На сайте: гостей - 80,
участников - 10 [ muha131, deepaer0, Toha821, Greenland, qwert0173, 13466, Мотроник, Voevoda, Silent, fantom1938]
 Форум —› Главный раздел —› Новый КВ приёмник Alinco DX-R8T
Yaesu FT-60R
Yaesu VX-3R
Yaesu VX-6R
Yaesu VX-8DR
Yaesu FT-1D
MAAT
Offline6.0
с мар 2008
Дата: 18 Мар 2011 21:31:44 #
The Alinco DX-R8T receiver covers 150 kHz to 30 MHz in SSB, CW, AM and FM. Other features include: IF shift, band and memory scanning, attenuator, preamp, RIT and noise blanker. Enjoy 600 alphanumeric memories (3 banks of 200 channels). Attenuation level may be set at -20, -10, 0 or +10 dB. There are rear panel connectors for external devices including IQ output for possible use in SDR applications, DRM, external decoding, etc. With SDR freeware (not supplied) you will be able to decode DRM with a PC with sound card. Here are some screen shots from some DRM receptions we made February 2011:
The front panel has both an external 3.5mm speaker jack and a 3.5mm headphone jack.
Requires 12 VDC at 1 amp. Please note that this radio comes with a EDC-37 12VDC power cable and Owner's Manual only. It does not include a power supply. An AC power supply that provides 12VDC filtered 3 amp (or greater) power supply is required for home operation. See Pyramid PS-3, RPS-1204CPBT (both below) or equivalent. Size: 9.45 x 3.95 x 11.54 inches (240x100x293mm 4.1 kg).
(Please note that this radio does not receive the FM broadcast band).
ИМХО приёмник припозднился лет на 5
mikhalych
с апр 2006
Горные Ключи (Шмаковка) Приморский край
Дата: 18 Мар 2011 23:46:22 #
Его уже чуть-чуть пытались обсудить.. Вопрос выбора КВ-приемника - Страница 3
Yupi
с июн 2005
Кот-д’Ивуар
Дата: 19 Мар 2011 08:47:56 · Поправил: Yupi (19 Мар 2011 08:59:12) #
MAAT
А тут похожий трансивер)))
Кстати неплохая цена для приёмника-500$
http://swling.com/blog/?p=1006 видимо призванного заполнить нишу Icom R-75
rn9aaa
ХМАО-Югра
Дата: 19 Мар 2011 10:18:05 #
RIT
Интересно зачем приёмнику RIT (расстройка относительно передатчика)
наверное в планах производство только передатчика типа Т8Т ;-))
MAAT
Offline6.0
с мар 2008
Дата: 19 Мар 2011 11:35:16 #
Теперь понятно всё. Сразу как-то не догадался.
RK3DIA
Offline5.5
Пушкино
Дата: 22 Мар 2011 01:28:32 · Поправил: RK3DIA (22 Мар 2011 01:29:22) #
RIT
Думаю, для случая когда надо зафиксировать приемник на частоте, а в случае, если принимаемая станция "уплывает вверх или вниз", определить насколько Герц этот уход. Как я понимаю, его будут использовать в том числе и для службы радиоконтроля, так там это имеет значение.
А так приемник интересный, имеет симпатичный дизайн, еще бы покрутить, чтобы посмотреть как он в деле.
АМГ
с апр 2008
Удельная
Дата: 30 Сен 2012 18:07:45 #
Кому нибудь удалось поработать с приемником, как ощущения?
АМГ
с апр 2008
Удельная
Дата: 01 Окт 2012 19:35:43 #
Совсем не конкурент ICOM R75?
ТАНК
KN88
Дата: 01 Окт 2012 19:54:58 #
АМГ
с апр 2008
Удельная
Дата: 01 Окт 2012 21:36:46 #
Ну и как там просвещаться, один отзыв оценка 5, другой совершенно противоположный оценка 2 или 0, а в основном там бред один и смысл один, как хорошо ящик смотрится на столе в моем гаражном шеке.
ТАНК
KN88
Дата: 01 Окт 2012 21:51:55 #
АМГ
Так почитать за что оценку поставили не? Вопрос про ощущения там раскрыт полностью. Характеристики - мануал откройте.
АМГ
с апр 2008
Удельная
Дата: 08 Окт 2012 21:53:35 #
Может у кого нибудь есть трансивер Alinco DX-SR8 аналог этого приемника, как у него динамика?
shadows_x
ХМАО-Югра
Дата: 08 Окт 2012 22:20:03 · Поправил: shadows_x (08 Окт 2012 22:20:41) #
Судя по этому совсем никак...
http://www.remeeus.eu/hamradio/pa1hr/productreview.htm
АМГ
с апр 2008
Удельная
Дата: 17 Окт 2012 18:50:48 #
Радио оправдало все ожидания, по качеству приема вполне сопоставимо с Kenwood ts2000.
shadows_x
ХМАО-Югра
Дата: 17 Окт 2012 19:38:33 #
Features of DX-R8T/E
Narrow ceramic filters (AM 2.4kHz/SSB 1kHz) and 0.5kHz audio-filtering for CW
Уже сопоставили ! :)
Думаю ts2000 наверное только на картинках и видели, а если и крутили то не понимая что и для чего. :)
АМГ
с апр 2008
Удельная
Дата: 17 Окт 2012 20:39:28 · Поправил: АМГ (17 Окт 2012 20:48:47) #
Кенвуд стоит рядом с алинкой и подключены через активный делитель, еще есть с чем сравнить R&S и IC-R9000, но это уже совсем другой класс РПУ.
По картинкам не гадаю.
Все дело в математике для приема нужных видов излучения.
shadows_x
ХМАО-Югра
Дата: 17 Окт 2012 20:50:28 · Поправил: shadows_x (17 Окт 2012 20:51:59) #
И что стоит, учитесь приемником работать или будите тут волну гнать что при 1 КГц фильтре пьезике в 2 пч DX-R8T/E. Может работать как TS2000 :) Ваша лапша в ухи не лезет уж извольте.
Слушать станции с ломовым уровнем можно и на детектор он даже лучше звучит чем супер :)
Да уж в математитке! В голове все дело. :)
АМГ
с апр 2008
Удельная
Дата: 17 Окт 2012 20:59:18 #
Для приема используется IQ output
ТАНК
KN88
Дата: 17 Окт 2012 21:00:08 #
Народ, зачем ругаться? Можно ж снять кино минут на 5, и выложить на ютюб.
shadows_x
ХМАО-Югра
Дата: 17 Окт 2012 21:19:51 #
Тогда при чем здесь TS2000 или вам надо обьяснять что TS2000 не нуждается во внешнем компьютере и звуковой карте для приема например CW с фильтром например 100 Гц и т.д., как и не нуждается в довеске
при приеме АМ с полосой в вариациях 0...500-2500...5000 Гц и прочее и прочее ... :)
Так что извините ищите другие уши для вашей лапши милейший.
Дата: 17 Окт 2012 21:41:59 · Поправил: AOR (17 Окт 2012 21:50:15) #
Даже наверное больше.
И делать нужно было не до 30 МГц, а до 60 МГц IMHO, а то сразу теряет какие-либо конкурентные преимущества, перед тем же R75.
Кстати, любопытно сравнения с TS-2000, если алинка аналогично работает, то не вызывает восхищения, ибо КВ приемник не сильная сторона этого трансивера.. А если КВ приемник - середнячок, то какую-то нишу алинка должна занять..интересно какую.
Но реальность узнаем когда появится у кого-нибудь опыт эксплуатации, мало ли что, вдруг чем-то удивит.
Приятно что есть, но декодеры в комплект не входят? Или какой-то софт поставляется с этим приемничком?
АМГ
с апр 2008
Удельная
Дата: 18 Окт 2012 08:57:17 #
ic746
с авг 2004
Дата: 18 Окт 2012 11:17:52 #
А почему решили что лапша? В таблице http://www.remeeus.eu/hamradio/pa1hr/productreview.htm приёмник обошёл FT2000, при том, что TS2000 в таблице вообще нет :-(
shadows_x
ХМАО-Югра
Дата: 18 Окт 2012 11:55:40 · Поправил: shadows_x (18 Окт 2012 12:05:04) #
Впишите сами
http://ebookbrowse.com/qst-review-kenwood-ts2000-pdf-d356928476
В каком месте таблиц трансивер Alinco DX-SR8T обошел FT2000D и в чем обошел ????
ic746
с авг 2004
Дата: 18 Окт 2012 12:06:27 #
shadows_x Если интерполировать 2 и 5 кГц разносы при замерах, то 2000к в конце таблицы будет. У Шервуда он тоже в таблицу не попал из-за низких значений динамики при малых (менее 15кГц) разносах сигналов.
shadows_x
ХМАО-Югра
Дата: 18 Окт 2012 12:32:05 · Поправил: shadows_x (18 Окт 2012 12:33:04) #
Вы для начало прокомментируйте без интерпляции у DX-SR8T - BDR 100dB :) а так же IP3 -1 dB при отстройке 20 KHz.
. У Шервуда
У шервуда даже IC706MK2G на 2 кГц самый крутой - элекрафта к2 делает, 1000d делает и немного отстает от от 756-3:)
http://www.sherweng.com/table.html
но это так к слову
ic746
с авг 2004
Дата: 18 Окт 2012 13:01:14 #
BDR 100dB - не о чем не говорит - без указания разноса бессмысленная величина. Для разноса 20кГц - слабовато. Большой BDR необходим при наличии мощного соседа. Для обычных условий приёма нормальная величина. IMD 3 порядка более актуальный параметр. Голландец именно по этому параметру сортирует аппараты.
Насчёт Шервуда полностью согласен с вами.
По цене качеству пожалуй альтернатив DX-R8T нет. Здорово что IQ output предусмотрели - не надо платы никакие городить внутри. Морда отстёгивается - удобно - лёжа на диване мониторить ;-)
shadows_x
ХМАО-Югра
Дата: 18 Окт 2012 15:37:26 #
ic746
По моему это вы тут что то пытаетесь доказать. Да и как то не убедительно и неумело.
АМГ ответил слушал он не приемник в динамик, IQ -> компьютер.
Остается добавить что при таком использовании не лучше ли иметь простой трансивер флекс 1500 при близкой цене. Или добавить на SDR нормальный :)
АМГ
с апр 2008
Удельная
Дата: 18 Окт 2012 16:18:11 #
Alinco стоит 450 долларов, R75, к сожалению, стал стоить намного дороже из-за платы DSP.
Мониторинг на КВ это не только прием аналоговых сигналов, сейчас все больше становится цифровых видов связи, так что без компьютера ни как.
Vik1010
с окт 2012
Челябинск
Дата: 28 Окт 2012 17:06:54 #
Для такой цены , очень достойный приемник
