Дата: 11 Июн 2015 19:54:51
Радиосеть "Управления Линк" = PFP 605A
частота 4258.5 кГц, J3E/USB.
LUB - LUEBECK (FFGH) (F 214) (D-N)
19.20
AUE - VIK copied all ARB shift my unit unable shift to 600B do too ... line 464 unable change 600C do too 600C ...
VIK - AUE Roger int ATC
AUE - VIK ATC.1
VIK - AUE int change ATC
AUE - VIK Roger my unit change ATC.3
VIK - AUE copied system check PU 2
AUE - VIK Roger request back ATC.1
19.25
VIK - AUE int do you hold ADA.1
AUE - VIK hold c/s LUB ADA.1 on 600A and c/s FRE 601C ADA.1
VIK - AUE Roger many thanks for system check ...
All stations - AUE radio check
AUE - ABL radio check Over
AUE - JDM radio check Over
JDM - AUE do you hold any PU in Alligator
AUE - JDM currently not active Alligator at this time
21.40
OCN - VIC c/s SAN is ASB your unit ASA in line 600C
OCN - VIC my unit operating on 600A c/s SAN ASB line 600C
Линк 11:
2048.5 кГц - PFP 600A
9101 кГц - PFP 600C
22.30
OCN - VIC my unit operating UHF Alligator request your unit come up
Дата: 11 Июн 2015 22:56:48
Радиосеть "Координации ПВО"
частота 2392 кГц, J3E/USB.
Позывные:
SW - КП ПВО - США = JDM - JASON DUNHAM (DDG 109) (US-N)
SC - ЗКП ПВО
E -
L -
V - США
22.50
Работают на фоне шумоподобной передачи - сильная помеха.
SC - SW with my 2200z sitrep follows
line 2 - white
line 3 - ...
line 4 - 2
line 5 - 360
line 6 - ...
line 7 to 11 nothing to report
line 12 - ...
line 13 - PFP 605A
line 14 - PFP 600A
line 15 - Hurst
line 16 - active V M E
line 16b - V
line 16c - V
line 17 - active
line 17a - V L
line 17b - L
line 17c - V
intention to maintain RAP report COI CCOI
Дата: 12 Июн 2015 10:18:22
HER - HERMELIN (PGFGM) (P 6123) (D-N)
WIE - WIESEL (PGFGM) (P 6129) (D-N)
10.12
OCN - SAN unable kick ARB.1 PFP 600A at this time
OCN - SAN int 600C.3
10.40
OCN - IDK Alligator sitrep ASA c/s VIC ADB.1 c/s VIC AGA.1 Hurst ARA.1 this circuit ARB.1 PFP 600A
13.00
HER - AUE Over
WIE - AUE Over
JDM - AUE int AAW and ASUW sitrep for our area
AUE - JDM my air defence sitrep follows
line 1 - 1000z
line 2 - white
line 3 - ...
line 4 - ...
line 5 - 360
line 13 PFP 605A
line 14 PFP 600A
line 15 - ...
line 16 active
line 16a - V M E
line 16b - V
line 16c - V
line 17 - active
![](http://www.radioscanner.ru/uploader/2015/12jun.jpg) Увеличить
13.55
LUB - WIE
IDK - WIE your PU ADA.3 |
Дата: 12 Июн 2015 11:03:22
Дата: 13 Июн 2015 14:50:01
PET - PETER WILLEMOES (FFGH)(F362)(DNK-N)
07.55
OCN - VIC Alligator sitrep follows ARA PFP 605A ARA.2 PFP 601C ARB.3 PFP 600A AGA Hurst ASA VIC ANA ATP.1
09.20
FRE - ABL int track 3460
ABL - FRE track 3460 c/s GOK
09.30
OCN - VIC is you unit active PFP 600A Alligator
OCN - VIC did you copy my last
10.00
OCN - VIC hold you ADA.3 on 600A
PET - VIC Over
10.05
OCN - VIC my unit holding c/s SAN WIE HER AUE all ADA.1 your station ADA.3
OCN - VIC my unit operating 601C and 600A
ABL - VIC holding your unit ADA.1 for Timber ADA.3 for Alligator
10.22
SW - M Over
E - M Over
Вероятно ошибся радиосетью, это турок.
M - GOKSU (FFGH) (F497) (TUR-N)
Дата: 13 Июн 2015 14:52:07
07.30
L - SW int status ranger
L - SW ETA
SW - L ETA 08..
M - E Over
V - E Over
Дата: 13 Июн 2015 15:29:27
Час назад 2 В-52 с Фэрфорда к Шведам, ICER 11,12
Дата: 13 Июн 2015 20:39:48
Дата: 14 Июн 2015 20:08:36
ZIE - ZIERIKZEE (MHC) (M862) (NLD-N)
GNI - GNIEZNO (822) (POL)
URK - URK (MHC) (M861) (NLD-N)
20.00
SAN - VIC
track 3332 c/s FRE
track 3334 c/s LUB
track 3527 c/s ZIE
track 3575 c/s GNI
track 3406 c/s PET
20.15
OCN - VIC my unit operating ARB.1 and ARB.2 PFP 601C PFP 600A UHF and HF
20.25
OCN - VIC prelude HURST
21.15
OCN - VIC track 3003 is c/s URK
Дата: 14 Июн 2015 22:08:30
Дата: 14 Июн 2015 22:23:08 · Поправил: Mamadu (14 Июн 2015 22:26:11)
sibirjac
Там вроде Виксбург оживлённо обсуждают. А позывные возможно опять греческие острова или боги какие.
Дата: 14 Июн 2015 22:35:15
Mamadu
Там открытых наименований нет, обсуждают NGS event // Naval Gunfire Support//
Про богов и острова я помню ... спасибо.
Дата: 14 Июн 2015 22:50:02
Линк 11:
2308 кГц - ???
Дата: 14 Июн 2015 23:30:27
Позывные:
SW -
E - англ. Iron Duke ?
L -
V - Vicksburg?
H - немец
S - дат. ?
O -
Влезал в радиосеть JDM, сначала вызывал всех на 2393.5 кГц.
Дата: 15 Июн 2015 08:43:41
Радиосеть предположительно "Командная ОГ"
частота 2732 кГц, J3E/USB.
около 04.00
Проверки связи
IDK -
JDM -
WIE -
HER -
ABL -
All units - IDK ... request OPFOR on 203A //Opposing Force//
All units - IDK set watch PFP 605A
All units - IDK do too heavy ... on PFP 605A request all units set watch on PFP 605B
- JDM Roger out
- HER - Roger out
