На сайте: гостей - 61,
участников - 2 [ tuner, pigkiller]
 Форум —› Программное обеспечение —› Прошивка Yaesu VX-3R (TX 120-220 & 300-576)
Цена Yaesu VX-3R в нашем магазине средств связи - руб.
digit99
Дата: 16 Янв 2008 21:21:38 · Поправил: digit99 (16 Янв 2008 21:53:37) #
THIS MOD COME FORM VARIOUS SOURCE ON THE NET.
THIS MOD CAN CHANGE THE "COUNTRY MODE" OF YOUR RIG BUT KEEP IN MIND THAT REGULATORY OF STATES ARE PRESERVED, SO YOUR RIG WILL ACT DIFFERENT FROM WHAT YOU EXPECT. ALSO REMEMBER THAT THE KEYBOARD LABELS CAN NOT REFLECT ACTUAL FUNCTIONS.
1. Set mode 19-CWID to AH028M
-power on, then press and hold SET to go to SET function
-turn the dial to 19-CWID
-press SET and turn to ON
-press V/M to text enter screen
-dial one character by one, press V/M for next character, to set it
to AH028M, press 2 more V/M to leave text enter screen
-press SET to go back to SET function
2. Power off
3. Press and hold both MODE key and TXPO key, then power on
4. You will not see voltage screen this time. Instead there are
operation modes for your choice (B1, C1, F1, ***, HAM, H1, A1, etc.):
!!Remember to record what mode you're initially in!!
- Turn the dial and press MODE (for changing 2nd digit) to select a
mode, then press F/W to set.
Your rig is now operates on a new mode!
*If you choose *** and press F/W, you will have an even wider TX
range, but Radio disabled. Others not tried yet, and I guess different version has different modes/ranges/settings
*If you want to restore your mode, follow all steps above and set it back to your recorded mode in step 4.
When you set *** mode you wheel have tx from 120-220 & 300-576Mhz but you must remove jumper from board,you can find it on second side behinde batery,behinde black sticker.
tx from 140-174 & 420-470 remove jumper!!!!and do master reset! Reset is:
Microprocessor Reset on Page 128 of the Manual kills all memories and settings Microprocessor Reset on Page 128 of the Manual kills all memories and settings
Power Off Power Off
Hold [MODE] + [V/M] and Power On Hold [MODE] + [V / M] and Power On
Press [F/W] Press [B / W] GOD LOCK
Crunch
Offline2.7
Дата: 17 Янв 2008 22:39:28 #
Интересно, но сколько у неё милливатт останется на краях диапазонов?...
digit99
Дата: 17 Янв 2008 23:40:50 #
120mhz-65mw 576mhz-38mw
Дата: 17 Янв 2008 23:54:54 #
digit99
А на 300..330 МГц?
digit99
Дата: 18 Янв 2008 00:35:35 #
72-110mW
Дата: 18 Янв 2008 01:10:24 #
digit99
Сами измеряете?
digit99
Дата: 18 Янв 2008 10:26:42 #
Da.
With dummy load 10w 50ohm and W&SWR meter.
digit99
Дата: 18 Янв 2008 10:34:27 #
Tested with Full batery charged.with no external power.I forgot to test with ex.power
candid
Дата: 21 Фев 2008 14:25:19 · Поправил: candid (21 Фев 2008 14:35:35) #
but Radio disabled всмысле нельзя будет одной кнопкой включать и слушать диапазон 88-108 ?
candid
Дата: 29 Фев 2008 02:56:58 #
Когда попали в режим переключения
нажатие MODE переключает B1 - B3 - B1 - B3 - B1.
Валкодер гоняет по кругу B1, C1, F1, ***, HAM, H1, A1,
Чтобы вернуться обратно на B3, сначала встаем на B1 и кнопкой MODE переключаемся на B3
ПРИ ПЕРЕКЛЮЧЕНИИ НА ДРУГОЙ ТИП
ВСЕ РАНЕЕ ЗАНЕСЕННЫЕ В ПАМЯТЬ БАНКИ, КАНАЛЫ И ПРОЧЕЕ --- СТИРАЮТСЯ!!!!
oxylive
с мар 2009
Беларусь
Дата: 15 Апр 2009 21:56:10 #
как-то страшновато, кто-нить делал такое???? и обратно вернуть чсё можно?
Sashman
р'Льех
Дата: 16 Апр 2009 01:24:39 #
Почему в подавляющем большинстве р/л изделий даже при полном их раскрытии тщательно вырезан диапазон по крайней мере 220-300? Это требования правительств, или диапазон просто "ни рыба, ни мясо" и не перекрывается ни VFO-144, ни VFO-430?
RX9AT
Дата: 16 Апр 2009 05:43:27 · Поправил: БЕГЕМОТ (29 Май 2009 21:29:13) #
//флуд//
kovcheg
с сен 2004
Москва. ЗАО
Дата: 16 Апр 2009 06:52:08 #
Жаль только софта "леченного" пока нет.
Если есть у кого поделитесь.
medvedko
с апр 2009
г.Герой-Ленинград
Дата: 21 Апр 2009 15:52:49 · Поправил: Вебмастер (25 Апр 2009 00:17:34) #
[ реклама. предупреждение ]
oxylive
с мар 2009
Беларусь
Дата: 22 Апр 2009 16:39:35 #
Кто-нибудь так делал?
Дата: 22 Апр 2009 18:19:09 · Поправил: БЕГЕМОТ (29 Май 2009 21:29:29) #
RX9AT
//флуд//
arkadiy73
с янв 2009
Королев, Моск. обл.
Дата: 07 Янв 2011 07:47:49 #
digit99
А на 300..330 МГц?
72-110mW
О, толково. Я так понимаю что на передачу это даже лучше чем у ближайших конкурентов VX-2R, VX-6R, VX-7R, и даже FT-60 ? Поделитесь, кто знает точно.
