Июн 2012 09:25:33
20 июня USS Dwight D. Eisenhower (CVN-69) и корабли убыли для развертывания в районы 5 и 6 флота.
Дата: 23 Июн 2012 09:51:17
Срок БД в передовых районах планируется около 9 месяцев!
Дата: 23 Авг 2012 22:52:05
Граждане, гляньте 8971. Частота активна. У меня кроме АНДВТ ничего не слышно.
Дата: 25 Авг 2012 08:59:41 · Поправил: drhell_78 (25 Авг 2012 09:09:58)
Дата: 25 Авг 2012 09:08:40 · Поправил: Mamadu (25 Авг 2012 16:39:57)
Ок, спасибо. Позывной слышу как Wafer. На второй записи ещё и ако [Funky], а на 8-й секунде вроде как и кто-то ручку ТАИшника крутил :-).
Дата: 26 Авг 2012 08:16:49
19 августа в районе Африканского рога закончило воевать транспортное средство USS Taylor (FFG 50). Сейчас возвращается домой с расчётным временем прибытия в город-герой Мэйпорт середина сентября.
Дата: 26 Авг 2012 11:42:04
А что народ думает по увеличению группировки кораблей сша в Средиземном море? Не считая Маунт Уитни в Средиземке на этой неделе находились:
эсминцы: DDG 58, DDG 67, DDG 79, DDG 98, DDG 109;
лодки: SSN 778, возможно SSGN 728;
десантник LSD 43.
Вчера через Суэц с 5 ОФ зашли SSN 769 и DDG 95
Не многовато ли их? |
Дата: 26 Авг 2012 11:51:48
MAMADU
не очень то вы уважительно о их фрегатах отзываетесь. Кстати что-то они в этот раз долго. Они должны были быть дома к началу сентября.
Дата: 26 Авг 2012 11:54:53
burlac
Не многовато ли их?
Так вроде б как и давно ясно, что как РККА и РККФ разрушили, то и шариться где хочешь, как хочешь и для чего хочешь стало нормой жизни. Грустно всё это. Но с московских высот то это не увидать, видны лишь бесконечные слайды, совешания, оптимизации всякого высвобождаемого и распродаваемого по 20 килотонн бакинских рублей за сотку земель военного ведомства. Оно ж интереснее, чем чего там строить развивать, обучать и воспитывать, да и рукам приятнее :-).
Дата: 26 Авг 2012 11:57:08
burlac
Да нет, тут речь не в уважении. Всё, что движется во всех 3-х сферах просто называю, как транспортное средство, а так-то назначение ясно.
Дата: 26 Авг 2012 12:13:39
MAMADU
Да грустно. А по Ирану есть какие-либо предположения?
Дата: 26 Авг 2012 12:16:01
Туда вроде как Стенниц раньше времени перегоняют.
