На сайте: гостей - 77,
 Форум —› Разработка, ремонт, схемы, модификации —› Помогите с OFDM
Yaesu FT-60R
Yaesu VX-3R
Yaesu VX-6R
Yaesu VX-8DR
Yaesu FT-1D
yang
с ноя 2009
Дата: 13 Май 2011 14:44:18 #
необходимо смоделировать в матлабе код офдм для qpsk и расчитать ber EbNo
код для офдм есть помогите подалуйста к нему найти как расчитать ber!
% A: Setting Parameters
M = 4; % QPSK signal constellation
no_of_data_points = 224; % have 128 data points
block_size = 4; % size of each ofdm block
cp_len = ceil(0.1*block_size); % length of cyclic prefix
no_of_ifft_points = block_size; % 128 points for the FFT/IFFT
no_of_fft_points = block_size;
% B: % +++++ TRANSMITTER +++++
% 1. Generate 1 x 128 vector of random data points
data_source = randsrc(1, no_of_data_points, 0:M-1);
figure(1)
stem(data_source); grid on; xlabel('Data Points'); ylabel('transmitted data phase representation')
title('Transmitted Data "O"')
% 2. Perform QPSK modulation
qpsk_modulated_data = pskmod(data_source, M);
scatterplot(qpsk_modulated_data);title('MODULATED TRANSMITTED DATA');
% 3. Do IFFT on each block
% Make the serial stream a matrix where each column represents a pre-OFDM
% block (w/o cyclic prefixing)
% First: Find out the number of colums that will exist after reshaping
num_cols=length(qpsk_modulated_data)/block_size;
data_matrix = reshape(qpsk_modulated_data, block_size, num_cols);
% Second: Create empty matix to put the IFFT'd data
cp_start = block_size-cp_len;
cp_end = block_size;
% Third: Operate columnwise & do CP
for i=1:num_cols,
ifft_data_matrix(:,i) = ifft((data_matrix(:,i)),no_of_ifft_points);
% Compute and append Cyclic Prefix
for j=1:cp_len,
actual_cp(j,i) = ifft_data_matrix(j+cp_start,i);
end
% Append the CP to the existing block to create the actual OFDM block
ifft_data(:,i) = vertcat(actual_cp(:,i),ifft_data_matrix(:,i));
end
% 4. Convert to serial stream for transmission
[rows_ifft_data cols_ifft_data]=size(ifft_data);
len_ofdm_data = rows_ifft_data*cols_ifft_data;
% Actual OFDM signal to be transmitted
ofdm_signal = reshape(ifft_data, 1, len_ofdm_data);
figure(3)
plot(real(ofdm_signal)); xlabel('Time'); ylabel('Amplitude');
title('OFDM Signal');grid on;
% E: % +++++ CHANNEL +++++
% Create a complex multipath channel
channel = randn(1,block_size) + sqrt(-1)*randn(1,block_size);
% F: % +++++ RECEIVER +++++
% 1. Pass the ofdm signal through the channel
after_channel = filter(channel, 1, ofdm_signal);
% 2. Add Noise
awgn_noise = awgn(zeros(1,length(after_channel)),0);
% 3. Add noise to signal...
recvd_signal = awgn_noise+after_channel;
% 4. Convert Data back to "parallel" form to perform FFT
recvd_signal_matrix = reshape(recvd_signal,rows_ifft_data, cols_ifft_data);
% 5. Remove CP
recvd_signal_matrix(1:cp_len,:)=[];
% 6. Perform FFT
for i=1:cols_ifft_data,
% FFT
fft_data_matrix(:,i) = fft(recvd_signal_matrix(:,i),no_of_fft_points);
end
% 7. Convert to serial stream
recvd_serial_data = reshape(fft_data_matrix, 1,(block_size*num_cols));
% 8. Demodulate the data
qpsk_demodulated_data = pskdemod(recvd_serial_data,M);
figure(7)
stem(qpsk_demodulated_data,'rx');
grid on;xlabel('Data Points');ylabel('received data phase representation');title('Received Data "X"')
yang
с ноя 2009
Дата: 13 Май 2011 14:57:27 · Поправил: yang (13 Май 2011 14:58:55) #
очень прошу помочь если кто может написать как здесь расcчитать ber От EbNo
Programmist
с ноя 2008
Дата: 13 Май 2011 15:09:18 #
Что это такое? Кусок кода, непонятно откуда. И кто такой ber?
yang
с ноя 2009
Дата: 13 Май 2011 15:19:04 #
код формирующий офдм сигнал приемник передатчик...ber- Bit error rate я прошу помощи в построении кода для построения BER от отношения сигнал шум
Programmist
с ноя 2008
Дата: 13 Май 2011 15:25:23 #
Здесь врядли кто поможет, я в матлабе не работаю, чтобы сказать что-то определенное, нужно смотреть весь проект, по приведенному отрывку непонятно вообще ничего.
yang
с ноя 2009
Дата: 13 Май 2011 15:29:44 #
а где помогут?
это не отрывок а полная программа
которую надо дополнить о чем я и прошу(
Programmist
с ноя 2008
Дата: 13 Май 2011 15:34:07 #
Какая она полная? Где описание матриц и все остальные модули? Помогут на форумах по матлабу, где этим занимаются.
Время загрузки страницы (сек.): 0.118; miniBB®
