На сайте: гостей - 39,
участников - 3 [ dxreceive, uve, NiXoN555]
 Форум —› Программное обеспечение —› ProScan
Icom IC-R6
Yaesu VR-120D
Icom IC-R75
Yaesu VR-160
Icom IC-R20
 Страница:  ««  1  2  3  4  5  6  7  8  9  10  11  »»Поиск в теме
emitremus
с фев 2018
Казань
Дата: 16 Мар 2018 18:38:40 #
Так же буду исключительно благодарен за "лекарство". Уже вторые сутки ищу, нигде не найду в сети.
Vox
Offline4.7
с авг 2008
МО
Дата: 16 Мар 2018 19:11:17 #
ole_ga
с сен 2012
Екатеринбург
Дата: 18 Мар 2018 18:38:00 #
Забираем
Спасибо, Vox
zeaxm
с апр 2012
Ханты-Мансийск
Дата: 18 Мар 2018 19:07:18 · Поправил: zeaxm (18 Мар 2018 19:09:01) #
Version 12.8 Newest Version 02/28/18
Fixed - DMR One Frequency systems not importing correctly from the RRDB.
Fixed - Web Server Status Log was displaying erroneous client disconnects.
Fixed - Importing from RRDB rebanded systems not setting Band Plan.
Fixed - Importing from RRDB option "Don't Import Encrypted TGID Channels" wasn't working.
Added - Web Server browser now has a File Explorer showing files such as Recordings.
Added - Update Scanner Clock upon start up and once a day option for the BCD436HP & BCD536HP.
Version 12.7
Fixed - RSOIP Published Servers Country field not looking up State/Province.
Fixed - DMR Conventional Networked systems wasn't importing from RRDB as DMR One Frequency system type.
Fixed - Google Maps not displaying Rectangles correctly for the BCDx36HP scanners.
Fixed - Google Maps JavaScript errors if system name contained quotes.
Fixed - Detached scanner window wasn't centering correctly.
Added - Database Lockout Frequencies and Talk Groups now showing the counts.
Added - Web Server - Option to Push the data to the Web Page verses the original Polling method for faster updates.
Added - Find & Replace - Change Alert Color based on Service Type on BCDx36HP scanners.
xin
с июл 2006
ДВ
Дата: 30 Мар 2018 03:37:10 · Поправил: xin (30 Мар 2018 03:39:28) #
What's New In Version 12.11 (Скачать)
За ключами в личку к Vox :)
Fixed - Importing from RadioReference NXDN system, LCN's wasn't correct.
What's New In Version 12.10
Fixed - NXDN Conventional channels Audio Type now includes NEXEDGE RAN & IDAS Area.
What's New In Version 12.9
Added - Web Server Metadata Delay option now delays the Display too so the audio and data appear in sync.
Added - Recording Option - Recording Files When Deleted Send To Recycle Bin (100 times slower when checked).
Added - BCD436HP & BCD536HP NXDN support.
Fixed - Database Quick Key Status grid wasn't scrolling far enough to show all the systems.
Fixed - Web Server - Server slow to respond when serving folders & files if thousands of files.
Many more small improvements.
xin
с июл 2006
ДВ
Дата: 30 Мар 2018 07:03:38 #
Способ активации ProScan 12.11 от меня:
Находите файл ProScan.cfg у себя на компе.
Он у меня находился в этом каталоге:
C:\Documents and Settings\xin\AppData\Local\VirtualStore\Program Files (x86)\ProScan\
Открываем на редактирование.
Находим в нём строчку
[PROGRAM MODE]=
редактируем её на
[PROGRAM MODE]=44569
Сохраняем файл.
Запускаем ProScan.
Всё.
915
с апр 2013
Приморье PN76vk
Дата: 30 Мар 2018 11:44:12 #
xin, спасибо за совет. В WinXP SP3 искомый объект в c:\Program Files\ProScan\.
gusevod
с июн 2015
Дата: 30 Мар 2018 13:58:20 #
лег сайт что-ли ?
не качается и на сайт не зайти :(
915
с апр 2013
Приморье PN76vk
Дата: 30 Мар 2018 14:07:06 #
gusevod, зарядите эту ссылку в любой имеющийся менеджер закачек.
DangerAlex
с мая 2008
Дата: 30 Мар 2018 14:50:42 #
gusevod
лег сайт что-ли ? не качается и на сайт не зайти :(
может причина в этом?
127.0.0.1 proscan.org
gusevod
с июн 2015
Дата: 30 Мар 2018 15:25:44 #
стопудово :D
дома проверю
aviation1
с апр 2017
UK
Дата: 30 Мар 2018 17:50:22 #
Товарищи! Поделитесь, пожалуйста, ключиком.
P.
gusevod
с июн 2015
Дата: 30 Мар 2018 22:23:38 #
[PROGRAM MODE]=
редактируем её на
Сохраняем файл.
Запускаем ProScan.
zelleny79
с дек 2017
Дата: 21 Апр 2018 12:02:34 #
C:\Documents и Settings\ксин\папка appdata\местные\виртуального хранилища\программные файлы (х86)\Проскан\
[РЕЖИМ ПРОГРАММА]=
редактируем её на
[РЕЖИМ ПРОГРАММА]=44569
Сохраняем файл.
Запускаем ProScan.
Всё.
а у меня нету такого файла???
Qwerty_Alex
Уфа
Дата: 21 Апр 2018 14:31:48 #
проскан надо хоть раз запустить, файл появится
Qwerty_Alex
Уфа
Дата: 21 Апр 2018 14:33:57 · Поправил: Qwerty_Alex (21 Апр 2018 14:34:45) #
xin
Огромное спасибо! Вопрос, лицензия написано "freeware", есть какая то разница по функционалу с нормальной?
zelleny79
с дек 2017
Дата: 21 Апр 2018 19:20:13 #
за два дня несколько раз открывал проскан.
Qwerty_Alex
Уфа
Дата: 22 Апр 2018 16:39:00 #
Вышел Proscan 12.12:
https://www.proscan.org/ProScan_12_12.zip
Version 12.12 Newest Version 03/30/18
Fixed - Importing from RRDB and clipboard NXDN RAN tones was importing as DCS tones on conventional frequencies.
Fixed - BCDx36HP Favorites Editor - Department and Dept / Site Quick Key Status broke.
Qwerty_Alex
Уфа
Дата: 22 Апр 2018 16:43:04 #
Зарегистрированный по методу xin Proscan 12.11 сам увидел обновление, сам его скачал и обновился (я только подтвердил что хочу обновиться). Все работает!
vova_sam
с дек 2008
РФ
Дата: 22 Апр 2018 22:01:58 · Поправил: vova_sam (22 Апр 2018 22:02:41) #
а столько лет использовал созданный своими руками сканер окон, который сам кликал на ОК раз в 30 минут
а так все просто
xin где же вы были :)
zelleny79
с дек 2017
Дата: 23 Апр 2018 21:08:14 #
vova_sam
блин, почему у меня ни чего не получается?
vova_sam
с дек 2008
РФ
Дата: 23 Апр 2018 22:10:32 #
zelleny79
вы нашли файл, ввели рекомендованное значение, но не активизируется?
zelleny79
с дек 2017
Дата: 24 Апр 2018 16:03:16 #
ура товарищи, заработало. не много не там искал
Qwerty_Alex
Уфа
Дата: 25 Апр 2018 06:13:17 #
zelleny79
Ну так подскажите другим, всем польза будет
Tigrokot
с мар 2010
ХМАО
Дата: 08 Май 2018 08:55:11 · Поправил: Tigrokot (08 Май 2018 08:56:36) #
Приветствую, парни будет ли про скан работать в 8 винде? Пробовал не видит сканер 436.
zelleny79
с дек 2017
Дата: 08 Май 2018 21:43:20 #
Tigrokot
ПРИВЕТ, поидее должен работать. сканер переводи в режим флешки когда подключаешь его к компу.
Tigrokot
с мар 2010
ХМАО
Дата: 09 Май 2018 00:10:46 #
Пробовал не могу зацепить сканер в прогу пишет что не видит его порт, или что то вроде того, сейчас попробую фото вставить.
Винцент
с авг 2009
Дата: 13 Май 2018 16:57:01 #
Вышла новая версия 12.13
xin
с июл 2006
ДВ
Дата: 18 Май 2018 15:01:58 #
Version 12.13 Newest Version 05/12/18
Fixed - Location Range in Favorites Editor wasn't allowing decimal point.
Fixed - Importing Unit ID's from Clipboard to BCDX36HP wasn't working.
Fixed - Importing from the RRDB - NXDN IDAS Type D TGID's wasn't formatted correctly.
Fixed - Web Server intermittent exemptions (errors).
Fixed - BCD536HP Wi-Fi - Source Client streaming to Broadcastify / Icecast / Shoutcast servers will now stay connected if the Wi-Fi goes down or glitches.
Added - BCDX36HP Favorites Editor message when finished reading & writing to the scanner.
Added - BCDX36HP Favorites Editor 'Monitor' parameter.
Added - History Import to BCDX36HP Favorites.
Винцент
с авг 2009
Дата: 19 Май 2018 12:54:05 #
Каким способом можно подать на компьютер звук с 536 на компьютер посредством проскана? Только шнур или по wi-fi можно?
Время загрузки страницы (сек.): 0.066; miniBB ®
