Дата: 01 Дек 2011 00:28:45 · Поправил: Гонец (01 Дек 2011 00:30:06)
/** rief RF filter band 0 options */
static const COMBO_ITEM_STRUCT _cisRFFilter0[]=
{QT_TR_NOOP("268MHz LPF"),TRFE_LPF268MHZ},
{QT_TR_NOOP("299MHz LPF"),TRFE_LPF299MHZ},
{NULL,0}
/** rief RF filter band 1 options */
static const COMBO_ITEM_STRUCT _cisRFFilter1[]=
{QT_TR_NOOP("509MHz LPF"),TRFE_LPF509MHZ},
{QT_TR_NOOP("656MHz LPF"),TRFE_LPF656MHZ},
{NULL,0}
/** rief RF filter band 2 options */
static const COMBO_ITEM_STRUCT _cisRFFilter2[]=
{QT_TR_NOOP("360MHz BPF"),TRFE_BPF360MHZ},
{QT_TR_NOOP("380MHz BPF"),TRFE_BPF380MHZ},
{QT_TR_NOOP("405MHz BPF"),TRFE_BPF405MHZ},
{QT_TR_NOOP("425MHz BPF"),TRFE_BPF425MHZ},
{QT_TR_NOOP("450MHz BPF"),TRFE_BPF450MHZ},
{QT_TR_NOOP("475MHz BPF"),TRFE_BPF475MHZ},
{QT_TR_NOOP("505MHz BPF"),TRFE_BPF505MHZ},
{QT_TR_NOOP("540MHz BPF"),TRFE_BPF540MHZ},
{QT_TR_NOOP("575MHz BPF"),TRFE_BPF575MHZ},
{QT_TR_NOOP("615MHz BPF"),TRFE_BPF615MHZ},
{QT_TR_NOOP("670MHz BPF"),TRFE_BPF670MHZ},
{QT_TR_NOOP("720MHz BPF"),TRFE_BPF720MHZ},
{QT_TR_NOOP("760MHz BPF"),TRFE_BPF760MHZ},
{QT_TR_NOOP("840MHz BPF"),TRFE_BPF840MHZ},
{QT_TR_NOOP("890MHz BPF"),TRFE_BPF890MHZ},
{QT_TR_NOOP("970MHz BPF"),TRFE_BPF970MHZ},
{NULL,0}
/** rief RF filter band 3 options */
static const COMBO_ITEM_STRUCT _cisRFFilter3[]=
{QT_TR_NOOP("1300MHz BPF"),TRFE_BPF1300MHZ},
{QT_TR_NOOP("1320MHz BPF"),TRFE_BPF1320MHZ},
{QT_TR_NOOP("1360MHz BPF"),TRFE_BPF1360MHZ},
{QT_TR_NOOP("1410MHz BPF"),TRFE_BPF1410MHZ},
{QT_TR_NOOP("1445MHz BPF"),TRFE_BPF1445MHZ},
{QT_TR_NOOP("1460MHz BPF"),TRFE_BPF1460MHZ},
{QT_TR_NOOP("1490MHz BPF"),TRFE_BPF1490MHZ},
{QT_TR_NOOP("1530MHz BPF"),TRFE_BPF1530MHZ},
{QT_TR_NOOP("1560MHz BPF"),TRFE_BPF1560MHZ},
{QT_TR_NOOP("1590MHz BPF"),TRFE_BPF1590MHZ},
{QT_TR_NOOP("1640MHz BPF"),TRFE_BPF1640MHZ},
{QT_TR_NOOP("1660MHz BPF"),TRFE_BPF1660MHZ},
{QT_TR_NOOP("1680MHz BPF"),TRFE_BPF1680MHZ},
{QT_TR_NOOP("1700MHz BPF"),TRFE_BPF1700MHZ},
{QT_TR_NOOP("1720MHz BPF"),TRFE_BPF1720MHZ},
{QT_TR_NOOP("1750MHz BPF"),TRFE_BPF1750MHZ},
{NULL,0}
Кусок взят отсюда https://github.com/csete/qthid/blob/newctl/mainwindow.cpp#L65 |
Дата: 01 Дек 2011 00:40:04
vova_sam
У меня такое ощущение, что программа отправляет команду на настройку частоты с каким-то особым масштабом сетки частот. Причем этот масштаб отличается от базового в HDSDR.
HDSDR отправляет частоту через свою DLL ExtIO_FCD_G0MJW.dll, которую вы должны были положить в папку с программой HDSDR. В ней настройка на частоту своя, ее можно увидеть, нажав на extIO - далее, в выпадающем окне ставим галочку expert и смотрим, что там в поле Frequency offsets.
У меня 0 kHz и -24 ppm
После внесения изменений и проверки надо делать File / Save default
Иначе при последующем запуске значения сбросятся к предыдущим.
Другие программы могут работать совсем не через ExtIO_FCD_G0MJW.dll
Например, через родную Windows fully functional front end (fchid.exe)
В ней точная настройка на частоту идет в окне Frequency correction и мои -24 ppm соответствуют значению 999977 если память не изменяет.
Дата: 01 Дек 2011 00:53:23
Гонец
Хе. Что только с этим делать дальше....
Дата: 01 Дек 2011 10:08:18
john_qkk, был вопрос про BPF, в листинге программы есть частоты.
Дата: 01 Дек 2011 11:22:57 · Поправил: vova_sam (01 Дек 2011 11:23:40)
друзья,
я имел ввиду не точность настройки частоты, а то, что при управлении из HDSDR частоты с разницей 25 кГц находятся в разных частях линейки частот на экране
а при работе Funsearch они находятся непосредственно рядом. так что окно Tune шириною в 12 кГц захватывает и частоту, которая на 25 кгц отличается, чего быть конечно не может.
я первый раз когда включить Funsearch то удивился, что какая то новая частота рядом активизировалась. А оказалось, что она давно известна, но в другом месте была.
DVE, я без претензий, не обижайтесь. В любом случае спасибо за утилиту. Я ее постоянно использую, поэтому просто разобраться хочу.
Дата: 01 Дек 2011 11:51:36 · Поправил: DVE (01 Дек 2011 12:06:14)
Я и не обижаюсь, просто констатирую факт что в дальнейшей доработке программы поиска не вижу смысла. Публиковать у себя на сайте Говард отказался, делать программу платной нецелесообразно, ну и после приобретения 396xt проблема поиска сигналов отпала сама собой :)
А погрешность выставления частоты есть, хз почему, также показалось что частота слегка плывет после прогрева Куба при включении, тут я подробно не разбирался, т.к. опять-таки повторюсь что на практике не мешает.
Про Funsearch кстати напомню еще раз, что HDSDR вообще не подхватывает изменение частоты Куба извне, так что отображение частоты в HDSDR при запуске Funsearch и не будет соответствовать действительности.
Дата: 01 Дек 2011 13:50:05
Кстати. Может уже обсждали, тогда пардон.
Это клон
FUNcube ? |
Дата: 01 Дек 2011 16:46:31
Гонец
Ну понятно, это список выпадающих менюшек, которые я уже ранее описал. Спасибо за ссылку на живые исходники.
Ответил мне спец из Элоникса, пишет, что на VHF могут только lowpass LC фильтр. Да и параметры не очень. То есть FunCube и так выжали из чипа что можно было...
Дата: 01 Дек 2011 19:00:21
да, на авиа вообще глухой. Icom R5 просто гремит там, где FCD видит немного несущую. жалко
Дата: 01 Дек 2011 20:37:40
От цэ о чем я и говорил!!!
Дата: 01 Дек 2011 20:39:26
Есть ли возможность сконфигурить вход так что бы все БПЛП были отключены, а LNA включены?
Дата: 02 Дек 2011 01:49:02
RK6AJE
Фильтры есть только те, что я описал.
Отключать совсем нельзя. Можно только переключаться между 16 фильтрами в каждом из 4 диапазонов.
При этом в 2-х VHF диапазонах 16 вырождены в всего 2 LPF на каждом из диапазонов.
Дата: 02 Дек 2011 02:12:55
450-460-433 принимает шикарно. Двойку слышит. Места не занимает.
К авиа особых претензий нет, не хуже VX-1r. Проверил на одну и ту же антенну.
Сатком на водопаде видно и слышно вполне. Ладно, оставлю пока. Пригодится еще спектры смотреть. Да и управление с компьютера радует. Опять же, есть программа для отслеживания спутников по Доплеру.
Дата: 02 Дек 2011 12:35:50
vova_sam
Странно,что у Вас на авиа тишина. У меня все борты "звенят" на 59.
Правда, я в Домодедово....
Дата: 02 Дек 2011 12:38:44 · Поправил: Влад К (02 Дек 2011 12:40:19)
john_qkk
Солидарен по всем пунктам! Мониторинг спутников, МКС на 5!Спутник "КЕДР" писал на нем: SSTV,телеметрия,голос- все великолепно.
На двойке даже DX (если их так можно назвать) проходят, с юга Москвы великолепно слышно Тулу,Калугу.
Доплер на SAT- вещь!
Дата: 02 Дек 2011 12:45:18
Походу какая то партия бракована, или с антеннами траблы?
Дата: 02 Дек 2011 14:10:36
Ховард говорит что проверяет перед отправкой чутье.
Двойку слышит
двойку и правда слышит. Но вопрос про авиа.
Влад К
вы слышите Домодедово или борта нак контролях? скажем 122.7 борта слышите?
ну с другой стороны конкретно в моем случае итак ясно, что авиа он не ловит.
Дата: 02 Дек 2011 15:20:44
Если жить у аэропорта, да еще антенна внешний дисконус, то наверно "звенеть" будет :)
Дата: 03 Дек 2011 00:00:19 · Поправил: Влад К (03 Дек 2011 00:03:38)
vova_sam
И Домодедово (естественно! :-)), и борта. Вот сейчас специально включил-набрал 127.7: идет интенсивный обмен "Москва-подход"-борта №№№. Проходят команды на снижение, набор эшелонов и т.д.
DVE
Не понятен Ваш сарказм...
И вообще, ребята, Вы тут обсуждаете железку за 5 тыр. и хотите от нее ТТХ аппарата за 5 тыс. УЁ. Не странно ли? Для своей цены- аппарат отменный во всех отношениях!Использую с начала года. не разу не разочаровался.
Дата: 03 Дек 2011 00:33:52
Да никакого сарказма, просто действительно получается что ниже 200МГц аппарат туповат, и на авиа прием не очень. Если жить у аэропорта, то это наверно и незаметно :)
Другой вопрос что цену свою он отрабатывает на 100%, это да.
Дата: 03 Дек 2011 10:04:54
DVE
Ну почему туповат? Я спутниковую телеметрию снимаю без вопросов ("КЕДР"). Спокойно по дисплею вручную корректировал Доплер, когда не было программы SatControl. SSTV без проблем. Маяки спутниковые принимаются не намного хуже, чем AR-3000. Радует наличие возможности аудиофиксации с последующим сканированием выбранного участка диапазона.
Да, требует настроек, да, есть куча недостатков , да, иногда зависает... Но еще раз повторю, что на сегодня - это лучшее компактное изделие для любительского использования. (Мое субъективное мнение)
Дата: 03 Дек 2011 10:12:27
И,еще, как любой нормальный радиоприемник, требует нормальную антенну.
Не жалейте средств на кабель при стационароном использовании,и будет вам счастье.
Если в носимом варианте, тоже возьмите что-нибудь приличное, а не кусок проволоки...
Извините за прописные истины!
Дата: 09 Дек 2011 23:23:07
На 144 -145 МГц полная глухота. Как вы думаете, почему так может быть.
на 433 - 450 вроде ничего.
Дата: 10 Дек 2011 15:17:29 · Поправил: DVE (10 Дек 2011 15:22:09)
Ну не то чтобы полностью глухой, но скажем так, не очень слышащий :)))
Вот только что проверил: 148.3, Uniden орет на весь динамик, Funcube звука нет, видна лишь такая несущая:
![](http://www.radioscanner.ru/uploader/2011/148300khz.gif) Увеличить
Антенны примерно одинаковые.
433 действительно лучше. |
Дата: 10 Дек 2011 15:21:11
DVE
спасибо. значит так сделан.
Дата: 10 Дек 2011 20:37:47
Не догоняю , чего-то я. Неужели ни у кого из имеющих сабж нет простейцшего ГСС, что бы проверить чувствительность на разных диапазонах. 6000р нашли на сабж, а простенького Г4-116 за 1000р не купить?
Дата: 10 Дек 2011 21:31:58
Продаете рабочий за 1000р? Уже иду.
Дата: 10 Дек 2011 21:37:22
Дата: 10 Дек 2011 23:25:39
Да как два пальца :) 74тыс за новый, 24тыс за 95го года выпуска, делов-то :)
http://www.printsip.ru/cgi/shop/item/G4-116
Да и как бы дома не сильно нужный прибор имхо.
Я могу разве что с VX-6R сравнить, если взять ее за эталон :) |
Дата: 11 Дек 2011 01:30:36
DVE
Ну так вопрос как раз к ats52 адресован. Вот жду, когда же он мне рабочий Г4-116 за 1000 р. отгрузит. Весь извелся уже.
