На сайте: гостей - 65,
участников - 3 [ ew2abc, Хайо, Quinta]
 Форум —› Главный раздел —› А мы и не знали Molotora® Gontor®
Hytera TC-320
Hytera TC-508
Hytera TC-580
Hytera PD-355
Hytera X1E
Хеликоптер
с фев 2006
Дата: 16 Янв 2011 16:33:08 #
Во какое чудо в 1940 году немцы разработали....
http://www.repeater-builder.com/molotora/gontor/molotora.gif
I've known of this old radio for quite a while and decided today is a good time to describe it to the radio community.
General Specifications:
The Molotora Gontor is based on the proprietary Gonculator device that was first developed in Germany in the mid-1940s. It's a low-power radio (under 100 watts) that covers all frequencies you'd ever want to use it on, even mirror image, negative, and imaginary / complex frequencies. Type-accepted and type-approved cognitive recognition techniques allow it to demodulate all signals on all frequencies. Its built-in variometer allows it to use any conductive material as an antenna, from full-length steel towers to wet, salty egg noodles. The radio also includes highly accurate wattmeter that can measure forward, reflected, inner-conductor, outer-conductor, incidental, and re-radiated power. It will even measure power of other transmitters up to 30 feet away. The TBQ antenna connector will readily accept any size coax from RG174 to 6 inch hard-line. The radio's cover is held in place by several triple-bitted, five-sided locks, each keyed differently, one on each corner, assuring the ultimate in security. The radio can be trunk, dash, or console mounted, duct-taped under an airplane, or easily held in two hands.
But wait, there's more! If you read this within the next 10 minutes, we'll double your fun! The Gontor can even be used as a stand-alone repeater. It has a built-in Vari-gain, hybrid ring-tone, auto-tuning duplexer, based on the international Gld / Slvr / Brnz medallion technology. This allows it to handle any split or offset and still provide over 200dB isolation, making it ideal for law enforcement and public safety triplex operation. All voice transmissions made by users will be heard by anyone within earshot.
Transmitter and Receiver Capabilities:
It has the ability to simultaneously do Amplitude Modulation (AM) up to +/- 150% symmetrical or asymmetrical depth, single, double, and triple sideband with suppressed or reduced carrier, Frequency Modulation (FM) up to +/- 200 kHz deviation, and even Phase Modulation (PM) so it's compatible with all existing one-way, two-way, and three-way radio equipment made by GE, Motorola, Yaesu, Kenwood, Johnson, Icon, Alinco, etc. Privacy-Plus, SecureNet, Trunking, LTR, ZOWIE, APCO, P25, SPECTRE, and secure 512-bit encryption protocols are fully supported, however the radio is not certified for use outside this country, due to the Remulak zurls and other software patents. CW is sent with true carrier on/off (high-voltage) switching, and a spark-gap filter removes all chirp and other desirable signals. A Variolosser circuit maintains the level under all conditions.
The frequency response of both the transmitter and receiver is 0.1 Hz to 100 kHz, so it can easily handle sub-audible (PL, CTCSS, DPL, or DCS) coding schemes as well as audible tone signaling (DTMF, tone-burst, noise-burst, etc). It can even encode and decode any and all of these simultaneously. The built-in DTMF decoder handles all 17 possible two-tone digits. It can also handle pulse dialing and SELCAL decoding at up to 100 Baud. A seven-speed Borg-Warmer transmission handles Baudot and ASCII data formats. Tall, blond, and handsome audio inputs are provided for easy wireless-line integration into any existing communications system. A GPS-disciplined, micro-miniature, cesium beam master oscillator insures the radio will be on any frequency at all times. The patented Merkeljammer circuit uses PermaQuay filters to remove all pulse-type noise interference picked up by the receiver. A heuristic audio filter will even mute the audio and retune the receiver to something better, when unintelligent signals are encountered.
Reproductive Devices:
The built-in three-way speaker faces forward and easily reproduces everything the receiver can hear, including noise and all variations of repeater courtesy tones, beeps, grunts, twangs, burps, etc. The rare-earth, liquefied, natural unobtanium microphone will pick up all noises coming from your body. It has a built-in "release-to-listen" button that doesn't violate the often-duplicated and patented "Push-To-Talk" system, allowing royalty-free use of every bit of electromagnetic spectrum. That well-known German scientist, Dr. Ruth Westheimer, seductively designed these two devices for maximum pleasure and enjoyment from your QSO partner. The neon-colored "Magic-Eye" tuning indicator automatically displays receive and transmit audio levels, and can be configured to display slow-scan, fast-scan, analog, or digital video signals. The MPEG5000 decoder can handle no-def, high-def, noun, verb, and synonym signals. A separate satellite receiving antenna (with down-converter) and universal decoder can also be attached. I have also heard rumors about a universal translator option (SP-UFP), but I have no idea why anyone would need that in this day and age.
Miscellaneous Details and Features:
The rear-panel display uses 9-character nixie tubes (the digits 6 and 9 use the same pattern but are shown in complementary colors). The front panel is ergonomically designed and each of the unlabeled buttons activates a random function. This ensures maximum enjoyment out of the radio. The user manual, when it was available, cost a mere $3,500AU. It is, unfortunately, no longer available. I could post a PDF copy, but it's a big file, nearly 100TB, so you'll need a high-speed sub-space connection to even think about downloading it.
An optional packet and expedition cluster detector is available. It will display the transmit, intermediate, and receive frequencies of all distant contest stations. APRS is automatically provided with the radio's exact location thanks to the built-in GPS receiver. The user's call sign is automatically recognized and included in every location report.
Standard DC and tone remote control is built in, using twist-lock XLR connectors, arranged in an aneroid pattern. There's even a phone patch with a comprehensive feedback and echo elimination system and an automatic "under" detector.
Programming and Power Options:
The radio is programmed using a Teletype Model 15 (Baudot) machine with a 130V, 60mA current loop interface, however only the numbers 2 through 9 are accepted for frequency input. Ordinary HTML codes are used, so you don't need to steal proprietary programming software or even obtain an RSS license, which is necessary for some other radios. Just like your luggage, the combination 12345 must be entered as the device access code. The programming data is stored in a Signetics 25120 EEPWOM chip. See the 80kB PDF file data sheet here. Unlike most of the Japanese radios that limit your labels to perhaps eight characters, you can label each channel in the Gontor by using up to 99.4% of available memory. An easily replaced 67V "B" battery provides memory retention for the life of the battery or the original owner, whichever expires last. An optional 22.5V "C" battery provides bias for those users who like to have a lot of political conversations. A built-in 33VDC voltage-doubling, electron-coupled (no ground required) power converter allows vehicular operation. This is far more universal than the railroad radios ever offered.
A Jedi-compatible accessory connector can be configured to charge a second-generation light epee, ensuring that darkons are eliminated from nearby fluorescent tubes.
Alternator and power line noise is completely eliminated by a 4.7 Faraday shielded, water-soluble flux capacitor. This is coupled to the audio circuit's Eustachian tubes for maximum intelligence.
I'd love to provide a better photo but every time I try to take one using the camera's flash, the radio changes color and the front panel lettering moves around.
Credits and Acknowledgements:
Molotora, Gontor, PL, DPL, and a bunch of other terms might be trademarks of their respective companies. They have been used without permission. Do you think I really care about copyrights?
This radio was eventually used as the basis for the Gonset Communicator and the Motorola Syntor.
The Motorola logo is commonly called a batwing. The Molotora logo can therefore be officially called a dingbat. Bats do hang upside down in caves and belfrys. Belfrys have bells. Bells go ding. QED.
This article has been carefully checked for spelling and grammatical errors. There are none. If you think you found a mistake, just keep reading it until it makes sense. Just like Microsoft technical support, everything stated herein is absolutely correct but completely useless.
The United States Department of Extreme Mismanagement and Homeland Insecurity and the Federal Candy Company approved the release of this information.
Гагарин
KO50
Дата: 16 Янв 2011 17:31:41 #
Хеликоптер
Здесь не форум "полиглотов". Переведите хоть вкратце, текст, что Вас удивил...
Codru
с янв 2011
Кишинев
Дата: 16 Янв 2011 21:05:53 #
Я тоже не полиглот, но там скорее всего об истории развития Моторолы с 40-х и до наших дней.
valevy
KO85RQМосква 145.625 RN3AVW
Дата: 16 Янв 2011 22:08:38 #
Так не Моторолы-же, а Молоторы! Просто похожее название.
Sashman
р'Льех
Дата: 16 Янв 2011 22:30:45 #
Гагарин
Вы ничего не потеряли. В тексте - типа юморное пародийное описание мифической радио-шарманки с 100500 выдуманных функций и опций.
ТС мог бы и подождать до 20110401:)
sicambrA
с мар 2010
LP04
Дата: 16 Янв 2011 22:34:15 #
Это все придумал Черчилль в восемнадцатом году! В клуб господа! До апреля ещё долго. )
Дата: 16 Янв 2011 22:37:28 #
Переводчик похоже ещё своих приколов добавил, читать это очень напрягает мозги :)
Я знал об этом старом радио долгое время и решил, сегодня хорошее время, чтобы описать это радио-сообществу.
Общие Технические требования:
Molotora Gontor основан на составляющем собственность устройстве Gonculator, которое было сначала развито в Германии в середине 1940-ых. Это - радио низкой власти (менее чем 100 ватт), который покрывает все частоты, Вы когда-либо хотели бы использовать это на, даже зеркальное отображение, отрицательное, и воображаемый / сложные частоты. Принятые типом и одобренные типом познавательные методы признания позволяют этому демодулировать все сигналы на всех частотах. Его встроенный вариометр позволяет этому использовать любой проводящий материал в качестве антенны, от стальных башен во всю длину до влажной, соленой лапши яйца. Радио также включает очень точный wattmeter, который может иметь размеры вперед, отраженный, внутренний проводник, внешний проводник, эпизод, и повторно излученная власть. Это даже измерит власть других передатчиков на расстоянии в 30 футов. Соединитель антенны TBQ с готовностью признает, что любой размер уговаривает от RG174 до бескомпромиссных 6 дюймов. Покрытие радио проводится в месте несколькими тройными-bitted, пятисторонними замками, каждый включенный по-другому, один на каждом углу, гарантируя окончательное в безопасности. Радио может быть стволом, чертой, или пультом, установленным, записанным на пленку трубочкой под самолетом, или легко проводимый в двух руках.
Но ждите, есть больше! Если Вы прочитаете это в течение следующих 10 минут, то мы удвоим Вашу забаву! Gontor может даже использоваться в качестве автономного ретранслятора. У этого есть встроенная Vari-выгода, гибридная музыка для мобильного телефона, автонастраиваясь duplexer, основанный на международном Gld / Slvr / технология медальона Brnz. Это позволяет этому обращаться с любым расколом или возмещать и все еще обеспечивать изоляцию на более чем 200 децибелов, делая это идеал для проведения законов в жизнь и операции по триплексу государственной безопасности. Все голосовые передачи, сделанные пользователями, услышит любой в пределах слышимости.
Передатчик и Способности Приемника:
У этого есть способность одновременно сделать AM Модуляции Амплитуды до +/-150%-ая симметрическая или асимметричная глубина, единственный, дважды, и тройная боковая полоса с подавленной или уменьшенной авиакомпанией, Модуляция Частоты (FM) до +/-отклонение на 200 кГц, и даже Модуляция Фазы (ПОПОЛУДНИ), таким образом, это совместимо со всеми существующее одностороннее, двухстороннее, и радиооборудование с тремя путями, сделанное Дженерал Электрик, Моторолой, Yaesu, Кенвуд, Джонсоном, Символом, Alinco, и т.д. Частная жизнь - Плюс, SecureNet, Trunking, БУКВА, ЗОВИ, APCO, P25, ПРИЗРАК, и безопасные 512-битовые протоколы шифрования полностью поддержана, однако радио не удостоверено для использования вне этой страны, из-за Remulak zurls и других патентов программного обеспечения. ПО ЧАСОВОЙ СТРЕЛКЕ послан с истинной авиакомпанией вклвыкл (высокое напряжение) переключение, и фильтр промежутка искры удаляет весь щебет и другие желательные сигналы. Кругооборот Variolosser поддерживает уровень при всех условиях.
Частотная характеристика и передатчика и приемника составляет 0.1 гц к 100 кГц, таким образом, это может легко обращаться инфразвуковой (МН, CTCSS, DPL, или DCS) кодирование схем так же как слышимая передача сигналов тона (DTMF, разорванный тоном, разорванный шумом, и т.д.). Это может даже закодировать и расшифровать любого и все их одновременно. Встроенный декодер DTMF обращается со всеми 17 возможными двухцветными цифрами. Это может также обращаться с импульсным набором и SELCAL, расшифровывающим в 100 бодах. Borg-более-теплая передача с семью скоростями обращается с форматами данных Baudot и ASCII. Высокие, светлые, и солидные звуковые входы обеспечены для легкой интеграции беспроводной линии в любые существующие коммуникационные системы. GPS-дисциплинированный, микроминиатюрный, генератор владельца луча цезия гарантирует, что радио будет на любой частоте всегда. Запатентованный кругооборот Merkeljammer использует фильтры PermaQuay, чтобы удалить все вмешательство шума типа пульса, поднятое приемником. Эвристический аудио фильтр даже приглушит аудио и повторно настроит приемник на что-то лучше, когда с невежественными сигналами столкнутся.
Репродуктивные Устройства:
Встроенные стороны спикера с тремя путями отправляют, и легко воспроизводит все, что приемник может услышать, включая шум и все изменения тонов любезности ретранслятора, звуковые сигналы, пехотинцев, протяжные звуки, отрыжки, и т.д. Редкая земля, сжижаемый, естественный unobtanium микрофон поднимет все шумы, прибывающие из Вашего тела. У этого есть встроенная кнопка "выпуск, чтобы слушать", который не нарушает часто дублированную и запатентованную систему "Толчка к разговору", позволяя единожды оплачиваемое использование каждой части электромагнитного спектра. Тот известный немецкий ученый, доктор Рут Весзэимер, обольстительно проектировал эти два устройства для максимального удовольствия и удовольствия от Вашего партнера по QSO. Настраивающий индикатор Неонового цвета "волшебно-глазной" автоматически показывает, получают и передают аудио уровни, и может формироваться, чтобы показать медленный просмотр, быстрый просмотр, аналог, или цифровые видео сигналы. Декодер MPEG5000 может обращаться без определений, высокое определение, существительное, глагол, и сигналы синонима. Отдельная антенна получения спутника (с вниз-конвертером) и универсальный декодер может также быть приложена. Я также услышал слухи об универсальном выборе переводчика (ИСПАНИЯ-UFP), но я понятия не имею, почему любой нуждался бы в этом в этот день и возрасте.
Разные Детали и Особенности:
Показ задней панели использует 9-символьные nixie трубы (цифры 6 и 9 используют тот же самый образец, но показаны в дополнительных цветах). Передняя группа эргономически разработана, и каждая из немаркированных кнопок активизирует случайную функцию. Это гарантирует максимальное удовольствие из радио. Пользовательское руководство, когда это было доступно, стоило простого AU за 3 500$. Это больше не, к сожалению, доступно. Я мог отправить копию PDF, но это - большой файл, почти 100TB, таким образом, Вы будете нуждаться в быстродействующей подкосмической связи, чтобы даже думать о загрузке этого.
Дополнительный датчик группы пакета и экспедиции доступен. Это покажет передавание, промежуточное звено, и получит частоты всех отдаленных станций соревнования. APRS автоматически предоставляют точное местоположение радио благодаря встроенному приемнику GPS. Позывной пользователя автоматически признан и включен в каждый отчет о местоположении.
Стандартное дистанционное управление DC и тона встроено, используя замок завихрения соединители XLR, устроенные в анероидном образце. Есть даже телефонный участок со всесторонней обратной связью и системой устранения эха и автоматическим "под" датчиком.
Программирование и Электропитание:
Радио запрограммировано, используя Модель 15 Телетайпа (Baudot) машина с 130V, 60mA текущий интерфейс петли, однако только номера 2 - 9 приняты для входа частоты. Обычные HTML коды используются, таким образом, Вы не должны украсть составляющее собственность программное программное обеспечение или даже получить лицензию RSS, которая необходима для некоторых других радио. Точно так же как Ваш багаж комбинация 12345 должна быть введена как код доступа устройства. Программные данные хранятся в Signetics 25120 чипов EEPWOM. См. 80 КБ технические спецификации файла PDF здесь. В отличие от большинства японских радио, которые ограничивают Ваши лейблы, возможно, восемью характерами, Вы можете маркировать каждый канал в Gontor при использовании 99.4 % доступной памяти. Легко замененный 67V "B" батарея обеспечивает задержание памяти для жизни батареи или первоначального владельца, какой бы ни истекает последний. Дополнительное 22.5V "C" батарея предоставляет уклон тем пользователям, которым нравится иметь много политических бесед. Встроенное 33VDC удвоение напряжения, соединенное с электроном (никакая требуемая земля) конвертер власти, позволяет vehicular операцию. Это намного более универсально чем радио железной дороги, когда-либо предлагаемые.
Совместимый с джедаем дополнительный соединитель может формироваться, чтобы зарядить шпагу света второго поколения, гарантируя, что darkons устранены из соседних флуоресцентных труб.
Шум генератора переменного тока и линии электропередачи полностью устранен 4.7 Фарадеями огражденный, растворимый в воде конденсатор потока. Это соединено с трубами Eustachian аудио кругооборота для максимальной разведки.
Я хотел бы обеспечить лучшую фотографию, но каждый раз, когда я пытаюсь взять тот, используя вспышку камеры, радио-цвет изменений и передняя групповая надпись перемещаются.
Кредиты и Подтверждения:
Molotora, Gontor, МН, DPL, и связка других сроков, могли бы быть торговыми марками их соответствующих компаний. Они использовались без разрешения. Вы думаете, что я действительно забочусь об авторских правах?
Это радио в конечном счете использовалось в качестве основания для Коммуникатора Gonset и Моторолы Syntor.
Эмблему Моторолы обычно называют крылом летучей мыши. Эмблему Molotora можно поэтому официально назвать болваном. Летучие мыши действительно висят вверх тормашками в пещерах и belfrys. У Belfrys есть колокола. Колокола идут звон. ЧТО И ТРЕБОВАЛОСЬ ДОКАЗАТЬ.
Эта статья была тщательно проверена на правописание и грамматические ошибки. Нет ни одного. Если Вы думаете, что нашли ошибку, только продолжайте читать это, пока это не имеет смысл. Точно так же как техническая поддержка Microsoft все заявило, здесь абсолютно правильно, но абсолютно бесполезен.
Отдел Соединенных Штатов Чрезвычайной Ненадежности Неумелого руководства и Родины и Federal Candy Company одобрили выпуск этой информации.
