На сайте: гостей - 67,
участников - 4 [ muha131, Silent, Несущий свет, yfotik]
 Форум —› Прочее —› Суперемкие аккумуляторы формфактора AA - миф или реальность?
 Страница:  ««  1  2  3  ...  14  15  16  17  18  19  20  »»Поиск в теме
Serhiy1970
с июл 2006
Chernihiv, Ukraine
Дата: 21 Ноя 2011 07:25:01 #
PowerGenix:
PowerGenix has gotten many kudos as one of its kind - a 1.6v AA Nickel Zinc rechargeable with the juice to deliver performance for those who need it. From portable devices such has power tools to glue guns and even electric toothbrushes, the PowerGenix is all about doing it in the name of power. But we'll have to see about that.
The company is selling 1.6v AA Nickel Zinc rechargeables at a variety of outlets now, with the MRSP for a 4-pack sitting at $14.99; the special charger (needed for charging NiZn batteries) can be purchased along with four cells for $34.99 (again, that's MSRP).
Eneloops:
As for the Eneloops, they run at a lower voltage (1.2v) compared to the PowerGenix, but that also means more applications. For instance, there were a few items we tested the PowerGenix in that simply would not work due to its higher voltage. Electronics such as keyboards, mice, and remote controllers - this is where the Eneloops excel.
The Eneloop batteries retail for $14.99 as well per 4-pack and $21.99 for the charger included.
Battery Tests:
While we tested both batteries in a variety of gizmos, the one test we found to be most reliable was the flashlight since it sat pretty much right in the middle between hardcore power-suckers and passive, low-consuming electronics. However, after reviewing the photos, we found there was no discernable difference between the power emitting from our Maglite flashlights.
Testing the longetivity of the flashlights with each battery set, we found both lasted a good 3 hours each, but the PowerGenixran out of juice about an hour before the Eneloops did. We repeated the test with a few other flashlights and after a few head nods around the office, we agreed there was not enough of a difference to justify using up more battery juice. Hence, the Eneloops get the crown for the flashlight test.
We had two other tests planned for the rest of our comparison, but our set of PowerGenix recharger mysteriously decided to stop functioning half-way through our final tests using a combination of camera flashes and portable DVD player. We're sure this may have just been a bad batch, but since the batteries tended up get used up faster than the Eneloops, we had already gone through the entire set of 4 we received before completely finishing up the tests.
So, we had a difficult decision to make. Do we publish our small set of data or toss them away completely due to the small number of tests conducted? And so, we've decided to continue publishing since we believe a bad consumer experience is still just as important to note as a good one.
TDK
с ноя 2009
Ярославль
Дата: 21 Ноя 2011 14:25:56 #
Как лучше заряжать: разряжать полностью или просто ставить на дозарядку?
Аккумуляторы в приёмнике стоят последовательно и соответственно разряжаются не равномерно. Одни уже разряжены, а другие ещё только до половины. Перед зарядкой всех разряжать до одинакового уровня или не обязательно?
Дата: 21 Ноя 2011 15:14:01 #
Разряжать желательно всегда, когда время позволяет - "эффект памяти" никто не отменял, как-бы не врали об этом производители.
Serhiy1970
с июл 2006
Chernihiv, Ukraine
Дата: 23 Ноя 2011 00:35:23 #
Другой производитель NiZn аккумуляторов - http://www.pkcellshop.com
Дата: 23 Ноя 2011 09:32:10 · Поправил: Sergey4565 (23 Ноя 2011 09:32:54) #
Каким образом соотносятся мВтч и мАч?
rv4hv
с июн 2007
Togliatti
Дата: 23 Ноя 2011 10:32:03 #
2500мВтч/1,6В=1562мАч
Дата: 23 Ноя 2011 11:18:48 #
Значит маркетинг... Чтоб цифру меньше, чем у других, не писать :)
rv4hv
с июн 2007
Togliatti
Дата: 23 Ноя 2011 11:51:34 #
не без этого.....но я лично доволен ими на все 100.
месяц назад купил их и досих пор с заводской зарядкой пашут в цифрофотике и приёмнике SONY SW-100, вот думаю когдаж заразы "сядут" чтоб хоть раз зарядить)
Tolan
Подмосковье
Дата: 23 Ноя 2011 12:22:22 #
В фотике есть настройки питания - надо выбрать аккумуляторы или батарейки, влияет на уровень напр. для подачи сигнала о разрядке эл.питания. С такими акками, начальное 1,6в. надо выбирать батарейки в настройках? Какое у niZn мин.напр. при разряде?
TDK
с ноя 2009
Ярославль
Дата: 23 Ноя 2011 12:33:35 #
rv4hv
... я лично доволен ими на все 100 ... купил их и до сих пор ... пашут в цифрофотике ... вот думаю когда ж заразы "сядут"...
Аналогично. Тоже пашут очень долго. Сначала обрадовался, а вот теперь задумался. Обычно аккумуляторы выходят на максимум ёмкости после нескольких циклов "заряд-разряд", эти же, похоже, уже на максимуме...
Не начнут ли активно проседать, в то время как обычные ещё только раскачиваются?
rv4hv
с июн 2007
Togliatti
Дата: 23 Ноя 2011 12:41:54 #
при их "копеечной стоимости" даже не задумываюсь об этом.
Serhiy1970
с июл 2006
Chernihiv, Ukraine
Дата: 24 Ноя 2011 00:39:13 #
rv4hv
То есть надолго их хватить должно без проседаний ?
Дата: 24 Ноя 2011 19:50:53 #
Перепроверил (прошлый раз померил в режиме discharge) Ansmann 2850 - реально оказалось 2620 - 2650мАч. "Всасывают" они 2900 (КПД 91%), через месяц пришлось дозарядить 900мАч - саморазряд за месяц 34%.
Дата: 01 Дек 2011 18:16:19 · Поправил: Sergey4565 (02 Дек 2011 14:34:41) #
Есть аккумы, которые при КЗ на амперметр показывают 200-500мА и ток постепенно растёт, хотя падать должен. Возможно их восстановить, или только в помойку? BC700 их пытается бесконечно заряжать, а разрядить не может, так-как напряжение при токе 100мА, сразу падает ниже 0.9В.
Ситуация оказалась лучше, если выставить 250/500мА, после заряда большим током отдача тоже улучшилась.
haba
Offline5.2
с авг 2003
Дата: 01 Дек 2011 23:10:16 #
ну а что такого... если вдуматься - то энелуп должен был бы честно написать на упаковке 2400mwh :)
Slowesno
Offline2.8
с мар 2008
Сибирь
Дата: 02 Дек 2011 13:57:59 #
Подскажите по зарядному устройству GP PowerBank Rapid 2 (GPPB16GS). Последний 1-1,5 года стало странно работать. Заряжает установленные 2-4 аккумулятора меньше 1 часа, после чего сигнализирует о полном заряде, аккумуляторы чуть теплые. Фактически аккумуляторы оказываются практически не заряженными и очень быстро садятся. Но если после первой индикации о полном заряде взять и не доставая АКБ включить на зарядку снова то будет заряжать еще около 1 часа и в итоге АКБ будут привычно горячие и вполне нормально заряженные. Ситуация одинаковая и на стареньких GP и свежей Varta?
Serhiy1970
с июл 2006
Chernihiv, Ukraine
Дата: 04 Дек 2011 09:27:40 #
Вот "нарыл" в интернете (спасибо Гуглу) и составил список некоторых украинских интернет-магазинов, торгующих продукцией LaCrosse, Sanyo Eneloop, Tenergy, Turnigy и др.
http://fonari.in.ua Кривой Рог
http://pda-energy.tk Харьков
http://zivaka.com.ua/category/elementy-pitanija Полтава
http://starled.com.ua/ru/16--tenergy-solar ???
http://lacrosse.io.ua/album Черкассы
http://fonariki.net.ua/catalog/category/86 Киев
http://www.fonarik.org.ua/catalog/elementy_pitaniya.html Киев
http://www.paparazzi.in.ua/catalog.aspx?type_id=760 Киев
Самые низкая цена LaCrosse BC/RS 700 - $35 (~280 грн.) в Черкассах.
На аккумуляторы LaCrosse 2600/1000 mA*h соответственно 30/19 грн.
На аккумуляторы Sanyo eneloop 2500/2000/800 mA*h соотвтственно 45/30/28 грн.
Larr
с сен 2010
Дата: 14 Дек 2011 05:35:01 #
Serhiy1970
вдогонку Россия
http://www.comp2.ru/
http://www.smart-charger.ru/
Как я понял, можно просто воткнуть на зарядку и посмотреть "долитые" мАч, но какая при этом будет погрешность - неясно.
фиг знает. но точно больше, чем если мерить нормально через разряд. отображаемая долитая ёмкость вероятно будет больше истинно долитой, за счёт погрешности определения момента полного заряда и резкого усиления саморазряда при приближении к полному заряду. на какую величину - зависит практически от всего, для таких условий пожалуй уместно только опытное определение для каких-то конкретных условий.
Serhiy1970
с июл 2006
Chernihiv, Ukraine
Дата: 23 Дек 2011 21:39:10 #
Сегодня получил по почте комплект из 4-х LSD аккумуляторов Tenergy Centura AA 2000 mA*h.
Планирую их использовать в приёмнике Degen DE 1103. Пока что вскрыл упаковку и замерял их напряжение.
Три показывали 1.27 V и один 1,28 V. Насторожило то, что Made in China, но штрих-код американский.
Кто пользуется такими, отзовитесь !
Дата: 26 Дек 2011 15:43:49 #
Duracell 2650мАч показали саморазряд 420мАч в месяц, ёмкость соответствует заявленной.
Чья то тень
с окт 2008
Дата: 09 Янв 2012 08:59:15 · Поправил: Чья то тень (09 Янв 2012 09:07:36) #
Положительный отзыв за
Battery Daewoo AA 2700 mAh
http://www.ric.spb.ru/shop/catalog/goodsfoto/original/60000/410287.jpg
Перешёл на NiZN - не нарадуюсь. И цена доступная, 8 шт стоят 14 долларов.
http://www.amazon.com/PowerGenix-ZRPGX-AA8-High-Voltage-Rechargeable-Batteries/dp/B002NJUJ16/ref=sr_1_3?ie=UTF8&qid=1314510717&sr=8-3
Ничего страшного что у них 1,6вольт ? ИЛи этого не может быть.
Молния
Дата: 09 Янв 2012 10:19:53 #
Трудно сказать что хуже. Хронический недоразряд (с существенным фактическим падением заряда) с возможным последующим хроническим перезарядом у NiMh. Думаю многие устройства (которым требуется 1.5V x N) не способны работать при понижении напряжения питания на 20%-30%.
Либо хуже легкий хронический переразряд у NiZn. Но уже увидел маркетинговый трюк - заряд у NiZn указывается не в mAh (как везде), а в mWh.
Думаю, что немалая часть радости помимо цены заключается и в способности отдать заряд NiZn более полностью. Только вот как это скажется на сроке работы.
haba
Offline5.2
с авг 2003
Дата: 09 Янв 2012 10:58:52 #
при цене этих акб равной нормальным батарейкам - 20-30 циклов это уже подарок.
непонятно о чем можно сожалеть :)
Дата: 09 Янв 2012 14:24:13 #
Поделюсь своими наблюдениями.
Купил себе новое зарядное устройство взамен ВС900, кот. очередной раз не хочет заряжать большим , чем 200мА током.
Пока разбираюсь , как оно работает. Есть подозрение , что кривая программа зашита, функционирует немного не так, как в описании.
Это было втсупление, а суть в том, что оно отказывается заряжать 90% моих аккумуляторов. Как ни странно :), заражает прекрасно новые SONY те, что продаются предзаряженные и старенькие DAEWOO, GP - c трудом.
А " собака порылась" в том , что у них ( 90% моих аккумов, это около 2десятков ) очень большое внутреннее сопротивление и для получения тока заряда 0,5 А четырех аккумов требуется до 10В напряжения и этому зарядному устройству это не нравится. Аналогично себя ведет @ GP "Power Bank", не хочет вообще старые аккумы заряжать . В общем хоть и ВС900 их заражает, показывая высокие емкости, но на самом деле она в реальности значительно меньше, т.е. Мощность источники зарядки, как бы , типа, сначала расходуется на восстановление емкости, а потом на заливку энергией. В результате - мала реальная емкость, хотя ВС900 показывает номинал , а то и больше :=( .
Владельцы ВС смотрите на напряжение заряда в начале цикла , если оно велико, то не расчитывайте на высокую емкость.
НЕ покупайте аккумы с большим саморазрядом, это как правило Суперемкие аккумуляторы с емкостью более 2000А*ч. Поищите с малым саморазрядом.
( Кстати, почти в защиту аккумов ДЕГЕНа, они при своих 1300 работают не хуже 2700, но встречаются с браком через десяток циклов :=( ).
А я еще раз убедился , что не бывают Суперёмкие аккумуляторы формфактора AA -это миф ,НЕреальность (про цинковые ничего не могу сказать, не имел).
Дата: 09 Янв 2012 14:54:06 #
Убитые аккумы, от них вообще хоть что-нибудь работает?
У меня фотик сразу даёт индикацию пустой батареи, если 1-2 акк из 4 имеют ток к.з. меньше 3А.
Дата: 09 Янв 2012 15:26:33 #
У приемников ток меньше. В них и используй. Я использую в GPSе еще. Жаба душит выкидывать.
В батарее если попадется одна " паршивая овца" - она все " стадо " испортит. Перед использованием я их сортирую.
Так же если есть подозрительный элемент, то ставлю на нем маркером крестик, после трех крестов выбрасываю элемент.
semizador
Offline7.1
Дата: 09 Янв 2012 17:09:49 #
ats52:
В батарее если попадется одна " паршивая овца" - она все " стадо " испортит. Перед использованием я их сортирую. Так же если есть подозрительный элемент, то ставлю на нем маркером крестик, после трех крестов выбрасываю элемент.
Это точно. Я пользуюсь вот таким зарядным устройством. Первый признак "паршивой овцы" - это когда такой аккумулятор вдруг "зарядился" намного раньше остальных. Ёмкость аккумуляторов я проверяю время от времени, засекая время разряда на одинаковую для всех аккумуляторов нагрузку в одних и тех же климатических условиях...
Дата: 09 Янв 2012 17:43:48 #
Как-то привык уже к цифирькам. Да и мне проще заплатить 2тр , чем платы травить. Если есть возможность , то пользуюсь готовым.
Подарили GP- зарядку она отказалась заряжать большинство моих аккумов, я догадывался, что не может выйти на режим, но не думал, что из-за нехватки напряжения ( ток-то заряда у нее о...о большой и не регулируется).
semizador
Offline7.1
Дата: 09 Янв 2012 18:14:37 #
ats52:
Можно так, а можно готовые платы...
CDMA
с июн 2006
Дата: 10 Янв 2012 15:39:53 #
ВОТ професиональные энелупы HR-3UWX-4BPY по невкусной цене. Зато реально выше 2000 мАч (2400) . И все параметры честные. Пользую такие.
КАРТИНКА
Время загрузки страницы (сек.): 0.082; miniBB ®
