На сайте: гостей - 69,
участников - 10 [ СЦБист, AlexRS, foxrus.87, sibirier, REGION86, UA0OAG, 4L6FU, milt, melom, Капитан]
 Форум —› Главный раздел —› Uniden BCD325P2. Еще одна "Handheld" новинка с поддержкой APCO-25 Phase I & II.
Tourist.223
с дек 2013
Somalia
Дата: 20 Мар 2015 18:35:58 · Поправил: Tourist.223 (20 Мар 2015 18:36:32) #
Собственно сам сабж:
ТТХ:
TrunkTracker V -- Tracks APCO Project 25 Phase I and II,
Motorola, EDACS, and LTR systems
25,000 Channels
Frequency Coverage
25.0000 - 512.0000 MHz
758.0000 - 823.9875 MHz
849.0125 - 868.9875 MHz
894.0125 - 960.0000 MHz
1240.0000 - 1300.0000 MHz
Channels: 25,000 maximum
Systems: 500 maximum
Groups per system: 20 maximum
Talkgroups per trunked system: 500 maximum
Channels per conventional system: 1000 maximum
Scan Rate: 100 channels per second (conventional mode)
Search Rate: 300 steps per second (on 5 kHz steps)
System Quick Key range: 0-99
Group Quick Key range: 0-9
Custom Search Ranges: 10
Startup Keys: 10
System Number Tagging: 999
Channel Number Tagging: 999
Preprogrammed Service Search Bands: 12
Band Scope Span Range: 0.2 MHz To 500 MHz
Band Scope Step: 5 kHz To 100 kHz
Band Scope Function
Frequency Span 0.2 MHz To 500 MHz
Frequency Step 5 kHz To 100 kHz
Two-Tone-Sequential
250.0-3500.0Hz , 0.1Hz Step Programmable
WX Alert
1050 Hz Tone System
NWR-SAME System (Warning / Watch / Advisory)
Supported trunking systems
Motorola Systems: Type I, II, II/I (hybrid)
EDACS Systems: FM, NFM, and SCAT
LTR Systems
APCO Systems: Astro Imbe, Astro 25
Dynamic memory allocation capacity
Systems: 500 max
Groups: 20 per system
Site: 1000 max (All) 256 per system
Channels: 25000 max (40128 memory blocks)
Channels per Trunked System: 500 max
Heterodyne System
1st IF: 380.7 to 380.8 MHz / 265.5 to 265.6 MHz
2nd IF: 10.8 MHz
3rd IF: 450 kHz
Обзоров на него пока нет.
Стартовая цена $499.99
Тетры и DMR разумеется нет и в обозримом будущем можно и не ждать.
Актуальность диапазона 1240.0000 - 1300.0000 MHz и емкость в 25000 каналов сомнительна.
Спасибо что не вставили цветной сенсорный дисплей и камеру для селфи, хотя miniSD явно бы не помешала..
Кто уже приобрел - делимся впечатлениями.
mzero
с июл 2011
Дата: 20 Мар 2015 22:29:54 · Поправил: mzero (20 Мар 2015 22:31:39) #
Судя по описанию, это тот же 396XT, но в корпусе от BC125AT, со следующей версией TrunkTracker и без поддержки GPS.
Я что-нибудь упустил? :)
Tourist.223
с дек 2013
Somalia
Дата: 21 Мар 2015 09:58:47 #
По GPS:
Location-Based Scanning
Connect this scanner to a compatible GPS receiver and it will automatically select programmed systems based on your exact location. You'll save time by scanning only the local signals.
На radioreference.com близки к мысли что в него можно всунуть всего две батарейки, а учитывая аппетиты BC125AT - жить скорее всего будет еще меньше.
Но размер радует, длинный 436HP все таки великоват для повседневного ношения..
Когда же они наконец решатся выпустить действительно что то революционное, на SDR, с поддержкой большинства форматов цифры и огромным заделом на будущее, выпускай себе специализированные прошивки для различных регионов (либо условий применения) и продавай их отдельно..
А уж варианты исполнения и модификации можно клепать десятками.
Pirat
с июл 2005
PI1RAT:)
Дата: 26 Май 2015 19:23:35 · Поправил: Pirat (26 Май 2015 19:27:36) #
Tourist.223
Скорее всего никогда. По крайней мере в ближайшем будущем точно. Ибо "сверху" просто не разрешат. AOR-овцы правда пытаются что-то такое изобразить, но в сравнении с функционалом Юниденов это вообще несерьёзно...
Кстати, цена на этот девайс радует. Но все же хочется дождаться отзывов пользователей. Кстати, его аналоговый предок 125AT мне не очень-то и доставил...
9c4772
Offline5.2
с июн 2005
Екатеринбург
Дата: 26 Май 2015 19:43:12 · Поправил: 9c4772 (26 Май 2015 19:56:16) #
На ебее Uniden bcd396xt в среднем дешевле продают чем Uniden BCD325P2. Так что я не разделяю оптимизм на счет цены на сканнер.
Добавлено.
Хотя наличие APCO25 Phase II делает Uniden BCD325P2 более интересным там где это востребовано.
Master485
с авг 2012
Дата: 26 Май 2015 20:31:23 · Поправил: Master485 (26 Май 2015 20:32:03) #
Фаза 2 на фиг не нужна! У нас ее не будет! К 2020 году будет свой стандарт в МВД!! Инфа 100%! Из ДИТС и ЗИ!
9c4772
Offline5.2
с июн 2005
Екатеринбург
Дата: 26 Май 2015 20:36:01 #
У нас ее не будет!
В наше время ни в чем нельзя быть уверенным. Особенно в такой длительной перспективе.
Pirat
с июл 2005
PI1RAT:)
Дата: 26 Май 2015 23:34:36 #
9c4772
396-й на данный момент и не должен стоить дороже сабжа по определению:) Модель-то свежайшая. Кстати, лично мне предыдущая моделька симпатичнее. Плюс небольшой осадочек от пользования 125-ми остался....
Konstantin
Offline5.3
Внуковская зона
Дата: 26 Май 2015 23:44:44 · Поправил: Konstantin (26 Май 2015 23:50:48) #
Сделали бы в таком форм-факторе аналог BC-346XT, да без дырки на 300-330 МГц, купил бы не задумываясь — нравятся мне эти информативные дисплеи и звук нравится. Но Фазы, транки и прочая "цифра" мне не нужна и переплачивать за это не хочется.
Киселев Егор
с авг 2013
Дата: 06 Июн 2015 21:29:27 #
А в чем тогда проблема то? Чем вас 125 не устраивает?
Konstantin
Offline5.3
Внуковская зона
Дата: 07 Июн 2015 00:39:18 · Поправил: Konstantin (07 Июн 2015 01:25:17) #
Киселев Егор
Отсутствием динамической памяти и привязанным к диапазонам шагам. Продал именно по этим причинам.
Киселев Егор
с авг 2013
Дата: 07 Июн 2015 13:28:08 #
Тогда без альтернативы 346, и стоит он не дорого. Извините за вопрос, а какой другой шаг вам нужен который не совпадает у 125 по сетке и на каком диапазоне?
Konstantin
Offline5.3
Внуковская зона
Дата: 07 Июн 2015 14:49:21 · Поправил: Konstantin (07 Июн 2015 14:50:26) #
Киселев Егор
Он у меня есть. Не нравится по звуку и дисплею.
На авиа там 8.33 жестко зашит. А хочется 25.
Киселев Егор
с авг 2013
Дата: 07 Июн 2015 14:50:06 #
А для каких целей 25 на авиа?
Konstantin
Offline5.3
Внуковская зона
Дата: 07 Июн 2015 14:51:10 #
Для более эффективного поиска.
Киселев Егор
с авг 2013
Дата: 07 Июн 2015 14:52:08 #
Но 8.33 * 3 = практически 25, да вроде и шаг на авиа 8.33, или нет?
Konstantin
Offline5.3
Внуковская зона
Дата: 07 Июн 2015 14:53:39 #
Киселев Егор
Нет. В России шаг на авиа — 25. А 8.33 это американская сетка.
Киселев Егор
с авг 2013
Дата: 07 Июн 2015 14:54:28 #
Понятно, я просто не сильно заметил разницу, видимо ш2 рядом.
Киселев Егор
с авг 2013
Дата: 07 Июн 2015 14:55:45 #
Хотя с другой стороны все частоты уже известны, и в 125 можно просто их забить сразу как на речном диапазоне и все.
Konstantin
Offline5.3
Внуковская зона
Дата: 07 Июн 2015 14:56:38 #
Киселев Егор
Если вы занимаетесь сканированием, то да. А если поиском, то нет.
Киселев Егор
с авг 2013
Дата: 07 Июн 2015 14:58:04 #
Может быть где нибудь глубже в область то поиск рулит, а в столице уже все что можно как я понимаю на авиа уже нашли - не будет же борт работать на новой частоте которую никто не знает.
Konstantin
Offline5.3
Внуковская зона
Дата: 07 Июн 2015 15:04:57 #
Киселев Егор
Рулит-рулит, еще как рулит!
А это смотря какой борт.
Егор, вы рассуждаете с позиции стационарного наблюдателя. А я очень много езжу. И прошитые номиналы мне просто не нужны. Я 346-й приемник использую исключительно как поисковый.
Киселев Егор
с авг 2013
Дата: 07 Июн 2015 15:08:35 #
Кстати на счет прошитых наглухо шагов сетки непонятно как наши умельцы до сих пор еще прошивку не вскрыли. Вы не в курсе что это за зверь Uniden Bearcat UBC 3500 XLT ?
Konstantin
Offline5.3
Внуковская зона
Дата: 07 Июн 2015 15:18:01 #
Киселев Егор
На Форуме есть волшебник. Его зовут xin. Эти вопросы к нему.
Киселев Егор
А по ассортименту у нас Pirat гуру. Я, увы, не в курсе.
forte
с мар 2009
Дата: 07 Июн 2015 21:44:40 #
Имею UBC 3500 xlt, это практически полный ручной аналог BCT-15
9c107
Offline4.7
с дек 2004
Свердловская область
Дата: 07 Июн 2015 22:45:51 · Поправил: 9c107 (07 Июн 2015 22:47:21) #
Ключевое слово "почти". Зачем же вы его имеете, им пользоваться надо! :)
Это во-первых европеец,во-вторых это "как бы" BR-330 c массой всяких полезностей, как например, работа в NFM в речном диапазоне, а так же возможность сканить в 343 мГц (у меня запрограммировано 40 р/т каналов, дабы в окрУге полным-полно радиоудлиннителей, не смотря на сотовую).
Вобщем, есть ещё достаточно полезностей и нужностей, "забытых" у американских братьев-близнецов.
forte
с мар 2009
Дата: 07 Июн 2015 22:59:49 #
9c107
Скажите, а сколько потребляет Ваш сканнер в дежурном режиме? Мой кушает почти 200mA, многовато что-то. Вот и интересуюсь, у всех так, или только в моём экземпляре?
9c107
Offline4.7
с дек 2004
Дата: 07 Июн 2015 23:11:51 #
Подрубил к БП, кажет 165мА без подсветки, с включенной подсветкой 185мА
xin
с июл 2006
ДВ
Дата: 08 Июн 2015 02:05:39 #
Существует слишком много всяческих радиостанций и сканеров которых нет у умельцев, либо которыми им неинтересно заниматься.
forte
с мар 2009
Дата: 08 Июн 2015 20:00:16 #
9с107
Спасибо!
