Дата: 26 Мар 2016 23:04:42
via http://www.brickolore.com/2016/03/xiegu-x5105.html via http://www.hellocq.net/forum/read.php?tid=348342 :
1, X5105 much power?
The whole band maximum 5W, minimum 1W, 0.5W in continuous steps.
2, X5105 which works in the band?
0.5 ~ 54MHz amateur band range.
3, X5105 which mode?
CW / SSB / AM / NFM / DIG, support digital mode;
4, X5105 screen how much?
About 3.2 inch grayscale display black and white screen;
5, the volume X5105 how much?
About 160 * 100 * 42mm
6, X5105 operating voltage range?
DC 8 ~ 15V
7, X5105 SDR is it?
X5105 itself is the second superheterodyne structure, built ADSP processor to complete part of SDR functions. With subsequent XDT1 products that can achieve all SDR functionality.
X5105 is the front end of the machine 2-conversion analog receiver, the rear end of the demodulated signal into the DSP chip, digital filtering, digital noise reduction, digital NB processing.
8, X5105's internal battery is in what form?
Is built-in battery, life time is about 6 to 8 hours;
9, the material is what X5105 shell?
Sheet metal chassis.
10, X5105 antenna interface What are the specifications?
BNC (Q9) Interface
11, X5105 can do with the computer on-line?
Can be connected to a computer, send and receive a host of software control by the HRD.
12, X5105 and XPA125, XDT1 how to connect?
A dedicated connection port, you can connect wires. Connection will be distribution, without having to purchase separately.
13, X5105 can charge the internal battery it?
Yes, the machine has a charging circuit.
14, X5105 can customize boot callsign it?
can.
15, X5105 weigh?
About 0.6 kg.
16, X5105 automatic key it?
There, you can manually key / auto key switch, adjustable rate;
17, X5105 automatic call / Beacon feature? How Built-in filter performance?
Automatic call / beacon function.
5105 machine filter as follows:
a roofing filter, Japan KDS custom 15K Bandwidth
b crystal filters, co Valley secret SSB, CW filter
c AM filter, FM filters, some of the products ordered in Chengdu
18, X5105 has approval code it? By inspection machine it?
It will apply for approval code, the whole index in line with requirements of the testing machine.
https://2.bp.blogspot.com/-mUtonMevUkg/VvQYMaE_3dI/AAAAAAAAGS0/dmMGIM9M2ockcLIYYRPwy73K5JdP_QyHg/s1600/8_411504_49979b2dd6b1d4c.jpg
https://1.bp.blogspot.com/-39B64xLiZMI/VvQYMesRmnI/AAAAAAAAGS0/b3cYL2LrpHoYyUOnRlk5DZzuBixIbJQrQ/s1600/8_411504_69c24024c59e24d.jpg
https://2.bp.blogspot.com/-NmlCjMyJ1Co/VvQYMXHxvyI/AAAAAAAAGS0/0LqRjAIas9QTr3K_LFbVYuhKN_2v3jClA/s1600/8_411504_bcbfe41847a8bae.jpg . |
Дата: 26 Мар 2016 23:41:30
Это в курсе. Ждем выпуска в "люди".
Дата: 02 Апр 2016 14:32:05
LNR выдало
SDR, прямая оцифровка. Все КВ, все виды, 5-8 ватт. Прикольно:) , но цена пока не очень....750$. Хотя может в бакинских и нормально:). |
Дата: 02 Апр 2016 15:01:09 · Поправил: Windk (02 Апр 2016 21:40:22)
LNR выдало
что 5й то 11й - по нутру похоже это "SoftRock" с демодуляцией/модуляцией на STM процессорах..была такая мысль сделать свой софтрок автономным. Онобы все здорово, но в отличие от Digital Down Converter заморочка с ДПФами и все равно всяких ложных сигналов и хвостов на панораме. Имхо, за такие деньги, лучше афедри+фт817.
Дата: 04 Апр 2016 21:48:27
На случай, если ещё не все видели:
![](http://www.radioscanner.ru/uploader/2016/tmb/baofeng_uv-7300.jpg) |
Дата: 04 Апр 2016 23:24:38 · Поправил: reeeeee89 (04 Апр 2016 23:26:54)
GoBliNuke
Гы:)
Да это же KN920. Плюс ходят слухи, что Baofeng выкупили там "чего-то" у Tokyo Hy-Power....возможно, что в скором времени будет что-то типа этого . |
Дата: 05 Апр 2016 00:48:39
Дата: 05 Апр 2016 01:31:53
Судя по фото надпись реально "подфотошоплена":)
Дата: 05 Апр 2016 04:06:01
Дата: 05 Апр 2016 13:48:58
Снял небольшое видео, где провожу QSO на 20ке , используя X108G.
ТЫЦ |
Дата: 09 Апр 2016 16:28:52
Дата: 23 Апр 2016 14:00:23
http://www.ruqrz.com/desyatidiapazonnyj-kv-transiver-fx-9a/
Китайские умельцы создали приближенную копию Elecraft KX3, а именно трансивер FX-9A.
Несмотря на свои небольшие размеры, он перекрывает все радиолюбительские диапазоны от 160 до 10 метров.
Виды модуляции CW, LSB/USB.
В трансивере предусмотрены встреченные фильтры на 2кГц SSB и 200Гц для режима CW.
Выходная мощность не более 15 Ватт, минимум устанавливается в 5 Ватт с встроенной защитой от высокого КСВ.
Питается трансивер от 10 до 15 Вольт. Ток потребления в режиме приема 360мА, на передаче 4А.
Размеры трансивера: длина 16 см х ширина 10 см, высота 4.8 см.
Вес 600 грамм.
Стоимость трансивера на eBay составляет 450 USD. |
Дата: 23 Апр 2016 14:47:53
GoBliNuke
Есть такое дело...занятное радио. Очень привлекает вес. Посмотрел и почитал обзоры KB2SDR про этот аппарат и записал в хотелки:)
Дата: 23 Апр 2016 15:10:02
reeeeee89
Но всё же пока КВ-баофенгом у китайцев и не пахнет. А теме уже больше трёх лет :)
Дата: 23 Апр 2016 17:09:28
GoBliNuke
Ога. Кроме Xiegu серийным производством кв радив никто больше не занимается.
Дата: 24 Апр 2016 15:50:57
а как по качеству кЕтайские трансиверы? как повезет?
Дата: 24 Апр 2016 17:17:54
Модест Петрович
Мне можно сказать повезло . Были косяки, но все исправлено.
Кстати, FX-9A делает товарищ BG2FX. Связался с ним, чтобы уточнить пару моментов....по англиЦки плохо говорит, но в целом я все понял :)) . Аппарат позицируется как HAM TOY и массового производства не будет.
Дата: 11 Май 2016 23:26:47
reeeeee89
Качать с официального сайта.
можно ссылку?
Дата: 12 Май 2016 00:00:12
locomosha
Давно залито сюда |
Дата: 15 Май 2016 13:37:46
Вот ещё один интересный "гаджет" от братьев китайцев. Цифровой модем со встроенным 1 ватт трансивером. |
Дата: 15 Май 2016 16:27:50
reeeeee89
...Freq Stability: 7 ppm (Si570 Grade C)...
нормальная такая стабильность :)
Дата: 15 Май 2016 17:20:02
Модест Петрович
Я тоже удивился. Для цифры как то не катит. Хотя продаётся и как модем без трансиверной платы.
Дата: 16 Май 2016 12:32:17 · Поправил: tigra (16 Май 2016 12:43:25)
Дата: 05 Июн 2016 00:50:53 · Поправил: reeeeee89 (05 Июн 2016 00:58:56)
Дата: 05 Июн 2016 09:13:49
reeeeee89 выше писал, что все эти кЕтайские поделки это Ham Toy. То есть игрушки без массового производства. Соответственно, без толкового мануала, сервиса и с чудесами ручной сборки. Плюс качество как повезёт.
Мне хватило Элекрафтовского мелкосерийного производства. И общения с их сервисом. Как будет в случае с кЕтайцем, ежели что-не знаю.
А игрушка по цене от 40 тыров, для меня это расточительно.
Дата: 05 Июн 2016 10:10:37
Но тем не менее прогресс налицо. Хотя все равно эти аппараты делаются на основе каких-либо готовых решений (на предыдущей ссылке чёрным по белому, что основа KX3). В целом то довольно интересные аппараты появляются, но не по сегодняшнему курсу их покупать :)).
З. Ы. Странно, что про x5105 никакой инфо.....вроде как обещали в июне.
Дата: 05 Июн 2016 12:36:24 · Поправил: Модест Петрович (05 Июн 2016 12:40:17)
я бы купил если бы знал, что аппараты изготовлены из качественных комплектующих, на них есть нормальный opetating и service manual, схемы, возможность получить квалифицированные ответы на возникшие в процессе эксплуатации вопросы ну и решенные вопросы с ремонтом.
а брать радио для "поиграться" это для избранных :)
тот же Российский ЕЕ нормальный мануал для SS выпустил через несколько лет после начала продаж. а на МВ-1, через полтора года.
так что работаем на Y-I-K, а изделия "гаражных кооперативов" в сад.
по моему мнению, в кЕтае, можно покупать УМ, т.к. в них деталей то всего-ничего и принцип работы известен.
а трансиверы, где более 1000 компонентов, отсутствие схемы, описания, ПО, это... не разумно.
Дата: 05 Июн 2016 12:40:29 · Поправил: DVE (05 Июн 2016 13:12:46)
Здесь есть обзор digital modem от этих же китайцев:
Вроде внутри все вполне прилично, и уровень вполне не "гаражного кооператива".
Другой вопрос, что быть бетатестером за свои кровные неохота, за и недешево уже.
С этим не поспоришь, да :)
Ну по сути так и есть, Y-I-K в отличие от китайцев, гарантируют качество, но если недорого и есть лишние деньги, то можно в качестве toy и "китайца" взять. Другой вопрос что при цене >500$ уже как-то смысл теряется. |
Дата: 26 Июн 2016 02:30:55
Дата: 17 Янв 2017 22:24:58
Из профильной группы на фейсбуке:
Brief Introduction of X5105 Ultra - portable HF + 50MHz Short - wave Transceiver
X5105 is an ultra-portable short-wave transceiver, it is compact, feature-rich, built-in automatic tuning, both to meet your outdoor mobile use needs, but also with supporting equipment, high-power base station, is a flexible short- Transceiver.
Features
compact size, about 160 * 100 * 42mm (excluding the protrusion)
Built-in automatic antenna tuner (ATU)
Built-in battery pack
Standard SSB standard filter (2.4k), CW narrow band filter (500Hz) Standard imported high stability TCXO (0.5ppm)
digital filtering, digital noise reduction function
Full-function digital hand microphone
XG RADIO V1.0
Basic parameters
Operating mode: SSB / CW / AM / FM / DIG Storage channel: 120 antenna impedance: 50 (BNC) Operating voltage: DC8 ~ 14.5V Current:
Emission (max) ..... 2A
Receive (max) ..... 0.25A
Operating temperature range: -20 ° C ~ 60 ° C
Frequency stability: ± 0.5ppm (-10 ° C ~ 50 ° C, 10 minutes after starting) Machine volume (without projection): about 160 * 100 * 42mm Machine quality: about 0.6kG
Emission parameters Transmit frequency band:
0.5 ~ 30MHz (amateur band only)
50 ~ 54MHz Transmitting power:
SSB / CW / FM / FSK ............... Max.5W
AM .......................... Max 1.25W Modulation:
SSB. . . . . . . . . Balanced modulation. . . . . . . . . Variable reactance. . . . . . . . . Low level
Spurious radiation:
160m ~ 10m band. . . . . . . . . . . . . . . . ≤-50dB
6m band. . . . . . . . . . . . . . . . . . . . . . ≤-55dB
Carrier Suppression (SSB). . . . . . . . . . . . . . . . . . . . . ≥40dB unwanted sideband suppression (modulation frequency 1.0kHz). . . . . Gt;
Maximum frequency deviation (FM). . . . . . . . . . . . . . . . . . . . . . . ± 5kHz emission frequency response. . . . . . . . . . . . . . . . . . . . . . . . . . . . 400 to 2800 Hz
(-6 dB)
XG RADIO V1.0
XIT Frequency fine tuning range. . . . . . . . . . . . . . . . . . . . ± 5 kHz
Receiver parameter Receive frequency range:. . . . . . . . . . . . . . . . . . . . 0.5 to 30 MHz / 50 to 54 MHz / reception sensitivity
SSB / CW / FSK (Sinad 12 dB). . . . 0.5 ~ 1.7MHz: better than 4uV 1.7 ~ 24.5MHz: better than 0.22uV
24.5 to 30.0 MHz: better than 0.22 uV
50.0 ~ 54.0MHz: Better than 0.22uV AM (Sinad 12dB). . . . . . . . . . 0.5 ~ 1.7MHz: better than 30uV 1.7 ~ 24.5MHz: better than 2uV
24.5 to 30.0 MHz: better than 1.3 uV
50.0 to 54.0 MHz: better than 1.3 uV FM (Sinad 12 dB). . . . . . . . . 28.0 to 30.0 MHz: better than 0.22 uV 50.0 to 54.0 MHz: better than 0.22 uV
Selectivity
SSB. . . . . . . . . . . . . . . . -6 dB: 2.7 kHz / -60 dB: 5.4 kHz
AM. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -6 dB: 5.0 kHz / -60 dB: 40.0 kHz
FM. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -6 dB: 12.0 kHz / -60 dB: 25.0 kHz
RIT Frequency fine tuning range. . . . . . . . . . . . . . . . . . . . . . . . . ± 5kHz
image rejection. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ≥ 70dB
1 IF suppression. . . . . . . . . . . . . . . . . . . . . . . . . . . . ≥ 70dB a
udio output (8, 10% distortion). . . . . . . . . . . . . . . . . . . . . ≥0.6W
Audio output impedance (EXT.SP). . . . . . . . . . . . . . . . . . . . . . . . 8
