На сайте: гостей - 62,
участников - 4 [ muha131, DangerAlex, killer258, Windk]
 Форум —› Радиостанции —› Codan 9360MR КВ ОБП трансивер
Беркут Hunter
Егерь 3
President Randy II P
Турист 3
Штурман 80
 Страница:  ««  1  2  3  4  5  6  7  8  9  »»Поиск в теме
ServiceK
с ноя 2013
Дата: 19 Ноя 2013 23:11:50 #
Интересный сайт http://www.hfradiosales.com.au/codan_%20barrett_hf_radio_information/9323_Tech.htm
Даже прописано куда GPS При желании
GPS connection
RS232 socket on rear of Main Transceiver.
Tip-Radio data input
Ring-Radio data output
Sleeve- Ground
Спасибо.Вот завтра поеду NGT VR забирать. 9360 с антенной пока в пути.
ServiceK
с ноя 2013
Дата: 19 Ноя 2013 23:22:54 #
Установки в сервисном меню ССылка
http://www.hfradiosales.com.au/codan_%20barrett_hf_radio_information/9323%20mods/Easy%20Guide%20to%20Personalising%20your%20Codan%209323%209360%209780.htm
Personalising the Codan 9323, 9360 and 9780 transceivers
(Thanks to Peter Harland of QLD)
Setup PROCEDURE
Enter setup mode by pressing the MODE button on the control panel 4 (four) times. Use mircophone keypad to enter Setup code:
Procedure Setup code Description Setting - Comment
BEEP LOUDNESS 33 change the volume of the beeps by the transceiver NORMAL (selectable)
CALL PREAMBLE LENGTH 242 sets the length of the preamble transmitted at the start select SELCALL - if ALE is not fitted
of a selcall
CALL PRIVACY 2443 limits stations that can receive your GPS, Page call and OFF - unless you have a specific reason to enable privacy
Status call transmissions
CLOCK CALIBRATION 412 calibrates the transceiver clock against a external standard - adjusts time gain or loss
CLOCK SETTING 411 sets time and date of the transceiver clock
DISPLAY BRIGHTNESS 311 changes brightness of display
DISPLAY CONTRAST 312 changes contrast of display
DISPLAY DIAGNOSTICS 314 switches on or off the diagnostics display of the transceiver if ON it replaces the channel info (tag)
DISPLAY FREQUENCY 313 set how the frequency is displayed for each channel Rx/Tx
FREE TUNE RECEIVER 3442 turns on/off ability to free tune receiver
PAGE CALL MESSAGE SETUP 24441 can store up to 3 pre recorded messages for sending except Version 1 Firmware
POWER UP MESSAGE 34411 allows for message to be displayed for a few moments when optional personal message
transceiver first starts up
POWER UP MUTE 34412 selects initial mute setting on start up select SELCALL, VOICE mute or NONE
POWER UP ADDRESS 34413 shows self I.D. (your selcall) on startup shows/hide your selcall
PTT RELEASE BEEP 3432 switches on/off PTT release beep saves saying "OVER" - other party hears a "BEEP" instead
PTT TRANSMIT CUTOUT 3431 prevents transceiver being left on transmit state set time - transceiver protection
POWER OUTPUT 3433 sets ability to select power output level - 10 or 100W ENABLE - not available on Version 1 firmware
RECALL CHANNEL BY FREQUENCY 32 enables recall channels by frequency ON -recalls either by frequency or channel number
RF GAIN 3443 switches on RF gain ON - transceiver is more sensitive to low strength signals
SELCALL ID 211 setup selcall and telcall ID's - up to 5 ID's assign ID
SELCALL SIZE 213 sets selcall ID size - 4 or 6 digits check with network provider
STATUS CALL AVAILABILITY 24442 allows you send and receive diagnostic, config and user calls ON - not available with Version 1 firmware
TELCALL AVAILABILITY 22 switches on ability to make telcall (phone calls) ON
IF GPS OPTION is AVAILABLE and GPS connected
GPS DISPLAY 3421 switches on the display of your GPS location ENABLE - replaces Channel tag info
GPS TIMEOUT 3422 GPS timeout warning DISABLE
RS-323 CONNECTED EQUIPMENT 3411 identifies equipment connected to either the RS-232 or GP select GPS NMEA-0183
ports - on back of transceiver
RS-232 BAUD RATE 3412 synchronise speed for information transfer set 4800 ( check GPS receiver baud rate - typically 4800)
Может кому пригодится
ServiceK
с ноя 2013
Дата: 19 Ноя 2013 23:25:22 #
ServiceK
с ноя 2013
Дата: 20 Ноя 2013 23:23:59 · Поправил: ServiceK (20 Ноя 2013 23:31:57) #
Да, уже паяю:
Уважаемый ASH[u][/u] !!! Кабель программирования РАБОТАЕТ ???????
СПАСИБО.
ASH
Offline7.2
Жуковский (ko95bo), RN3DAS
Дата: 20 Ноя 2013 23:35:56 · Поправил: ASH (20 Ноя 2013 23:38:52) #
Да, работает, как описано в этом сообщении Codan 9360MR КВ ОБП трансивер
Только микрофонный разъем сложно найти, пришлось "колхозить")
А Да, уже паяю: относилось к кабелю управления через rs232, который втыкается сзади, управление через rs232 также работает. Codan 9360MR КВ ОБП трансивер
ServiceK
с ноя 2013
Дата: 20 Ноя 2013 23:39:26 #
Понял.спасибо. Пойду ваять для программирования NGT vr.
tigra
Offline4.8
с ноя 2004
Tashkent
Дата: 21 Ноя 2013 09:28:02 #
Если аппарат для себя (любимого:) ) , то мона и доп разъем поставить и не париться с микрофонным.
ASH
Offline7.2
Дата: 21 Ноя 2013 09:32:04 #
Да оно не так уж часто нужно, чтобы еще раэъем ставить. При желании микрофонный разъем на ebay можно купить, но как-то дорого)
ServiceK
с ноя 2013
Дата: 21 Ноя 2013 09:46:57 #
Извините .Только сейчас дошло. Джек 3.5мм - это только для управления или и программировать можно с него?
Спасибо
ServiceK
с ноя 2013
Дата: 21 Ноя 2013 09:48:05 #
Да Выкладываю софт для программирования NGT VR и иже с ним.
ASH
Offline7.2
Дата: 21 Ноя 2013 09:53:42 #
Только для управления. Программировать у меня с него не получилось.
Да и в инструкции описано программирование именно через микрофонный разъем. Причем режим программирования - отдельный режим работы радиостанции. Тоесть на выключенной станции втыкаем кабель программирования в микрофонный разъем, включаем станцию, она включается в режиме программирования, на прием и передачу не работает. После окончания программирования отключаем кабель, радиостанция предлагает ее выключить и включить для продолжения работы.
ASH
Offline7.2
Дата: 21 Ноя 2013 18:59:35 #
ServiceK
Смотрю я на этот кабель http://www.ebay.com/itm/Codan-NGT-Series-USB-Programming-Cable-/370889896088?pt=UK_Mobile_Phones_Communication_Radio_Parts_Accessories&hash=item565ac2b098
И есть у меня мысль, что NGT возможно и через "зад" программируется..
DEN
Родина-мать
Дата: 21 Ноя 2013 19:08:32 #
нормальный (от производителя) NGT программируется с клавиатуры микрофона, поэтому смысла нет софтом пользоваться
Ware
Offline6.5
с июн 2003
Дата: 21 Ноя 2013 23:43:33 #
Смысл пользоваться софтом есть, т.к. отдельным группам пользователей требуется не 3-4 канала программировать (что действительно будет удобнее сделать с клавиатуры), а, например, 3-4 сложных системы и еще сто-двести фикс каналов в довесок. А если станций несколько? А если это куст из 40 абонентов?
Не очень хочется ситуацию, когда придётся к аппарату искать сменные резинки клавиатуры, а уж время и вовсе бесценно.
ServiceK
с ноя 2013
Дата: 22 Ноя 2013 00:20:43 · Поправил: ServiceK (22 Ноя 2013 00:35:56) #
Уважаемый ASH!
Кабель РАБОТАЕТ .
Ура.Благодарю.
p.s. А через зад он не может шиться, там разьемов минимум и не одного 3.5мм.
разьем для программирования у него прямо в тангенте выведен.
tigra
Offline4.8
с ноя 2004
Tashkent
Дата: 22 Ноя 2013 00:34:57 #
TRX-manager Codan-ами помоему управляет, только переключение каналов. Вот можно бы в Кода нах VFO режим поиметь...ходила байка, что есть такая прошивка, но это только байка, я думаю...
Fujik
Дата: 22 Ноя 2013 00:40:32 #
Не байка это. Днействительно такая фича точно была для 8528 и судя по австралийским форумам похоже был код, открывающий на 9360. Но капиталисты крепко хранят тайну....
ServiceK
с ноя 2013
Дата: 22 Ноя 2013 00:56:52 #
Вот к стати для этого и нужно управление и программирование с компа. В NGT например уровни доступа есть типа User -- Admin Мне аппарат достался запароленный под админа.Вот приедет 9360 тоже займусь поисками.Спасиб
tigra
Offline4.8
с ноя 2004
Tashkent
Дата: 22 Ноя 2013 10:04:52 #
Эх! Для HF-90 кто-нить прошивочку с VFO придумал бы...
ASH
Offline7.2
Дата: 02 Дек 2013 22:01:32 #
Приехал с ебея 9360 с выносной головой:
В очень хорошем состоянии. Будет установлен в радиотрак)
А второй такой же кто-то из наших купил у этого продавца?
4L2ika
с июн 2008
Грузия
Дата: 27 Дек 2013 04:31:42 #
ASH
Offline7.2
Дата: 27 Дек 2013 09:20:36 #
Да да, у меня так управляется на радиовыносе по bluetooth с помощью простого bluetooth - rs232 адаптера на расстоянии 127 метров.
Но терминал это не удобно, надо программу писать для управления, все никак программиста знакомого не допинаю чтобы сделал это.
ServiceK
с ноя 2013
Дата: 06 Янв 2014 17:41:32 #
Уважаемые.А нет у кого инстукции номер codan 15-02055. Уж очень хочется её почитать.
Спасибо.
Fenix
с ноя 2008
Дата: 06 Янв 2014 18:17:08 · Поправил: Fenix (06 Янв 2014 18:24:40) #
codan 15-02055
это French translation from the HF SSB transceiver 9323/9360/9390/9780 Technical Service Manual Codan Part No. 15-02051 Issue 4, August 1997
Сейчас выложу в файлы.
Codan 9360 - Technical Service Manual (French)(15-02055)
15-02051 - уже есть в файлах - Codan 9360 - Technical Service Manual
ServiceK
с ноя 2013
Дата: 06 Янв 2014 21:33:11 · Поправил: ServiceK (07 Янв 2014 00:52:04) #
Спасибо.пошел читать.
Приехал долгожданный 9360 с антенной 9350. Теперь на даче 9360 ,а в машине NGT VR.
Pavelectric
Offline5.8
с авг 2007
Жуковский (KO95BN)
Дата: 06 Янв 2014 22:17:23 #
с антенной 9350 как же я долго её ищу... На Стелс денег жалко, хотя она того стоит.
БЕГЕМОТ
Offline7.8
с авг 2004
из ниоткуда в никуда
Дата: 06 Янв 2014 22:21:39 #
Pavelectric
Тоже не смог найти в свое время ))
9350
Pavelectric
Offline5.8
с авг 2007
Жуковский (KO95BN)
Дата: 06 Янв 2014 22:28:51 #
БЕГЕМОТ, дорого... Была "одна", но меня опередили её сломали )))
ServiceK
с ноя 2013
Дата: 06 Янв 2014 22:34:49 · Поправил: ServiceK (06 Янв 2014 22:52:20) #
У меня была 9350 а самого Codan не было , продал. Потом по дешевке NGT взял и опять стал искать антенну.Наткнулся на 9360 с антенной и решил тоже прикупить. Вот тут выставил сначала на продажу 9360 ,но уж больно понравился.Решил оставить для дачи. А вот куда новый ic-7200 теперь ?????.В запас ! продавать не хочу.слишком долго хотел его.
Да штырь хочу родной на MFJ-1966 заменить.
По поводу Покупки аппарата и Антенны. Все агрегаты из бывших союзных республик - (теперь незалежные государства). Барахолки рулят.....
Первый с Казахстана ,второй с неважно . Благодарен продавцам до безобразия.Не обманули. Все работает,все крутится.
А на какой СТЕЛС денег - то жалко?
Я вот теперь хочу попробывать AT-125 от МЕГАСЕРВИС .
Да NVIS HF Mobile Antenna Stealth 9400 такую за 10-12 тыр во владике встречал.
Имеется ввиду Владивосток (в Владикавказе еще не интересовался антеннами)
Кому файлы на выкладывание кинуть??????
Спасибо.
ServiceK
с ноя 2013
Дата: 06 Янв 2014 22:42:44 #
А что сломать-то там можно ????
Если не секрет.В файлах схема лежит 9350.
Я на машине ,для этого антенну сзади поставил за запаской полочку варил,а спереди АШ-4 с тюнером в крыле.
