13:48
VZCZC UU
RR YLNS VIR-T-RAN
DE YLNZ NZ 002/16
ZNR UUUUUI S 161140B NOV 11
FM LVNS~DUNDA
TO LVBG RANDA
CTG
BT
UNCLRRLRIED
SIC AZA
EXER/FLOTEX 11//
SUBJECT/TABORD SRL 16027/002 CONOYEX//
GENTEXT/GENINFO OPFOR ACTION/SRL 16027/CONVOYEX//
A/!)953~!2011/SRL 16027/CONVOYEX//
B/CINC LN//
C/COS LNF//
3%2/CO VIR//
D2/CO SKR//
F1/VIR VAR VAL LOD ZIB//
F2/:9 =84//
F9/20//
G1/SKR RAA//
G2/CO SKR//~+H/BRAVO
J/17900B NOV11//
JJ/210000B NOV11//
K/NW EXERCISE AREA C3//
L1/SED
K SISE AREA B7/COURSE AND SPEED TBS SEPARATELY//
N1/UPON ENDEX OF SRAFQYPWWXX
N2/C2 C3K~R C5 C6 B5 B6 B7//
N5/FISHING GE S WITHIN 20M DEPTHLINE//
Q/NO LIVE FIRING EXERCISE//
T/BLUES AR
ASSUMED TO FORM A CONVUOY IOT ESCORT 2 HVUS INTO S PART
OF RIGA BAY. V~
TASK OF OPFOR FORCES IS TO LIMIT
BLUES FREEDOM OF MOVEMENT IN S PART OFDIGA BAY AND TO DENY BLUES
FROM ENTERING AREA C5. BLUES HAS DECLARED ITSRILL TO
ENFORCE ITS FREEDOM OF MOVEMENT INCLU~
D USE OF FORCE IF
NEC
ARRY. A LIMITED SURFACE WEAPON ENGAGEMENT RANGE OF 0,5NM VS
1,0Z FOR OPFOR FORCES GIVES OPFORS A TACTICAL ADVANTAGE AGAINST
BLUES WHICH SHCLD BE UILIZED BY OPFOR~T ANY TIME. DEADLY
FORCE (SIMULATED) IS TO B
GRED ONLY IN E PART OF AREA C4 WHICH IS
DECLARED AS BUFFER ZONE FOR OPFO IOT PREVENT CONVUOY
FROM ENTERING AREA C5. WARNING SHOTS (SIM~AT
RUP CAN BE USED IN
AREA C3 AND W PART OF AREA C4 IOT DEMONSTRATE SERINR
ESS
OF INTENTION TO DENY CONVUOY FROM CROSSING THE BUFFER ZONE.
VAR VL TO ACT AS BLUES HVUS WHICH SHOULD BE PROTECT~ BY ANY MEANS
BY BLUES.`#90!94 59 `590 `#8,8,& -8` 8,!94.-89, 161430B
SNIPE PROCEDURES AND SIGNAD
ARE TO BE TRANSMITTED IAW WHITE
SETTING CONVOYEX/SERIAL 16027/001/1516 &?
-%%8589,-) 8,!~-589,. INTENTION OF CO SKR IS TO MAINTAIN
INITIATIK
ATT ALL TIMES. EXERCISING OF TACTICAL ADVANTAGE BY
INREASED SURFACE WEAON ENGAGEMENT RANGE IS MANDATORY TO ACHIEVE
MISSION GOAL.
OPFOR~WITS T ACT INDEPENDENTLY FROM BOTH SIDES OF CONVOY . C/S
SKR S FROM CONVOQM C/S RAA N FROM CONVOY.
HOWEVER ON SIGNAL /OPERATION BACKFIRE/ OFER UNITS TO EXECUTE
MANEUVER IOT TO DEA~ASLUES PICKET UNITS/GUARDS TO CNVUOY
REAR AREA IOT GAIN ADVANTAGE OF DIRECT ENGAGEING OF HVUS AND
PREVENI
D CONVOY TO ENTER AREA C5.
ST/WARNING SHOTS WILL BE SIMULATED BY IND
ECT LIGHT WITH~EN SHORT
FLASHES INTO DIRECTION OF THE TARGET. LIGHN
ET TO BE
DIRECTED AGAINST WHEELHOUSE.//
U1/IMM VHF
CH 69 FOR SALE REPORTS//
~6932.5
U1/IMM VHF
CH 77 FOR TACTICAL REPORTING WITHI~OPFOR SAGJX
U2/IMM VHF
CH 16 BTB SAFETY//
U3/DURING SRL FOR TACTICAL PURPOSR
LFXS SKR TO ASSIGN C/S BOBBY.
C/S RAA TO ASSIGN C/S MOBBY//
375/FLASHING LIGHTS NOT TO BE USED F~ INTERNAL SAG COMMS ONLY TO
SIMULTE FIRING BY 10 SHORT INDIRECT FLASHES AGAINST THE
TARGET.//
UU/5 BLES ASSUMED TO BE FORMED IN SOME FORM OF A CLOSED SCREEN
WITH SHORT DISTANCE
SETWEEN U~~S DUE TO LIMITED
ENGAGEMENT RANGE. BLUES CONVUOY HEADING ASS
ED IN SE AND E
DIRECTION IOT REACH AREA C5 NLT 162100B. BLUES WILL NT SHINE
AIS INFORMATION. SPEED OF CONVUOY ASSUMED NOT TO~XCEED 11 KNO
DM
W/C/S SKR/10/40/42 C/S RAA/217//
Z/PROCEED TO SRL 1630/
ZZ/ACKNLDGE/YES ALL//
BT
INT QSL
![](http://www.radioscanner.ru/uploader/2011/varonis.jpg)
