На сайте: гостей - 67,
участников - 7 [ Unkers89, Несущий свет, telefon, Pavlik, ГЭС, Silent, muha131]
 Форум —› Радиостанции —› Пока "монстры" в кризисе - новинка от Alinco: трехбендовая DJ-G7
Denznak
с ноя 2007
Дата: 07 Апр 2010 10:08:13 #
Что-то не слышно отзывов реальных пользователей данного аппарата. А они уже есть, так как станция продается. Что там с модуляцией, с громкостью,с чувствительностью?
ua4wbk
с апр 2009
Глазов, Удмуртия
Дата: 08 Апр 2010 21:07:51 #
Здравствуйте БРАТЬЯ!
Даю ссылочку на полное описание на Алинку ДЖЭЙ СЭВАН, английское.
http://www.alinco-radio.ru/download.php?id=3001&idf=11
Shephard
Offline6.3
из эфира
Дата: 08 Апр 2010 22:47:52 #
How to enter service/adjustment menu for DJ-G7E
Contact author. Contact author:
G1ZGZ
Print Print this article. A new window is open.
1.
Switch on and press FUNC key for 2 seconds to lock keys.
2.
Enter the following key sequence: 3-1-2-3-2-1
You are now in service/adjustment mode. To exit, press the FUNC key, which takes you back to normal operation.
Service operation controls:
Left frequency dial: Adjust frequency/Push to adjust squelch.
Left volume control: Adjust volume. Right frequency dial: Adjust parameter.
Right volume control: Adjust parameter in steps of 5 per increment.
"A" key: Forward
"B" key: Return
"D" key: Set
Happy adjusting!
I accept no responsability for any adjustments YOU make. So if you're not sure what you are doing, DON'T do it.
This method came straight from the Alinco service manual, so don't email me if you can't get your G7 to work!
Possible way to reflash a broken Alinco DJ-G7
John Makris SV9OFO
It is already well-known that should flashing a new software in the DJ-G7 fails, you owe to send it back to Alinco service for repair.
A friend of mine managed to blew his G7 up, thanks to the local power company, so I searched and found a way to bypass several constraints involved in order to reflash it. I found a solution, but my friend had sent the HT to alinco already.
Alinco set the G7 to start the cloning - flashing IO procedure via a software menu, requiring to keep pressing "MONI" button while pressing the PTT three times.
That guides the CPU to set a signal via pin 65 "EXT" to Q10, which normally "Locks" into HIGH state the CLN signal, to "release" that high state, thus enabling direct access to CPU's RXD-TXD serial pins via the CLN bus.
Q10 is powered via the R60, which is at the left top corner (why Alinco put THAT over there, BTW?!?) of the rear side of the CPU board, same side with the processor.
On page 48, top left corner, you can find the R60 resting there, powering the CLONE switch transistor Q10.
Should you be desperate enough, you can give it a try. Remove R60, reassemble the HT, place back the battery, connect the HT to the interface and start the program. If no "error" dialog appears, but instead a "success" window pops up, remove the battery, disassemble the connectors, resolder the R60, and power up the HT while holding the "FUNC" button.
The HT should start, all memories cleared.
***And remember, you saw it first on MODS.DK!!!!****
DISCLAIMER
Repairing any high tech device requires severe engineering skills.
Leave all messing with the internals of high technology devices to the professionals.
This hack is a theoretical approach - I, or anyone I know, have never performed the hack in any G7, ever. Due to the location of R60, it is the most plausible scenario for the restoration of DJ-G7. But should you
* Fail to restore your HT
* Fail to safely follow the instructions above -not have the basic knowledge and skills to follow the instructions -fail to understand that this is a not-tested-yet theoretical approach
You should NOT try to repair your HT.
In any case, neither I or mods.dk can take any responsibility if you destroy your transceiver.
Undocumented features for Alinco DJ-G7
HB9DWW, Peter
More SET modes
Press the [V/P/M] key for about 2 seconds.
MONI: Item change and Dial:val.change appears on the display.
Press the [MONI] key to change the items and use the dial knob to change the values.
Item Default Value Value 2 Value 3 Value 4 Range Description
Vol display type Normal Center (Active) Center (Non. act.) - - Display options for volume values
Scan operation 1 touch 2 touch - - - Start scan operation by pressing SCAN 1 or 2 times.
MONI key TX DISABLE Sub-band Main-band L pow. Main-band H pow. - Options to use the MONI key as a second PTT
S METER Normal Simple - - - S Meter display options
FSK Round Time 2000ms. - - - 0 to 2540ms Packet communication parameter
FSK Tx Amount 20 - - - 0 to 254 Packet communication parameter
Shephard
Offline6.3
из эфира
Дата: 08 Апр 2010 22:51:40 #
сервис мануал для сабжа
Service Manual DJ-G7
Stasiz
Новосибирск
Дата: 09 Апр 2010 11:55:31 #
Да и обзор от QST тоже:
Alinco DJ-G7T - QST Review
ios
с окт 2007
Дата: 21 Ноя 2010 19:04:37 #
есть тут владельцы? или я один? пока что пользую аппарат около месяца, постепенно собираюсь с мыслями для написания отзыва в рейтингах.
zug
с июн 2008
Erfurt Deutschland
Дата: 21 Ноя 2010 19:37:07 #
Петля на руку по уму вполне, но вот фаст текс на онной как корове седло, удобнее "липучку" велкро.
А так интересный апарат (хотя я не поклонник данного бренда) да и 23 см как то не совсем в колхозах развит)
Stasiz
Новосибирск
Дата: 21 Ноя 2010 20:16:36 #
ios
Похоже надо быть первопроходцем - ждем отзыва.
ios
с окт 2007
Дата: 03 Дек 2010 03:03:11 #
о, уже появился первый отзыв. UA0LTB отличился. не могу сказать, что согласен с ним. но всё-таки свой отзыв писать пока не готов, хочется сделать его максимально объемлющим. но обязательно отпишусь. в принципе если есть конкретные вопросы, готов ответить.
ios
с окт 2007
Дата: 03 Дек 2010 16:16:25 · Поправил: ios (03 Дек 2010 20:20:13) #
ua4wbk
1) есть и междиапазонный дуплекс и междиапазонный ретранслятор. естественно только на разнесённых диапазонах: другого в портативках и не существует. прикольно, оказалось что дуплекс работает не только между любительскими диапазонами (под "любительскими" понимаю не буквально 144-146 и 430-440, а расширенный вариант 136-174, 420-470). то есть принимать можно например на 250, при этом передавая на 430. но работает такой вариант не со всеми диапазонами, например пара 330-430 уже не наботает.
ретранслятор при такой конфигурации тоже может работать, но только в одном направлении.
2) в комплекте не поставляется, докупать надо отдельно если нужен.
3) как уже сказал, на одном диапазоне работать дуплексом нельзя. и не понял - с чего бы это частоты 145 и 145,5 кратные?:) что касается 145 и 435, то тут ситуация стандартная и заключается в следующем: если передавать на 145, то на кратной частоте (435) принимать невозможно, только в стороне от кратной. если же передавать на 435, то на 145 приём возможен, хотя бывают нюансы в зависимости от конкретной пары частот - возможно и полное закрытие приёма, и приём с просаженной чувствительностью.
4) не производил пока. это утомительно в плане чётко режим (1:1:8 или любой другой) соблюдать. проще замерить потребление в разных режимах, и рассчитывать время через потребление и ёмкость батареи.
ua4wbk
с апр 2009
Глазов, Удмуртия
Дата: 03 Дек 2010 21:55:36 #
ios
Я имел ввиду
в пределах одного диапазона (145МГц и 145,5МГц)
Спасибо за развёрнутый ответ, многое прояснилось. Кстати, по какой цене приобретали и где?
ios
с окт 2007
Дата: 05 Дек 2010 04:07:05 #
заказывал из-за границы. увы там её в наличии больше нет (хотя так вообще вроде много где есть - найти не проблема). обошлась в $380. цена в российских же магазинах (под $600) конечно умиляет...
Green
Красноярск
Дата: 07 Дек 2010 05:36:21 · Поправил: Green (07 Дек 2010 06:03:38) #
USPS или как там её, почтовая служба, что-то там баксов 20-30, до Красноярска - недавно заказывал тюнер от Elecraft-a, тоже из штатов. Пришло быстрее, чем с Москвы :)
ios правильно подметил - сделайте пробный заказ (не подтверждая оплату), там должно быть видно.
PS Народ на почте был в шоке. Большой белый красивый (по сравнению с нашими, "советскими") мешок со штатов, размером с куль для картошки, запечатанный. В нем для меня была одна маленькая коробка размером, грубо говоря, с обычную книгу, и всё :)
ua4wbk
с апр 2009
Глазов, Удмуртия
Дата: 07 Дек 2010 10:16:33 · Поправил: ua4wbk (07 Дек 2010 11:04:18) #
Вчера получил ответ на свой запрос в эту контору. Написали, что с заграницей не работают.
Вот текст:
- Sorry, but Universal Radio is not currently accepting orders for international export.
Our decision to stop exporting was not made lightly. Many factors were involved in the decision including, but not limited to, over zealous customs officials interpretation and enforcement of CE certification and ROHS compliance, damaged, lost or stolen packages, warranty issues, credit card fraud, etc.
Thank you.
Rick
Universal Radio, Inc. Orders 800.431.3939
6830 Americana Pkwy. Information 614.866.4267
Reynoldsburg, OH 43068 Fax 614.866.2339
http://www.rffun.com dx@universal-radio.com
Надо искать через тех, кто со штатов таскают технику под заказ. Но это снова посреднические расходы :( Цена снова станет не приемлемой. Так что будем ждать или искать другие варианты доставки со штатов. В принципе там много торгующих точек, может кто и сработает.
Вот ЗДЕСЬ ещё нашёл, запрос отправил, посмотрим что ответят.
Green
Красноярск
Дата: 08 Дек 2010 05:37:28 #
Ответили?
ua4wbk
с апр 2009
Глазов, Удмуртия
Дата: 09 Дек 2010 14:16:10 #
Green
Ответили?
Да.
Dear Sir,
Thank you for your email. The cost of shipping to Russia is 20.00 GBP
Best regards
В общем я так понимаю 20.00 GBP (Фунт стерлингов), это наверно $33, если правильно считаю.
В общем получается $330 с доставкой в Россию. Цена более, чем приемлемая. Так что думайте. Цена здесь около 600 долларов, так что экономия на лицо.
Mikle Shaman
с мая 2005
Дата: 13 Дек 2010 10:56:07 #
Граждане, а просветите чайника, плз. Это вот диапазон 1,2 Мгц он ЗАЧЕМ?
Green
Красноярск
Дата: 13 Дек 2010 11:39:59 #
Вопрос из серии "В чем смысл жизни?".
Но отвечаю - для любительского интереса! :)
Triazalon
с мар 2010
UAE
Дата: 13 Дек 2010 22:32:46 #
Mikle ShamanГраждане, а просветите чайника, плз. Это вот диапазон 1,2 Мгц он ЗАЧЕМ?
Тогда зачем радиолюбителям диапазон 240ГГц?
ios
с окт 2007
Дата: 14 Дек 2010 00:03:33 #
это троллинг
за такие "вопросы" банить надо
Mikle Shaman
с мая 2005
Дата: 14 Дек 2010 10:57:23 #
это троллинг
Отнюдь. Если тема где-то обсуждалась ткните где читать. Насколько я помню школьный курс физики, с уменьшением длины волна падает дальность распространения. Вот и спрашиваю кто или что у нас есть в эфире на этом диапазоне? Кого слушать-то? А так можно и Wi-Fi воткнуть. Недалеко вобщем-то до 2.4 МГц.
Green
Красноярск
Дата: 14 Дек 2010 12:44:58 #
Да, в общем-то недалеко ;) ;)
EW3BI
с ноя 2009
Брест
Дата: 26 Дек 2010 17:31:45 #
Кто еще чего-нибудь хорошего/плохого про сабж скажет? В планах - обзавестись.
van
с ноя 2007
107-109
Дата: 26 Дек 2010 21:53:05 #
Green
И кого Вы там хотите услышать?
Тут на 430 МГц народ по договоренности связи проводит...
Green
Красноярск
Дата: 27 Дек 2010 13:12:19 #
Ну и что? Ну, например, как вариант, работа через ИСЗ. Да мне и так, просто любопытно, диапазон испытать, как себя ведет.
rw4hfn
Offline2.7
с дек 2009
SAMARA
Дата: 27 Дек 2010 13:26:59 · Поправил: rw4hfn (27 Дек 2010 13:27:22) #
Тут на дружественном форуме хорошо сказано... http://forum.qrz.ru/post472116-33.html
EW3BI
с ноя 2009
Брест
Дата: 04 Фев 2011 19:37:55 #
Подскажите кто в курсе существует ли инструкция на русском языке для сабжа или нет, а то оригинальная как-то не воспринимается:)
Larr
с сен 2010
Дата: 13 Фев 2011 16:43:12 #
EW3BI
Не существует. Есть на английском с возможностью поиска в тексте. но сюда залить не могу - файл превышает лимит объёма.
ua3reh
с мар 2009
Тамбов
Дата: 06 Сен 2012 22:16:09 #
Как можно "переключить" версию Е в Т? Просто прошить нужной прошивкой?
ua3reh
с мар 2009
Тамбов
Дата: 11 Сен 2012 14:58:23 #
Разобрался. Ничего переключать не нужно. в новой версии софта (Е5.100) все функции версии Т доступны: и репитер и баг-сканнер.
Станция нравится все больше и больше (сравнивать есть с чем - есу 8др рядом стоит).
 Страница:  ««  1  2  3  4  »»
Время загрузки страницы (сек.): 0.066; miniBB ®
