sebastjan perejra ![6.0](http://www.radioscanner.ru/forum/img/ranks/6.gif) |
G&G COMMUNICATIONS |
Для тех кто ищет и интересуется.
Этот список содежит более четырехсот известных моделей радиосканеров.
AOR AR1000XLT Programmable Scanner
Portable Continuous Coverage Bands 1000 Channels
AOR AR1500 Programmable Scanner
AOR AR160 Programmable Scanner
Base or Mobile High, Low, and UHF Bands 16 Channels
AOR AR2001 Programmable Scanner
AOR AR2002 Programmable Scanner
Base or Mobile Continuous Coverage Bands 20 Channels
AOR AR22A Programmable Scanner
AOR AR22B Programmable Scanner
AOR AR22C Programmable Scanner
AOR AR22D Programmable Scanner
AOR AR22E Programmable Scanner
AOR AR2500 Programmable Scanner
Base or Mobile Continuous Coverage Bands 1000 Channels
AOR AR2515 Programmable Scanner
Base or Mobile Continuous Coverage Bands 2016 Channels
AOR AR2800 Programmable Scanner
AOR AR3000A Programmable Scanner
Base or Mobile All Band Coverage 400 Channels
AOR AR33B Synthesized Scanner
Portable High Band Only Single Channel
AOR AR800 Programmable Scanner
Portable All Bands including 800mhz 20 Channels
AOR AR8000 Programmable Scanner
Portable All Band Coverage 1000 Channels
AOR AR880 Programmable Scanner
Portable High, Low, UHF, and 800 mhz 20 Channels
AOR AR900 Programmable Scanner
Portable All Bands including 800mhz 100 Channels
AOR AR950 Programmable Scanner
Base or Mobile All Bands including 800mhz 100 Channels
AOR R8190AC2 Programmable Scanner
Portable All Band Coverage 500
BEARCAT BC1 Pre-Programmed
Base or Mobile High, Low, and UHF Bands Pre-Programmed
BEARCAT BC100 Programmable Scanner
Portable High, Low, and UHF Bands 16 Channels
BEARCAT BC100X Programmable Scanner
BEARCAT BC100XL Programmable Scanner
Portable High, Low, UHF and Aircraft Bands 16 Channels
BEARCAT BC100XLT Programmable Scanner
Portable High, Low, UHF and Aircraft Bands 100 Channels
BEARCAT BC101 Programmable Scanner
Base High, Low, and UHF Bands 16 Channels
BEARCAT BC12 Crystal Scanner
Base or Mobile High, Low, and UHF Bands 10 Channels
BEARCAT BC120XLT Programmable Scanner
Portable High, Low, and UHF Bands 100 Channels
BEARCAT BC140 Programmable Scanner
BEARCAT BC142XL Programmable Scanner
BEARCAT BC144XL Programmable Scanner
BEARCAT BC145XL Programmable Scanner
BEARCAT BC147XLT Programmable Scanner
BEARCAT BC148XLT Programmable Scanner
BEARCAT BC15 Crystal Scanner
Base or Mobile High, Low, UHF and Aircraft Bands 10 Channels
BEARCAT BC150 Programmable Scanner
Base High, Low, and UHF Bands 10 Channels
BEARCAT BC151 Programmable Scanner
BEARCAT BC155 Programmable Scanner
10 Channels
BEARCAT BC160 Programmable Scanner
BEARCAT BC170 Programmable Scanner
BEARCAT BC172XL Programmable Scanner
Base or Mobile High, Low, UHF and Aircraft Bands 20 Channels
BEARCAT BC175XL Programmable Scanner
Base or Mobile High, Low, UHF and Aircraft Bands 16 Channels
BEARCAT BC177XLT Programmable Scanner
BEARCAT BC178XLT Programmable Scanner
Base or Mobile High, Low, UHF and Aircraft Bands 100 Channels
BEARCAT BC180 Programmable Scanner
BEARCAT BC1H Crystal Scanner
Base or Mobile High Band Only 8 Channels
BEARCAT BC1L Crystal Scanner
Base or Mobile Low Band Only 8 Channels
BEARCAT BC1U Crystal Scanner
Base or Mobile UHF Band Only 8 Channels
BEARCAT BC20/20 Programmable Scanner
Base or Mobile High, Low, UHF and Aircraft Bands 40 Channels
BEARCAT BC200 Programmable Scanner
BEARCAT BC200XLT Programmable Scanner
Portable All Bands including 800mhz 200 Channels
BEARCAT BC201 Programmable Scanner
BEARCAT BC205XLT Programmable Scanner
BEARCAT BC210 Programmable Scanner
BEARCAT BC210XL Programmable Scanner
Base or Mobile High, Low, and UHF Bands 18 Channels
BEARCAT BC210XLT Programmable Scanner
BEARCAT BC210XW Programmable Scanner
Base or Mobile High, Low, and UHF Bands 20 Channels
BEARCAT BC211 Programmable Scanner
Base or Mobile High, Low, UHF and Aircraft Bands 18 Channels
BEARCAT BC220 Programmable Scanner
BEARCAT BC220XLT Programmable Scanner
BEARCAT BC230XLT Programmable Scanner
BEARCAT BC235XLT Programmable Scanner
Portable All Bands including 800mhz 300 Channels
BEARCAT BC244XLT Programmable Scanner
Base High, Low, UHF 30 Channels
BEARCAT BC245XLT Programmable Scanner
BEARCAT BC248CLT Programmable Scanner
Base High, Low, UHF, AM-FM Bands 50 Channels
BEARCAT BC2-4TS Crystal Scanner
Portable High and Low Bands 4 Channels
BEARCAT BC250 Programmable Scanner
Base or Mobile High, Low, and UHF Bands 50 Channels
BEARCAT BC2500XLT Programmable Scanner
Portable Continuous Coverage Bands 400 Channels
BEARCAT BC250XL Programmable Scanner
BEARCAT BC260 Programmable Scanner
MobileBase High, Low, UHF and Aircraft Bands 16 Channels
BEARCAT BC2H Crystal Scanner
BEARCAT BC2L Crystal Scanner
BEARCAT BC2U Crystal Scanner
BEARCAT BC3 Crystal Scanner
Base or Mobile High and Low Bands 8 Channels
BEARCAT BC300 Programmable Scanner
Base or Mobile High, Low, UHF and Aircraft Bands 50 Channels
BEARCAT BC3000XLT Programmable Scanner
Portable All Band Coverage 400 Channels
BEARCAT BC310A Pre-Programmed
BEARCAT BC330A Pre-Programmed
BEARCAT BC350 Programmable Scanner
BEARCAT BC350A Programmable Scanner
BEARCAT BC4 Crystal Scanner
Base or Mobile High, Low, and UHF Bands 8 Channels
BEARCAT BC400XLT Programmable Scanner
BEARCAT BC4-6 Crystal Scanner
Portable High, Low, and UHF Bands 6 Channels
BEARCAT BC4-6TS Crystal Scanner
BEARCAT BC5 Crystal Scanner
Base High, Low, and UHF Bands 8 Channels
BEARCAT BC5/800 Crystal Scanner
Base or Mobile High, Low, UHF, and 800 mhz 8 Channels
BEARCAT BC50XL Programmable Scanner
Portable High, Low, and UHF Bands 10 Channels
BEARCAT BC55XLT Programmable Scanner
BEARCAT BC5-6 Crystal Scanner
Portable High, Low, UHF and Aircraft Bands 6 Channels
BEARCAT BC560XLT Programmable Scanner
MobileBase High, Low, and UHF Bands 16 Channels
BEARCAT BC580XLT Programmable Scanner
BEARCAT BC590XLT Programmable Scanner
BEARCAT BC6 Crystal Scanner
Base High and Low Bands 6 Channels
BEARCAT BC600XLT Programmable Scanner
BEARCAT BC60XLT Programmable Scanner
BEARCAT BC65XLT Programmable Scanner
BEARCAT BC700A Programmable Scanner
Base or Mobile All Bands including 800mhz Pre-Programmed
BEARCAT BC70XLT Programmable Scanner
Portable High, Low, UHF and Aircraft Bands 20 Channels
BEARCAT BC760XLT Programmable Scanner
MobileBase All Bands including 800mhz 100 Channels
BEARCAT BC8 Crystal Scanner
BEARCAT BC800XLT Programmable Scanner
Base or Mobile All Bands including 800mhz 40 Channels
BEARCAT BC80XLT Programmable Scanner
Portable All Bands including 800mhz 50 Channels
BEARCAT BC8500XLT Programmable Scanner
Base or Mobile All Band Coverage 500
BEARCAT BC855XLT Programmable Scanner
Base or Mobile All Bands including 800mhz 50 Channels
BEARCAT BC860XLT Programmable Scanner
BEARCAT BC890XLT Programmable Scanner
Base or Mobile All Bands including 800mhz 200 Channels
BEARCAT BC895XLT Programmable Scanner
Base or Mobile HLUA8* 300 Channels
BEARCAT BC8TRACK Crystal Scanner
Mobile High and Low Bands 4 Channels
BEARCAT BC9000XLT Programmable Scanner
BEARCAT BC950XLT Programmable Scanner
BEARCAT BCALERT Crystal Scanner
Base Weather Band 1*
BEARCAT BC-BCT2 Pre-Programmed
MobileBase High, Low, and UHF Bands Pre-Programmed
BEARCAT BCFIVE-SIX Crystal Scanner
BEARCAT BC-SC150B Pre-Programmed
BEARCAT BC-SC150Y Pre-Programmed
BEARCAT BCSPHL Crystal Scanner
BEARCAT BCT10 Pre-Programmed
Base or Mobile All Bands including 800mhz *
BEARCAT BCT2 Programmable Scanner
MobileBase High, Low, and UHF Bands *
BEARCAT BCT7 Pre-Programmed
BEARCAT COMPUSCAN Programmable Scanner
BEARCAT CR2021 PRE-PRG/RADAR DET
BEARCAT JOLLYROGER Crystal Scanner-tunable
Base High Band Only
BEARCAT MR8100 Programmable Scanner
BEARCAT SC180 Programmable Scanner
Portable High, Low, UHF, Air, 800mhz 100 Channels
CHANMASTER 6258 Crystal Scanner
High and Low Bands
CHANMASTER CS6794 Crystal Scanner
COBRA SR10 Programmable Scanner
COBRA SR12 Programmable Scanner
COBRA SR15 Programmable Scanner
COBRA SR900 Programmable Scanner
COBRA SR901 Pre-Programmed
COBRA SR925 Programmable Scanner
COURIER COP50HL Crystal Scanner - TUNABL
High and Low Bands
COURIER COP75 Crystal Scanner
CRAIG 1254 Crystal Scanner
CRAIG 4350 Crystal Scanner
CRAIG 4350A Crystal Scanner
CRAIG 4353 Crystal Scanner
FAIRMATE HP-200E Programmable Scanner
FANON M8-HLU Crystal Scanner
FANON SLIM6 Crystal Scanner
FEDERAL 10-10 TONE ACT MONITOR
Low Band Only Single Channel
FOX BMP1060 Programmable Scanner
FOX PAC-100 Pre-Programmed
GE 7-2990 Crystal Scanner
HEATHKIT GR110 Crystal Scanner
HEATHKIT GR740-BC20/20 Programmable Scanner
HYGAIN 846 Crystal Scanner
Portable High Band Only 4 Channels
HY-GAIN 618H/L Crystal Scanner
Base or MobilePortable High and Low Bands 8 Channels
HY-GAIN 624G Crystal Scanner
Low Band Only 4 Channels
HY-GAIN PROSCAN Crystal Scanner
High and Low Bands
ICOM R1 Programmable Scanner
Portable All Band Coverage 100 Channels
ICOM R100 Programmable Scanner
Base or Mobile All Band Coverage 100 Channels
ICOM R7000 Programmable Scanner
Base All Band Coverage 99
ICOM R7100 Programmable Scanner
Base All Band Coverage 900
ICOM R71A Programmable Scanner
Base or Mobile SW 32 Channels
ICOM R72 Programmable Scanner
Base SW 100 Channels
ICOM R9000 Programmable Scanner
Base or Mobile All Band Coverage 1000 Channels
INSTALERT EC22 Pager-Monitor
High Band Only
JIL SX100 Programmable Scanner
JIL SX200 Programmable Scanner
High, Low, UHF and Aircraft Bands 32 Channels
JIL SX400 Programmable Scanner
JOHNSON DUO SCAN Crystal Scanner
JOHNSON MINISCAN Crystal Scanner
Portable
KENWOOD RZ-1 Programmable Scanner
LAFAYETTE 4B-10 Crystal Scanner
LAFAYETTE DB-8 Crystal Scanner
High and Low Bands
LAFAYETTE HA155 Crystal Scanner
High and Low Bands
LAFAYETTE MICROP450 Crystal Scanner-tunable
UHF Band Only
LAKE 3000 Crystal Scanner
Base or Mobile High and UHF Bands 8 Channels
MACDONALD CE100 Crystal Scanner
High and Low Bands
MACDONALD CE206 Crystal Scanner
Base or Mobile High and Low Bands 6 Channels
MIDLAND 13-912 Crystal Scanner
High Band Only
MIDLAND 13-916 Crystal Scanner
Mobile High Band Only 4 Channels
MIDLAND 13-950 Crystal Scanner
MIDLAND CR2021 Crystal Scanner SCANNER
MobileBase High Band Only 4 Channels
MONT WARD GED845A-BC220 Programmable Scanner
MONT-WARD 846 Crystal Scanner
MOTOROLA DIRECTOR HI Pager-Monitor
Pager High Band Only
MOTOROLA DIRECTOR LO Pager-Monitor
Pager Low Band Only
MOTOROLA DIRECTOR UHF Pager-Monitor
Pager UHF Band Only
MOTOROLA L01CND Pager-Monitor
MOTOROLA L03CND Pager-Monitor
MOTOROLA L04CND Pager-Monitor
UHF Band Only
MOTOROLA M01CNB Pager-Monitor
Low Band Only
MOTOROLA M03CNB1100A Pager-Monitor
High Band Only 6 Channels
MOTOROLA M04CNB Pager-Monitor
UHF Band Only
MOTOROLA METRX HI Pager-Monitor
MOTOROLA MINITOR II H Pager-Monitor
MOTOROLA MINITOR II L Pager-Monitor
Pager Low Band Only
MOTOROLA MINITOR II U Pager-Monitor
Pager UHF Band Only
MOTOROLA MINITOR-HI Pager-Monitor
MOTOROLA MINITOR-LO Pager-Monitor
Pager Low Band Only
MOTOROLA MINITOR-UHF Pager-Monitor
Pager UHF Band Only
MOTOROLA MO3CNB1103A Pager-Monitor
Base or Mobile High Band Only 2 Channels
MOTOROLA PAGEBOY I HI Pager-Monitor
MOTOROLA PAGEBOY I LO Pager-Monitor
Pager Low Band Only
MOTOROLA PAGEBOY I UH Pager-Monitor
Pager UHF Band Only
MOTOROLA PAGEBOY II H Pager-Monitor
MOTOROLA PAGEBOY II L Pager-Monitor
Pager Low Band Only
MOTOROLA PAGEBOY II U Pager-Monitor
Pager UHF Band Only
MOTOROLA PAGECOM HI Pager-Monitor
MOTOROLA PAGECOM LO Pager-Monitor
Pager Low Band Only
MOTOROLA PAGECOM UHF Pager-Monitor
Pager UHF Band Only
MOTOROLA SPIRIT HI Pager-Monitor
MOTOROLA SPIRIT LO Pager-Monitor
Pager Low Band Only
MOTOROLA SPIRIT UHF Pager-Monitor
NEC PR150-V2-10A Pager-Monitor
PortableG High Band Only
PACE CR2021 Crystal Scanner SCANNER
PACE SCAN10-4 Crystal Scanner
Base or Mobile High and Low Bands 4 Channels
PLECTRON 846 PAGER
Base or Mobile High Band Only Single Channel
PLECTRON CR2021 Pager-Monitor
PLECTRON R19A4 Pager-Monitor
PLECTRON R20A4 Pager-Monitor
PLECTRON R519B1 Pager-Monitor
Base or Mobile Low Band Only Single Channel
PLECTRON R719B2 Pager-Monitor
PLECTRON R8190AC2 Pager-Monitor
PLECTRON R8200 Pager-Monitor
PLECTRON SM312 Crystal Scanner
High and Low Bands
P-SIMPSON COMMANCHE16 Crystal Scanner
RCA 16S100 Crystal Scanner
High and Low Bands
RCA 16S150 Crystal Scanner
UHF Band Only
RCA 16S300 Crystal Scanner
RCA 16S400 Crystal Scanner
RCA CR2021 ALERT MONITOR
Base Low Band Only Single Channel
RCA SCANAIRE Crystal Scanner
RCD MRP1H Crystal Scanner
RCD MRP1L Crystal Scanner
Portable Low Band Only Single Channel
RCD MRP1U Crystal Scanner
Portable UHF Band Only Single Channel
REALISTIC 20-169 Crystal Scanner
UHF Band Only
REALISTIC COMP100 Programmable Scanner
REALISTIC PRO-11
REALISTIC PRO-12
REALISTIC PRO-13
REALISTIC PRO-14 Crystal Scanner
REALISTIC PRO-16
REALISTIC PRO-16A
REALISTIC PRO-2001 Programmable Scanner
REALISTIC PRO-2002 Programmable Scanner
REALISTIC PRO-2003 Programmable Scanner
Base or Mobile High, Low, and UHF Bands 60
REALISTIC PRO-2004 Programmable Scanner
Base or Mobile High, Low, and UHF Bands 300 Channels
REALISTIC PRO-2005 Programmable Scanner
Base or Mobile High, Low, and UHF Bands 400 Channels
REALISTIC PRO-2006 Programmable Scanner
Base or Mobile All Bands including 800mhz 400 Channels
REALISTIC PRO-2008 Programmable Scanner
REALISTIC PRO-2009 Programmable Scanner
REALISTIC PRO-2010 Programmable Scanner
REALISTIC PRO-2011 Programmable Scanner
Base High, Low, and UHF Bands 20 Channels
REALISTIC PRO-2014 Programmable Scanner
REALISTIC PRO-2020 Programmable Scanner
REALISTIC PRO-2021 Programmable Scanner
Base or Mobile High, Low, and UHF Bands 200 Channels
REALISTIC PRO-2022 Programmable Scanner
REALISTIC PRO-2023 Programmable Scanner
Base High, Low, UHF and Aircraft Bands 20 Channels
REALISTIC PRO-2024 Programmable Scanner
Base High, Low, UHF and Aircraft Bands 60
REALISTIC PRO-2025 Programmable Scanner
REALISTIC PRO-2026 Programmable Scanner
REALISTIC PRO-2027 Programmable Scanner
REALISTIC PRO-2028 Programmable Scanner
REALISTIC PRO-2029 Programmable Scanner
REALISTIC PRO-2030 Programmable Scanner
Base or Mobile All Bands including 800mhz 80
REALISTIC PRO-2032 Programmable Scanner
REALISTIC PRO-2033 Programmable Scanner
Base High and UHF Bands 10 Channels
REALISTIC PRO-2034 Programmable Scanner
REALISTIC PRO-2035 Programmable Scanner
REALISTIC PRO-2036 Programmable Scanner
Base or Mobile LHUA8 200 Channels
REALISTIC PRO-2037 Programmable Scanner
REALISTIC PRO-2038 Programmable Scanner
MobileBase LHUA8 50 Channels
REALISTIC PRO-2039 Programmable Scanner
Base or Mobile LHUA8 100 Channels
REALISTIC PRO-2040 Programmable Scanner
REALISTIC PRO-2042 Programmable Scanner
Base or Mobile All Bands including 800mhz 1000 Channels
REALISTIC PRO-2043 Programmable Scanner
Base or Mobile High, Low, and UHF Bands 30 Channels
REALISTIC PRO-2044 Programmable Scanner
REALISTIC PRO-2045 Programmable Scanner
REALISTIC PRO-2046 Programmable Scanner
REALISTIC PRO-20A
4 Channels
REALISTIC PRO-21 Crystal Scanner
REALISTIC PRO-21A Crystal Scanner
REALISTIC PRO-22
REALISTIC PRO-23 Programmable Scanner
Portable HUA8 50 Channels
REALISTIC PRO-24 Programmable Scanner
Portable High, Low, UHF, and 800 mhz 16 Channels
REALISTIC PRO-25 Programmable Scanner
REALISTIC PRO-25A Programmable Scanner
Portable All Bands including 800mhz 4 Channels
REALISTIC PRO-26 Programmable Scanner
Portable All Band Coverage 200 Channels
REALISTIC PRO-27 Crystal Scanner
Portable High and UHF Bands 2 Channels
REALISTIC PRO-28 Programmable Scanner
Portable High, Low, and UHF Bands 30 Channels
REALISTIC PRO-29 Programmable Scanner
Portable All Bands including 800mhz 60
REALISTIC PRO-30 Programmable Scanner
REALISTIC PRO-31 Programmable Scanner
REALISTIC PRO-31A Programmable Scanner
REALISTIC PRO-32 Programmable Scanner
Portable High, Low, UHF and Aircraft Bands 200 Channels
REALISTIC PRO-32A Programmable Scanner
REALISTIC PRO-33 Programmable Scanner
Portable High, Low, and UHF Bands 20 Channels
REALISTIC PRO-34 Programmable Scanner
REALISTIC PRO-35 Programmable Scanner
REALISTIC PRO-36 Programmable Scanner
REALISTIC PRO-37 Programmable Scanner
REALISTIC PRO-38 Programmable Scanner
REALISTIC PRO-39 Programmable Scanner
REALISTIC PRO-4 Crystal Scanner
REALISTIC PRO-40 Crystal Scanner
REALISTIC PRO-41 Programmable Scanner
REALISTIC PRO-42 Programmable Scanner
REALISTIC PRO-43 Programmable Scanner
REALISTIC PRO-44 Programmable Scanner
Portable High, Low, UHF and Aircraft Bands 50 Channels
REALISTIC PRO-46 Programmable Scanner
REALISTIC PRO-47 Crystal Scanner
REALISTIC PRO-48 Crystal Scanner
REALISTIC PRO-49 Programmable Scanner
Portable LHU 10 Channels
REALISTIC PRO-4A Crystal Scanner
REALISTIC PRO-5 Crystal Scanner
UHF Band Only 4 Channels
REALISTIC PRO-50 Programmable Scanner
Portable LHU 20 Channels
REALISTIC PRO-508 Programmable Scanner
REALISTIC PRO-51 Programmable Scanner
Portable LHUA8 200 Channels
REALISTIC PRO-52 Crystal Scanner
REALISTIC PRO-53 Crystal Scanner
REALISTIC PRO-54 Crystal Scanner
REALISTIC PRO-55 Crystal Scanner
REALISTIC PRO-56 Crystal Scanner
REALISTIC PRO-57 Programmable Scanner
REALISTIC PRO-58 Programmable Scanner
REALISTIC PRO-59 Programmable Scanner
REALISTIC PRO-6 Crystal Scanner
REALISTIC PRO-60 Programmable Scanner
REALISTIC PRO-62 Programmable Scanner
REALISTIC PRO-63 Programmable Scanner
REALISTIC PRO-64 Programmable Scanner
Portable All Bands including 800mhz 400 Channels
REALISTIC PRO-66 Programmable Scanner
Portable High, Low, UHF, and 800 mhz 50 Channels
REALISTIC PRO-70 Programmable Scanner
Portable High, Low, and UHF Bands 50 Channels
REALISTIC PRO-77 Crystal Scanner
REALISTIC PRO-77A Crystal Scanner
REALISTIC PRO-7A Crystal Scanner
REALISTIC PRO-7B Crystal Scanner
REALISTIC PRO-88 Crystal Scanner
Base or Mobile LU 8 Channels
REALISTIC PRO-9 Crystal Scanner SCANNER
Base or Mobile High Band Only 8T
REALISTIC PRO-90 Programmable Scanner
REGENCY ACT-1 Pager-Monitor
REGENCY ACT16K Programmable Scanner
REGENCY ACTC1W Crystal Scanner
High Band Only
REGENCY ACTC4 Crystal Scanner
Base High, Low, and UHF Bands 4 Channels
REGENCY ACTC4H Crystal Scanner
REGENCY ACTC4L Crystal Scanner
Base Low Band Only 4 Channels
REGENCY ACTC4U Crystal Scanner
Base UHF Band Only 4 Channels
REGENCY ACTE10 Crystal Scanner
REGENCY ACTE106 Crystal Scanner
REGENCY ACTE16 Crystal Scanner
REGENCY ACTE8 Crystal Scanner
REGENCY ACTR10 Crystal Scanner
MobileBase High, Low, and UHF Bands 10 Channels
REGENCY ACTR106 Crystal Scanner
REGENCY ACTR1H Crystal Scanner
MobileBase High Band Only Single Channel
REGENCY ACTR1L Crystal Scanner
MobileBase Low Band Only Single Channel
REGENCY ACTR1U Crystal Scanner
MobileBase UHF Band Only Single Channel
REGENCY ACTR20/6 Crystal Scanner
REGENCY ACT-R92A
REGENCY ACT-T720A Programmable Scanner
Base or Mobile A 16 Channels
REGENCY ALERT 1 Pager-Monitor
REGENCY C403 Crystal Scanner
REGENCY C403H Crystal Scanner
REGENCY C403L Crystal Scanner
REGENCY C403U Crystal Scanner
REGENCY D100 Programmable Scanner
REGENCY D300 Programmable Scanner
REGENCY D310 Programmable Scanner
REGENCY D810 Programmable Scanner
REGENCY DX3000 Programmable Scanner
REGENCY E106 Crystal Scanner
REGENCY H604 Crystal Scanner
REGENCY HX1000 Programmable Scanner
Portable High, Low, UHF and Aircraft Bands 30 Channels
REGENCY HX1200 Programmable Scanner
Portable High, Low, UHF and Aircraft Bands 45 Channels
REGENCY HX1500 Programmable Scanner
Portable High, Low, UHF and Aircraft Bands 55
REGENCY HX2000 Programmable Scanner
Portable HUA8 20 Channels
REGENCY HX2200 Programmable Scanner
Portable 20 Channels
REGENCY HX650 Crystal Scanner
REGENCY HX750 Crystal Scanner
REGENCY INF-1 Pre-Programmed
REGENCY INF-10 Pre-Programmed
Base or Mobile Pre-Programmed
REGENCY INF-3 Pre-Programmed
REGENCY INF-5 Pre-Programmed
Pre-Programmed
REGENCY INF-50 Pre-Programmed
REGENCY INF-7 Pre-Programmed
REGENCY INF-75 Pre-Programmed
REGENCY K100 Programmable Scanner
REGENCY K500 Programmable Scanner
REGENCY M100 Programmable Scanner
REGENCY M400 Programmable Scanner
Base or Mobile High, Low, and UHF Bands 40 Channels
REGENCY MCA611 Pager-Monitor
Base or Mobile High, Low, and UHF Bands Single Channel
REGENCY MX3000 Programmable Scanner
REGENCY MX4000 Programmable Scanner
Base or Mobile HUA8 20 Channels
REGENCY MX4200 Programmable Scanner
REGENCY MX5000 Programmable Scanner
REGENCY MX7000 Programmable Scanner
REGENCY R1040 Programmable Scanner
REGENCY R1050 Programmable Scanner
REGENCY R106 Crystal Scanner
REGENCY R1060 Programmable Scanner
REGENCY R1070 Programmable Scanner
REGENCY R1075 Programmable Scanner
Base High, Low, and UHF Bands 15 Channels
REGENCY R1077 Programmable Scanner
Base
REGENCY R1080 Programmable Scanner
Base High, Low, and UHF Bands 30 Channels
REGENCY R1090 Programmable Scanner
Base High, Low, and UHF Bands 45 Channels
REGENCY R1099 Programmable Scanner
Base
REGENCY R1600 Programmable Scanner
REGENCY R1H Crystal Scanner
REGENCY R1L Crystal Scanner
REGENCY R1U Crystal Scanner
Base or Mobile UHF Band Only Single Channel
REGENCY R2060 Programmable Scanner
Base
REGENCY R2066 Programmable Scanner
Base High, Low, and UHF Bands 60
REGENCY R3020 Programmable Scanner
REGENCY R4010 Programmable Scanner
REGENCY R4020 Programmable Scanner
REGENCY R4030 Programmable Scanner
REGENCY R804 Crystal Scanner
REGENCY R806 Crystal Scanner
REGENCY TME16HL Crystal Scanner
REGENCY TME16HLU Crystal Scanner
REGENCY TME8HL Crystal Scanner
REGENCY TME8HLU Crystal Scanner
REGENCY TMR12H Crystal Scanner
High Band Only 12 Channels
REGENCY TMR1H Crystal Scanner
REGENCY TMR1L Crystal Scanner
REGENCY TMR4 Crystal Scanner
REGENCY TMR8 Crystal Scanner
REGENCY TS1 Programmable Scanner
Base or Mobile High, Low, UHF and Aircraft Bands 35 Channels
REGENCY TS2 Programmable Scanner
Base or Mobile All Bands including 800mhz 75
REGENCY WHAMO-10 Programmable Scanner
Base or Mobile All Band Coverage 10 Channels
REGENCY Z10 Programmable Scanner
REGENCY Z30 Programmable Scanner
REGENCY Z45 Programmable Scanner
Base or Mobile High, Low, and UHF Bands 45 Channels
REGENCY Z60 Programmable Scanner
Base or Mobile High, Low, UHF and Aircraft Bands 60
RELM HS200 Programmable Scanner
RELM MS180 Programmable Scanner
RELM MS200 Programmable Scanner
MobileBase All Bands including 800mhz 200 Channels
ROBYN 100B Crystal Scanner
ROBYN 4+4 Crystal Scanner
ROBYN 8+8 Crystal Scanner
Base or Mobile High and Low Bands 16 Channels
RUSSELL DIGI-10 Crystal Scanner
High and Low Bands 10 Channels
SBE 846 Crystal Scanner
SBE OPTISCAN Programmable Scanner
SEARS 308.38760050 Crystal Scanner
SEARS 564.36290600 Crystal Scanner
SEARS CR2021 Crystal Scanner SCANNER
SHINWA SR001 Programmable Scanner
Base or Mobile All Band Coverage 200 Channels
SHINWA SR52VT Pager-Monitor
SONAR FR104 Crystal Scanner
SONAR FR105 Crystal Scanner
SONAR FR2512 Crystal Scanner
SONAR FR2515 Crystal Scanner
SONAR FR2516 Crystal Scanner
SONAR FR2517 Crystal Scanner
Low Band Only
SONAR FR2518 Crystal Scanner
High Band Only
SONAR FR2526 Crystal Scanner
SONAR REGULAR Pager-Monitor
High Band Only
SONAR SENATOR Pager-Monitor
High Band Only
TEABERRY T-SCAN Crystal Scanner
TEABERRY T-SCAN UHF Crystal Scanner
UHF Band Only
TENNELEC 846 Crystal Scanner
TENNELEC MCP1 Programmable Scanner
TENNELEC MS1 Programmable Scanner
TENNELEC MS2 Programmable Scanner
TENNELEC TENNETRACI Crystal Scanner
TENNELEC TENNETRACII Crystal Scanner
TRIDENT TR1200XLT Programmable Scanner
TRIDENT TR2 Pre-Programmed
Mobile NA NA
TRIDENT TR2400 Programmable Scanner
TRIDENT TR4500 Programmable Scanner
Base or Mobile All Band Coverage 2016
TRIDENT TR980 Programmable Scanner
Portable All Band Coverage 125
ULTRA CR2021 Crystal Scanner SCANNER
Base or Mobile High Band Only 5
UNIDEN CR2021 SW RADIO
Base SW NA
UNIMETRICS DIGISCAN8 Crystal Scanner
Base High and Low Bands 8 Channels
UNIMETRICS DURASCAN4 Crystal Scanner
MobileBase UHF Band Only 4 Channels
UNIMETRICS DURASCAN8 Crystal Scanner
High Band Only
UNIMETRICS MINICOM Crystal Scanner
UNIMETRICS REPORTER Crystal Scanner
Base or Mobile High Band Only 4 Channels
UNION SC101 Crystal Scanner
Base High and UHF Bands 8 Channels
YAESU FRG9600
YUPITERU MVT-7100 Programmable Scanner
PLECTRON R15X5 Pager-Monitor
Base or Mobile Low Band Only(Simultaneous Monitor) 2 Channels
REALISTIC PRO-91 Programmable Scanner
Portable All Bands including 800mhz 150 Channels
BEARCAT SC200 Programmable Scanner
Portable High, Low, UHF, Air, 800mhz 200 Channels
BEARCAT BC780XLT Programmable Scanner
Base or Mobile High, Low, UHF, Air, 800mhz 500 Channels
BEARCAT BC60XLT-1 Programmable Scanner
REALISTIC PRO-94 Programmable Scanner
Portable All Bands including 800mhz 1000 Channels
Вебмастер Редактор
![4.8](http://www.radioscanner.ru/forum/img/ranks/4.gif) |
25 Июн 2009 17:54
Все-таки надо указывать, что это о-о-о-очень старый список.
Файл создан: 25 Июн 2009 17:32, посл. исправление: 16 Окт 2009 15:47 |
