На сайте: гостей - 69,
участников - 7 [ andory, John79, skytruck, Хайо, CDMA, SPBOBL, makcet]
 Форум —› NATO Scanner —› AFSATCOM или SSC "Giant Star"
РУБИН
Из России
Дата: 20 Авг 2008 00:29:15 #
Уважаемые коллеги!!))
Скажите кто-нибудь работал с этой системой связи в домашних условиях?
Какое оборудование и ПО необходимо для наблюдение этой системы?
РУБИН
Из России
Дата: 20 Авг 2008 07:36:00 · Поправил: РУБИН (21 Авг 2008 00:08:49) #
Ситстема работает на частоте 243.7 Mhz
БЕГЕМОТ
Offline7.8
с авг 2004
из ниоткуда в никуда
Дата: 20 Авг 2008 11:57:57 #
РУБИН
AFSATCOM provides secure, reliable and survivable two-way global commu-nications between the NCA and the stra-tegic nuclear forces. The AFSATCOM system is used for EAM dissemination, JCS/CINC Internetting, CINC force di-rection message dissemination, force re-port back and other high-priority user traffic dissemination. Strategic nuclear forces include ICBM launch and control centers, B-52, B-1B and B-2 bombers and nuclear capable submarines (SSBNs). On the FLTSATCOM satel-lites, all twelve 5 KHz narrow-band channels and the one 500 KHz wide-band channel have been dedicated to the AFSATCOM mission. Seven of the twelve 5 KHz narrow-band channels are regenerative and can only be used for 75 BPS digital communications (not voice). The frequency range is UHF. In addition to FLTSATCOM satellites, AFSATCOM also has transponders on board other host satellites to provide coverage over the North Pole. There are two systems in use for polar coverage: the Satellite Data System (SDS) and Package D, a piggy-back payload on classified host vehicles. SDS satellites include a payload similar to the twelve-channel 5 KHz system on-board the FLTSATs. However, all twelve are regenerative and can only be used for 75 BPS data. Package D satel-lites provide a UHF package similar to the SDS satellites. Ground control is ac-complished by the host satellite network.
Оборудовние - приемник и см. ветки про satcom.
DED REX
с дек 2003
Минск
Дата: 20 Авг 2008 21:17:13 #
Уже ничего подобного не отмечается!!!!!!
РУБИН
Из России
Дата: 01 Сен 2008 20:39:09 #
Кто мониторит Satcom ?
РУБИН
Из России
Дата: 17 Фев 2009 01:46:46 · Поправил: РУБИН (17 Фев 2009 08:58:12) #
Раньше был солидный объем информации.
guard
с фев 2009
Дата: 17 Фев 2009 08:47:35 #
Date: 20.09.2003 Time: 19:35:51 Windo: 0:21
3kan
1100000011000000110000001100000011101010101010110110100010100010
WBUT7R+20 F1 2122B2A2A*
а поподробней об етом ....наскольько известно они уже ушли из старых дорожек
РУБИН
Из России
Дата: 17 Фев 2009 08:56:57 #
Правильно, это можно сказать раритетные записи найденные на просторах интернета... Конечно было бы интересно посмотреть на эту систему лет 10 назад.
guard
с фев 2009
Дата: 17 Фев 2009 12:00:08 #
вид сигнала WBUT7R+20, а вот было б интересно узнать кому и зачем он предназначался. Еще один интересный момент встречался когда сигнал повторял заправщик
РУБИН
Из России
Дата: 10 Дек 2016 20:59:14 #
Система ушла в резерв или модифицирована..
