Дата: 23 Май 2023 22:25:53
Дата: 25 Май 2023 21:10:08
Дата: 26 Май 2023 14:20:34
Дата: 31 Май 2023 20:06:59
Дата: 01 Июн 2023 13:30:10
09.49 - 11.10
EM 01, EM 02 два самолета F35 "Lightning II" ВВС Норвегии взлет и посадка на аб Эвенес.
09.49
EM 01 flight - Evenes ... military ... runway 35 flight level 200 squawk 1303 1304
09.50
EM 01 flight - Evenes wind 320 10 knots runway 35 clear for take off
10.53
Evenes - EM 01 approach EM 01 and 02 ... 1000
10.59
EM 01 flight - Evenes heading 200 aprox 200 10 miles to base
11.01
EM 01 flight - Evenes wind 340 10 knots runway 35
11.10
EM 01 flight - Evenes A1 Yankee to parking
https://www.nato-radio-scanner.ru/radiosvyaz/norvegiya/127-1-iyunya-em-01-flight-dva-f35-lightning-ii-norvegii |
Дата: 01 Июн 2023 16:43:58
16.00 - 16.32
Caret 23, Caret 43 - два самолета ВВС Норвегии перелет с аб Эвенес на аб Бардуфосс.
16.02
Caret 23 - Evenes squawk 2622
Caret 43 - Evenes squawk 2651
16.07
Caret 43 - Tower wind 340 9 knots runway 35 clear take off
Caret 23 - Tower wind 340 10 knots runway 35 clear take off
16.32
Caret 23, 43 - Evenes contact Bardufoss 118.8 //BARDUFOSS Approach:118.80//
https://www.nato-radio-scanner.ru/radiosvyaz/norvegiya/128-1-iyunya-caret-23-caret-43 |
Дата: 02 Июн 2023 11:09:03
Дата: 02 Июн 2023 11:11:06
взлет c аб Эвенес.
10.48
EM 01 flight - Evenes squawk 1303 1304
10.51
EM 01 flight - Evenes wind 230 7 knots runway 17 ... take off negative way
10.53
EM 01 flight - Evenes Roger contact tactic gold
Посадка на аб Эвенес
11.55
EM 01 flight - Evenes qnh1020 ... and requested active firing range RAMNES open do not flight below 500 feet over RAMNES open we can firing ...
EM 01 flight - Evenes you presently in RAMNES and south western ...
12.16
EM 01 flight - Evenes copy me on 369.325
12.18
EM 01 flight - Evenes wind 240 8 knots runway 17 good land
12.20
EM 01 flight - Evenes confirm parking M1
https://nato-radio-scanner.ru/radiosvyaz/norvegiya/130-2-iyunya-em-01-flight-dva-f35-lightning-ii |
Дата: 02 Июн 2023 17:53:42
Дата: 02 Июн 2023 21:07:33
sibirjac
P-8 "Посейдон" Норвегии
Приветствую.
У них с переходом с Р3 на Р8 в организации радиосвязи поменялось что-нибудь на КВ?
Дата: 02 Июн 2023 21:43:26
Mamadu
Приветствую!
Можно сказать P8 на КВ не работают ... или же я их не слышу ...
Дата: 02 Июн 2023 22:07:33 · Поправил: Romanbak (02 Июн 2023 22:08:06)
P8 на КВ
Несколько дней мониторю частоты БПА Норвегии, не слышу
Дата: 04 Июн 2023 13:23:51
Jaws 23 - P-8 "Посейдон" Норвегии, взлет с аб Эвенес, направление на аб Будё и далее на юг.
Evenes:
10.18
Jaws23 - good morning qnh 1016 ... to Evenes ... 1E departure flight level 80 squawk 2423
11.06
Jaws 23 - wind 240 13 knots runway 17 clear to take off
11.13
Jaws 23 - contact Polaris control 126.45
Bodo:
11.22
Bodo - Jaws 23 flight level 80
11.32
Jaws 23 - Bodo contact Polaris control 118.55
https://nato-radio-scanner.ru/radiosvyaz/norvegiya/134-4-iyunya-jaws-23-p-8-posejdon |
Дата: 04 Июн 2023 13:43:03
Дата: 05 Июн 2023 10:09:12
Swan 20 - P-8 "Посейдон" Норвегии № 9584
Evenes:
9.36 - 9.54
Swan 20 - Evenes good morning ... back to Evenes flight ... to 1E departure ... 90 squawk 2420
Swan 20 - Evenes confirm 1E departure
Swan 20 - Evenes started aprove qnh 1011
Swan 20 - Evenes taxi to holding point Runway 17 way Yankee
Swan 20 - Evenes line ... Runway 17
Swan 20 - Evenes wind 230 10 knots Runway 17 clear to take off
Swan 20 - Evenes identify passing to 3200 feet plan flight level 210
- Swan 20 copied level 210
9.58
Swan 20 - Evenes ... direct Tromse
- Swan 20 direct Tromse
10.00
Swan 20 - Evenes contact Polaris control 126.45
- Swan 20 126.45
Polaris - Swan 20 good morning to passing level 107 for ...
- Swan 20 live flight level 330
Alta:
10.20
Polaris - Swan 20 request
Polaris - Swan 20 estimated point {uplot} time 0747 and we to requested squawk operational now and to inclusive RVSM exeption
- Swan 20 affirm we are RVSM aproved but operational squawk will need RVSM exeption force
- Swan 20 thank you
- Swan 20 0737
Tromse:
15.32
Polaris - Swan 20 ... from flight level 200 for flight level 110
Polaris - Swan 20 switching Evenes 120.1
Evenes:
15.55
Swan 20 - Evenes wind 250 10 max 17 knots runway 17 good land
https://nato-radio-scanner.ru/radiosvyaz/norvegiya/135-5-iyunya-phone-20-p-8-posejdon-9584 |
Дата: 05 Июн 2023 17:50:42
Возможно HMS Queen Elizabeth в составе кораблей находиться в районе Вест-фьорд.
HMS Queen Elizabeth сегодня в районе Плимута
Дата: 05 Июн 2023 20:19:15
GlobeMaster
Спасибо.
Будем числить в районе Вест-фьорд только HMS Defender.
Дата: 06 Июн 2023 10:14:06
Дата: 07 Июн 2023 07:04:20
6 июня LAGR 33 - KC-135R Reg.:62-3541
В районе Polaris control sector 25, полет по направлению Буде, точка LEBDO.
14.57
clear direct BDO ... first point for Lagr 33
LEBDO Lagr 33
15.04
Lagr 33 - ... BDO
redirect BDO - Lagr 33
 Увеличить |
Дата: 07 Июн 2023 11:02:40
10.43 - 10.55
EM 01, EM 02 два самолета F35 "Lightning II" ВВС Норвегии взлет c аб Эвенес, squawk 1303, 1304, flight level 205, contact Polaris control 126.45
11.53 - 12.10
Посадка на аб Эвенес.
Дата: 07 Июн 2023 14:03:17
14.00 - 14.10
Saint 75 - P-8 "Посейдон" Норвегии подготовка к вылету с аб Эвенес, squawk 1675, Runway 17, участие в учении Arctic Challenge 2023.
14.11
Saint 75 - Evenes identify passing 4000 ft level 240
- Saint 75 f/l 240
Saint 75 - Evenes redirect GILEN
- Saint 75 direct GILEN
14.16
Saint 75 - Evenes identification terminate can you to ... military area flight level 240 contact FS16
- Saint 75 contact FS16 ...
14.19
Polaris - Saint 75 ...
14.26
Saint 75 - Evenes contact sweden 131.055
//SWEDEN CONTROL Flight Information Service Frequency: 131.055 MHz//
17.25 - 18.15
Saint 75 посадка на аб Эвенес
Дата: 08 Июн 2023 09:54:25
9.29 - 9.46
Nike 23 - P-8 "Посейдон" №9584 Норвегии взлет с аб Эвенес, squawk 2423, направление на север, точка EVANI, 2700 ft, flight level 150, contact Polaris control 126.45, патрулирование.
15.19 - 16.11
Возвращение на аб Эвенес, Runway 35.
При патрулировании в районе работал на частоте 6282 кГц, вид передачи Link 11.
Дата: 09 Июн 2023 10:19:53
9.55 - 10.12
EM 01, EM 02 два самолета F35 "Lightning II" ВВС Норвегии взлет c аб Эвенес, Runway 17, squawk 1303, 1304, contact Polaris control 126.45
11.34 - 11.44
Дата: 09 Июн 2023 14:48:42
13.08 - 13.51
Saint 75 - P-8 "Посейдон" Норвегии №9584 вылет с аб Эвенес, squawk 1675, Runway 17, направление точка PEMAB, участие в учении Arctic Challenge 2023.
17.07
Дата: 12 Июн 2023 21:24:35
9.27 - 10.06
Nike 23 - P-8 "Посейдон" №9584 Норвегии взлет с аб Эвенес, Runway 17, squawk 2423, направление на север, точка EVANI, contact Polaris control 126.45, патрулирование.
16.10 - 16.23
Возвращение на аб Эвенес.
Дата: 13 Июн 2023 10:08:41
9.32 - 10.06
Hydra 21 - P-8 "Посейдон" Норвегии №9583 взлет с аб Эвенес, Runway 17, squawk 2421, направление на север, точка EVANI, contact Polaris control 126.45, патрулирование.
15.39 - 16.08
Посадка аб Эвенес.
Дата: 13 Июн 2023 11:33:31
03.30 - 11.08
Poseidon 18 - P-8 "Посейдон" Норвегии №9582, перелет с аб Патаксент-Ривер на аб Эвенес, 10.50 - 11.08 посадка на аб Эвенес, contact Approach 120.1, Tower 118.0, Runway 17, оператор (экипаж?) США.
Дата: 14 Июн 2023 10:08:02
9.46 - 10.02
Saint 22 - P-8 "Посейдон" Норвегии №9584 взлет с аб Эвенес, Runway 17, squawk 2422, направление на север, точка EVANI, contact Polaris control 126.45.
Дата: 15 Июн 2023 09:28:58
По данным flightradar на evenes 5 бортов ВВС Швеции летят
Дата: 15 Июн 2023 09:29:33
Даже 6 бортов
