На сайте: гостей - 76,
участников - 8 [ dxreceive, wazzoo, ic746, AlexR, Edd, John79, morze, andory]
 Форум —› Любительская радиосвязь —› Icom ID-5100 VHF/UHF D-STAR — новинка с тачскрином
R2ACN
с авг 2013
Дата: 02 Фев 2014 23:42:56 #
В Токио намедни показали новую мобильный транссивер ID-5100 с тачскрином на выносной морде (как у IC-7100). Совместим с приложением для Android, позволяющим пересылать через D-STAR фотографии и текстовые сообщения. Поддержка D-PRS. В продаже в Японии с конца февраля 2014 г.
Подробности (на английском)
Icom are pleased to announce details of the new ID-5100 dual band D-STAR mobile. As with Icom’s latest range of products, this new model has a new generation design and range of features including large, responsive touch screen LCD, Bluetooth connectivity and second station control through an Android device*.
* Optional Bluetooth unit UT-133 is required. Android software is available free.
Planned Features
• Large, responsive touch screen LCD
• Optional UT-133 Bluetooth unit enables audio accessory connection and Android terminal connection (CI-V via Bluetooth SPP profile).
• Optional VS-3 Bluetooth pendant earpiece microphone has volume adjust buttons, PTT and three programmable buttons. Third party Bluetooth audio accessories may also be compatible (not guaranteed).
• RS-MS1A Android application will be a free to use download. It controls the radio for DR mode operation, exchanging text messages/pictures and showing GPS location over Google Maps.
• Independent VHF and UHF band units (VV/UU capable) for 50W output
• Enhanced DR mode (also include analogue repeaters)
• Added “Nearby Repeater Scan” in DR scan function
• D-Plus reflector usability (can select “reflector” in TO field)
• DV Dual Watch for simultaneously waiting in two DV voice streams (decodes one only)
• Home button (same as ID-51 feature)
• D-PRS enhancements (details to be announced)
• 1,000 memory channels
• Built-in GPS engine (inside the controller, no EXT antenna possible)
• ESN (Electronic Serial Number) / SD Card slot (in the black box main unit).
• New HM-207 control microphone is supplied as standard.
• Other Features
o Wideband receiving (receives 118-137MHz(AM), 137-174/375-550MHz only)
o Antenna RX diversity (second antenna connector)
o TNC/9600bps modem connectivity
o DTMF decode (and mini-repeater control)
These are still preliminary details of the new radio series and specifications may change.
yury98
Дата: 03 Фев 2014 12:06:14 #
Могу добавить, что производство европейской версии планируется в марте-апреле и ориентировочная цена будет в районе 40000 рублей.
us8cp
Дата: 18 Фев 2014 02:09:09 · Поправил: us8cp (18 Фев 2014 02:21:24) #
в Америке можно будет купить
в начале марта...
и дешевле чем ждать когда в Европу то бишь к нам -приедет
да еще добавлю
вот эта беда
gps модуль с антенной= плюс к цене как минимум 360 баксов
и еще вот это
VS-3 -Bluetooth pendant earpiece-microphone(это на любителя блютуз)
еще 60уев как минимум в Америке
итого 850+360+60=1270уев....
и это в Америке а у нас ? умножить на 1.3---1.4..
круто за эту навороченную D-STAR станцию
у меня прекрасно работает в машине D-STAR такой тандем:
ICOM ID-51A +усилитель 144.....430 сдвоенный V-ULA-50 RM Italy (70вт50вт)+ анатенна DIAMOND SG-7700
счастье...все супер
