Дата: 20 Июл 2010 14:26:55 · Поправил: Mesh (20 Июл 2010 14:27:53)
Elabuga НА вражеском сайте указано, что русские подводные лодки используют не только СДВ скажите пожалуйста какое откровение, со стороны варжеский сайтов, прям глаза раскрыли. "Aкула" ВМФ РФ и СНГ гугль и не скрывает, для чего система, причём ссылки на русском языке. :-) Очень интересно где там позывные? Хотя если считать 130-й передаёт 41-му то наверно это позывные, и естественно подводных лодок, а как иначе? |
Дата: 20 Июл 2010 17:03:49 · Поправил: Elabuga (20 Июл 2010 17:15:30)
Mesh
Не сердитесь, пожалуйста. Что мне сделать чтобы вы так не расстраивались? Ссылку найдем)))
http://www.astrosol.ch/networksofthecisforces/vlfmorsedigmodenetwork/index.html
On VLF (Very Large Frequencies) broadcasts in FSK Morse Code and T-600 mode may be received 7 days a week and 24 h a day. Following a complex sked all or parts of the messages are transmitted in parallel on a variety of frequencies between 3 and 23 MHz.
Command of this network is VGK, the General Staff in Moscow, which apparently make use of VLF Time Signal transmitters in Russia and some other CIS members for Command and Control of the SNF (Strategic Nuclear Forces). As the Navy is an important part of SNF, we are looking for interactions between the VGK transmissions and Navy units. All T-600 messages are encrypted and we can't monitor all relevant Navy frequencies for transmission acknowledgements, thus the following pages only can describe some keyhole views, as well as many speculations !, of a very interesting part of CIS Navy communications.
The most important callsign used by VGK is RDL, which means "to all units concerned". Since many years the callsign RGT77 can be heard on HF and in Morse Code only with broadcasts and xxx messages. Only callsign RGT77 appears, which imply this is, like RDL, the addressee not the sender. Several sources suggest this is the counterpart of RDL, operated by the General Staff of another branch with its office in Moscow. Operation times are very sporadic, frequencies constantly change, try these: 3161, 6438, 14092, 7050, 11408.5 and - unfortunately - many others.
A multitude of HF channels parallel to 18,1 kHz allow monitoring the network on higher frequencies too. At least some of the HF transmitters probably are co-located at the 6 VLF transmitters. HF channels constantly change, I haven't found a sked so far. These frequencies may be worth to listen to: 14411, 14664, 10535, 7657, 6342, 5438 kHz.
Дата: 20 Июл 2010 17:13:13
Elabuga Прикольно. Странные люди, одни знает чем я занят, другой в курсе моего эмоцанальлного состояния, форум каких-то экстрасенсов.
Дата: 20 Июл 2010 17:19:25
Mesh
Не берите в голову. Главное, чтобы вам было комфортно.
Дата: 20 Июл 2010 22:28:49
У меня из дома вид на подводные лодки
"Северсталь" и "Дмитрий Донской"?
Жаль, что "Северсталь" на иголки распилят. Так жалобно она гудела, когда "Дмитрий Донской" выходил из бухточки на пуск "булавы". Вблизи это просто монстры какие-то...
Дата: 20 Июл 2010 23:30:54
Даю ссылку на статью о Музее Службы связи ВМФ, который расположился на базе в/ч №56135, что в селе Ям под Москвой, а точнее недалеко от известной усадьбы Горки. Эта в/ч обеспечивала связь ГШ ВМФ в том числе и с подводными лодками в ДВ-диапазоне. Почитайте, там в том числе даны обзоры и по приемникам и передатчикам, которые использовались на подводных кораблях:
МУЗЕЙ СЛУЖБЫ СВЯЗИ ВМФ РОССИИ.
Есть там и схема организации связи ВМФ, которая с небольшими изменениями актуальна и сейчас, на ней кстати, указаны населенные пункты, где находятся ПРЦ ДВ и СДВ:
и еще, хочу сказать, что вся информация на подводные лодки из штабов и обратно идет в засекреченном виде, для этого используется аппаратура засекречивания телефонных и телеграфных сообщений, о ней в статье тоже есть инфа. |
Дата: 20 Июл 2010 23:41:32
Могу рекомендовать для приема СДВ, приемник Р-683 "Кашалот", диапазон от 3 до 100 кГц.
вроде как достать их еще можно. |
Дата: 22 Июл 2010 03:22:41
схема организации связи ВМФ … на ней кстати, указаны населенные пункты…
Интересная схема.
Заметил, что QTH «Бронзового» указан верно - Алабушево. А с «Параваном» наверное не захотели раскрывать своё местонахождение.
Дата: 22 Июл 2010 14:54:50
Село Ям, недалеко от Горок Ленинских, в/ч №56135
Дата: 23 Июл 2010 04:52:23
RK3DIA
Село Ям, недалеко от Горок Ленинских …
Совершенно верно. Там, правда, не только в/ч 56135. Но на схеме Параван «прописан» не в Яме, а в Москве.
А Москва - это скорее «Компас», «Юность» и пр. (- но они не РЦ). Интересно: «Юность» - там же, где и управление известного 224-го лётного отряда. (Кстати, и там же - одно сооружение из обсуждаемых в теме «Что за девайсы на крыше дома» - как всё связано…) Есть ещё «Ювелир» - КВ-связь авиации ВМФ. А самое интересное, система радиосвязи ВМФ имеет «выходы» на систему радиосвязи ВВС и активно участвует в р/обмене «не морских» самолётов.
Дата: 23 Июл 2010 08:54:25 · Поправил: Akonit (23 Июл 2010 08:55:15)
каким образом? подручными средствами возможно зафиксировать?
Дата: 23 Июл 2010 22:35:40
Совершенно верно, там еще Научно-испытательный полигон и Учебно-боевой центр.
Дата: 24 Июл 2010 05:16:53
Akonit
Как всегда - КВ-приёмником :) Если р/о открытый, то там обычные доклады - что прошёл, куда идёт, остаток топлива и т.д.
Тут интереснее другое, ближе к теме:
Иногда, не часто, после установления р/связи вызывают «своего абонента». Если знать кто есть кто, можно предполагать принадлежность борта и сопоставить её с позывным. Напр., авиацию ВМФ «выдают»: Ювелир/Жетон - ЦУС (Подмосковье), Люстра (Владивосток), Дворец (Североморск) и т.д. У каждого ведомства свои абоненты. После набора р/линии переходят на другой канал или тут же обмениваются в коде. Часто бывают т.н. формализованные сообщения - группы (по три цифры), за каждой - доклад об определённом событии или команда. Все эти Люстры, Алмазы и Кузницы позывными не являются, хотя в эфире могут звучать. Это адреса - названия узлов связи. Часто при мониторинге бывает путаница: напр., «Оратор» как позывной - управление в р-не одного полигона + есть «Оратор» - Остафьевский узел связи, по земле соединённый с «Саксофоном», с Ямом, с Монино и мн. другими.
Дата: 24 Июл 2010 20:55:47
Дата: 26 Июл 2010 23:14:57
Дата: 02 Авг 2014 02:51:39 · Поправил: NBFM (02 Авг 2014 03:02:24)
Дата: 02 Авг 2014 14:28:56
Прочитал, всё в кучу сложено, но вроде всё по делу, бывает и хуже... Не заметил сильных неточностей. Конечно я не спец в этой области, поэтому явные ляпы может и пропускаю.
К слову сейчас ежедневно просматриваю частоту Зевса, но как назло. когда у меня есть возможность помониторить, передач нет. Уже несколько дней подряд. (сверяю с Итальянским граббером)
Шумановские резонансы уже удалось увидеть на спектрограмме. Осталось дело за малым. чтобы совпали моё свободное время и выход на связь "Зевса"
По результатам обязательно отпишусь в тематической ветке форума.
Дата: 02 Авг 2014 20:46:42
morze
Володь, там надо как на дв- поставил комп и смотри картинки за сутки из архива. иначе-никак.
насчёт же ляпов в статье - не резануло глаз?
>> И все же, исследования в данной области проводились еще в первой половине XX века - их результатом стал невероятный Der Goliath («Голиаф»). Очередной представитель немецкого «вундерваффе» - первая в мире сверхдлинноволновая радиостанция, созданная в интересах Кригсмарине.
особенно в свете достаточно известного факта.
человек, который писал статью, безусловно почитал и наш форум, это видно, но в истории радиотехники, он мягко скажем- плавает.
изначально, все радиостанции были сверхдлинноволновые. и никак иначе.
даже изобретение радиоламп и то не сразу изменило картину.
и до некоторых пор, считалось, что на самые большие расстояния лучше всего распространяются именно самые длинные волны. в целом, это так и есть, но с оговорками.
Шумана на природе смотрел или удалось в городе увидеть? |
Дата: 03 Авг 2014 15:53:05
Буду в городе смотреть примерно через пару недель. А пока я на дачном участке. О результатах пишу Здесь и далее по теме... |
Дата: 09 Сен 2014 18:37:17
Есть информация, что завтра из Баренцева моря будут пускать Булаву
Уже 10 сентября возможен пуск Булавы http://itar-tass.com/politika/1428642 из акватории Белого моря. Зоны, опасные для судоходства и полетов (падение отработанных ступеней) закрыты с 10 по 14 сентября. Жители побережья, и шире могут что-нибудь заметить, особенно если пуск будет ночью и небо не в облаках. По NOTAM закрытые периоды с 5 утра до 21 вечера по московскому времени.
на итальянском граббере можно сопоставить возможное включение зевса с этим событием |
Дата: 12 Сен 2014 19:17:33
Одиночный пуск баллистической ракеты "Булава" из акватории Белого моря по полигону Кура на Камчатке прошел успешно. Об этом сообщило агентство ИТАР-ТАСС.
Запуск был произведен стратегической атомной подводной лодкой проекта 955 «Владимир Мономах». Представитель российского Минобороны генерал-майор Игорь Конашенков рассказал, что пуск происходил из подводного положения в рамках программы испытаний систем вооружения и жизнеобеспечения атомного подводного ракетоносца. Все параметры траектории полета ракеты были заранее отработаны в штатном режиме, боевые блоки успешно прибыли в полигон Кура на Камчатке.
Отметим, что на борту субмарины в ходе стрельбы находились члены комиссии по госиспытаниям подводной лодки, которые высоко оценили профессионализм и мастерство командования и экипажа.
На Итальянском граббере включения я 12:00 MSK не было, но не факт, просто было трудно его разглядеть, ОНЧ диапазон очень шумел от локальных итальянских помех... Нужно налаживать свою мониторинговую точку :(
Дата: 17 Апр 2015 17:48:04
