Радиосеть "Донесений ОГ/Управления Линк"
частота 5069.5 кГц, J3E/USB.
Позывные:
0WI - общий вызов
3EJ -
8WS - немец
KE6 -
P0A -
2DP -
2NE - КП РЭР?
D9Q -
T3X -
21.05
3EJ - 8WS suspect 7000 178 Rome 3.4 =
suspect 7226 164 Rome 6.8 =
suspect 2712 164 Rome 9.6 =
suspect 7211 158 Rome 12.6 = Over
3EJ - P0A suspect 7008 is ID as tattoo 7008
suspect 7226 is ID as tattoo 7222
suspect 7230 is ID as tattoo 7212
suspect 7211 is ID as tattoo 7211
21.20
P0A - 8WS request PCS
8WS - P0A request authenticate -1820
P0A - 8WS authenticate T
8WS - P0A authenticate M2
P0A - 8WS authenticate S
8WS - P0A Roger my signal NA22 012 Rome 12 tracking 000 speed 9
21.32
KE6 - 8WS request your PCS
8WS - KE6 NA22 040 ... 8.1 tracking 165 speed 9.7
P0A - 8WS did you have position screen contact in 017 Rome 5.8
8WS - P0A regarding your last affirm I hold 1 neutral visual identify as INA3
![](http://www.radioscanner.ru/uploader/2016/ina3.jpg)
Можно вычислить REF POINT - Rome
INA3 - примерно 5500сев 01235вост
21.42
8WS - 3EJ request up-date tattoo 7211 7212 7222
0WI - 8WS tattoo 7211 129 Rome 14
tattoo 7212 108 Rome 5
tattoo 7222 077 Rome 3.3
22.07
0WI - 8WS tattoo 7222 059 Rome 7
tattoo 7212 057 Rome 7.7
tattoo 7008 202 Rome 3.9
tattoo 7211 115 Rome 18.8
22.29
3EJ - P0A my NA22.5 012 Rome 12.4 tracking 157 speed 05
P0A - 3EJ my NA22.5 106 Rome 34.2 tracking 148 speed 10
23.15
KE6 - 8WS check your NB 207
23.47
0WI - 2NE new Racket from tattoo 7222
23.52
3EJ - 2NE new Racket DA.08 from tattoo 7210 in bearing 267
00.02
8WS - P0A do you hold c/s T3X
P0A - 8WS negative
00.24
0WI - 2DP entering this net authentication time 2124 authenticate M
00.30
3EJ - 2DP int ref point Rome in force
00.40
8WS - 2DP int information over friendly track 7201 faker 2324 faker 7226
00.47
2DP - 8WS track 7201 is c/s KE6 = track 7222 is tattoo 7222 = track 2324 is
really russian warship AGI identify by visual - наш разведчик на учении ...
00.50
0UI - 8WS track 2324 position 076 Rome 25.3 tracking 257 speed 10
01.45
0UI - 8WS Joker 2521 position 222 Rome 6.3 heading 254 speed 1 identify tattoo 7008
8WS - 3EJ int tattoo 7005
3EJ - 8WS tattoo 7005 position 070 Rome 16.8 tracking 259 speed 1
01.50
3EJ - P0A signal NA22 006 Rome 48.3 tracking 18 speed 11
