Районы учений
![](http://www.radioscanner.ru/uploader/2011/areanm2011.jpg)
"NOBLE MARINER 11" exercise.
1. GENERAL
"NOBLE MARINER 11" exercise will take place from 28th February
to 10th March 2011 within Madrid and Barcelona
FIR/UIR, affecting the following areas and corridors.
The activation and deactivation of these areas and corridors
will be carried out by means of tactical coordination between
airspace control elements involved. All hours will be UTC.
2. RESERVED AREAS
AREA GATA
Lateral Limits: 365200N 0013000W, 365200N 0004600W,
362600N 0020400W, 363012N 0021834W,
363725N 0021244W, 365200N 0013000W.
Vertical Limits: SFC to FL100.
Dates and Times: 28 FEB from 1200 to 2359.
01 MAR - 06 MAR from 0001 to 2359.
Note: For higher level up to FL240, in tactical coordination
with ECAO Sevilla.
R-63SW
Lateral Limits: 365100N 0014000W, 365100N 0015000W,
370700N 0021000W, 370700N 0023200W,
372800N 0032100W, 381125N 0022439W,
372536N 0014936W, 370819N 0013016, from
this point along a parallel line 12 NM away
from the coast line up to 365100N 0014000W.
Vertical Limits: GND/SFC to FL240.
Dates and Times: 28 FEB from 1230 to 1500.
01 MAR from 0900 to 1100 and from 1600 to 1800.
02 MAR from 1000 to 1200 and from 1500 to 1600.
03 MAR from 0001 to 1000 and from 1800 to 2000.
04 MAR from 0900 to 1100 and from 1200 to 1600.
05 MAR -06 MAR from 0900 to 1100.
Note: For higher level up to FL280 in tactical coordination with
ECAO Sevilla.
MURIANO
Lateral Limits: Circular area of 15 NM radius centered on
380953N 0043802W.
Vertical Limits: 6000 ft AMSL to FL150.
Dates and Times: 09 MAR from 1000 to 1200.
10 MAR from 1000 to 1200.
LED-1 CERRO MURIANO (Córdoba)
Lateral Limits: 380400N 0045100W, 380500N 0044800W,
380300N 0044200W, 380000N 0044600W,
380400N 0045100W (AIP-ESPAÑA).
Vertical Limits: GND to FL180.
Dates and Times: 09 MAR - 10 MAR from 1000 to 1200.
LED-22 MAZARRÓN
Lateral Limits: 371300N 0011500W, 371300N 0004500W,
365600N 0004500W, 365600N 0011500W,
371300N 0011500W (AIP-ESPAÑA).
Vertical Limits: SFC to FL200.
Dates and Times: 01 MAR - 04 MAR from 0001 to 2359.
05 MAR - 06 MAR from 0001 to 0700.
Vertical Limits: SFC to FL300.
04 MAR - 05 MAR from 0700 to 2359.
ALMERÍA NORTE
Lateral Limits: 370700N 0023000W, 370700N 0021720W,
365820N 0021959W, 370115N 0022228W,
365354N 0022548W, 370000N 0023000W,
370700N 0023000W.
Vertical Limits: 2000ft AMSL to FL130.
Note: For higher level in tactical coordination with ECAO Sevilla.
Dates and Times: 01 MAR from 1300 to 1400 and from 1800
to 2000.
02 MAR from 1500 to 1600.
03 MAR from 0900 to 1000.
04 MAR from 1200 to 1600.
05 MAR from 0900 to 1000.
Note: The star/end of the activity in the area, will be carried
out by means of tactical coordination with Almeria TWR in
real-time.
LED-36 ÁLVAREZ SOTOMAYOR (Almería)
Lateral Limits: 370116N 0022229W; 365812N 0021955W;
365305N 0022149W; 365235N 0022316W;
365350N 0022547W; 370116N 0022229W
(AIP-ESPAÑA).
Vertical Limits: GND to FL130.
to 2000.
real-time.
D-97B
Lateral Limits: 373000N 0003110W, 373000N 0002327W,
365100N 0002400W, 365100N 0014000W
from this point along a parallel line 12 NM
away from the coast line up to 373000N
0003110W.
LED-90A GOLFO DE CÁDIZ
Lateral Limits: 362600N 0063500W, 362720N 0063254W,
355847N 0062149W, 355847N 0064100W,
362600N 0063500W (AIP-ESPAÑA).
Vertical Limits: SEA to FL280.
Dates and Times: 07 MAR - 10 MAR from 0001 to 2359.
LED-90B GOLFO DE CÁDIZ
Lateral Limits: 355847N 0062149W, 361338N 0062734W,
362735N 0061455W, 355847N 0062149W
(AIP-ESPAÑA).
Vertical Limits: SEA/GND to FL280.
LED-90C GOLFO DE CÁDIZ
Lateral Limits: 362720N 0063254W, 362900N 0063000W,
362904N 0062511W, 362735N 0061455W,
361338N 0062734W, 362720N 0063254W
(AIP-ESPAÑA).
LED-119 ARENOSILLO NORTE SUPERIOR
Lateral Limits: 370900N 0064500W, 365650N 0063410W,
362000N 0072130W, 365530N 0072130W,
370500N 0070710W, 370900N 0064500W
(AIP-ESPAÑA).
Vertical Limits: FL245 to FL600.
LED-120 ARENOSILLO NORTE INFERIOR ESTE (Golfo de
Cádiz)
365033N 0064303W, 370537N 0070137W,
370900N 0064500W (AIP-ESPAÑA).
Vertical Limits: SEA/GND to FL245.
LED-121 ARENOSILLO NORTE INFERIOR OESTE (Golfo de
Cádiz)
Lateral Limits: 370537N 0070137W, 365033N 0064303W,
362000N 0072130W, 370230N 0072130W,
370537N 0070137W (AIP-ESPAÑA).
LED-122 ARENOSILLO SUR (Golfo de Cádiz)
Lateral Limits: 362000N 0072130W, 361330N 0063800W,
355130N 0064230W, 355700N 0072130W,
362000N 0072130W (AIP-ESPAÑA).
Vertical Limits: SEA/GND to FL240.
LED-123 EL ANDEVALO INFERIOR (Huelva)
Lateral Limits: 380500N 0070000W, 374900N 0062400W,
374100N 0063600W, 373500N 0062300W,
372300N 0063600W, 372000N 0065400W,
371800N 0070300W, 372100N 0072700W
along the Spanish-Portuguese border to
380500N 0070000W (AIP-ESPAÑA).
Vertical Limits: 2000 ft AGL to FL245.
Dates and Times: 07 MAR - 10 MAR from 0800 to 1800.
LED-128 ARENOSILLO ESTE (Golfo de Cádiz)
Lateral Limits: 365630N 0063406W, 365118N 0062918W,
361318N 0063800W, 361418N 0064302W,
365020N 0064302W, 365630N 0063406W
(AIP-ESPAÑA).
Vertical Limits: 6000 ft AMSL to FL240.
LED-129 ARENOSILLO CENTRO (Golfo de Cádiz)
Lateral Limits: 365020N 0064302W, 361418N 0064302W,
362000N 0072118W, 365020N 0064302W
(AIP-ESPAÑA).
Vertical Limits: SEA to FL240.
LED-135 ALBORÁN INFERIOR
Lateral Limits: 361216N 0043835W; 361100N 0035200W;
363245N 0035204W; 361100N 0020200W;
355000N 0020700W; 355000N 0045400W;
361216N 0043835W. (AIP-ESPAÑA).
Vertical Limits: SEA/GND to 5000 ft AMSL.
Dates and Times: 28 FEB from 0800 to 2359.
01 MAR from 0001 to 2359.
02 MAR from 0001 to 2359 (from 1100 to 1500 for firing exercise).
03 MAR from 0001 to 2359 (from 1100 to 1300 for firing exercise).
04 MAR - 05 MAR from 0001 to 2359
06 MAR from 0001 to 2359 (from 1500 to 1800 for firing exercise).
LED-136 ALBORÁN OESTE
Lateral Limits: 361200N 0043800W; 361050N 0040139W;
355035N 0034212W; 355000N 0045400W;
361200N 0043800W (AIP-ESPAÑA).
Vertical Limits: 5000 ft AMSL to FL150.
Dates and Times: 28 FEB from 1200 to 1800.
01 MAR - 06 MAR from 0700 to 1800.
LED-137 ALBORÁN CENTRO
Lateral Limits: 355400N 0032000W; 362700N 0035200W;
363810N 0035206W; 363816N 0023849W;
355400N 0032000W (AIP-ESPAÑA).
LED-138 ALBORÁN ESTE
Lateral Limits: 355000N 0020700W; 355000N 0030300W;
363808N 0021825W; 363800N 0015449W;
355000N 0020700W (AIP-ESPAÑA).
For higher FL, tactical coordination with ECAO
Sevilla is required.
01 MAR from 0700 to 1800.
02 MAR from 0700 to 1800 (from 1100 to 1500 for firing exercise).
03 MAR from 0700 to 2000 (from 1100 to 1300 for firing exercise).
04 MAR - 05 MAR from 0700 to 1800.
06 MAR from 0700 to 1800 (from 1500 to 1800 for firing exercise).
LED-139 ALBORÁN SUPERIOR
Lateral Limits: 355000N 0045400W; 361224N 0043816W;
363811N 0040344W; 363800N 0015449W;
(AIP-ESPAÑA).
Vertical Limits: FL150 to FL310
Dates and Times: 02 MAR from 1100 to 1500 (for firing exercise).
03 MAR from 1100 to 1300 (for firing exercise).
06 MAR from 1500 to 1800 (for firing exercise).
Vertical Limits: FL280 to FL310
02 MAR from 0700 to 1100 and from 1500
03 MAR from 0700 to 1100 and from 1300 to 1800.
06 MAR from 0700 to 1500.
07 MAR - 10 MAR from 0700 to 1800.
Note: The start/end of the activity on this area will be carried
out in tactical coordination with ECAO Sevilla.
AOA RETIN
Lateral Limits: 362000N 0053600W, 362000N 0061700W,
355850N 0062200W, 355500N 0061500W,
355500N 0053600W, 362000N 0053600W.
Vertical Limits: SEA/GND to 6000 ft AMSL.
Dates and Times: 07 MAR from 0001 to 2359.
08 MAR - 10 MAR from 0001 to 2359.
AOA RETIN SUPERIOR
355500N 0054342W, 355850N 0053604W.
Vertical Limits: FL160 to FL200.
For different FL, tactical coordination with
ECAO Sevilla is required.
Dates and Times: 07 MAR - 10 MAR from 0800 to 2359.
FAOR ALGECIRAS
Lateral Limits: 363601N 0052016W, 363601N 0050350W,
362705N 0050325W, 360538N 0054000W,
362000N 0054000W, 363601N 0052016W.
Vertical Limits: SFC/GND to FL200.
ISLA DE ALBORÁN
Lateral Limits: Circular area of 4 NM radius centered on
355647N 0030214W.
Vertical Limits: SFC/GND to 2000 ft AMSL.
Dates and Times: 04 MAR from 1400 to 1600.
05 MAR - 06 MAR from 1000 to 1100.
ONUBA
371900N 0071000W, 372100N 0072700W,
from this point along the Spanish-Portuguese
border up to 380500N 0070000W.
Vertical Limits: FL280 to FL310.
01 MAR - 10 MAR from 0001 to 2359.
Note: The activation/deactivation of this area will be carried
ZAFRA-C
Lateral Limits: 383800N 0071500W, 383810N 0053522W,
380100N 0060500W, 374900N 0062400W,
380500N 0070000W from this point along the
Spanish-Portuguese border up to 383800N
0071500W.
LER-164 ALGECIRAS
Lateral Limits: 362637N 0051620W; 362500N 0050916W;
362228N 0050707W; 361054N 0051610W;
from this point, following a parallel line at 3 NM
from shoreline until 360857N 0051636W;
360914N 0052016W; 360910N 0052021W;
360918N 0052044W; 360918N 0052106W;
360917N 0052108W; 360922N 0052102W;
360922N 0052407W; 360540N 0052303W;
360445N 0052303W; 360226N 0052433W;
from this point, following a parallel line at 2NM
from shoreline until 360126N 0054124W;
360322N 0053953W; 361220N 0053930W;
362637N 0051620W (AIP-ESPAÑA).
Vertical Limits: SFC/GND to FL300.
DZ-ÁGUILA
Lateral Limits: A Circle 05 NM radius centered on 361250N
0055151W.
Vertical Limits: SEA to 6000 ft AMSL.
Dates and Times: 07 MAR - 09 MAR from 1000 to 1100.
Note: For parachute jumping. For higher altitude up to 9000 ft,
tactical coordination with ECAO Sevilla is required.
DZ-QUEMADO
Lateral Limits: A Circle 03 NM radius centered on 363600N
0062400W.
Vertical Limits: SEA to 9000 ft AMSL.
Dates and Times: 08 NOV from 1000 to 1100.
2. TRANSIT CORRIDORS
The communication of the activation and deactivation of corridors
will be carried out at least 10 minutes before, by means
of tactical coordination between GRUCAO/ECAO and the involved
ACC. Exercise traffic will always have priority.
Aircraft shall be established at level inside the areas and
03NM before ENTRY/EXIT to/from a corridor. Aircraft in emergency
are excluded of this rule.
TC: EC-001. LEMO → LED-123
Lateral Limits: 2.5 NM either side of a line drawn between
371050N 0053713W (MRN), 372549N
0061107W and 373139N 0063121W.
Vertical Limits: 3000 ft AMSL to 4000 ft AMSL.
Note: To activate higher levels, (FL120 to FL140 and FL200 to
FL210), tactical coordination with ECAO Sevilla is required.
TC: EC-002 LEMO → LED-120
371050N 0053713W (MRN), 371901N
0055548W and 365618N 0063422W.
Vertical Limits: FL080 to FL090.
Note: To activate higher levels, (FL200 to FL210), tactical coordination
TC: EC-003 L/H. LED 121 → LED-123
Lateral Limits: 3 NM either side of a line drawn between
370323N 0070428W and 372059N 0070958W.
Vertical Limits: 3000 ft AGL to 5000 ft AGL (L).
FL200 to FL220 (H).
