На сайте: гостей - 54,
участников - 2 [ Dr.Floid, Фотограф]
 Форум —› NATO Scanner —› Учения НАТО - Joint Warrior 202
sibirjac
Модератор раздела
Offline5.1
Дата: 05 Окт 2020 11:06:42 #
Радиосеть "Полигона Cape Wrath"
частота 2161 кГц, J3E/USB.
Позывные:
Range control - полигон Cape Wrath
D7P - CORTE REAL (FFGH) (F332) (POR-N)
P2U - англ. координатор на корабле D7P
9MW - координатор на полигоне
U3H - координатор на полигоне ?
1YQ - полигон Cape Wrath?
Nato warship Corte Real - CORTE REAL (FFGH) (F332) (POR-N)
10.00
1YQ - Nato warship Corte Real Over
Range control - D7P Over
9MW - D7P Over
Range control - D7P gurf report
A D7P
B on station and ready until 2000z
C 9439614609
D N.05.1.D N.05.18.A
10.27
Range control - P2U on board D7P
Range control - P2U confirm this c/s working c/s 9MW
10.30
U3H - D7P Over
9MW - D7P Over
10.34
9MW - D7P ship on station and ready go for fire for dry firing run
9MW - D7P waiting 314C
9MW - D7P fire mission target number UT5501 position grid 913190 altitude 50 direction 5130
9MW - D7P gun target line 3876 ready 50
9MW - D7P coastal defence spotter adjust
fire out shot splash out //стрельба и корректировка//
11.00
9MW - D7P round complete
9MW - D7P end off mission coastal defence destroyed
11.05
Range control - P2U on board D7P will requesting second 314C ... ship on station ....
9MW - D7P ship on station and ready go for fire dry firing run
9MW - D7P fire mission target number UT5501 position grid 913190 altitude 50 direction 5120 coastal defence spotter adjust send summit out
9MW - D7P gun target line 3556 summit 3921 meters ready 51
11.24
9MW - D7P round complete end off mission
11.32
9MW - D7P N.01.20.A Over
11.57
9MW - D7P fire mission target number UT5501 grid 913990 altitude 50 direction 5120 coastal defence spotter adjust send summit out
9MW - D7P gun target line 206 summit 10879 feet ready 50
12.08
12.10
Range control - P2U on board D7P request ... 314C ship on station ...
13.26
9MW - D7P fire mission target number UT5501 grid 913990 altitude 50 direction 5120 coastal defence at my command spotter adjust out
9MW - D7P gun target line 220 ready 56 summit 13668 feet
=отменили стрельбу =
9MW - D7P GURF report
A D7P
C 9719713581
D N05.1.D N05.18.A
9MW - D7P ship on station ready for go for fire/fire mission target number UT5501 grid 913990 altitude 50 direction 5120/coastal defence at my command spotter adjust send summit/ gun target line 3558 summit 10879 feet/ready 50
13.51
9MW - P2U ... N.01.10.E command fire again request fire mission ...
9MW - P2U N06 and N07 for last mission
14.03
9MW - D7P ship on station ready for go for fire/fire mission target number UT5501 grid 913990 altitude 50 direction 5120/morter position spotter adjust / gun target line 3538 summit 12146 feet/ready 52
14.14
- D7P end off mission morter destroyed
- D7P report gun safe voice empty
sibirjac
Модератор раздела
Offline5.1
Дата: 05 Окт 2020 15:45:20 #
Радиосеть "Самолетов БПА НАТО"
частота 4620 кГц, J3E/USB.
Octopus 01 - "Атлантик 2" Франция №16
15.34
MKL - Octopus 01 take off EGPK 1127z POB 19
Octopus 01 - MKL do you have any relay instruction for your message
MKL - Octopus 01 negative stand by telegraphic message
Octopus 01 - MKL wait 5 min
= RATT =
16.20
MKL - Octopus 01 on task 1300z PLE EGPK 1750z
20.04
MKL - Octopus 01 we are off task 1700z
20.56
MKL - Octopus 01 I am now good contact with my control I be leave frequency
sibirjac
Модератор раздела
Offline5.1
Дата: 05 Окт 2020 21:48:34 #
Стрелял сегодня португалец CORTE REAL (FFGH) (F332) (POR-N), хотя на карте AIS отображается только француз PM L HER (FFL) (F792) - это и ввело меня в заблуждение (но осталась запись с Nato warship Corte Real). Возникает вопрос - а есть ли этот француз в данном месте или же под него "косит" португалец?
sibirjac
Модератор раздела
Offline5.1
Дата: 06 Окт 2020 05:38:04 #
частота 3071 кГц, J3E/USB.
Sunfish - "Атлантик 2" Франция №3
MKL - Sunfish take off from EGPK at 2316z on station estimated at 0100z relay to EGPK
MKL - Sunfish normal operation on area next contact in 10 minutes for on station
sibirjac
Модератор раздела
Offline5.1
Дата: 06 Окт 2020 11:41:52 #
Радиосеть неустановленная
частота 2250.5, 2249 кГц, J3E/USB, ANDVT.
Позывные:
D1R - главный
L0O -
Q6O -
S5J -
R0U -
N5L -
8AV -
11.30
Вызовы на связь, установление связи.
8AV - D1R request you int your track 2343
D1R - 8AV my unit no hold track 2343
sibirjac
Модератор раздела
Offline5.1
Дата: 06 Окт 2020 15:09:22 #
частота 2080 кГц, ANDVT.
15.00
= ANDVT =
sibirjac
Модератор раздела
Offline5.1
Дата: 06 Окт 2020 16:32:44 #
частоты 5050, 5055 кГц, J3E/USB.
16.17
Steel 10 - Steel 40 radio check
Steel 10 - Steel 40 nothing heard out
sibirjac
Модератор раздела
Offline5.1
Дата: 06 Окт 2020 22:08:07 #
частота 2078,5 кГц, ANDVT, J3E/USB.
Позывные:
1ON -
2XB -
Q9Y -
V6V -
22.05
Вызовы на связь.
sibirjac
Модератор раздела
Offline5.1
Дата: 06 Окт 2020 22:51:22 #
частота 2249, 2272 кГц, J3E/USB
22.35 - 22.40
D1R - S5J radio check Over
D1R - S5J nothing heard out
sibirjac
Модератор раздела
Offline5.1
Дата: 07 Окт 2020 10:38:57 #
Радиосеть предположительно "Донесений ОГ/Координации ПВО"
частота 2250.5 кГц, J3E/USB.
Позывные:
7QI -
7BZ -
E1E -
R7G -
9FX -
4CE -
8JW -
M4E -
V3V -
E -
G -
DE -
DK -
DN -
22.40
E1E - R7G request you set watch AY328 //asw control uhf-hf//
R7G - E1E Roger stand by
22.41
E1E - R7G request you set watch AY213 //tg reporting-link 11 coord uhf//
sibirjac
Модератор раздела
Offline5.1
Дата: 08 Окт 2020 06:27:01 #
Dinkum 01 - CP-140 Аврора Канада 140113
MKL - Dinkum 01 radio check on HF
Dinkum 01 - MKL weak readable
MKL - Dinkum 01 request HC1
Dinkum 01 - MKL be advise requesting change frequency arcn 112
MKL - Dinkum 01 switcing ARCN 112
sibirjac
Модератор раздела
Offline5.1
Дата: 08 Окт 2020 06:42:06 #
Позывные:
A2T -
U8W -
B4F -
C0D -
5JM -
H0Y -
3WX -
4DI -
sibirjac
Модератор раздела
Offline5.1
Дата: 08 Окт 2020 11:12:00 #
Sunfish 01 - "Атлантик 2" Франция №3
10.00
MKL - Sunfish 01 take off from EGPK at 0656z on task estimated at 0815z relay to EGPK next contact 1 hour
10.53
MKL - Sunfish 01 RTB for my unit ETA to EGPK at 0815z
sibirjac
Модератор раздела
Offline5.1
Дата: 08 Окт 2020 15:01:37 #
частота 4620, 6697 кГц, J3E/USB, RATT
14.41
MKL - Octopus 01 for information take off EGPK 1130z
15.51
16.52
MKL - Octopus 01 normal operations on area calling back 1 hour
20.05
MKL - Octopus 01 off task time 1702z
20.50
MKL - Octopus 01 good contact with the ground request you leave the frequency
sibirjac
Модератор раздела
Offline5.1
Дата: 09 Окт 2020 09:37:36 #
Позывные:
R4V - корабль
9RX - корабль - USS ROOSEVELT (DDG 80)???
2FZ - координатор на полигоне
3YB - координатор на полигоне
N6F - координатор на полигоне
09.20
R4V 9RX - Range control radio check Over
Range control - R4V you loud and clear how me
R4V - Range control Roger out
10.15 - 10.50
2FZ - R4V radio check Over/ nothing heard out
3YB - R4V Over/nothing heard out
9RX - R4V nothing heard out
N6F - R4V you garbled
10.53
Range control - R4V we are chop 155
10.54
Range control - 9RX Over
9RX - R4V Range control change frequency
R4V - 9RX roger stand by new designator
Range control - 9RX int new freq or stand this freq
Range control - 9RX roger stand by 3YB
3YB - 9RX Over
11.00
- 9RX roger check 155 out
11.00
Range control - 9RX my unit unable kick 155 due to limit ...
11.15
N6F - 9RX stand by GURF report
A 9RX
B 0800 until 2000z
C 30V VL 03621211
D ...
E candy 150 //Ammunition state report.//
11.20
N6F - 9RX ship on station ready to go fire 314C dry gun
N6F - 9RX fire mission target number UT 5803 / 911978 altitude 98 direction 4940/gun target line 3804 ready 46
sibirjac
Модератор раздела
Offline5.1
Дата: 09 Окт 2020 19:22:45 #
Позывные:
R4V -
9RX -
5IN -
I3R -
R6K -
R4V - 9RX confirm how you hold my unit in Alligator
R4V - 9RX my unit hold your unit ADA.3 how me
9RX -смена позывного на X3U - USS ROOSEVELT (DDG 80)???
R4V - смена позывного на G8G.
sibirjac
Модератор раздела
Offline5.1
Дата: 10 Окт 2020 11:42:51 #
Позывные:
G8G -
this is X3U stand by surfpick 5709.2 north 00010.0 100600z // ошибка в координатах при передачи?//
113 - 43 - 5EL
110 - 14 - G8G
?05 - 41 - 1WD
115 - 47 - S7W
114 - 50 - Z6C
118 - 48 - Z6W
171 - 11 out
sibirjac
Модератор раздела
Offline5.1
Дата: 10 Окт 2020 11:46:14 #
Позывные:
X3U - корабль - USS ROOSEVELT (DDG 80)???
Pilot 10 - лоцманское судно
sibirjac
Модератор раздела
Offline5.1
Дата: 11 Окт 2020 09:05:54 #
Позывные:
N1S - USS ROSS (DDG 71)??
Pilot 01 - лоцманское судно
Pilot 01 - N1S HF in the red radio check Over
Pilot 01 nothihg heard choping uniform primary
sibirjac
Модератор раздела
Offline5.1
Дата: 11 Окт 2020 14:06:30 #
частота 6697 кГц, J3E/USB.
MKL - Dinkum 01 requesting HC1
Dinkum 01 - MKL say again your request
MKL - Dinkum 01 requesting RATT
Dinkum 01 - MKL send this frequency
= RATT =
Dinkum 01 - MKL Over
sibirjac
Модератор раздела
Offline5.1
Дата: 13 Окт 2020 20:15:33 #
20.04
MKL - Octopus 01 on task at 1700z next call 1 hour
21.25
MKL - Octopus 01 normal operations calling back on 1 hour
MKL - Octopus 01 off task at 2042z
sibirjac
Модератор раздела
Offline5.1
Дата: 14 Окт 2020 09:24:14 #
Позывные:
8YB - NIELS JUEL (FFGH)(F363)(DNK-N)
6CC - TRITON (F) (F358) (DNK-N) ?
A1M - координатор на корабле 8YB
Y9Z - координатор на полигоне
09.11
Вызовы на связь.
09.25
Range control - A1M on board 8YB
Range control - A1M 8YB and 6CC have in grid split the FS day ... and 8YB will be operating to the west and 6CC to the east message end
Range control - A1M can you confirm coastal c/s that 8YB
Range control - A1M Roger read back Y9Z
Y9Z - 8YB Over
09.32
Any station - 6CC Over
Range control - A1M can you confirm 8YB and 6CC will be working on that for circuit for gunnary serial
09.37
6CC - Range control change freq JW 155
09.40
Y9Z - 8YB we are ready for conduct 314C
Y9Z - 8YB
A 8YB
B until 1800z
C E934 N112
Y9Z - 8YB fire mission target number HT1850 grid 917975 alt 80 direction 4900 target havy machine mission /at my command spotter adjust
Y9Z - 8YB gun target line 184 summit 6000 ready 35
10.00
Range control - 8YB end off mission target HT1850 destroyed
Range control - 8YB range is clear
Range control - 8YB N01.10B
10.14
Y9Z - 8YB N01.05B
Y9Z - 8YB we are ready for go to fire
Y9Z - 8YB fire mission target number HT1850/grid 917975 alt 80 direction 4900 target havy machine going position/at my command spotter adjust/gun target line 178 summit 5000 ready 34
10.27
Y9Z - 8YB end off mission HT1850 target destroyed
Y9Z - A1M send N06 and N07
10.33
Y9Z - 8YB ship on station and ready to go for fire
Y9Z - 8YB fire mission target number HT1501/grid 91609758 alt 80 direction 5680/ soft skean beagle danger close south east 230 ... F520/ ....
gun target line 187 summit 4000 ready 30
10.56
Y9Z - 8YB end off mission HT1501 target destroyed out
11.00
Y9Z - 8YB fire mission target number HT1851/grid 918974 alt 80 direction 4860/gun target line 93 summit 4000 ready 29
11.05
Y9Z - 8YB fire mission target number HT1852 left 200 drop 200 gun target line 190 summit 4000 ready 30 ..
11.18
Y9Z - 8YB N01.05A out
Y9Z - 8YB ready
11.24
- 8YB end off mission HT1851 target 1851 destroyed end off mission HT1852 target 1852 destroyed out
11.30
Y9Z - 8YB we are gun ship reloading request 5 m adjust ....
11.37
Y9Z - 8YB requesting result of HT1851 and HT1852
12.00
Y9Z - 8YB we are ready to recomand N05.50A
Y9Z - 8YB fire mission target number .HT Wave 01 /grid 91829727 alt 80 direction 4860/ gun target line 193 summit 5000 ready 33
13.10
Y9Z - 8YB N01.05A
Y9Z - 8YB N01.10.A
13.32
Y9Z - 8YB N01.15.A
13.35
Range control - 8YB ...A1M is not available ...
Range control - 8YB A1M will be on line to 61 minutes
Range control - 8YB Roger 1130z or 1230 local
sibirjac
Модератор раздела
Offline5.1
Дата: 14 Окт 2020 19:51:50 #
MKL - Octopus 01 take off EGPK at 1558z call back on 1 hour
20.00
aviation1
с апр 2017
UK
Дата: 15 Окт 2020 17:58:25 #
Спасибо.
P.
