Поделюсь впечатлениями о продукте, представленном здесь -
http://herostechnology.co.uk/pages/SCR_Preselector.html
![](http://www.radioscanner.ru/uploader/2014/heros_photo.jpg)
Вот краткое изложение основных параметров (на сайте чуть подробнее):
- Six selectable bands and preselector By-Pass.
- Five Tuneable Band Pass Filter bank for HF Bands covering 1.8 to 30 MHz plus 50MHz band BPF.
- All filters are LC passive. No active switching or amplifier devices in the signal path, (LNA Off), therefore it does not contribute to IMD (Intermodulation Distortion).
- PTT feature enables connecting in-line with a 100Watts transceiver allowing to by-pass the preselector in transmission.
- Two antenna inputs and one antenna output lets insert a converter, filter, etc between the antenna and the Preselector.
- 0dB, 6dB, 12dB, 18dB input attenuator using MiniCircuits PAT series dedicated attenuation cells.
- Embedded -110dB stop band Broadcast MW Band Rejection Filter.
- Six Band Pass Filters.
- Tuning coils wound on large toroid cores T-106 size, rated for 100Watts RF applications, avoiding saturation in front of large signals.
- Band Pass Filters have Notch filters centered on the adjacent amateur bands giving an exceptional stop-band attenuation.
- Digital tuning. Nine bits variable digital capacitor. One pF resolution. (Variable capacitor emulator).
- Two embedded 7th order, 60MHz, Elliptic Low Pas Filter for FM broadcast band rejection and sampling frequency attenuation.
- Switchable low noise amplifier (LNA). 25dB Gain, 38dB IP3, 2.7dB Noise Figure.
- 12V DC/1Amp DC max. output connector for an external 150 Watts RF rating Input/Output by-pass dual power relay. (PTT or Keying line activated).
- Power supply: 12Volts DC/ 0.5Amp max. 2.5mm plug power connector.
- Dimension: 220mm x 165mm x 52mm (8.661 x 6.496 x 2.047in).
- Weight: 1.5Kg.
Начну с программного обеспечения. Оно отвратительно и бездарно. Видно, что программист на фирме один и он самоучка. Программа установки не требует, запускается сразу. Запустил, появилось какое-то окошко и быстро исчезло. Попробовал управлять, кнопки работают, как-бы аттенюатор переключается, предусилитель включается, частота перестраивается (правда, прямой ввод частоты не сделали в основном меню, хотя окошко программы занимает малую часть экрана, можно было бы увеличить окно и все функции вывести легко, видимо, человек как писал под мониторы 640 на 480 и 16 цветов, так и пишет). Только вот анализатор спектра показывает, что на самом деле ничего не происходит. В общем, не работает аппарат по всем признакам.
Но на самом деле просто нужны драйвера, и при запуске быстро исчезнувшее окно сообщало об отсутствующем подключении к аппарату. Вопрос – почему только эта надпись так быстро исчезает (будто аппарат обнаружен и проблема исчезла), а оболочка ведет себя так, будто все команды исполняются.
Попробовал поставить драйвер – не ставится, т.к. нет цифровой подписи. Почитал описание в папке с драйвером – эти ребята не сделали цифровую подпись и предлагают для windows 8 отключить проверку цифровой подписи (в инструкции -
http://herostechnology.co.uk/pdf/SCR_Preselector_CAT_User_manual_web.pdf - этот момент также описан). Приведена пошаговая инструкция:
By default Windows 8 enforces driver signatures (covert taxation); to disable it:
From the Metro or Desktop
Bring up mouse over to the right of the screen
Go to Settings
Change PC Settings
General
Advanced Start-up > Restart Now
Trouble shoot
Advanced options
Start-up Settings
Restart
New Blue Window: Start-up Settings/ 'Disable driver signature enforcement"/ press F7
Reboot
Install the relevant driver, allowing the non signed driver message to install.
Хорошо, уровень их единственного программиста уже давно ясен, отключаю защиту. Но винда все равно не принимает драйвер.
Ладно, преодолевая психоделическое меню на морде изделия, попадаю в режим местного управления преселектором. И вот здесь ждет основное разочарование.
Как Вам такая вот АЧХ:
![](http://www.radioscanner.ru/uploader/2014/hcopy_019.gif)
Это верхний для КВ поддиапазон.
Если выбрать диапазон пониже (кажется, от 9 до 15 МГц), то ситуация лучше:
![](http://www.radioscanner.ru/uploader/2014/hcopy_013.gif)
Поддиапазоны частично перекрываются, но по краям диапазона потери в полосе пропускания выше. Это видно на картинках в архиве:
http://www.radioscanner.ru/uploader/2014/heros_scr_preselecto.zip
Остается посмотреть интермодуляцию и шумы. Избирательность пока не впечатлила.
