На сайте: гостей - 59,
участников - 1 [ Атлас]
 Форум —› Главный раздел —› КВ DSP радиоприёмник "Белка"
Зарядные устройства
Гарнитуры и тангенты
Аккумуляторы
Динамики
Переходники
 Страница:  ««  1  2  ...  140  141  142  143  144  ...  195  196  »»Поиск в теме
alexwilks
с авг 2015
Йошкар-Ола
Дата: 12 Ноя 2021 09:55:32 #
По совету автора приемника Belka приобрел конвертер 0-1500 кГц производства SV2CZF Theodoros
Although V-LFR10 is a very new product and it's webpage is still under construction, it is now available for sale only for direct orders accepted by email and the payment can be made by PayPal or bank transfer
It costs 49,99 EUR plus 6.99 EUR for registered post shippings
V-LFR10 is an RX up converter that shifts the entire
0 - 1.500 KHz frequency range to the 10.000 - 11.500 KHz frequency range.
It is a Hi-Z input unit optimized for use with telescopic whip antennas but it also accepts many other antenna types.
It is amazing that with just
1 meter long telescopic antenna gives great reception results down to the VLF frequency range.
Output impedance matches the also Hi-Z input of the Belka DSP and Belka DX radios makes it a great little unit to easily extend the lower frequency end of the Belka receivers down to just few kHz.
You can now scan and receive on all VLF - LF - MW bands with your Belka radio.
Tune your Belka above 10.000 MHz and just ignore first digit (1)
This means that if you want to receive at 729 kHz AM you have to tune your radio to 10.729 MHz
If you want to receive 77.5 kHz
Tune the radio to 10.077,5 MHz.
Although V-LFR10 RX converter is optimised for the Belka radios it will also work with other portable radios like icom R30, R20, AOR 8200, Malachite SDR and others.
Most of these portables can't go below 150 or 100 kHz or their performance on these LF frequencies is very poor.
The V-LFR10 will extend their lower frequency end and it will also improve their reception performance in the entire frequency range up to 1500 kHz.
The unit is powered from a 6V battery type 4LR44 which is replaceable by the user.
A new alkaline battery operates the unit for approx 65 hours.
First battery is included so you can try your unit out of the box.
Handling time is 2-4 working days after payment received
No antenna loop or whip or telescopic is included, you will only get the V-LFR10 RX up converter unit with a battery inside.
Please don't forget, this is a receive ONLY converter, it's not a transverter,
Пока протестировал с рамкой LZ1AQ, ловит хорошо на MW, на VLF просачиваются вещалки, похоже, фильтров нет.
Позднее потестирую на улице со стандартным телескопом 80см от Белки.
фото конвертера по ссылке
SLB_MN
с дек 2017
Ставрополь
Дата: 12 Ноя 2021 11:20:43 #
alexwilks
Спасибо, интересный конвертер, маленький, и даже питание есть у него, мне нравится. На моих самодельных конвертерах VLF чисто проходит с Белкой, нет побочных эффектов. На Малахите надо иногда, когда прохождение сильное, ATT включать. Мои конвертеры ток жрут из за транзисторного 50-омного выхода, но можно конечно выход и одним витком реализовать, кому ровная АЧХ не так важна.
alexwilks
с авг 2015
Йошкар-Ола
Дата: 13 Ноя 2021 18:22:38 #
В продолжение темы про совместную работу конвертера с Белкой.
Проверил работу на улице с родным 80см телескопом и 120см, длинный даёт чуть больше сигнал на ДВ, фантомов или сигналов с КВ, СВ не было, все чисто, приятно слушать на Белку. На улице слышно 153, 171, 225 и 270кГц (присутствие) и битком забит СВ диапазон.
Видео приёма 225 кГц на 80см телескоп:
225кГц Belka-DX
SLB_MN
с дек 2017
Ставрополь
Дата: 01 Дек 2021 00:10:49 #
Товaрищ Игонин гуляет c Белкой:
Что нaдо делaть, когдa нaдоело рaдио cлушaть:
igorevich88
с мая 2017
Хабаровск
Дата: 05 Дек 2021 16:30:17 #
Кажется в VLF есть смещение на пару килогерц ниже реальной частоты:
https://www.youtube.com/watch?v=80E3TCFvkFw&t=9s
https://www.youtube.com/watch?v=IdcsqM_wHn4&t=84s
r75
с авг 2018
Белгород
Дата: 09 Янв 2022 16:01:56 #
alexwilks
Приветствую.
А где вы приобрели конвертер?
Во сколько обошелся?
М.б. фото внутренностей есть?
SLB_MN
с дек 2017
Ставрополь
Дата: 09 Янв 2022 16:09:21 · Поправил: SLB_MN (09 Янв 2022 16:09:47) #
igorevich88
А 10,000МГц точно у него нacтроен? Это можно и "через воздух" измерить.
buka
Подмосковье
Дата: 09 Янв 2022 19:57:24 #
r75
Основная инфа есть у sv2czf на facebook:
"Новый продукт, заказы только по запросу, оплата PayPal, цена 49,99 Евро плюс доставка"
r75
с авг 2018
Белгород
Дата: 10 Янв 2022 05:52:18 #
buka
Спасибо за информацию.
Цена конечно зашкварная.
Вот бы схемку посмотреть или фото внутренностей, но пока не нашел.
Ничего там сложного нет. Смеситель и генератор, ну и м.б. фильтр на входе.
r75
с авг 2018
Белгород
Дата: 17 Янв 2022 15:10:16 · Поправил: r75 (17 Янв 2022 15:11:22) #
alexwilks
Вы вскрывали конвертер?
Интересно глянуть.
Kolomchanin
с янв 2013
Коломна
Дата: 18 Янв 2022 09:50:39 #
Смотрим внимательно на фотку...))
https://mp.weixin.qq.com/s/skH4JRCjSUGokmVkhKTNbQ
r75
с авг 2018
Белгород
Дата: 18 Янв 2022 13:00:20 #
Kolomchanin
Радует, что Белка засветилась на обложке такого издания!
Правда в такой компании, ну да и ладно.
alexwilks
с авг 2015
Йошкар-Ола
Дата: 18 Янв 2022 13:36:05 #
alexwilks
Интересно глянуть.
Открывал заднюю крышку, там мелкая батарейка 4LR44 6V питание, оригинально сделано,
плата на треть занята элементом питания, еще столько же залито пластиком.
Поскольку меня не интересует начинка, знаю много схем конвертеров, то просто пользуюсь им и доволен.
Это у Белки смещение в режиме CW (по факту телеграф в Белке - это узкая SSB), поэтому так кажется.
alexwilks
с авг 2015
Йошкар-Ола
Дата: 18 Янв 2022 13:42:11 #
После пребывания Belka-DX на морозе ручка валкодера перестает реагировать, словно "замерзает".
Говорят, есть вариант замены на валкодер с "трещоткой".
Кто-то сталкивался, что-то меняли?
r75
с авг 2018
Белгород
Дата: 18 Янв 2022 15:39:58 · Поправил: r75 (18 Янв 2022 15:41:00) #
залито пластиком
Как то не догадался, что будет залито.
М.б. дадите ссылки на схемы конвертеров.
Не на теорию, а на реальные конструкции.
Вы каким способом покупали конвертер?
По ссылке на пэйпал или списывались с автором?
Во сколько все обошлось?
Что бы тут не рекламировать можно в личку.
Спасибо.
kia59
с мая 2020
Латвия
Дата: 18 Янв 2022 22:11:54 #
Radiouser 11.2021 и Белка)
andory
с июн 2015
Дата: 18 Янв 2022 22:56:41 #
kia59
Результаты теста в соседней теме
r75
с авг 2018
Белгород
Дата: 21 Янв 2022 05:14:55 · Поправил: r75 (21 Янв 2022 05:16:09) #
SLB_MN
А можно поподробнее про ваш конвертер.
Можно в личку.
SLB_MN
с дек 2017
Ставрополь
Дата: 21 Янв 2022 12:31:07 #
r75
Вcё в этой ветке опиcaнно. Мне cейчac копaть некогдa.
Edd
с ноя 2007
Подмосковье
Дата: 21 Янв 2022 16:56:07 · Поправил: Edd (21 Янв 2022 16:59:54) #
Просьба, кто может, разместить записи приёма ДВ/СВ на Белку с конвертером. Пока видел только приём 153, 225, 810 кГц. Как принимаются, например, Исландия - 189, 207 кГц, Индия, Япония на СВ и т. п. - вообще дальние и слабые станции. Вести ФМ, Свобода, Румыния, Иран и др. мощные "монстры" не интересуют. Сравнение с Дегеном, Санжином, Сони вообще бы было здорово.
r75
с авг 2018
Белгород
Дата: 22 Янв 2022 10:56:26 #
SLB_MN
спасибо
SLB_MN
с дек 2017
Ставрополь
Дата: 22 Янв 2022 11:32:10 · Поправил: SLB_MN (22 Янв 2022 11:53:24) #
r75
спасибо
Не зa что cпacибо говорить, я же вaм ничего не зaпоcтил. Теперь еcть время, вот вaм ccылки.
Это оригинaльнaх cхемa VLF-LW конвертерa:
https://www.box73.de/product_info.php?products_id=3164
Еcли cильно cложно, еcть по проще конвертеры, тут нaпример cхемa нa SA602:
Тут я передaлaл cхему от Box73 нa VLF-MW и c входным трaктом нa мaгнитной aнтенне, для домaшнего пользовaния. Стaрaлcя везде импедaнcы и привaзку прaвильно подогнaть, итд. Извиняюcь что зaново не нaриcовaл, хотел проcто изменения в cрaвнении c оригинaлом покaзaть:
КВ DSP радиоприёмник "Белка" - Страница 140
Позже я cделaл тaкой же конвертер, но c телеcкопом нa входе, для выходa нa природу:
КВ DSP радиоприёмник "Белка" - Страница 141
Тaк кaк хотелоcь 50 Ом нa выходе иметь, и довольно ровную АЧХ, оcтaвил этот прожорливый кacкaд нa выходе c ВС550В. Но жор тaм большой получaетcя, позже зaменил 100 Ом нa его коллекторе нa 220 Ом, и тaк хвaтaет. Чтобы cовcем убрaть большое потребление токa, нужно проcто cделaть вторую выходную обмотку нa Т1, одного виткa хвaтит, но АЧХ конечно тaкaя ровнaя не будет, нa что можно и нaплевaть еcли cильно не нaдо. Нa выходе кacкaдa cделaйте ещё 47 Ом поcледовaтельно, по cовету в ветке.
Прaвильнaя привязкa к Белке оcтaётcя открытым вопроcом. Некоторые делaли тут бaлун итд. Можно конечно и 50 Ом нaпрямую к Белке, и рaботaет вроде, но конечно не тaк идеaльно кaк c телеcкопом, не нa cчёт приёмa, a нa cчёт звукa. Через переменный конденcaтор, кaк было когдa-то зaявленно, вcё рaвно лучше не выходит. Видно не cовcем резонaнc получaетcя, кaк c телеcкопом.
r75
с авг 2018
Белгород
Дата: 22 Янв 2022 11:37:20 #
SLB_MN
Большое спасибо!
Хотел к Белке сделать конвертер, а то готовый у грека ну уж очень дорогой.
М.б. для них это копейки, а для наших пенсов дороговато.
SLB_MN
с дек 2017
Ставрополь
Дата: 22 Янв 2022 11:38:14 #
А cколько cтоит у грекa? Вроде видел 29 евро?
r75
с авг 2018
Белгород
Дата: 22 Янв 2022 13:29:29 #
SLB_MN
Почти 5 тыр!
andory
с июн 2015
Дата: 22 Янв 2022 16:22:04 #
Потратив ~12т.р. на Белку за новый диапазон ещё 5т.р. вполне адекватная цена.
Для путешествий по радиоволнам на улице/природе Белка очень подходит. Малахит ещё лучше, существенно дороже и тяжелее. Вдвое дешевые D-808 и pl-330 неудобны, а сравнимый по цене pl-880 уже великоват для прогулок/ постоянного ношения с собой.
Обсуждаемый конвертер, 6в 2,5мА. Это маловато, а с учетом, что питание от экзотической недешевой батарейки, крайне неудобно. Был бы он с аккумулятором и встроенной зарядкой, как в других устройствах грека, было бы интереснее. Ещё лучше конвертер встроить в Белку-2, при сохранении адекватной цены.
r75
с авг 2018
Белгород
Дата: 22 Янв 2022 17:20:58 #
andory
Я бы не сравнивал Белку и Малахит с китайскими мыльницами.
Малахит прилично работает только с полноразмерными антеннами, а на телескоп
фигня, а не прием. Если бы не водопад, то я не знаю сколько бы у него было поклонников.
Цена в половину стоимости приемника не адекватная.
Приемник законченная конструкция, а конвертер, как дополнение.
2-3 тыр была бы вполне норм.
sergsib
с сен 2015
Дата: 22 Янв 2022 18:07:25 #
фигня, а не прием
Похоже у Вас нет ни Малахита, ни хорошей направленной антенны, а только полноразмерные.
Малахит вряд-ли выдержит направленную антенну, ее Элад не выдерживает, а тут Малахит.
Сколько еще, Вы будете в каждой ветке нести бред про телескоп?
Хотите сравнение, вот пожалуйста, прием СВ станции за 16000км 1350kHz , Radio Buenos Aires (Argentina), ELAD FDM-S2 (SDR Receiver), antenna - Beverage 300m/300deg.
1350kHz , Radio Buenos Aires (Argentina), Tecsun PL-880 receiver, telescopic antenna
Что сильно большие отличия по приему? Вы не расслышали Radio Buenos Aires, вы не услышали слово Аргентина? Что Вам еще показать в сравнении, Австралию, Филиппины, может США?
r75
с авг 2018
Белгород
Дата: 22 Янв 2022 18:49:01 #
sergsib
По поводу бреда язык прикусите.
Был у меня и первый и второй вариант Малахита.
Это у вас видимо нет Малахита, а то знали бы на счет помех от тача и пораженные области и частоты.
Смотрите видео и читайте форум по поводу этих проблем.
Внешняя антенна выправляла эту проблему.
Вы, как с шпингалетами со своим СВ DX.
Разговор не об этом.
sergsib
с сен 2015
Дата: 22 Янв 2022 18:55:38 #
У меня есть руки и голова, поэтому, пораженных областей в моем Малахите нет.
А у Вас видимо только язык есть, да еще который прикусили, раз другим советуете!!!
Время загрузки страницы (сек.): 0.254; miniBB ®
