Дата: 03 Авг 2016 12:18:17 · Поправил: tigra (03 Авг 2016 12:34:56)
Информация появилась на офф.сайте - deepace.net и в группе FB.
The S9-C broadband SDR receiver covers a frequency range of 0.25-1002MHz.
The SDR performs a direct sampling when receiving signals below 54MHz.
While above 54MHz, it down-convert the signal.
Real-time spectrum display, demodulation, record and other digital signal processing has 1200 KHz bandwidth.
(1). Providing 2-SMA antenna port, HF+UV and UV-only antenna port.
(2)The SMA ports have gas-discharge-tube protection.
(3)8 electronically switchable pre-selector with high dynamic range.
(4)In U/VHF bands, it uses tracking filter to reach image rejection rate higher than 70db.
(5)equipped with Mini-circuits LPF-B50+ anti-alias low pass filter.
(6)ADL520 (same type in FLEX6700)large dynamic pre-amplifier (OIP3>50dBm).
(7)SI570/514 low-jitter arbitrary frequency synthesizer system clock.
(8)0.28ppm 20MHz TCXO tertiary clock as the overall frequency standard.
(9)Linear LTC2208-16 130MPS high accuracy and high speed ADC.
(10)ALTERA’s high-capacity FPGA (EP4C115) for multichannel and more application.
(11)Using FT232H (FTDI’s high-speed USB2.0 frontend).
(12)Two FPGA expansion interface ports with power supply and clock.
(13)Reference clock’s injection interface REF CLK inside
(14)Able to be operated with other famous software like HDSDR, CUSDR, SDR# and GUNRDIO etc.
(15)Support the operation systems like Windows series (XP, 7, 8, 10), Linux and IOS etc.
Receiver Type <54MHz ADC direct mining/>=54MHz direct mining after primary frequency conversion
frequency Range 0.25-54MHz/54-1002MHz
Sampling Rate 120MHz
Sampling Accuracy 16bit
ADC LTC2208-16
VU down-conversion TDA18275A Tuner Template
Frequency Resolution 1Hz
Demodulations AM/FM/SSB/DSB/ISB/CW/PSK……
IP3 +28dBm +19dBM(pre-amp on)
Pre-amplified 0~+10dB 1dB STEP Template
Attenuator 0~-20dB 1dB STEP
Spurious Free Dynamic range (SFDR) 107dB 103dB pre-amp on
Minimun Detectable Signal (MDS) -133dBM@10MHz,500Hz BW-137dBM @ 10MHz,500Hz BW pre-amp on
Phase Noise -145dBc/Hz @ 10kHz
RSSI Accuracy 2dB
Recording and Demod DDC Bandwidth 3000 KHz
Sensitivity
AM -106dBm 1.12uV @ 10dB S+N/N 30% modulation @ 14MHzSSB -121dBm 0.2uV @ 10dB S+N/N 2.1k BW @ 14MHz
CW -127dBm 0.1uV @ 10dB S+N/N 500Hz BW @ 14MHz
FM -117dBm 0.32V @ 12dB SINAD 3K Offset Frequency 12kHz BW
Audio Filter 300-3000Hz De-emphasis -6dB/0ct
Preselecting Filter Multiband Filter Template
Antenna Protection Gas Discharge Tube
Power Demand 6V 2A DC
Data Output 24bit IQ
Audio Output PC machine
Operation Temperature 0~50 Centigrade Degree, Non Condensation
Shell Volume 148.5mm * 88.5mm * 34.5mm(Non Protrusion)
Antenna Interface Double SMA 50
Program Loading Power-on Automatically Load
Extend Module TX、ATU、POWER AMP、ATT Template
Control and Communicate Interface USB 2.0 HS
599.00
Дата: 03 Авг 2016 12:48:59 · Поправил: Olenevod (03 Авг 2016 12:52:21)
С вентилятором в крышке корпуса ? :)
по описанию вроде хорош, но дорогой
Дата: 03 Авг 2016 12:53:50
Direct sampling, 16bit, 599$? Нормальная цена.
Дата: 03 Авг 2016 13:05:58 · Поправил: Olenevod (03 Авг 2016 13:21:27)
Вообще они уже утомили, не успели Lime разослать всем желающим, XTRX еще не продаются, так этот выпустили уже и продают. Глаза разбегаются. Все-таки эра SDR весьма интересна своей движухой. В аналоговом мире по 10 лет на одном месте стояли.
Дата: 03 Авг 2016 14:12:08 · Поправил: AOR (03 Авг 2016 14:14:30)
Это лишь так казалось последнее время, когда уже перепробовали все схемы и не появлялись компоненты с кардинальными улучшениями, сделать приемник чуть лучше оказывалось сильно дороже. И то, лишь на первый взгляд, однако в "аналоговом мире" в его начале и в середине 20 века прогресс был постоянный. А если более глубоко взглянуть в тему, то применение DSP, более мощных процессоров управления, меняло и "аналоговую" технику, её возможности даже в последние годы.
Эра SDR началась лишь 15 лет назад и только сейчас появились действительно годные и доступные для любителей устройства, понятно что совершенствование компонентной базы, схемотехники и софта сейчас будет очень бурное.
Дата: 03 Авг 2016 14:26:09
0.25-1002MHz.
Маловато по верхнему участку. Хоть бы до 1700 дотянули бы!
Дата: 03 Авг 2016 15:31:33
Это не для любителей инмарсат)))
Дата: 03 Авг 2016 16:18:50
DVE
Direct sampling, 16bit, до 54-х : direct sampling when receiving signals below 54MHz.,
а дальше - >=54MHz direct mining after primary frequency conversion
marvel
0.25-1002MHz. Маловато по верхнему участку. Хоть бы до 23см дотянули бы... ИМХО.
Дата: 03 Авг 2016 16:21:38
Дата: 03 Авг 2016 16:37:55 · Поправил: tigra (03 Авг 2016 16:43:58)
Судя по выложенной схеме оного:
Ссылкой не кинете на обсуждение на CqHAM? (чет никак не вижу...)
Может не от него pdf-ка?
Дата: 03 Авг 2016 16:56:31
tigra
В этой теме на второй странице ссылка на эту пдф-ку. |
Дата: 03 Авг 2016 16:58:38
TNX!
Чёт не видел, оказца давно уже...
Дата: 03 Авг 2016 17:11:13 · Поправил: marvel (03 Авг 2016 17:11:59)
На самом деле верхняя граница задается конвертером TDA18275A, и если нет аппаратных ограничений то прием теоретически возможен и свыше гига.
Вообщем надо писать китайцам, и все уточнять.
Дата: 03 Авг 2016 17:17:03
Себя же поправлю. Судя по http://www.nxp.com/documents/short_data_sheet/TDA18275_SDS.pdf аппаратные ограничения все-таки есть: fRF RF frequency full range of RF input 42 - 1002 MHz
Хотя сам чип сам по себе и неплохой для УКВ: ICP1dB 1 dB input
compression point
at the tuner input and
minimum gain
120 - - dBV |
Дата: 13 Июн 2017 22:22:49
В "фейсбуке" сегодня проскочило сообщение о еще одном появившемся изделии от Deepace:
Deepace SDR development kit DSK-1 for radio communication research. It include a high performance SDR hardware that cover 70Mhz to 6GHz frequence and 2 wideband antenna with cable. It is a full function radio communication develop platform for every RF researchers.
![](http://www.radioscanner.ru/uploader/2017/tb2kkvlsrnkpufjy0fax.jpg) Увеличить
Frequence range 70Mhz-6GHz
Using AD9361 provide 56MHz real-time bandwidth
Full duplicate 2*TX/RX and MIMO support
High performance LX150 FPGA
Full compatible with USRP B210
Support Gnu radio, OPENBTS, LIBVIEW
Max Power Out Put 10dBm typical.
http://www.deepace.net/shop/deepace-sdr-development-kit-dsk-1/ |
Дата: 14 Июн 2017 02:32:24 · Поправил: tt01 (14 Июн 2017 02:33:47)
И на это чудо какой софт? Старый кривой SDR в заплатках? Особено для MAC до сих пор не наблюдаю ничего серьезного (((
Дата: 14 Июн 2017 17:29:07 · Поправил: tigra (14 Июн 2017 17:30:43)
tt01
А для HackRF-One какой???
Наверно такой же, там же указано:
Support Gnu radio, OPENBTS, LIBVIEW...
И о каком конкретно "старом кривом и в заплатках SDR" речь - я вообще не понял!
