Дата: 26 Сен 2009 16:17:16
EXER Joint Warrior 092 is about to take place Oct. 5th - 23rd 2009.
The guided missile frigate USS John L. Hall (FFG 32), and guided missile destroyers USS Ramage (DDG 61) and USS Cole (DDG 67), led by Commander, Destroyer Squadron 24, departed Naval Station Norfolk Sept. 23 to participate in Exercise Joint Warrior 2009.
Joint Warrior is a multi-warfare exercise designed to improve interoperability between allied navies and prepare participating crews to conduct combined operations during deployments.
The exercise, which is scheduled to commence Oct. 5 - 23, promotes Commander, U.S. 2nd Fleet's three focus areas: conducting safe and effective fleet operations to achieve mission, providing ready maritime forces for global assignment, and teaming with allies and partners in execution of the maritime strategy.
Hall, Ramage, and Cole, along with ships from the Royal Navy, Canadian Forces, the Royal Danish Navy, the Brazilian Navy, and the Turkish Navy will be participating. The Royal Navy's HMS Illustrious (R 06), Northumberland (F 238), Portland (F 79), Bangor (M 109), Penzance (M 106), and Shoreham (M 112); the Canadian Force's ship HMCS Halifax (FFH 330), Montreal (FFH 336), Athabaskan (DDH 282), and Preserver (AOR 510); the Royal Danish Navy's HDMS Absalon (L 16); the Brazilian Navy's BNS Defensora (F 41); and the Turkish Navy's TCG Orucreis (F 245), will be divided into separate groups to represent fictional forces. Scenarios will include small boat attacks, exercise air defense, anti-submarine warfare, and boarding operations. Ships will be required to respond appropriately in order to accomplish their mission.
Дата: 27 Сен 2009 00:02:45
Дата: 27 Сен 2009 13:36:46
Убыли 23 сентября из Норфолк для участия в учении Joint Warrior 092.
USS Ramage (DDG 61)
USS Cole (DDG 67)
Планируют участие в учении:
Royal Navy:
Portland (F 79)
Bangor (M 109)
Penzance (M 106)
Shoreham (M 112)
Canadian Force's :
Montreal (FFH 336)
Preserver (AOR 510)
Royal Danish Navy:
HDMS Absalon (L 16)
Brazilian Navy:
Turkish Navy:
Дата: 29 Сен 2009 08:09:37
H4473/09 - EXER JOINT WARRIOR. UP TO 7 ACFT AND 4 HEL WILL OPR WI CARRIER
OPERATING AREA (CVOA) BOUNDED BY 5015N 00700W-5040N 00700W-5100N
00630W-5120N 00530W-5120N 00500W-5100N 00440W-5050N 00440W-5015N
00600W-5015N 00700W (BRISTOL CHANNEL). ACFT WILL REMAIN CLR OF
CONTROLLED AIRSPACE UNLESS CLEARED AND UNDER CTL OF THE APPROPRIATE
AUTHORITY. ACFT MAY NOT BE ABLE TO COMPLY WITH RAC.
CTC HMS ILLUSTRIOUS AIR OPS VIA WHITEHALL OPR 0207 218 9000.
AUS 09-10-0015/AS4. SFC - 5000FT AMSL, 29 SEP 07:00 2009 UNTIL 29 SEP 18:00
2009. CREATED: 28 SEP 12:30 2009
Дата: 29 Сен 2009 13:54:50
H4490/09 - EXER JOINT WARRIOR 092. LIVE FIRING FROM SURFACE VESSELS AGAINST
SURFACE AND AIR TOWED TARGETS WI AREA BOUNDED BY 5715N 00940W-5715N
00910W-5704N 00815W-5630N 00815W-5639N 00940W-ORIGIN (AREA J1). THIS
AREA DOES NOT COMMAND DANGER AREA STATUS HOWEVER ACFT ARE ADVISED
TO AVOID. CTC 01436 674321 EXT 4187/4006/4007.
AUS 09-10-0015/AS4. SFC - 55000FT AMSL, 06 0630-1000 1130-1500, 07 0530-0730
0830-1500, 09 1200-1330, 06 OCT 06:30 2009 UNTIL 09 OCT 13:30 2009. CREATED:
29 SEP 09:21 2009
H4489/09 - EXER JOINT WARRIOR 092. TARGET TOWING WI AREA BOUNDED BY 5642N
00815W-5610N 00654W-5544N 00654W-5636N 00904W-5630N 00815W-ORIGIN (J1
STREAM AND RECOVERY). CONTACT 01436 674321 EXT 4187/4006/4007.
AUS 09-10-0015/AS4. SFC - 19000FT AMSL, 06 0800-1030 1300-1530, 07 0800-1030,
09 1130-1400, 06 OCT 08:00 2009 UNTIL 09 OCT 14:00 2009. CREATED: 29 SEP 09:21
2009
H4488/09 - EXER JOINT WARRIOR 092. TARGET TOWING WI AREA BOUNDED BY 5905N
00500W-5915N 00500W-5907N 00410W-5835N 00410W-5835N 00430W-5900N
00430W-ORIGIN (J4/5 STREAM AND RECOVERY). CTC 01436 674321 EXT
4187/4006/4007. AUS 09-10-0015/AS4. SFC - 24000FT AMSL, 0800-1030 1300-1530,
08 OCT 08:00 2009 UNTIL 08 OCT 15:30 2009. CREATED: 29 SEP 09:17 2009
H4487/09 - EXER JOINT WARRIOR 092. LIVE FIRING FROM SURFACE VESSELS AGAINST
SURFACE AND AIR TOWED TARGETS WI AREA BOUNDED BY 5924N 00500W-5924N
00557W-5905N 00556W-5844N 00555W-5859N 00500W-ORIGIN (AREA J4/5).
THIS AREA DOES NOT COMMAND DANGER AREA STATUS HOWEVER ACFT ARE
ADVISED TO AVOID. CTC 01436 674321 EXT 4187/4006/4007.
AUS 09-10-0015/AS4. SFC - 55000FT AMSL, 0830-1000 1330-1500, 08 OCT 08:30 2009
UNTIL 08 OCT 15:00 2009. CREATED: 29 SEP 09:16 2009
H4484/09 - UP TO 7 ACFT AND 4 HEL WILL OPR WI CARRIER OPERATING AREA (CVOA)
BOUNDED BY 5200N 00530W-5303N 00530W-5303N 00453W-5250N 00453W-5233N
00412W-5220N 00412W-5206N 00450W-5200N 00530W (CARDIGAN BAY). ACFT
WILL REMAIN CLR OF CONTROLLED AIRSPACE UNLESS CLEARED AND UNDER CTL
OF THE APPROPRIATE AUTHORITY. ACFT MAY NOT BE ABLE TO COMPLY WITH
RAC. CONTACT HMS ILLUSTRIOUS AIR OPS VIA WHITEHALL OPR 0207 218
9000.AUS 09-10-0015/AS4. SFC - 5000FT AMSL, 30 SEP 07:00 2009 UNTIL 30 SEP 18:00
2009. CREATED: 29 SEP 08:32 2009
Дата: 30 Сен 2009 14:08:37
H4492/09 - EXER JOINT WARRIOR 092. INTENSE ACT WI AREA BOUNDED BY 5940N
00130W-5910N 00100W-5747N 00100W-5740N 00131W-5740N 00258W-5819N
00553W-5950N 00602W-ORIGIN FJA (FAST JET AREA) N.
LARGE FORMATIONS OF ACFT WILL CONDUCT HIGH ENERGY MANOUEVRES AND MAY
NOT BE ABLE TO COMPLY WITH RAC. ROUTINGS THROUGH THE UIR OF THIS
AREA MAY BE TACTICALLY AVBL ON REQUEST FROM SCOTTISH AIRWAYS OR
SHANWICK OCEANIC. CONTACT 01436 674321 EXT 4187/4006/4007.
AUS 09-10-0015/AS4. SFC - FL550, 05-09 12-16 0900-1130 1300-1630, 05 OCT 09:00
2009 UNTIL 16 OCT 16:30 2009. CREATED: 29 SEP 10:29 2009
H4491/09 - EXER JOINT WARRIOR 092. INTENSE AERIAL ACT WI AREA BOUNDED BY 5759N
00652W-5746N 00610W-5635N 00522W-5606N 00630W-5610N 00654W-5642N
00815W-5750N 00815W-ORIGIN (FAST JET AREA S). LARGE FORMATIONS OF
FAST JET ACFT WILL CONDUCT HIGH ENERGY MANOUEVRES AND MAY NOT BE
ABLE TO COMPLY WITH RAC. ROUTINGS THROUGH THE UIR OF THIS AREA MAY
BE TACTICALLY AVBL ON REQUEST FM SCOTTISH AIRWAYS OR SHANWICK
OCEANIC. CONTACT 01436 674321 EXT 4187/4006/4007. AUS 09-10-0015/AS4. SFC -
FL550, 05-09 12-16 0900-1130 1300-1630, 05 OCT 09:00 2009 UNTIL 16 OCT 16:30
2009. CREATED: 29 SEP 10:25 2009
Дата: 30 Сен 2009 14:09:11 · Поправил: magic (30 Сен 2009 14:14:02)
exercise Joint Warrior 09-2
Kinloss, UK 1x CP-140 CAF
1x ATL-2 FN
1x P-3C GN MFG3
1x P-3C RNoAF 333Skv
1x P-3C USN
Lossiemouth?,
UK + Hawk T1A RAF
+ Tornado GR4 RAF
+ Typhoon RAF
Дата: 30 Сен 2009 14:41:03
Дополнение
планируют участие в учении:
USNS LARAMIE (T-AO-203)
FS STYX (M614)
FS EMERAUDE (S602)
HMS TRAFALGAR (S107)
KNM TBA 2-Sub
Дата: 30 Сен 2009 16:46:33 · Поправил: Zesty67 (30 Сен 2009 16:47:34)
EXER Joint Warrior 092 is about to take place Oct. 5th - 23rd 2009. Данной заметки хватило бы,даже импортные споттеры не выкладывают в таких объёмах информацию резервирования, которая является служебной, несмотря на то что ПОКА находится в свободном доступе.
Извиняюсь за OFF TOP,
Дата: 30 Сен 2009 20:09:38
Чертовски верное замечание. Что имеем - не храним. Присоединяюсь к мнению Zesty67.
Дата: 01 Окт 2009 00:11:50
Zesty67
asv
Не понял в чем проблема?
Это не служебная информация - данные распространяются открыто - это предупреждения о закрытии районов на учения - они всегда будут доступны.
Дата: 01 Окт 2009 10:19:01
Это не служебная информация - данные распространяются открыто - это предупреждения о закрытии районов на учения - они всегда будут доступны. Данная информация предназначенна для ознакомления в первую очередь ПИЛОТАМ и НАВИГАЦИОННЫМ службам,как вы наверное знаете там проходят не только предупреждения о закрытии районов,но и другая специальная информация."Лавочка"пока открыта,но в любой момент всё может прикрыться,а случаи такие были.
Дата: 01 Окт 2009 12:15:17
Zesty67
Всё открыто. Если данной навигационной информации не будет то это война.
Собирается группировка кораблей, самолетов, проводят стрельбы (в том числе и ракетные) и всё это очень по-тихому ничего не сказав... Дальнейшие действия можно представить ...
Дата: 01 Окт 2009 13:57:55
Всё открыто. Если данной навигационной информации не будет то это война.Пока открыто,навигационные данные существовали и будут всегда,хоть в мирное время или войну, в настоящее время информация доступна широкому кругу людей не имеющих отношение к навигации,обращение к этой информации и её изучение пока не запрещенно и это радует,копировать и приводить на форуме служебную/ построение и форма данных сообщении является таковыми/ не стоит.
Дата: 01 Окт 2009 19:06:57
Дата: 02 Окт 2009 19:49:22
сегодня зашёл Канадец в Глазго, и Абсалон туда. Кто знает а где сейчас Трафальгар???
Дата: 02 Окт 2009 21:29:26
Дата: 03 Окт 2009 09:32:16
HMS Illustrious arrive in HM Naval Base Clyde from Friday, October 2.
Дата: 03 Окт 2009 09:33:21
2009-10-03 04:11:34 BST
54°59'53" N 5°29'47" W
Курс: 351°
Скорость: 27 km/h
Дата: 03 Окт 2009 12:08:10
02 октября прибыли в Глазго (King George V dock)
HMCS HALIFAX (330)
HMCS MONTREAL (336)
HMCS ATHABASKAN (282)
HMDS ABSALON (L16)
02 октября на якоре районе Гринок.
HMCS PRESERVER (510)
29 сентября прибыпи в Фаслейн
HMS Vanguard |
Дата: 03 Окт 2009 23:34:07
(не надо вводить в заблуждение, Вэнгард нет в Фаслейне, она НЕ ЗАХОДИЛА 29 числа!)
Уточнения про HMS Vanguard.
Ниже фотографии они были подписаны HMS Vanguard, возможно это не она - тогда кто?
Там же были и фотографии BNS Defensora - они заходили примерно в одно время.
Посмотрите, возможно кто-то узнает знакомую подводную лодку?
 Увеличить |
Дата: 03 Окт 2009 23:53:07
sibirjac
блин, читай на том сайте коменты к этим фоткам!!! так и быть вскрою карты.... Вэнгард пошла на смену, это именно она и ни кто друой, а вторая Скептр, куда пошла - не скажу! :-) а где ты встретил эти фотки???? думаю там же что и я ...... напиши в личку.
Дата: 04 Окт 2009 00:01:57
usamil
Вот всё и выяснилось - она выходила 29 сентября из Фаслейн.
Спасибо за уточнения. Посмотрел комментарии - всё правильно, был не внимателен.
HMS Vanguard Leaving Faslane Base.
HMS Sceptre Departs Faslane Naval Base.
Дата: 04 Окт 2009 11:15:29
Eight Harrier GR9s from the Naval Strike Wing, Two ASW Merlin from 814, Two Sea King ASAC from 854 and one Lynx helicopter embarked on to HMS Illustrious on Monday 28th September. The aircraft are onboard to take part in Exercise Joint Warrior 092, which is a UK wide, tri-service exercise that takes place between 5 - 23 October.
The aim of the Joint Warrior is to provide coordinated training for all 3 UK Armed Services and forces from allied nations. The Exercise includes participants from the UK and up to 10 Foreign Nations including Land participation from the RAF Regt, 18 surface and 3 sub-surface maritime units and approximately 50 aircraft.
Based on HMS Illustrious , the Commander UK Carrier Strike Group (COMUKCSG), Commodore Simon Ancona will lead a Task Group, consisting of 9 warships from differing countries, demonstrating the UK Carrier Strike Group (CSG) capability and utility.
Дата: 04 Окт 2009 11:45:54
02-Oct-2009 19:25:51
ZCZC OL*** FOSNNI SUBFACT* AND GUNF*CTS WARNING (ALL TIM*S UTC). *M DIVED SUBMARINE OPERATIONS*IN PROGRESS:* FIRTH OF CLYDE - INSIDE *ULL OF KINTYRE AND CORSEWALL POI*T. BETWEEN 030001 AND 030700 OCT. NORT* CHANN*L *A NORTH OF CALF OF MAN AND EAST OF*TI*E*. *BETWEE**02**YPP *ND 0*PUPP **T. SE* O* T*E HEBRID*S - WE*T O***IREE AND **UTH *F NEI*T*PO**T: **ET***P EWQUPR OR FASLANE OPERATION* PH*NE*(44) (0)1436 674321 *EXT 3206 CANCEL OL02 NNNN
Дата: 04 Окт 2009 16:04:17
о, вот и началось, наши участники начали разбегаться... ловим, ловим товарищи.... :-)
Дата: 05 Окт 2009 13:26:24
Радиосеть "Координации Линк 11/Линк 16"
Частота 4872 кГц, USB, ANDVT.
Позывные:
Blackadder -
F7H -
7ZP -
0UJ -
J5H -
T1J -
D6X -
L8O -
K3Z -
5OR -
0AA -
F7H - Blackadder ... K04 for program ...
F7H - Blackadder ... K07
F7H - Blackadder for alligator K08
F7H - Blackadder in voice K04
Blackadder - F7H check my CO on ... side
Blackadder - F7H ... Timber ....
Blackadder - F7H frequency 281.765
= ANDVT =
Blackadder - F7H my Timber is on ...
Blackadder - F7H my unit ASA
16.40
D6X - 7ZP interrogative Alligator HF
7ZP - D6X thet negative Timber only at this time
F7H - D6X from c/s 7ZP int. Alligator HF
16.55
T1J - F7H ...c/s D6X on task anyface ... on Timber
17.10
D6X - L8O pass toT1J request AEA on ASB PU nuco JW unuco in my window
21.44
T1J - F7H Alligator F14 Prelude PE01
F7H - T1J my PU 005
21.45
0AA - T1J Over
22.40
T1J -F7H confirm you conduct serial J05240
22.48
T1J - F7H confirm set watch for serial J05240 .... DTG 042214z oct09 ...0UJ ..set watch AC404E ... stand by my signal ...
23.58
T1J - F7H ... AC405U7
J5H - F7H c/s Tiger 1 Tiger 2
Дата: 05 Окт 2009 14:05:11
Zesty67
asv
NOTAMS:
H4597/09 - EXER JOINT WARRIOR. UP TO 7 ACFT AND 4 HEL WILL OPR WI CARRIER
OPERATING AREA (CVOA) BOUNDED BY 5530N 00730W-5620N 00730W-5620N
00620W-5600N 00620W-5530N 00645W-5530N 00730W (ISLAY/TIREE AREA).
ACFT WILL REMAIN CLR OF CONTROLLED AIRSPACE UNLESS CLEARED AND UNDER
CTL OF THE APPROPRIATE AUTHORITY. ACFT MAY NOT BE ABLE TO COMPLY
WITH RAC. CTC HMS ILLUSTRIOUS AIR OPS VIA WHITEHALL OPR 0207 218
9000. AUS 09-10-0015/AS4. SFC - 5000FT AMSL, 05 OCT 08:00 2009 UNTIL 05 OCT
23:59 2009. CREATED: 04 OCT 09:19 2009
http://euromon.blogspot.com/2009/09/preview-exercise-joint-warrior-092.html |
Дата: 05 Окт 2009 14:21:58
05-Oct-2009 03:24:40
ZCZC OA20 NAVAREA ONE 276 NORTH ATLANTIC AND WESTERN NORTH SEA. CHART BA 2. MAJOR NAVAL EXERCISE INVOLVING SHIPS, SUBMARINES AND AIRCRAFT WILL TAKE PLACE BETWEEN 050800 UTC AND 151500 UTC OCT 09 IN AREA BOUNDED BY ARDNAMURCHAN POINT 56-43N 006-14W, 56-00N 007-40W, 56-00N 012-00W, 61-00N 012-00W, 61-00N 000-00W, 55-00N 000-00W, 55-00N 001-25W,THE ENGLISH AND SCOTTISH COASTS ANTI-CLOCKWISE TO CAP* WRATH 58-38N 005-00W, THEN TO ARDNAMURCHAN POI*T. WARSHIPS MAY CONDUCT IDENTITY*CHALLENGES ON VHF*N MARINERS ARE REQUESTED TO CO-OPERATE. CANCEL THIS MESSAGE 151600 UTC OCT *POM NNNN
Дата: 05 Окт 2009 14:43:56
Радиосеть "JAAWSC CAOC 9"
Частота 4484 кГц, USB.
Позывные:
7ZP - предположительно ЦУО
F7H - корабль
Установление радиосвязи, проверка паролей, запрос у корабля: request duty intentions.
F7H - 7ZP ... look sector 180 west to 330 ....
F7H - 7ZP new Kilo ML006 MKKL 3741 heading 280
F7H - 7ZP request your PCS
16.30
F7H - 7ZP new anyface KH504 MKPL2139 heading 283 high 280
F7H - 7ZP my tactical JK546 MKPL3127 heading 135 high 280
18.10
F7H - 7ZP new zombi KL413 MKJL5102 heading 300 strength 2
18.15
F7H - 7ZP new zombi MK544 MKKL 0745 heading 340
F7H - 7ZP new zombi EA252 MKLL0825 heading 345
