Дата: 23 Окт 2014 01:59:19 · Поправил: Yupi (23 Окт 2014 13:41:34)
Собственно отсюда
The The CountyComm GP-5/SSB provides serious HF communications monitoring in a unique form factor and at a great price. The radio covers medium wave 520-1710 kHz shortwave 2300-30000 kHz and the FM band. Unlike most radios in this price category, the GP-5/SSB provides LSB and USB single sideband reception. It has a very unique Easy Tuning Mode (ETM). ETM does more the usual ATS. It scans all frequencies without taking up the memory spaces. So you get quick access to all local stations. Great for the traveller. There are also 450 regular memories (100 AM, 100 FM and 250 shortwave) available for tuning into your favorite stations. Another unique feature of the radio is its removable high sensitivity external AM ferrite antenna. This directional antenna clearly enhances AM band reception. The CountyComm GP-5/SSB even employs DSP (Digital Signal Processing) technology, improving clarity and tone quality. There is even an adjustable sleep timer.
The CountyComm GP-5/SSB can be powered by three AA batteries (not included). It also has 5V mini-USB DC input jack. When using the USB jack, the radio can be used to charge the batteries (rechargeable AA batteries only).
Your CountyComm GP5/SSB system includes: MW bar antenna, stereo ear buds, wire antenna and manual.
This new model is expected December 2014. We are not accepting orders quite yet. provides serious HF communications monitoring in a unique form factor and at a great price. The radio covers medium wave 520-1710 kHz shortwave 2300-30000 kHz and the FM band. Unlike most radios in this price category, the GP-5/SSB provides LSB and USB single sideband reception. It has a very unique Easy Tuning Mode (ETM). ETM does more the usual ATS. It scans all frequencies without taking up the memory spaces. So you get quick access to all local stations. Great for the traveller. There are also 450 regular memories (100 AM, 100 FM and 250 shortwave) available for tuning into your favorite stations. Another unique feature of the radio is its removable high sensitivity external AM ferrite antenna. This directional antenna clearly enhances AM band reception. The CountyComm GP-5/SSB even employs DSP (Digital Signal Processing) technology, improving clarity and tone quality. There is even an adjustable sleep timer.
Перевод вкратце выглядит так:
CountyComm GP-5/SSB позволяет серьёзный коротковолновой мониторинг в малом формфакторе и за небольшую цену, покрывая диапазон от 520 кГц до 30мГц с дыркой от 1710кГц до 2,3 мГц + конвенциональный FM. Он также позволяет приём SSB, имеет 450 ячеек памяти: 100 для АМ, 100 для FM и 250 для коротких волн. Радио имеет интеллектуальную функцию ETM(временное запоминание частот при сканировании без архивации их в постоянную память приёмника), цифровой процессор для улучшения качества приёма(разборчивости и тембра). В нём есть также настраиваемый sleep таймер. Одной из особенностей CountyComm GP-5/SSB являются: съёмная, вращающаяся ферритовая антенна, пятивольтовый вход мини usb и возможность зарядки 3-х аккумуляторов размера AA в самом приёмнике. В комплект входит съёмная ферритовая антенна, антенна "длинный провод", наушники и инструкция.
Модель ожидается в декабре 2014 года. |
Дата: 23 Окт 2014 09:17:47
Что то этот CountyComm сильно Тecsun 360 напоминает.
Дата: 23 Окт 2014 11:07:47 · Поправил: Yupi (23 Окт 2014 11:32:05)
vitalik76
Близнецы, но в проц забит и SSB, скорее всего с Тексаном вместе и забадяжили
Tecsun PL360
 Увеличить |
Дата: 23 Окт 2014 14:04:01 · Поправил: tigra (23 Окт 2014 14:11:20)
Дата: 23 Окт 2014 17:52:06
Дата: 23 Окт 2014 18:53:16
Очередное китайское говно?
Сорри, за резкое выражение, но нет ни капли доверия описанию. Да и цена соответствует.
Дата: 23 Окт 2014 20:51:27
Не скажите, Тексаны с ДСП, что у меня были 350 и 380 просто отлично работали на УКВ ФМ (лучше ДЕ 1103 и АЙКОМА Р8500 при прочих равных) и, так скажем, прилично на КВ. Им явно не хватало приёма на боковой и пошире диапазона. Вроде здесь это есть. я бы с удовольствием его покрутил. А цена? Так там считай пусто, копеечный процессор, коих штампуют миллионами, да ЖК дисплей с динамиком в хитом пластике.
Дата: 24 Окт 2014 01:54:31
ИМХО, китайцы делают шаг в сторону от рефренсной схемы, то можно ожидать подвоха.
PL-310 отличный приемник, все работает, как завещал разработчик микрухи.
Почти аналогично работает PL-880, но нововведенный режим SSB очень сырой; как после PL600 появился 660, так после 880 должно появиться что-то похожее, с менее сырым SSB. А GP-5 с ОБП - типа нашей первоапрельской шутки, поживем -увидим, может я ошибаюсь?
Дата: 28 Ноя 2014 09:53:37 · Поправил: Yupi (28 Ноя 2014 17:14:35)
Дата: 31 Дек 2014 08:00:52 · Поправил: clef30 (31 Дек 2014 09:45:52)
судя по видео неплохой приемник . продают какие то проходимцы из Калифорнии специализирующиеся на выживальческом барахле . http://www.countycomm.com/gp5ssb.html
копия 360 с добавкой одной боковой полосы , что интересно само по себе . |
Дата: 31 Дек 2014 08:33:44
Дата: 03 Янв 2015 17:20:45
Дата: 07 Янв 2015 23:07:53 · Поправил: us8cp (07 Янв 2015 23:55:59)
Только вот это что написано :
Turn on either the upper or lower sideband, depending on the meter band (generally, 40 meters and below are lower; all else, upper).
When you hear a signal, use the 1 kHz tuning increments to find where it’s strongest.
Now, press the BFO button once to activate BFO tuning; the U or L (indicating upper or lower) will begin to blink.
While the sideband indicator is blinking, use the tuning wheel to adjust the BFO. Adjust tuning until the voices in the signal sound natural.
в обзоре сразу отбивает желание ----покупать это китайское чудо
шаг 1кгц потом колесиком подбираем тон....
а ля Тексун 600.....ляпота
еще и дизайн.....нет слов....
кирпич узкий в длину.... 90г прошлого века
видимо короткого телескопа не нашли для антенны
и слепили из того что было...
Дата: 08 Янв 2015 00:08:49
us8cp
А по мне так наоборот, самый классный дизайн.
Не чета новомодным кривокосым зюзюлинам)
Дата: 08 Янв 2015 01:37:09
посмотрите в ЮТУБ ролики...на укус и цвет...
вопрос больше не к дизайну а к самой начинке
прием в SSB препакосный а сам процесс настройки в SSB
прошлый век..минимальный шаг шаг 1кгц однако...
и USB ...LSB нет переключателя а крутилка....
Дата: 08 Янв 2015 02:13:10
USB-LSB есть, крутилка для точной подстройки в пределах 1 Кгц. Будет продаваться как Tecsun PL-365. Если на батарейках будет работать как COUNTYCOMM GP-5 DSP 225 часов, то,наверное, имеет смысл купить. Полный диапазон, DSP, да ещё и SSB для кучи. Для рыбалки самое то.
Дата: 08 Янв 2015 12:55:29
только крутилка
как у Тексун 600
он у меня есть НО искать и подстраивать под нормальное прослушивание SSB
целое мучение....а уже у 660 сделали по уму без этого гимора
и цена адекватная..
так что Вам решать
Дата: 08 Янв 2015 16:42:44
Что деген, что 600 жрут батарейки как не в себя, проверено. Вот Ritmix RPR-7020 понравился больше, батареек хватает часов на 50-60. Если эта штука переплюнет его по экономичности, имеет смысл взять.
Дата: 08 Янв 2015 21:11:32 · Поправил: navigat (08 Янв 2015 21:20:07)
насторожило однако))))
Как то странно их сравнивать в таком контЭксте.
Дата: 08 Янв 2015 21:59:34
А чего странного сравнить время работы на одном комплекте батареек-аккумуляторов? Немаловажный фактор для карманного приёмника.
Дата: 08 Янв 2015 23:30:08 · Поправил: navigat (08 Янв 2015 23:41:17)
dir320
Немаловажный конечно. Но разве решающий? (как и цвет)) А как же например звук??? Мне вот DEGEN DE 1105 нравится на порядок больше, чем Ritmix7020, в том числе и по экономичности. Однако очевидно, что 1103 или 600 приёмники другого класса.
Дата: 09 Янв 2015 00:30:05
По звуку мне из транзисторов больше всего "Интеграл" нравится, из ламповых - "Pioneer SX-410", но их в кармане не потаскаешь. Для улучшения акустики ноутбука и Ритмикса-Тексуна есть вот такой бумбокс, звук чистый и мощный. CountyComm GP-5/SSB - Tecsun PL-365, из-за смешных размеров, DSP, условный SSB, и, надеюсь, рекордно малого энергопотребления, всё-таки будет болтаться у меня в кармане постоянно. Как приемнику, который всегда с собой и не мешается, да и потерять не особо жалко, пока конкурентов нет (из тех, что на борту имеют ОМ). Подожду пока отзывов и тестов первых владельцев. |
Дата: 09 Янв 2015 01:53:14
В России продается?
Дата: 10 Янв 2015 09:40:04 · Поправил: clef30 (10 Янв 2015 09:40:38)
кручу второй день этот аппарат . чувства смешанные . серьезные минусы - затыкание звука при ручном поиске по диапазону и хрупкий он какой-то легкий , при первой же попытке открыть крышку батарейного отсека она треснула по середине .
кому хочется подобный аппарат лучше подождать тексана который готовит к выпуску похожую модель с SSB . она будет дешевле с теми же характеристиками .
Дата: 10 Янв 2015 17:01:51
"Будем искать..."(c)
Дата: 10 Янв 2015 17:21:22
Уж очень удобный у него форм- фактор!
Дата: 28 Фев 2015 18:53:29
Tecsun PL-365 поступил в продажу!!!И PL-680 тоже.
Вообщем Anon-Co вернулся с новогодних каникул,и я все-таки заказал у него Tecsun PL-365-люблю компактные я,че поделать...Ну и видео посмотрел на YouTube,американские радиолюбители довольны этим аппаратом,вовсю крутят уже ...Заказывал не через eBay,а напрямую отсюда...кстати на eBay он так и не появился,Anon-Co видимо решил обойтись без eBay...
http://www.anon-co.com/product/pl365
У меня PayPal аккаунт то есть уже,я там просто зарегался и заполнил как надо и все...зарегался я давно уже,а вот только буквально не давно стал доступен к оплате PL-365,до этого он висел,но
как-бы нельзя купить было,не продавался,а на eBay и сейчас еще нет,вернее есть,там два каких-то иди##та из США,его толкают аж за 16 тыщ рублей!!! Больные...
У него же там,доступен PL-680-подороже конечно,а PL-365 обошелся в 3.830 рублей,47.99$+11.90$доставка...
P.S. И уже на следующий день,около 12.00 мск. был выдан трек-номер. |
Дата: 28 Фев 2015 18:56:23
Согласен,имею PL-360-действительно удобно пользоваться,при перевозке/переноске,места не много занимает...
Дата: 28 Фев 2015 19:29:58
А есть ли что-то похожее портативное, но с SD-картой для встроенной записи? (если бы еще имя файла называло в соответствии с частотой, было бы вообще круто)
Дата: 01 Мар 2015 05:33:02
Ого-о фантазия-с записью,еще и соответствие с частотой...)))...лет ****ть подождите,может что и появится...А так-DE-1125,1126,1127 с записью,при чем запись можно настроить по расписанию,DE-1129A-с записью+карта памяти(до 32Gb),RDS...но все без SSB
