На сайте: гостей - 86,
участников - 1 [ Simon]
 Форум —› Разработка, ремонт, схемы, модификации —› Раскрыть Yaesu FTH-2006
BOBEP
с ноя 2009
Минск
Дата: 29 Мар 2011 09:08:21 #
Подскажите, кто располагает информацией, как раскрыть эту радиостанцию. Имеется экземпляр, который работает в диапазоне 160-174. Можно ли помочь ему работать на радиолюбительском участке. Заранее благодарен всем откликнувшимся.
kenwood33
Дата: 29 Мар 2011 12:05:39 · Поправил: kenwood33 (29 Мар 2011 12:47:38) #
А разве она не программируется с 145? В описании 145-172.
PROGRAMMING YAESU FTH-2006
Programming this rig needs only a small screwdriver and some skill, no computer or interface cords are needed. Normally this rig display only a channel number " CH 0 " to " CH 9 " if all memories where programmed. You can't modify the frequency with the 4 keyboard's keys. But there are some (4) hidden keys somewhere to achieve this. A) Right of the display, remove the keyboard plastic cover with a small screwdriver or a knife (it's glued) and you will see 4 additional keys on the keyboard just under the originals. B) Those keys are like this: 1) Power on the rig 2) Change display from channel to frequency by pressing once the "hidden" "Channel/Frequency " key. 3) Adjust to the desired frequency using the big upper right knob or " Scan + " or "Scan - " keys (You can obtain a 1 MHz step depressing the " Function " key before turning the knob or " Scan + " or " Scan - " keys. 4) From the frequency display, press the " Function " key (a small F is displayed) and quickly press the " Channel/Frequency " key, a small blinking memory number will appear in the upper left corner of the display, change the memory number using the big upper right knob or " Scan + " or " Scan - " keys and press again the " Channel/Frequency " key to store the memory. 5) Back to "channel display" mode using the " Channel/Frequency " key, the desired frequency is stored in the chosen memory.
To use a "shift" (repeater operation), press the " Channel/Frequency " key and power on the rig, the display shows .000, rotate the big upper right knob to change to the desired value, then the " Function " key (small F in display) and the " Priority " key to display a + or - CTCSS Under the " Light " key there is the key for the CTCSS First press will enable CTCSS at transmit (" enc " displayed). Second press of the key will enable CTCSS at receive (" dec" displayed) Third press of the key will disable both. Pressing the " Function " key and then the " CTCSS" key you can adjust the CTCSS frequency. In fact, programming this rig is exactly like the well-known FT-23R except for some functions Some other adjustments are inside the box (solder pads) (Do it at your own risks! ) Default setup is: Solder pads 1 open 2 shorted 3 open 4 shorted 5 shorted 6 open 7 open 8 open 9 open 10 shorted Frequency step is solder pad #4: open = 5 KHz step, shorted = 12.5 KHz step. (May needs replacing some components) Battery saver is solder pad #6: open = on, shorted = off Channel / frequency display is solder pad #7: open = channel, shorted = frequency Busy channel lock out is solder pad #8: open = off, shorted = on Busy tone lock out is solder pad #9: open = off, shorted = on Behind PTT rubber cover you will find a switch for testing/clone mode
That's all Enjoy F6BXM
BOBEP
с ноя 2009
Минск
Дата: 29 Мар 2011 12:46:30 #
Может быть и программируется, только нет такой возможности. На местном форуме спрашивал-безрезультатно. А на ней под батарейным отсеком бирка о том, что это версия "С" с диапазоном работы:160-170, хотя на приём работает где-то со 151.ХХХ до 180.ХХХ. Но, что удивительно, на передачу примерно со 140.ХХХ до 180.ХХХ
kenwood33
Дата: 29 Мар 2011 12:50:44 #
BOBEP
с ноя 2009
Минск
Дата: 29 Мар 2011 13:07:31 #
Спасибо огромное буду пробовать. Отпишусь по результатам
kenwood33
Дата: 29 Мар 2011 13:29:41 #
BOBEP
Удачи.
