Дата: 19 Май 2009 02:11:30 · Поправил: electrocat (19 Май 2009 18:06:32)
новый радиоприёмник TECSUN PL-300WT(ссылка на ебей liypn, удовольствие стоит $49.99 + $24 доставка в Россию) на американском рынке похоже называется Grundig G8 Traveler II ( на universal-radio написано "This radio is expected in late June 2009.")
описание с ебея:
TECSUN PL-300WT WORLD TIME FM STEREO/AM/SW WORLD BAND DIGITAL SIGNAL PROCESSING RADIO
FREQUENCIES:
FM General: 87 ~ 108 MHz. Russia, Campus broadcast (part) : 64 ~ 108 MHz. N. America & Europe : 87.5 ~ 108 MHz.
Japan : 76 ~ 108 MHz.
MEDIUM WAVE Europe, Asia & Africa : 552 ~ 1620 KHz. North America : 520 ~ 1710 KHz.
LW - 153 ~ 513 KHz.
SW - 3150 ~ 21950 KHz.
Uses Silicon Labs 4737 digital signal processing (DSP) chip
DSP converts AM / FM analog signals to digital signals that greatly improves the sensitivity, selectivity, signal to noise ratio and anti-interference of the radio has multi-function tuning knob to control time, frequency and pre-sets
4 types of tuning method including ATS can store up to 500 stations
Frequency, signal strength, signal to noise ratio, temperature and battery capacity can be displayed on the panel
has AM signal to noise meter (double digit)
30 steps electronic volume control
Automatic turn on of radio by setting the timer
Good sound quality, loud and clear!
FM Stereo Listening by earphone.
With earphone socket, for private stereo FM listening!
Using the world clock dial, it is easy to examine the local time and other times in the world гы?
This radio is excellent for travellers, reporters, foreign students and people working in a foreign country
Dimensions: 5.3 x 3.4 x 1 inch / 135 x 86 x 26 mm (approx.)
Battery: Uses 3 AA size 1.5V. battery (not included)
Net Weight of Radio : 7.8 oz. / 220 g (approx.)
Искал по форуму и в рунете - ничего не нашёл ( если паршиво ищу, извините)
кто-чего про этот приёмник думает ? :) |
Дата: 19 Май 2009 02:13:26 · Поправил: DVE (19 Май 2009 02:15:57)
Ручка переключения (частот?) явно взята от китайского тестера :)
Судя по параметрам, SSB отсутствует, соответственно смысла в таком девайсе весьма немного.
Дата: 19 Май 2009 02:17:09 · Поправил: electrocat (19 Май 2009 02:36:29)
эта ручка меня тоже озадачила, я так понял, это часовые пояса переключать. в нормальном виде она не видна.
в описании написано "Using the world clock dial, it is easy to examine the local time and other times in the world" |
Дата: 19 Май 2009 14:04:03 · Поправил: ajv (19 Май 2009 14:13:57)
Это как-то можно включить? Или присутствует в некоторых исполнениях?
Сколько у него ячеек памяти?
Дата: 19 Май 2009 19:07:44 · Поправил: Bukimoner (19 Май 2009 19:21:41)
Надо было им вместо ручки встроить динамо-машинку, чтобы подзаряжать аккумуляторы. Покрутил, и приемник снова играет :-) Тем более, что приемник позиционируется как Travel Radio. А на обратную сторону откидной крышки солнечную батарею.
Дата: 20 Май 2009 01:34:21
было бы любопытно посмотреть мануал
например, непонятно как вводить частоту, как переходить между 500 пресетами.
и
что это за 4 types of tuning method
маловато кнопок, в общем, и как они вывернулись ? любопытно
Дата: 20 Май 2009 01:36:04 · Поправил: electrocat (20 Май 2009 01:37:51)
исполнение одно, подозреваю, как и во всех подобных переключается режим, что-то в духе нажмите в выключеном состоянии "fm-set" и стрелку верх 4 раза :) но без документации можно только гадать. в инете инфы - кот наплакал. и вся по китайски
вроде "can store up to 500 stations "
Дата: 20 Май 2009 15:20:57
По большому счету, для "радиомониторинга" (к чему относится данный раздел форума) данный приемник - обычная мыльница, коих на любом радиорынке туча по 20$/шт.
Манул не искал, из того что видно по фотографии:
- режимов приема USB/LSB(SSB) похоже нет, значит большое количество станций прослушать в режиме АМ не удастся.
- неясно есть ли вход для внешней антенны.
- неясно есть ли валкодер, или переключение частоты только цифровое. Если нет, то для поиска не подойдет.
Если интересен именно Grundig, то стоит искать что-то типа Grundig G5/G6, ну а это - разве что повесить на ремешок чтобы на даче маяк слушать :)
PS: На DSP сильно надеяться не стоит, даже в проф.трансиверах за сотни баксов не всегда удается сделать нормальную цифровую обработку, а уж тут в девайсе за 50$ и подавно.
PPS: Я в свое время совершил похожую ошибку, купив Grundig Yachtboy 2000, который оказался обычной бытовой мыльницей совершенно не приспособленной для серьезного изучения КВ. Просто деньги на ветер.
Дата: 20 Май 2009 17:06:37 · Поправил: Yupi (20 Май 2009 17:14:24)
Думаю, что приёмник найдёт своего покупателя. Небольшая стоимость, наличие DSP даже при отсутствии суперчуствительности как у Sony icf 4920 (который "сделает" любое из мне известных портативных радио), но даст определённый комфорт при прослушивании коротковолновых вещалок без свистов и писков подобно Degen/Kaito-1123 |
Дата: 20 Май 2009 23:58:03
Дата: 21 Май 2009 02:54:25
для слушания "маяка на даче" (да и в квартире) у меня есть degen 1103, TECSUN pl-600, и Sony ICF-SW7600GR :)
а это скорее в нагрудный карман положить, во время прогулки или в близкую коммандировку... хотя может в карман рубашки не влезет, придётся в куртку класть ))
ну просто приглянулась внешне модель. любопытно стало.
да и TECSUN я доверяю
Дата: 21 Май 2009 11:50:01
Жду Grundig G3
![](http://www.radioscanner.ru/uploader/2009/20090515152715733.jpg) |
Дата: 10 Сен 2009 22:19:46
Прикупил Tecsun PL-300WT, он же Grundig G8.
Обзор небольшой, но красноречивый (пдф)
Приемник оказался отличный, если сравнивать с моими ожиданиями.
размер 2 пачки сигарет
с одной стороны 2 колесика с шажками - звук и настройка, с другой вход 6 В (блока питания нет) и наушники.
Больше входов/выходов нет.
SSB нет.
Прямого ввода частот нет.
Жаль, не сделали переключение ширины полосы на АМ (1, 2, 3, 4 и 6 кГц), микросхема позволяет легко.
ДВ, шаг 1/(9/10)/100 кГц, тупой довольно (феррит настроен на СВ), дальних станций не услышал, только местную
СВ, шаг 1/(9/10)/100 кГц, отлично, избирательность супер (ДСП)
КВ, шаг 1/5/100 кГц, отлично, избирательность супер (ДСП), чувствительность тоже, на 50 см антеннку слышно почти также как на Деген 1103
УКВ, 64-108, шаг 10!!/100/1000 кГц, отлично, избирательность супер (ДСП), чувствительность очень хорошая, до суперчувствительности Дегена конечно не дотягивает, длины антенны явно не хватает, надо наращивать, слышно 4 кВт передатчики на 66-74 за 80 км. На антенну в 50 см.
Подавление зеркалок и разных гармоник фантастическое, в 2 км от телецентра эфир почти чист. Только у некоторых станций +200 или 300 кГц.
Если сравнить с Дегеном - тот забит весь, кроме отдельных частот.
Настройка необычная для небольших приемников:
2 режима - быстро и медленно.
В медленном режиме при тихом вращении шаг на КВ 1 кГц, при быстром вращении переключается на 5 кГц, после остановки через пару секунд опять на 1.
В быстром режиме соответственно - 5 и 100 кГц.
На СВ 1/9 и 9/100.
На УКВ 0,01/0,1 и 0,1/1,0 МГц.
При листании 1,0 МГц 64-108 пролистывается за 10 секунд, вру, за 6 секунд, скорость космическая.
АТС - автоматическая настройка,
листание программ, как в Дегене.
Как все дспэшные приемники показывает силу сигнала и соотношение с/шум.
Температура, 2 или 3 времени.
Динамик очень маленький, бэ.
В наушниках нормально.
3 батарейки АА
У меня появилась надежда, что даже на этой микросхеме (Si4734) возможно кто-то сделает очень хороший приемник. |
Дата: 10 Сен 2009 23:20:01
Ссылка не работает.
Дата: 11 Сен 2009 13:32:17 · Поправил: NIP (11 Сен 2009 13:49:11)
По ссылке пишет :
You are trying to access from a non-authorized domain. (www.radioscanner.ru)
Так что открывайте статью A Review of the Grundig G8 and Tecsun PL-300WT на той странице куда попадаете
Дата: 11 Сен 2009 13:45:55 · Поправил: Viru (11 Сен 2009 13:46:24)
Дата: 11 Сен 2009 19:54:12
Дата: 13 Сен 2009 18:58:54 · Поправил: Viru (13 Сен 2009 20:46:18)
Дата: 13 Сен 2009 19:48:12 · Поправил: Viru (13 Сен 2009 20:44:35)
Дата: 13 Сен 2009 20:40:59
Дата: 13 Сен 2009 20:49:06
Интересно, почему я должен думать, почему долбаная Опера не проигрывает видео и некорректно обрабатывает разные разрешения?
Дата: 28 Сен 2009 18:55:24
Дата: 28 Сен 2009 20:44:43 · Поправил: ajv (29 Сен 2009 13:57:48)
Судя по описанию есть советский УКВ диапазон, что есть хорошо. Жаль, что RDS не воткнули, пустячок, а приятно.
Дата: 29 Сен 2009 19:59:16
Дата: 29 Сен 2009 22:33:44 · Поправил: Yupi (29 Сен 2009 23:14:51)
сравнение Tecsun PL-300WT и Sangean ATS 909 на 66-74 МГц
Тексан:FREQUENCIES: FM General: 87 ~ 108 MHz. Russia, Campus broadcast (part) : 64 ~ 108 MHz[/i]
Санжин: FM General: 76 ~ 108 MHz
то бишь сравнивался неизвестно кем крученный Санжин, c отрегулированным на заводе-изготовителе Тексаном?
Дата: 29 Сен 2009 22:49:46
Сравнивались мои экземпляры.
И могу поспорить, что на "отрегулированным на заводе" Sangean результаты были бы практически такие же, если не хуже (из-за еще более широких фильтров).
Дата: 16 Окт 2009 09:07:42
Заказал PL-310. Очень интересно какие плюсы дает применение в приемнике DSP
Питание приемника сделали от USB, вот бы еще сделали управление контроллером с компа, но это так, мечты... |
Дата: 16 Окт 2009 10:18:51
Viru Жду Grundig G3
И как? Я дождался. Первое впечатление - на ДВ и СВ раза в два тупее Дегена-1103.
При подключении внешней антенны не ловит ничего. Похоже, надо лезть внутрь, смотреть
как устроен разъем.
Дата: 16 Окт 2009 11:54:53
И как?
Что-то я почитал первые обзоры, как-то противоречиво.
Да и платить почти 200 долларов.
Пыл несколько угас.
Дата: 21 Окт 2009 01:22:26 · Поправил: AntonR (21 Окт 2009 10:38:38)
