На сайте: гостей - 71,
участников - 5 [ vladisslav2011, Nefteugansk24, Kolomchanin, Вебмастер, dalex]
 Форум —› Радиостанции —› Опознание разных радиостанций
 Страница:  ««  1  2  ...  10  11  12  13  14  ...  102  103  »»Поиск в теме
Fujik
Дата: 21 Май 2012 04:16:49 #
Lemmy
с ноя 2008
Королёв
Дата: 21 Май 2012 06:16:51 #
Lemmy
с ноя 2008
Королёв
Дата: 21 Май 2012 06:20:28 #
Thuraya XT-DUAL is one of the finest and latest satellite phones for your work and travel in the Middle East, Africa, Central, East and Southeast Asia. Works with simcards for any GSM carrier including USA and Canada. FEATURES:Thuraya satellite voice services Always-on Internet service (GmPRS) Text Messaging (SMS) Image/Video Messaging (MMS) Voicemail Enhanced GPS Services Tri-band global GSM (900/1800/1900) Circuit-switched data and fax at 9.6 Kbps Ingress Protection: IP64/IK03 standard (splash water, dust, shock proof) Roaming onto 300 GSM networks - Outgoing calls: postpaid subscribers only - Incoming calls: prepaid and postpaid Specifications:System: Thuraya & tri-band GSM 900 / 1800 / 1900 Unlocked, works with SIM-cards of any GSM carrier, including USA and Canada. Phone Memory: -Internal 320 MB -External: 2GB SD card included Dimensions: 139 x 53 x 27 mm (5.5 x 2.1 x 1.1 in.) Weight: 211 g (7.4 oz) Color Display: 5 cm (2 in.) color display 1.3 Megapixels camera (photo and video) Polyphonic ringtones USB Connectivity Operating System: Windows CE Multilingual support, including English and Spanish. Battery (SAT): Talk time up to 6 hours, stand-by time up to 60 hours Battery (GSM): Talk time up to 11 hours, stand-by time up to 160 hours Thuraya XT-DUAL Fact Sheet, Brochure, FAQ. In the box: Thuraya XT-DUAL satellite phone Li-Ion rechargeable battery 2520 mAh USB data cable AC Power Adapter 110-220V, 50/60Hz AC International plug kit 2 GB microSD Memory card CD-ROM with software Hands-free earset Spare plugs for antenna connector User manual (English, Arabic, Russian, French)
Caprice Classic
Offline5.5
Дата: 21 Май 2012 07:37:58 #
Lemmy
На ebay самый дешевый за 800+ баксов. Можт себе взять?
А с симками наших ОпСоСов сможет работать, интеоесно?
clips
Дата: 21 Май 2012 07:59:58 #
да
dezigner
Offline4.9
с авг 2008
Дата: 21 Май 2012 13:15:27 #
Заглянул на досуге на выставку фотографий Ай Вейвея.
Фрагмент его фотки с двумя полицейскими и непонятными радиостанциями.
Дело было в середине восьмидесятых.
Caprice Classic
Offline5.5
Дата: 21 Май 2012 15:49:11 #
dezigner
Motorola MX300, да?
Гляньте здесь - хороший сайт по древним радиостанциям:
http://metrocommnj.tripod.com/id9.html
iopta
с мар 2008
Дата: 21 Май 2012 16:00:35 #
Fujik
Lemmy
Спасибы.
dezigner
Offline4.9
с авг 2008
Дата: 22 Май 2012 01:40:56 #
Caprice Classic
Спасибо за ссылку, похоже это точно MX300. Совсем дремучие времена, до саберовские.
Дата: 22 Май 2012 08:09:04 #
MX300
Прикольная станция. У менять есть такая, нулячая досталась. Имеет регулируемый ручкой шумодав как у РЛ станций.
iopta
с мар 2008
Дата: 22 Май 2012 14:56:01 #
Есть ли возможность сфоткать с разных ракурсов ? )
SP171
с сен 2011
KP50EB (Санкт-Петербург)
Дата: 28 Май 2012 14:48:26 #
Видел тут станции у местных сотрудников,стало интересно что за станции(раньше другие были,а тут новые).
100%,что моторола...
Похожи на GP300,только в верхней части(крутилки,микрофон) идёт утолщение...
300 ровная как кирпич,а там вверху утолщение...
scanner2000
Offline5.5
Дата: 28 Май 2012 14:58:24 #
SP171
Motorola P110?
haba
Offline5.2
с авг 2003
Дата: 28 Май 2012 15:00:49 #
scanner2000
да скорей всего она и есть.
SP171
с сен 2011
Дата: 28 Май 2012 19:33:59 · Поправил: SP171 (28 Май 2012 19:37:32) #
Не,не,не...
Дизайн по новее(вряд ли станут всем по новой старьё выдавать...)
И расширение не в ту сторону=)
Можно так сказать,что динамик чуть выпирает из ровного корпуса...
Как бы обьяснить...Незнаю.
(+ наверху оранжевая кнопочка,как у некоторых моторов).
Caprice Classic
Offline5.5
Дата: 28 Май 2012 19:44:46 #
SP171
Надо бы фото...
А то это какой-то аборт по интернету получается.
Или зайдите на www.motorola.com, может там чего узнаете?
SP171
с сен 2011
Дата: 28 Май 2012 19:51:34 #
В следующий раз подойду,попрошу в руках подержать,сфотографирую.Интересно.
Caprice Classic
Offline5.5
Дата: 29 Май 2012 08:01:09 #
SP171
Смотрите, осторожнее! А то могут неправильно такую просьбу понять =)
если удастся в руках подержать - попросите разрешения снять аккум, под ним наклейка. Запомните model number и сообщите его. Тут и посмотрим что это такое.
Если б мне в руки станцию дали, я б еще и частоты срисовал :)
Может тогда MTS2000? Или даже DP3xxx?
Алкор
с сен 2008
Невинномысск
Дата: 02 Июн 2012 10:31:39 · Поправил: Алкор (02 Июн 2012 10:35:55) #
снесли, блин!!
Valeriys
с мар 2010
Новороссийск
Дата: 05 Июн 2012 14:39:13 · Поправил: Valeriys (05 Июн 2012 14:46:53) #
Сказали что локомотивная станция, но не более.
Кто поможет опознать и найти описание на управление ей.
http://s019.radikal.ru/i607/1206/cb/eed03ef35c3e.jpg
http://s018.radikal.ru/i511/1206/e4/ffd634c20835.jpg
http://s019.radikal.ru/i634/1206/bd/00a540623d27.jpg
5318
с фев 2010
р/сеть Грация
Дата: 05 Июн 2012 15:38:56 · Поправил: 5318 (05 Июн 2012 15:55:36) #
Попробуйте набрать в поиске "Маяк 16Р22"
Схем и рекомендаций по этой р/станции в сети довольно много.
В том числе и на этом форуме.
Карт
с июл 2010
Дата: 09 Июн 2012 22:17:05 #
Pedro
с фев 2006
Дата: 09 Июн 2012 23:58:17 #
Это Блок передатчика от РСИУ-3
andreu85
с окт 2007
Киев-UKKK
Дата: 13 Июн 2012 04:31:35 #
В Киеве проходит Евро-2012, вчера был матч со шведками, а перед этим и шведи ходили колонной по городу, их сопровождала шведская полиция, вот нашел фото, никто не подскажет, что за рация у шведа?
Caprice Classic
Offline5.5
Дата: 13 Июн 2012 10:21:55 #
Sepura SRH-3800...?
СЦБист
Offline6.6
Дата: 13 Июн 2012 15:41:22 #
Да не... она ж хлипкая...
Caprice Classic
Offline5.5
Дата: 13 Июн 2012 19:57:07 #
СЦБист
Точно Сепура! Одна ручка, оранжевая кнопка на квадратном "постаменте", а если не поленитесь увеличить, даже сможете прочесть надпись Sepura над дисплеем.
Ну и что из этого? Полиция многих европейских стран пользует тетру, вон та же английская полиция вся с сепурами
scanner2000
Offline5.5
Дата: 13 Июн 2012 20:00:39 #
Какое высокоинтеллектуальное лицо с сепурой, я думал такие только в нашей полиции встречаются.
СЦБист
Offline6.6
Дата: 13 Июн 2012 20:15:08 #
Ну то что похожа на SEPURA я тоже подметил, но не верится... на работе 3500-ые мрут как мужи- хлипкие до нельзя... значит и у них такая же фигня- так же с обеспечением...
Карт
с июл 2010
Дата: 13 Июн 2012 20:22:10 #
Еще неизвестная аппаратура на опознание.
http://www.radioscanner.ru/uploader/2012/k-gyranthn0.jpg
Время загрузки страницы (сек.): 0.092; miniBB ®
